02-27-2016, 12:28 | #1 (permalink) |
Freak Poster Join Date: May 2007 Location: Big iran Age: 40
Member: 509921 Status: Offline Thanks Meter: 24 | is it possible to write motorola xt926 factory firmware with easy jtag? Hi I have a motorola xt926 the phone bootloader is corrupted and phone is in qualcomm emergency download mode (qloader hsusb 9008) can I write it's factory firmware directly to its EMMC? my file is like this : |
02-27-2016, 12:46 | #2 (permalink) |
Member: 509921 Status: Offline Thanks Meter: 24 | there is a xml file in the firmware package and here is it's content: Code: <?xml version="1.0"?> -<flashing> -<header> <phone_model model="VZW_XT926_CFC"/> <software_version version="vanquish_vzw-user 4.4.2 KDA20.62-15.1 15 release-keysVANQUISH_BP_100731.020.64.21P"/> -<interfaces> <interface name="AP"/> </interfaces> </header> -<steps interface="AP"> <step var="max-download-size" operation="getvar"/> <step var="fb_mode_set" operation="oem"/> <step operation="flash" MD5="CD46ADE3593552AC58F6176C2DD78ACD" filename="gpt.bin" partition="partition"/> <step operation="flash" MD5="CBE04E7858872030678FCD51D17D2F9D" filename="sbl1.mbn" partition="sbl1"/> <step operation="flash" MD5="E4D68F543805545166C9EDB302C554AD" filename="sbl2.mbn" partition="sbl2"/> <step operation="flash" MD5="05D969C78245050C4BD6489AB1A30B38" filename="sbl3.mbn" partition="sbl3"/> <step operation="flash" MD5="6ACFA1DA4F8FF45341D7C2EC40C733F7" filename="rpm.mbn" partition="rpm"/> <step operation="flash" MD5="69406DE9A02DD2B83604820338DB3AC7" filename="tz.mbn" partition="tz"/> <step operation="flash" MD5="55A33EF063277D8798C9742DBF4F94C1" filename="emmc_appsboot.mbn" partition="aboot"/> <step operation="flash" MD5="43EF4C0BCA6B2A688A6CD3F7830A78C5" filename="NON-HLOS.bin" partition="modem"/> <step operation="flash" MD5="CE3D0DDF2CEDCDA2CF2604ACFE216761" filename="fsg.mbn" partition="fsg"/> <step operation="erase" partition="modemst1"/> <step operation="erase" partition="modemst2"/> <step operation="flash" MD5="06C07C2970460A4E656A3206859A3617" filename="logo.bin" partition="logo"/> <step operation="flash" MD5="A558610C140CDE2990D3C3F9A204B62C" filename="boot.img" partition="boot"/> <step operation="flash" MD5="A41EF69C233947162D6F452D8AE7A20A" filename="recovery.img" partition="recovery"/> <step operation="flash" MD5="9B665960E00E394A43A42AC6BD141CDD" filename="system.img" partition="system"/> <step operation="erase" partition="tombstones"/> <step operation="erase" partition="cache"/> <step operation="erase" partition="userdata"/> <step var="fb_mode_clear" operation="oem"/> </steps> </flashing> |
10-13-2016, 13:30 | #7 (permalink) |
Freak Poster Join Date: Jan 2012
Member: 1713460 Status: Offline Thanks Meter: 28 | Hello. Do you still need help? Have xt926 with eMMC desoldered. Was trying to make ISP pinout picture but can not find CLK. Or my board damaged, or CLK goes to CPU directly. Can read eMMC using direct method, but also not sure if it have good USER AREA |
