01-06-2018, 07:31 | #1 (permalink) |
Freak Poster Join Date: Nov 2012 Location: pune india Age: 45
Member: 1838311 Status: Offline Sonork: 100.1638474 Thanks Meter: 103 | Plz Help Note 2 N7100 Daed Boot OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights OK Android Explorer ver:1.0.0.24 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.11.3 QUALCOMM Direct ver:1.0.6306.57125 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 3.0.1.0, are OK Z3X Card Serial : AA27-8D49 , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Selected pinout: EasyJTAG GEN1 ISP Pinout Change EasyJTAG Pinout OK Compression is ON Z3X EasyJtag Software ver. 2.8.0.2 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: 080806061FBF02CB, ,FW Ver.: 01.62 CMD Pullup Level:711 mV CMD Active Level:1866 mV Box IO Level:1800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 15010056545530304DF7F9AF025E214C EMMC CSD : D02701320F5903FFF6DBFFFF8E406008 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 02/2014 Rev.0xF7 EMMC NAME: VTU00M , S/N: 4188996190 EMMC NAME (HEX): 56545530304D00 Can't init EMMC, Reason: DATA RCV CRC Error Check Data Line! Done. Compression is ON Z3X EasyJtag Software ver. 2.8.0.2 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: 080806061FBF02CB, ,FW Ver.: 01.62 CMD Pullup Level:649 mV CMD Active Level:1763 mV Box IO Level:1800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Compression is ON Z3X EasyJtag Software ver. 2.8.0.2 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: 080806061FBF02CB, ,FW Ver.: 01.62 CMD Pullup Level:690 mV CMD Active Level:1732 mV Box IO Level:1800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Compression is ON Z3X EasyJtag Software ver. 2.8.0.2 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: 080806061FBF02CB, ,FW Ver.: 01.62 CMD Pullup Level:732 mV CMD Active Level:1742 mV Box IO Level:1800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Compression is ON Z3X EasyJtag Software ver. 2.8.0.2 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: 080806061FBF02CB, ,FW Ver.: 01.62 CMD Pullup Level:660 mV CMD Active Level:1732 mV Box IO Level:1800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Compression is ON Z3X EasyJtag Software ver. 2.8.0.2 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: 080806061FBF02CB, ,FW Ver.: 01.62 CMD Pullup Level:701 mV CMD Active Level:1763 mV Box IO Level:1800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. Compression is ON Z3X EasyJtag Software ver. 2.8.0.2 Loading eMMC GEN1 Firmware... IO: 1800 mV Box S/N: 080806061FBF02CB, ,FW Ver.: 01.62 CMD Pullup Level:721 mV CMD Active Level:1845 mV Box IO Level:1800 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 15010056545530304DF7F9AF025E214C EMMC CSD : D02701320F5903FFF6DBFFFF8E406008 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 02/2014 Rev.0xF7 EMMC NAME: VTU00M , S/N: 4188996190 EMMC NAME (HEX): 56545530304D00 Can't init EMMC, Reason: DATA RCV CRC Error Check Data Line! Done. what is the problem |
01-06-2018, 12:11 | #3 (permalink) |
No Life Poster Join Date: Aug 2011
Member: 1630066 Status: Offline Sonork: 520074 Thanks Meter: 215 | Connct datao line properly select 2.8v if not detect then remove 2.8v and 1.8v lines and use usb cable direcly from pc to mobiles mother board note:never use any external sorce for power (chareger,battery,power supply e.t.c.....) |
