Old 09-28-2018, 09:09   #1 (permalink)
Member: 1743727
Thanks Meter: 76
easy jteg gpg (old hadware) not connecting any emmc
Z3X EasyJtag Software ver. 3.2.0.3
Loading eMMC GEN1 Firmware... IO: 3300 mV
Box S/N: 0F0F1010BF8FEF3B, ,FW Ver.: 01.63
CMD Pullup Level:391 mV
CMD Active Level:2846 mV
Box IO Level:3300 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD]
Done.
Loading eMMC GEN1 Firmware... IO: 2800 mV
CMD Pullup Level:381 mV
CMD Active Level:2330 mV
Box IO Level:2800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Done.
i m using this adopter with a charger
https://www.5g-m.com/it/boxes-dongle...1-adapter.html
Old 09-28-2018, 12:21   #2 (permalink)
Member: 1743727
Thanks Meter: 76
can it be the driver problem
Old 09-28-2018, 12:49   #3 (permalink)
royalnasim's Avatar
Member: 1037372
Thanks Meter: 557
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Done.
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Done.
Your connection is good and this error
Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] means your emmc dead or external power supply problem
Do one more time but this time use (cmd , clk , dato, gnd )and connect usb poswer to motherboard and check do not use 1.8 and 2.8
The Following User Says Thank You to royalnasim For This Useful Post:
Old 09-28-2018, 13:52   #4 (permalink)
Member: 1656416
Thanks Meter: 23
Box Drivers version: 0.0.0.0, may affect on box performance
I have the same problem in v3.2, in v3.1 everything is fine
Old 09-29-2018, 06:02   #5 (permalink)
Member: 1743727
Thanks Meter: 76
this time trying with fully working samsung e5 but still didnt conect
Compression is ON
Z3X EasyJtag Software ver. 3.1.0.0
Warning: CMD Pullup Level (61 mV) too low , check cables etc.!
CMD Active Level:1515 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Can't init device, Reason: CMD Timeout Error
Done.
Old 09-29-2018, 08:02   #6 (permalink)
royalnasim's Avatar
Member: 1037372
Thanks Meter: 557
Use 2 100ohm resistor
1st cmd to 1.8v
2nd dato to 1.8
And try again
Old 09-29-2018, 15:51   #7 (permalink)
Member: 1743727
Thanks Meter: 76
Compression is ON
CMD Pullup Level:464 mV
CMD Active Level:2444 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 15010056325730304D00568953538084
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 08/2013 Rev.0x0
eMMC NAME: V2W00M , S/N: 1451840339
eMMC NAME (HEX): 56325730304D
IC Name: Samsung , KMV2W000LM-B506/32GB @FBGA169
EMMC ROM1 (Main User Data) Capacity: 29820 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.7 (MMC 5.0)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: V2W00M_1451840339_20180929_2021.extcsd
Blocks Reading Error (0x0 , 1 , Reason: CMD CRC Error )
Old 09-30-2018, 08:16   #8 (permalink)
Member: 1743727
Thanks Meter: 76
n900 repair done but facing problem in j200g phon received in kernal enforcing and binary blocked by frp i try to flesh but faild.i try to flesh in octopuse all ways pit file error this is the log from phon with emmc
eMMC CID : 150100464E31324D4200AAA9D060A2FE
eMMC Date: 10/2015 Rev.0x0
eMMC NAME: FN12MB , S/N: 2863255648
eMMC NAME (HEX): 464E31324D42
IC Name: Samsung , KMFN10012M-B214/8GB @BGA221
EMMC ROM1 (Main User Data) Capacity: 7456 MB
Backup saved: FN12MB_2863255648_20180930_1244.extcsd
Partition table scan:
GPT: not present
Done.
Skip loading eMMC Addon Firmware
CMD Pullup Level:412 mV
CMD Active Level:1784 mV
Length limit is enabled!
Input file : C:\Users\joni\Downloads\Compressed\SAMSUNG_SM-J200G\boot1.bin
Writing 0000100000 bytes to 0000000000... ROM1 (USER ROM)
Full Verify Enabled!
Done, time taken: 4 sec. Average Write Speed: 237 kB/s
Input file : C:\Users\joni\Downloads\Compressed\SAMSUNG_SM-J200G\boot2.bin
Writing 0000400000 bytes to 0000000000 ...ROM2 (BOOT1 ROM)
Done, time taken: 15 sec. Average Write Speed: 270 kB/s
Old 10-04-2018, 14:37   #9 (permalink)
Member: 41105
Thanks Meter: 43
i have same error
Box Drivers version: 0.0.0.0, may affect on box performance.
Jtag Classic suite ver 3.2.0.3
any ideea is welcome
Old 10-26-2018, 00:16   #10 (permalink)
mrnazam's Avatar
Member: 1001269
Thanks Meter: 226
EasyJtag Suite Classic ver.: 3.2.0.3 / wxWidgets 3.1.0-W-U started.
same
Old 10-26-2018, 11:29   #11 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
same
it's not a error. Box work with this driver
The Following User Says Thank You to layder For This Useful Post:
Page generated in 0.20044 seconds with 8 queries
