11-02-2018, 10:22 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Shiraz Iran Age: 37
Member: 1171122 Status: Offline Sonork: 100.1623220 Thanks Meter: 151 | Is it possibe root device by direct emmc? for some device that can't rooted easy |
11-02-2018, 12:01 | #3 (permalink) |
Freak Poster Join Date: May 2014 Location: Anywhere
Member: 2182001 Status: Offline Thanks Meter: 52 | Root isnt only a copy/past in the bin folder need r/w permission in the kernel for new devices |
The Following User Says Thank You to genhack23 For This Useful Post: |
11-02-2018, 12:46 | #6 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Use third part files (SU) we may enter into legal conflict with their respective owners, so we will not add them to our program You can add su files manually with buy EFM license (Emmc File Manager software) http://forum.gsmhosting.com/vbb/f672...eased-2210118/ License is add write function to EXT partition |
The Following User Says Thank You to layder For This Useful Post: |
11-02-2018, 12:49 | #7 (permalink) |
Member: 2182001 Status: Offline Thanks Meter: 52 | Nope isnt only that. I give you an example, when you open an app, this app make a proces in sandbox mode = user level; if i have root permission i can start an app and start a root (guid 0) process thats mean i have the root privileges, but for do that kernel need to be patched in new phone, becouse evry phone have ToC Trust of chain; if i take off an emmc and push all file in the /bin (this isnt relevant of architecture of phone) this process can be run only in the sandbox mode becouse kernel sandbox it. The last phone do the same work of ios, and you need to patch the kernel before run outside the Box... I hope my explaination is good. |
11-02-2018, 13:08 | #9 (permalink) | |
Member: 1171122 Status: Offline Sonork: 100.1623220 Thanks Meter: 151 | Quote:
11-02-2018, 13:10 | #10 (permalink) | |
Member: 2182001 Status: Offline Thanks Meter: 52 | Quote:
The old days when you prompt "fastboot oem unlock" are gone my friend, for old device i thinks is possible if you are able to reverse the boot and unlock it with a patch inside. For the new bootloader all need to be "trusted" cpu to secure boot to bootloader to second stage to kernel and bla bla bla.. Crypto is the problem, and the solution is change our job.... LOL Read somethings is better than talk Becouse in the old phone the security was low level, patch the ramdisk and make the root. Take a look on the url, you will find better explaination then mine Last edited by layder; 11-02-2018 at 13:32. Reason: merge posts | |
11-02-2018, 13:31 | #11 (permalink) | |
For example I want do OEM OFF for J701F in android 8.1 that it is not in developer option... Really I want root J701F but OEM is ON and I can't root it or write TWRP or downgrade it now How can I root or do OEM OFF?! | |
11-02-2018, 13:46 | #12 (permalink) | |
Thats is what i mean we need to change our job. At moment i think you cant in the same ways in the past. Idk if the remove frp in the tool can be useful on android 8 for two reason FullDiskEncryption On and TrustOfChain, oem function is not allowed on every phone.the only ways is like jailbreak in ios, make a lot of exploit for breach security and patch it after, but isnt for all ... Edit: i take a look on the shell and the are a lot of combination with a dev Boot, if you flash that file odin mode you can try to remove frp, after that you can try to root, and remember say in any case thanks to people who find this awesome packet becouse for ios are a dream to have and if one is stoled from factory 1 can be flash only for the mobo signed for it! Last edited by genhack23; 11-02-2018 at 13:54. | |
