07-29-2018, 07:03 | #661 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Yureka Plus Dead Recover Repair Emmc Done Dead Received Repair Emmc Set Alive Now Logs Set Alive Now |
The Following 4 Users Say Thank You to Deepesh Sharma For This Useful Post: |
08-06-2018, 08:04 | #662 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Intex Aqua Power Stuck On Andriod Problem Solve Intex Aqua Power Stuck On Andriod Logo Solve With Repair Emmc Image Log Sucessfully Alive Handset |
The Following 2 Users Say Thank You to Deepesh Sharma For This Useful Post: |
08-12-2018, 08:09 | #663 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Samsung J3 Stuck On Logo Solve Repair Emmc/All Opration Done Samsung J3 Stuck On Logo Solve With Reapir Emmc Image Emmc Repair Read Dump Set ALive Sucessfully All Done |
09-21-2018, 08:06 | #664 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Mumbai--Great INDIA
Member: 665441 Status: Offline Sonork: 100.1670531 Thanks Meter: 603 | Motorola xt1706 dead recovered eMMC_tool Suite ver. 1.4.9.0 (release date: 12.12.2017) Microsoft Windows 7 (64 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 2022 EasyJTAG Box Serial = A7E0B62E74463E4F Card Serial = AA0D-A0F2 EasyJTAG Box Firmware = 2.30 Changelog: 12.12.2017 (ver 1.4.9.0) Fix: Bugs that have been found through your crash report Fix: RandomVerify function Fix: Creation of GPT for Samsung (write by vendor) Fix: Failed to mount large Fat partitions (explorer) Fix: Extraction from contact2.db (explorer) Fix: Error in the "build.prop" parser Fix: CID Parser Add: Support for EasyJtag Plus Box Add: Path for TempDir and InitialDir (option in settings) Add: Unpack Lenovo QSB (utilities) Add: Selecting a PIT file from CSC (write by vendor Samsung) Add: Detect for encrypted dumps from GPG Box Add: Detect for FullDiskEncryption Partition (explorer) Add: LinearVerify of the Partition (read by vendor) Add: Information base about emmc compatibility (thanks to phonemicrodb) Add: Resizing the window (for small screen resolutions) Add: Converting large partitions in SparseImage when reading by vendor (option in settings) Add: Mounting SparseImage (explorer) Add: Automatic backup of the EFS partition for Samsung (read by vendor) Add: Formatting of EFS partition for Samsung on request (write by vendor) Setting interface to EasyJtag2/E-Socket Setting bus width to 4 Bit Setting frequence to 42 Mhz EMMC Device Information : EMMC CID: 150100464531324D4206CF5A232C7141 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture Name: SAMSUNG , EMMC NAME: FE12MB , EMMC NAME (HEX): 464531324D42 , S/N: CF5A232C , rev. 0x06 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 7/2014 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: FE12MB_CF5A232C_20180905_151912.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: proinfo, [000000080000 - 000000380000], size: 000000300000 Partition: nvram, [000000380000 - 000000880000], size: 000000500000 Partition: protect1, [000000880000 - 000001280000], size: 000000A00000 Partition: protect2, [000001280000 - 000001C80000], size: 000000A00000 Partition: lk, [000001C80000 - 000001D00000], size: 000000080000 Partition: para, [000001D00000 - 000001D80000], size: 000000080000 Partition: boot, [000001D80000 - 000002D80000], size: 000001000000 Partition: recovery, [000002D80000 - 000003D80000], size: 000001000000 Partition: logo, [000003D80000 - 000004580000], size: 000000800000 Partition: expdb, [000004580000 - 000004F80000], size: 000000A00000 Partition: seccfg, [000004F80000 - 000005000000], size: 000000080000 Partition: oemkeystore, [000005000000 - 000005200000], size: 000000200000 Partition: secro, [000005200000 - 000005800000], size: 000000600000 Partition: keystore, [000005800000 - 000006000000], size: 000000800000 Partition: tee1, [000006000000 - 000006500000], size: 000000500000 Partition: tee2, [000006500000 - 000006A00000], size: 000000500000 Partition: persist, [000006A00000 - 000009A00000], size: 000003000000 Partition: efuse, [000009A00000 - 000009A80000], size: 000000080000 Partition: frp, [000009A80000 - 000009B80000], size: 