03-23-2017, 18:05 | #16 (permalink) |
Freak Poster Join Date: Oct 2011 Location: uf1 b0x land
Member: 1675290 Status: Offline Thanks Meter: 177 | |
03-23-2017, 18:22 | #17 (permalink) | |
No Life Poster Join Date: Jan 2003 Location: GMT +5 Age: 49
Member: 19737 Status: Offline Thanks Meter: 133 | Quote:
But main problem is ufi not available outside its country. | |
03-23-2017, 23:14 | #18 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
Yes i see little time of this video and this is about COOLPAD E501 ,what is related to samsung? anyway as i know if you have full backup then you write to blank eMMC,You lose imei if you write backup to repaired original eMMC,You lose IMEI if you write any other dump to phone then restore efs modemst1,2 etc from original backup ,You have imei Please note Repaired eMMC it mean update FW,not only format/reset | |
03-24-2017, 05:00 | #19 (permalink) | |
Member: 1675290 Status: Offline Thanks Meter: 177 | Quote:
im doing emmc repair everyday sir , firmware update just temporary fixed 75 % will backin 1 week- 1month ... so at this time we chaged emmc every time for 100% repair . | |
03-24-2017, 07:09 | #20 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
Just my 2 cents - most Samsung-s will keep and have after eMMC repair / change / own IMEI relative info if you backup important partitions ( even on 000000 name state ) via eMMC connected on reader or ISP with wires, then flash firmware parts on new or repaired eMMC - pit, bootloader, AP, CP, CSC ( via eMMC or cable, or using SD repair or what you like ... ) or just pit, bootloader and boot - and after this put important partitions backups, stored, read initialy from damaged eMMC in own places, if THEY are OK, mean do not affected from eMMC fault, then for sure Samsung unit will be OK back with original IMEI... this is valid till Galaxy S6 for sure! Tested on many i9300 / N7100 / S4 / S4 mini ... WBR, DebeliaMark, BG | |
The Following User Says Thank You to debeliamark For This Useful Post: |
