03-10-2020, 05:16 | #1 (permalink) |
No Life Poster Join Date: Apr 2012
Member: 1743727 Status: Offline Thanks Meter: 76 | samsung c701f dump file need |
03-19-2020, 07:55 | #3 (permalink) |
Member: 1743727 Status: Offline Thanks Meter: 76 | please help layder sir got another working phon and read 4 gb dump and write in ded phon every thing seems to be ok now but phone is still ded no download mode nothing detected with usb cable > Setting interface to EasyJtag2/ISP_HiPower 19-03-2020 12:16:52> Setting bus width to 1 Bit 19-03-2020 12:16:52> HiPower mode is ON 19-03-2020 12:16:52> Setting frequence to 9 MHz 19-03-2020 12:16:52> CMD Pullup Level: 1800 mV 19-03-2020 12:16:52> CMD Active Level: 1855 mV 19-03-2020 12:16:52> eMMC Init returned = 0 19-03-2020 12:16:52> EMMC Device Information : 19-03-2020 12:16:52> EMMC CID: 150100524331344D420C21A3CA1F3497 19-03-2020 12:16:52> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 19-03-2020 12:16:52> EMMC Manufacture : SAMSUNG , EMMC NAME: RC14MB , HEX: 524331344D42 , S/N: 21A3CA1F , rev. 0x0C 19-03-2020 12:16:52> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2017 19-03-2020 12:16:52> EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) 19-03-2020 12:16:52> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 19-03-2020 12:16:52> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 11684 , Response: Not Clean 19-03-2020 12:16:52> EMMC Permanent Write Protection: No 19-03-2020 12:16:52> EMMC Temporary Write Protection: No 19-03-2020 12:16:52> Extended CSD Information : 19-03-2020 12:16:52> Extended CSD rev: 1.8 (MMC 5.1) 19-03-2020 12:16:52> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 19-03-2020 12:16:52> Boot Bus Config: 0x00 , width 1bit 19-03-2020 12:16:52> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 19-03-2020 12:16:52> Supported partition features [PARTITIONING_SUPPORT]: 0x07 19-03-2020 12:16:52> Device supports partitioning features 19-03-2020 12:16:52> Device can have enhanced technological features in partitions and user data area 19-03-2020 12:16:52> Device can have extended partitions attribute 19-03-2020 12:16:52> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 19-03-2020 12:16:52> Backup saved: RC14MB_21A3CA1F_20200319_121652.extcsd 19-03-2020 12:16:52> EMMC Init completed. 19-03-2020 12:16:52> 19-03-2020 12:16:53> Scanning soft partitions 19-03-2020 12:16:53> GPT header is found and is valid 19-03-2020 12:16:53> Partition: sbl1, [000000400000 - 000000480000], size: 000000080000 (512. KB) 19-03-2020 12:16:53> Partition: sbl1bak, [000000480000 - 000000500000], size: 000000080000 (512. KB) 19-03-2020 12:16:53> Partition: ddr, [000000500000 - 000000580000], size: 000000080000 (512. KB) 19-03-2020 12:16:53> Partition: rpm, [000000580000 - 000000600000], size: 000000080000 (512. KB) 19-03-2020 12:16:53> Partition: tz, [000000600000 - 000000800000], size: 000000200000 (2.00 MB) 19-03-2020 12:16:53> Partition: aboot, [000000800000 - 000000A00000], size: 000000200000 (2.00 MB) 19-03-2020 12:16:53> Partition: sec, [000000A00000 - 000000A40000], size: 000000040000 (256. KB) 19-03-2020 12:16:53> Partition: lksecapp, [000000A40000 - 000000AC0000], size: 000000080000 (512. KB) 19-03-2020 12:16:53> Partition: keymaster, [000000AC0000 - 000000B00000], size: 000000040000 (256. KB) 19-03-2020 12:16:53> Partition: cmnlib, [000000B00000 - 000000B40000], size: 000000040000 (256. KB) 19-03-2020 12:16:53> Partition: cmnlib64, [000000B40000 - 000000B80000], size: 000000040000 (256. KB) 19-03-2020 12:16:53> Partition: fsg, [000000B80000 - 000000F80000], size: 000000400000 (4.00 MB) 19-03-2020 12:16:53> Partition: pad, [000000F80000 - 000001000000], size: 000000080000 (512. KB) 19-03-2020 12:16:53> Partition: modemst1, [000001000000 - 000001400000], size: 000000400000 (4.00 MB) 19-03-2020 12:16:53> Partition: modemst2, [000001400000 - 000001800000], size: 000000400000 (4.00 MB) 19-03-2020 12:16:53> Partition: efs, [000001C00000 - 000002C00000], size: 000001000000 (16.0 MB) 19-03-2020 12:16:53> Partition: fsc, [000002C00000 - 000002F40000], size: 000000340000 (3.25 MB) 19-03-2020 12:16:53> Partition: ssd, [000002F40000 - 000002F80000], size: 000000040000 (256. KB) 19-03-2020 12:16:53> Partition: devcfg, [000002F80000 - 000002FC0000], size: 000000040000 (256. KB) 19-03-2020 12:16:53> Partition: apdp, [000002FC0000 - 000002FE0000], size: 000000020000 (128. KB) 19-03-2020 12:16:53> Partition: msadp, [000002FE0000 - 000003000000], size: 000000020000 (128. KB) 