Old 01-07-2019, 08:05   #1 (permalink)
CoMoBat's Avatar
Member: 1171122
Sonork: 100.1623220
Thanks Meter: 151
Question Is there a "preloader parser" for a brand other than MediaTek?
Is there a preloader parser that is available for same emmc in the MediaTek series for other brands?
for example for samsung...
[IMG]****************************/convkey/6937/2hk8vmm0a95hip0zg.jpg[/IMG]
The Following User Says Thank You to CoMoBat For This Useful Post:
Old 01-07-2019, 11:19   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Mediatek is CPU brand
Samsung is phone brand
Samsung use Qualcomm/Exinos/Mediatek/Spreadtrum CPUs
The Following 2 Users Say Thank You to layder For This Useful Post:
Old 01-07-2019, 13:26   #3 (permalink)
CoMoBat's Avatar
Member: 1171122
Sonork: 100.1623220
Thanks Meter: 151
Mybe I had bad question
I want help easy jtag plus to find same emmc in samsung device for replace emmc like and MTK device CPU by select "scatter"...
Is it possible this option use for samsung and other bracnds that dos not has a "Scatter" file?
Old 01-07-2019, 15:36   #4 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Preloader are present at MTK CPU based phones.
Preloader contains flash IC CID to correct initialize chips RAM
Parser shows CID, which are located at preloader and shows Flash IC name from database with some CID
The Following User Says Thank You to layder For This Useful Post:
Old 01-07-2019, 16:56   #5 (permalink)
CoMoBat's Avatar
Member: 1171122
Sonork: 100.1623220
Thanks Meter: 151
I don't know how ask my question!!!
I know it, but I want find a way for samsungs, that how can find same emmc by use original firmware like as huawei MTK phone?
Old 01-07-2019, 17:21   #6 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
if you parser preloader from Samsung with MTK cpu, you also can view supported CID at it
You can extract preloader from BL_xxxxx.tar and parse it
Also you may try it without creating a topic and wait for answer
Old 01-08-2019, 13:29   #7 (permalink)
CoMoBat's Avatar
Member: 1171122
Sonork: 100.1623220
Thanks Meter: 151
Thanks for replaying
So it looks like only the MTK processor has a list of supporting CIDs in the flash file in the preloader file, and other processors do not have such a list inside their flash file.
Old 01-10-2019, 01:15   #8 (permalink)
Member: 1112585
Sonork: 100.1645028
Thanks Meter: 91
Different platform has Different design. Qualcomm, MTK, etc, Different.
Maybe platform other then MTK also implement similar design or entirely Different.
Or maybe it buried on different location, not on "preloader/Bootloader".
there's are third party doing RE of it. & we are the "technician" get benefit from it.
The Following User Says Thank You to pai_d For This Useful Post:
Old 01-10-2019, 02:11   #9 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
CID in preloader are exist only in MTK-CPU phones, and only if board use MCP (flash and RAM at one case) - BGA 162/221/254
The Following 4 Users Say Thank You to layder For This Useful Post:
Page generated in 0.20743 seconds with 8 queries