000000100000 Partition: nvdata, [000009B80000 - 00000BB80000], size: 000002000000 Partition: metadata, [00000BB80000 - 00000DB80000], size: 000002000000 Partition: preload, [00000DB80000 - 000015800000], size: 000007C80000 Partition: system, [000015800000 - 000075800000], size: 000060000000 Partition: cache, [000075800000 - 00008E800000], size: 000019000000 Partition: userdata, [00008E800000 - 0003A0280000], size: 000311A80000 Partition: otp, [0003A0280000 - 0003A2D80000], size: 000002B00000 Partition: flashinfo, [0003A2D80000 - 0003A3D80000], size: 000001000000 GPT header successfully parsed Get firmware version Brand = motorola Manufacturer = motorola Model = XT1706 Phone platform = mt6735m CPU Abi = armeabi-v7a Mediatek platform = MT6735 Android release = 6.0 Firmware version = XT1706_S151_180706_ROW Firmware date = 2018? 07? 06? ??? 11:39:10 CST |
The Following 2 Users Say Thank You to hanif007 For This Useful Post: |
10-09-2018, 17:56 | #667 (permalink) |
No Life Poster Join Date: Feb 2011 Location: LALGANJ RAEBARELI
Member: 1525102 Status: Offline Sonork: 100.1626123 Thanks Meter: 159 | sam i9192 qualcom mode only first conect isp pinouts give error cmd time out error remove emmc conect emmc soket same error find emmc srap board lava x1 16gb reprograme emmc put it board set alive but blank screen raboll pm ic job done 08-10-2018 21:28:24> Looking for EasyJTAG box... 08-10-2018 21:28:24> EasyJTAG API ver. 2100 08-10-2018 21:28:24> Setting IO Levels to 2.8V 08-10-2018 21:28:24> Setting frequence to 36 Mhz 08-10-2018 21:28:24> EasyJTAG Box Serial = 6B197AB34F228236 08-10-2018 21:28:24> EasyJTAG Box Firmware = 2.30 08-10-2018 21:28:24> Setting interface to EasyJtag2/ISP 08-10-2018 21:28:24> Setting bus width to 1 Bit 08-10-2018 21:28:25> Setting frequence to 36 Mhz 08-10-2018 21:28:25> CMD Pullup Level: 2033 mV 08-10-2018 21:28:25> CMD Active Level: 2487 mV 08-10-2018 21:28:25> eMMC Init returned = 0 08-10-2018 21:28:25> EMMC Device Information : 08-10-2018 21:28:25> EMMC CID: 150100564E5730304D006F5E42D7A039 08-10-2018 21:28:25> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 08-10-2018 21:28:25> EMMC Manufacture : SAMSUNG , EMMC NAME: VNW00M , HEX: 564E5730304D , S/N: 6F5E42D7 , rev. 0x00 08-10-2018 21:28:25> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 10/2013 08-10-2018 21:28:25> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 08-10-2018 21:28:25> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 08-10-2018 21:28:25> EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) 08-10-2018 21:28:25> EMMC Permanent Write Protection: No 08-10-2018 21:28:25> EMMC Temporary Write Protection: No 08-10-2018 21:28:25> Extended CSD Information : 08-10-2018 21:28:25> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 08-10-2018 21:28:25> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 08-10-2018 21:28:25> Boot Bus Config: 0x00 , width 1bit 08-10-2018 21:28:25> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 08-10-2018 21:28:25> Supported partition features [PARTITIONING_SUPPORT]: 0x07 08-10-2018 21:28:25> Device supports partitioning features 08-10-2018 21:28:25> Device can have enhanced technological features in partitions and user data area 08-10-2018 21:28:25> Device can have extended partitions attribute 08-10-2018 21:28:25> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 08-10-2018 21:28:25> Backup saved: VNW00M_6F5E42D7_20181008_212825.extcsd 08-10-2018 21:28:25> EMMC Init completed. 08-10-2018 21:28:25> 08-10-2018 21:28:26> Scanning soft partitions 08-10-2018 21:28:26> GPT header is found and is valid 08-10-2018 21:28:26> Partition: modem, [000000400000 - 000004000000], size: 000003C00000 (60.0 MB) 08-10-2018 21:28:26> Partition: sbl1, [000004000000 - 000004020000], size: 000000020000 (128. KB) 08-10-2018 21:28:26> Partition: sbl2, [000004020000 - 000004060000], size: 000000040000 (256. KB) 08-10-2018 21:28:26> Partition: sbl3, [000004060000 - 0000040E0000], size: 000000080000 (512. KB) 08-10-2018 21:28:26> Partition: aboot, [0000040E0000 - 0000042E0000], size: 000000200000 (2.00 MB) 08-10-2018 