pinout can not found error hello... i am new user and i also new box....you can see on the image... first when i try to repair the dead boot then i got the error "Done with errors" then i try to find out the pin....but i got error "pinout can not found" i read on the forum about the connection of some pins i am using here riff box pcb...please check on the image.. and tell me which pin number i need to join. if there is another solution then please guide me.. http://s7.postimg.org/mqh7f5u5j/pinout_problem.png http://s7.postimg.org/n4ijere93/working.jpg here the pin 2,17,19 are free pin 4.6.8.10.12.14.16.18.20 are grounds pin -3 is TRST pin- 5 is TD1 pin- 7 is TMS pin-9 is TCK pin-11 is RTCK pin-13 is TD0 pin-15 is NRST i hope i will get the answer soon... |
i also try the jtag adapter and try to connect the i9100...but still same error ... done with error after connection.... before of this is was trying on i9100G... i am waiting answer from the product supporter ...... |
product supporter can you please guide me...i am still wait your reply... |
1 Attachment(s) Man, your phone is I9100G ? test this pinout! |
[QUOTE=Bruno Rafael;10125076]Man, your phone is I9100G ? test this pinout![/QUOTE yes i gave i9100G nad i also use the pin of i9100G... |
your pinou not same for pinout in my picture! |
anyway now i will try your pinout and then i will inform you the Result thank you |