19-03-2020 12:16:53> Partition: param, [000003000000 - 000003C00000], size: 000000C00000 (12.0 MB) 19-03-2020 12:16:53> Partition: backup, [000003C00000 - 000004000000], size: 000000400000 (4.00 MB) 19-03-2020 12:16:53> Partition: boot, [000004000000 - 000006000000], size: 000002000000 (32.0 MB) 19-03-2020 12:16:53> Partition: recovery, [000006000000 - 000008000000], size: 000002000000 (32.0 MB) 19-03-2020 12:16:53> Partition: bota, [000008000000 - 000008800000], size: 000000800000 (8.00 MB) 19-03-2020 12:16:53> Partition: fota, [000008800000 - 000008C00000], size: 000000400000 (4.00 MB) 19-03-2020 12:16:53> Partition: persist, [000008C00000 - 00000AC00000], size: 000002000000 (32.0 MB) 19-03-2020 12:16:53> Partition: persistent, [00000AC00000 - 00000AD00000], size: 000000100000 (1.00 MB) 19-03-2020 12:16:53> Partition: steady, [00000AD00000 - 00000AE00000], size: 000000100000 (1.00 MB) 19-03-2020 12:16:53> Partition: keystore, [00000AE00000 - 00000AF00000], size: 000000100000 (1.00 MB) 19-03-2020 12:16:53> Partition: config, [00000AF00000 - 00000B000000], size: 000000100000 (1.00 MB) 19-03-2020 12:16:53> Partition: dsp, [00000B000000 - 00000C000000], size: 000001000000 (16.0 MB) 19-03-2020 12:16:53> Partition: modem, [00000C000000 - 000012000000], size: 000006000000 (96.0 MB) 19-03-2020 12:16:53> Partition: apnhlos, [000012000000 - 000014000000], size: 000002000000 (32.0 MB) 19-03-2020 12:16:53> Partition: reserved2, [000014000000 - 000014800000], size: 000000800000 (8.00 MB) 19-03-2020 12:16:53> Partition: system, [000014800000 - 000168800000], size: 000154000000 (5.31 GB) 19-03-2020 12:16:53> Partition: cache, [000168800000 - 000175000000], size: 00000C800000 (200. MB) 19-03-2020 12:16:53> Partition: hidden, [000175000000 - 00017B400000], size: 000006400000 (100. MB) 19-03-2020 12:16:53> Partition: nad_refer, [00017B400000 - 00017B800000], size: 000000400000 (4.00 MB) 19-03-2020 12:16:53> Partition: userdata, [00017B800000 - 000E8F7FBE00], size: 000D13FFBE00 (52.3 GB) 19-03-2020 12:16:53> GPT header successfully parsed 19-03-2020 12:16:53> 19-03-2020 12:16:53> Get firmware version 19-03-2020 12:16:53> 19-03-2020 12:16:56> Brand = samsung 19-03-2020 12:16:56> Manufacturer = samsung 19-03-2020 12:16:56> Device = c7prolte 19-03-2020 12:16:56> Model = SM-C701F 19-03-2020 12:16:56> Phone platform = msm8953 19-03-2020 12:16:56> CPU Abi = arm64-v8a 19-03-2020 12:16:56> Android release = 8.0.0 19-03-2020 12:16:56> Firmware version = R16NW.C701FDDU1CSD2 19-03-2020 12:16:56> Firmware date = Fri Apr 26 21:04:23 KST 2019 |
03-19-2020, 12:43 | #5 (permalink) | |
Member: 1743727 Status: Offline Thanks Meter: 76 | Quote:
firmware info is below when i revived it as ded phone Brand = samsung Manufacturer = samsung Device = c7prolte Model = SM-C701F Phone platform = msm8953 CPU Abi = arm64-v8a Android release = 7.0 Firmware version = NRD90M.C701FDDU1BRC2 Firmware date = Fri Mar 16 19:05:08 KST 2018 | |
03-19-2020, 14:50 | #6 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | it's strange try to write boots from firmware by vendor (from service firmwaree) |
The Following User Says Thank You to layder For This Useful Post: |
03-30-2020, 04:11 | #9 (permalink) |
Member: 1743727 Status: Offline Thanks Meter: 76 | layder after writing dull dump phone comes in restart i write 4 flesh files with latest version but phone still restart plz help all redy tied to wipe from recovery and clear catch |
04-02-2020, 10:53 | #11 (permalink) |
Member: 1743727 Status: Offline Thanks Meter: 76 | phone working good now just wana restore imei is 000000 i try to wite efs with z3x but error Waiting ADB device... OK Reading phone info... Model: SM-C701F Android version: 8.0.0 PDA version: C701FDDU1CSK1 CSC version: C701FODD1CSJ1 Phone version: C701FDDU1CSK2 Product code: Not Active CSC country code: India CSC sales code: INS Phone SN: RZ8J31GCFPF IMEI: HW version: MSM8953.00 RF cal date: NONE Chip name: MSM8953 Modem board: MSM8953 Security patch: 2019-10-01 Boot Warranty bit: 0 Checking Super user right... true Extracting EFS file... Exception: ' ' is not a valid integer value Done with Samsung Tool PRO v.39.8 its a qualcom phone and i have boot backup read by vender by selcting samsung and read by vendor by selecting qualcome plz tell me which file i have to restore for imei Last edited by kumarrocky; 04-02-2020 at 11:00. |
04-04-2020, 11:08 | #12 (permalink) | |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
Z3X-Team Products - GSM-Forum | |
