Old 09-30-2015, 15:49   #1 (permalink)
Member: 1938255
Thanks Meter: 28
PJ83100 Dead Repair
Good Day z3x team,
I just received my new easy jtag and I am very excited to use it but I am getting problem with it. I am trying to repair HTC ONE X PJ83100. I have soldered all wires and done Pinout Search. This is result
Starting Z3X Jtag Pin Finder...
Successfully connected to box on COM83
Waiting for box reset...
Box S/N: 00000000ADE4575A
Box Working Mode: JTAG Pin Finder.
Stage 1: Search TCK / TMS / TDI / TDO...
Get IDCODE...
JTAG Pinout Found: TCK: Pin 9 / TMS: Pin 7 / TDI: Pin 5 / TDO: Pin 13
CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4
CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9
Stage 2: Searching TRST...
TRST Pin Found: TRST: Pin 3
Box S/N: 0B001013ADE4575A, ,FW Ver.: 01.42
Box Working Mode: JTAG Box.
Which shows all pin out is right. The device appears in my driver menu as it should when plug into usb but when I try to connect with easy jtag the device disappears from driver menu and I get error then few seconds after error on easy jtag device appears again. I have tried this on both dead boot phone and working emmc phone to ensure that maybe emmc on one phone was not damaged. Can you help easy jtag team? Here is log
For support and updates visit EasyJtag ? most powerfull eMMC and JTAG tool on market. | EMMC BOX, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL
Check security...OK
Initialising: HTC HTC One X LTE PJ83100 Config ver.:1.00
I/O Level set to : 2200 mV
Box S/N: 0B001013ADE4575A ,FW Ver.: 01.42
Connecting to Target...
Done with error(s)...
As you see it is not connecting to target.
Old 01-25-2018, 14:17   #2 (permalink)
Member: 17326
Thanks Meter: 2
I have some problem (
Old 01-25-2018, 14:29   #3 (permalink)
Member: 1569669
Thanks Meter: 257
Hi,
CPU IDCODE : 0x4BA00477 require correct SRST pin.
Pin Finder does not support searching SRST pin.
After soldering correct SRST pin It should works fine.
Best Regard
Old 01-26-2018, 16:10   #4 (permalink)
Member: 17326
Thanks Meter: 2
Originally Posted by vikboston View Post
Hi,
Best Regard
But I solder pins according to the instruction from the program
Page generated in 0.15318 seconds with 9 queries
