Old 12-04-2018, 15:35   #1 (permalink)
Registered User
Member: 2072293
Thanks Meter: 9
Coolpad 8297l-100 getting error-------------
Coolpad 8297l-100 getting error during dead boot repair-
Setting interface to EasyJtag2/ISP
Setting bus width to 1 Bit
Setting frequence to 24 Mhz
CMD Pullup Level: 1771 mV
CMD Active Level: 1881 mV
EMMC Device Information :
EMMC CID: 90014A48384731650507D309651D5257
EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3
EMMC Manufacture Name: SKHYNIX , EMMC NAME: H8G1e , EMMC NAME (HEX): 483847316500 , S/N: D309651D , rev. 0x07
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 5/2015
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
Backup saved: H8G1e_D309651D_20181204_193845.extcsd
EMMC Init completed.
Opening file: rawprogram0.xml
The size of the last section has been updated
CMD Pullup Level: 1765 mV
CMD Active Level: 1878 mV
Backup saved: H8G1e_D309651D_20181204_193852.extcsd
Operation: Write by vendor (Qualcomm/HiSilicon)
Creating GPT-partitioninig
GPT-partitioning done
Partition name: modem
Filename: NON-HLOS.bin , Offset: 000002000000 , filesize: 47793664 bytes
eMMC switching to ROM1
Erasing partition...
Writing partition...
Done writing partition. Write speed: 2617.20 KB/s
Partition name: sbl1
Filename: sbl1.mbn , Offset: 000006000000 , filesize: 250664 bytes
Done writing partition. Write speed: 2116.46 KB/s
Partition name: sbl1bak
Filename: sbl1.mbn , Offset: 000006080000 , filesize: 250664 bytes
Done writing partition. Write speed: 2134.89 KB/s
Partition name: aboot
Filename: emmc_appsboot.mbn , Offset: 000006100000 , filesize: 2255244 bytes
Done writing partition. Write speed: 2544.29 KB/s
Partition name: abootbak
Filename: emmc_appsboot.mbn , Offset: 000007000000 , filesize: 2255244 bytes
Done writing partition. Write speed: 2573.60 KB/s
Partition name: rpm
Filename: rpm.mbn , Offset: 000007F00000 , filesize: 150848 bytes
Done writing partition. Write speed: 1517.90 KB/s
Partition name: rpmbak
Filename: rpm.mbn , Offset: 000007F80000 , filesize: 150848 bytes
Done writing partition. Write speed: 1516.53 KB/s
Partition name: tz
Filename: tz.mbn , Offset: 000008000000 , filesize: 387016 bytes
Done writing partition. Write speed: 2336.29 KB/s
Partition name: tzbak
Filename: tz.mbn , Offset: 000008080000 , filesize: 387016 bytes
Done writing partition. Write speed: 2219.83 KB/s
Partition name: hyp
Filename: hyp.mbn , Offset: 000008100000 , filesize: 20520 bytes
Done writing partition. Write speed: 566.73 KB/s
Partition name: hypbak
Filename: hyp.mbn , Offset: 000008180000 , filesize: 20520 bytes
Done writing partition. Write speed: 564.77 KB/s
Partition name: modemst1
Filename: dummy.bin , Offset: 000008300000 , filesize: 1572864 bytes
Done writing partition. Write speed: 2635.90 KB/s
Partition name: modemst2
Filename: dummy.bin , Offset: 000008480000 , filesize: 1572864 bytes
Done writing partition. Write speed: 2618.90 KB/s
Partition name: misc
Filename: MISC.img , Offset: 000008600000 , filesize: 1048576 bytes
Done writing partition. Write speed: 2565.13 KB/s
Partition name: fsg
Filename: nv.tar.mbn , Offset: 00000A008000 , filesize: 77608 bytes
Done writing partition. Write speed: 1022.41 KB/s
Partition name: sec
Filename: sec.dat , Offset: 00000A188000 , filesize: 428 bytes
Done writing partition. Write speed: 30.22 KB/s
Partition name: boot
Filename: boot.img , Offset: 00000A18C000 , filesize: 8366080 bytes
Done writing partition. Write speed: 2604.35 KB/s
Partition name: params
Filename: param.bin , Offset: 00000C000000 , filesize: 10752 bytes
Done writing partition. Write speed: 325.71 KB/s
Partition name: panic
Filename: panic.img , Offset: 00000C100000 , filesize: 4579328 bytes
Done writing partition. Write speed: 2676.99 KB/s
Partition name: system
Filename: system.img , Offset: 00000E000000 , filesize: 1513087820 bytes
Sparse image found v.1.0 Total chunks: 3140
Done writing partition. Write speed: 1718.43 KB/s
Partition name: persist
Filename: persist.img , Offset: 00008E000000 , filesize: 4427960 bytes
Sparse image found v.1.0 Total chunks: 13
Done writing partition. Write speed: 2415.63 KB/s
Partition name: cache
Filename: cache.img , Offset: 00008EA00000 , filesize: 6348948 bytes
Sparse image found v.1.0 Total chunks: 10
Done writing partition. Write speed: 2503.26 KB/s
Partition name: recovery
Filename: recovery.img , Offset: 000096A00000 , filesize: 8953856 bytes
Done writing partition. Write speed: 2626.26 KB/s
Partition name: userdata
Filename: userdata.img , Offset: 000097E00000 , filesize: 259079868 bytes
Sparse image found v.1.0 Total chunks: 312
Done writing partition. Write speed: 2576.97 KB/s
Check BOOT_PARTITION_EN for the selected vendor
All done time: [00:19:49:734]
Old 12-05-2018, 00:03   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
This log have no error
Old 12-05-2018, 04:41   #3 (permalink)
Registered User
Member: 2072293
Thanks Meter: 9
What does the mean of Check BOOT_PARTITION_EN for the selected vendor ??
Old 12-05-2018, 09:25   #4 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
During the writing process, the BootConfig is not write.
You must check that the BootConfig is correct.
This is just a warning.
The Following User Says Thank You to layder For This Useful Post:
Old 12-07-2018, 05:14   #5 (permalink)
Registered User
Member: 2072293
Thanks Meter: 9
Mobile still in dead condition, try with sd card method mobile come in download mode but ygdp cant start flash. what next step for now?
Old 12-07-2018, 13:59   #6 (permalink)
Pijush Das's Avatar
Member: 1902789
Thanks Meter: 1,100
Hello THE SLUTE,
I found a problem in log...
Problem is "Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot"
Actual Coolpad 8297I-100 Model Boot from ROM1 (Main User Area)
So, Please Check BOOT_PARTITION_EN & Do Correct Boot Configuration.
Do This Steps:
1. Universal Factory Format,
2. Change Boot Config. no boot to ROM1 (Main Use Area),
3. Write Full Flash with tested .xml firmware from write By vendor Tab...
After that Re check ur Mobile...
The Following 2 Users Say Thank You to Pijush Das For This Useful Post:
Old 12-09-2018, 15:22   #7 (permalink)
Registered User
Member: 2072293
Thanks Meter: 9
CMD Pullup Level: 1813 mV
CMD Active Level: 1879 mV
Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area)
Backup saved: H8G1e_D309651D_20181209_183721.extcsd
CMD Pullup Level: 1823 mV
Backup saved: H8G1e_D309651D_20181209_183727.extcsd
Done writing partition. Write speed: 2627.75 KB/s
Done writing partition. Write speed: 1807.18 KB/s
Done writing partition. Write speed: 2135.69 KB/s
Done writing partition. Write speed: 2439.98 KB/s
Done writing partition. Write speed: 2573.42 KB/s
Partition name: rpm
Done writing partition. Write speed: 1527.40 KB/s
Done writing partition. Write speed: 1540.21 KB/s
Partition name: tz
Done writing partition. Write speed: 2225.02 KB/s
Done writing partition. Write speed: 2229.14 KB/s
Partition name: hyp
Done writing partition. Write speed: 569.93 KB/s
Done writing partition. Write speed: 597.05 KB/s
Done writing partition. Write speed: 2432.48 KB/s
Done writing partition. Write speed: 2651.67 KB/s
Done writing partition. Write speed: 2266.95 KB/s
Partition name: fsg
Done writing partition. Write speed: 1016.68 KB/s
Partition name: sec
Done writing partition. Write speed: 29.65 KB/s
Done writing partition. Write speed: 2606.74 KB/s
Done writing partition. Write speed: 333.33 KB/s
Done writing partition. Write speed: 2603.38 KB/s
Done writing partition. Write speed: 2501.01 KB/s
Done writing partition. Write speed: 2420.01 KB/s
Done writing partition. Write speed: 2497.60 KB/s
Done writing partition. Write speed: 2623.15 KB/s
Done writing partition. Write speed: 2594.13 KB/s
All done time: [00:14:37:166]
mobile still in dead condition, even not entering in download mode by sd card method now.
Old 12-10-2018, 06:27   #8 (permalink)
Pijush Das's Avatar
Member: 1902789
Thanks Meter: 1,100
Partition name: rpm
Partition name: tz
Partition name: hyp
Partition name: fsg
Partition name: sec
Now Log OK But I think Need eMMC Change....
Bcoz Hardware Partition already Done By You, So now no others option you have for recovery this eMMC....
The Following User Says Thank You to Pijush Das For This Useful Post:
Old 12-10-2018, 07:35   #9 (permalink)
Registered User
Member: 2072293
Thanks Meter: 9
Sir i have an questions first time log with error that time mobile comes in download by sd card method. Second time log comes without any error but this time mobile not comes in download by sd card.
Page generated in 0.27660 seconds with 9 queries