21:28:26> Partition: rpm, [0000042E0000 - 000004360000], size: 000000080000 (512. KB) 08-10-2018 21:28:26> Partition: tz, [000004360000 - 0000043E0000], size: 000000080000 (512. KB) 08-10-2018 21:28:26> Partition: pad, [0000043E0000 - 000005060000], size: 000000C80000 (12.5 MB) 08-10-2018 21:28:26> Partition: param, [000005060000 - 000005860000], size: 000000800000 (8.00 MB) 08-10-2018 21:28:26> Partition: efs, [000005860000 - 000006600000], size: 000000DA0000 (13.6 MB) 08-10-2018 21:28:26> Partition: modemst1, [000006600000 - 000006900000], size: 000000300000 (3.00 MB) 08-10-2018 21:28:26> Partition: modemst2, [000006900000 - 000006C00000], size: 000000300000 (3.00 MB) 08-10-2018 21:28:26> Partition: boot, [000006C00000 - 000007600000], size: 000000A00000 (10.0 MB) 08-10-2018 21:28:26> Partition: recovery, [000007600000 - 000008000000], size: 000000A00000 (10.0 MB) 08-10-2018 21:28:26> Partition: fota, [000008000000 - 000008A00000], size: 000000A00000 (10.0 MB) 08-10-2018 21:28:26> Partition: backup, [000008A00000 - 0000090FE000], size: 0000006FE000 (6.99 MB) 08-10-2018 21:28:26> Partition: fsg, [0000090FE000 - 0000093FE000], size: 000000300000 (3.00 MB) 08-10-2018 21:28:26> Partition: ssd, [0000093FE000 - 000009400000], size: 000000002000 (8.00 KB) 08-10-2018 21:28:26> Partition: persist, [000009400000 - 000009C00000], size: 000000800000 (8.00 MB) 08-10-2018 21:28:26> Partition: persdata, [000009C00000 - 00000A800000], size: 000000C00000 (12.0 MB) 08-10-2018 21:28:26> Partition: system, [00000A800000 - 000068400000], size: 00005DC00000 (1.46 GB) 08-10-2018 21:28:26> Partition: cache, [000068400000 - 000074C00000], size: 00000C800000 (200. MB) 08-10-2018 21:28:26> Partition: hidden, [000074C00000 - 000077000000], size: 000002400000 (36.0 MB) 08-10-2018 21:28:26> Partition: userdata, [000077000000 - 0001D1FFBC00], size: 00015AFFBC00 (5.42 GB) 08-10-2018 21:28:26> GPT header successfully parsed 08-10-2018 21:28:26> 08-10-2018 21:28:26> Get firmware version 08-10-2018 21:28:26> 08-10-2018 21:28:27> Brand = samsung 08-10-2018 21:28:27> Manufacturer = samsung 08-10-2018 21:28:27> Model = GT-I9192 08-10-2018 21:28:27> Phone platform = msm8960 08-10-2018 21:28:27> CPU Abi = armeabi-v7a 08-10-2018 21:28:27> Android release = 4.4.2 08-10-2018 21:28:27> Firmware version = KOT49H.I9192XXUCOA2 08-10-2018 21:28:27> Firmware date = Thu Jan 29 21:28:57 KST 2015 Last edited by durgesh4rbl; 10-09-2018 at 18:00. Reason: log attach |
The Following 2 Users Say Thank You to durgesh4rbl For This Useful Post: |
10-10-2018, 11:14 | #668 (permalink) |
Freak Poster Join Date: Dec 2014 Location: nepal,lalitpur
Member: 2306223 Status: Offline Sonork: 1660968:1234 Thanks Meter: 117 | Quote: Sent from my Redmi Note 4 using Tapatalk |
11-11-2018, 18:08 | #672 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Tecno K8 Dead Boot repaired Code: Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 Mhz CMD Pullup Level: 2749 mV CMD Active Level: 2808 mV EMMC Device Information : EMMC CID: 150100514536334D42031C0DD007B48F EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: 1C0DD007 , rev. 0x03 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2017 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_1C0DD007_20181111_204411.extcsd EMMC Init completed. Opening file: MT6737M_Android_scatter.txt The new format of scatter config_version: V1.1.2 platform: MT6737M preloader_rlk6737m_35g_n.bin Found 4 supported eMMC CID: name = 'FE62MB' hex = 0x464536324D42 [SAMSUNG] name = 'EHAEE8' hex = 0x454841454538 [KINGSTONE] name = 'QE63MB' hex = 0x514536334D42 [SAMSUNG] name = 'HAG4a2' hex = 0x484147346132 [SKHYNIX] H9TQ17ABJTACUR/16GB @BGA221 The size of the last section has been updated Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 Mhz CMD Pullup Level: 2749 mV CMD Active Level: 2808 mV EMMC Device Information : EMMC CID: 150100514536334D42031C0DD007B48F EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: 1C0DD007 , rev. 0x03 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2017 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_1C0DD007_20181111_204431.extcsd EMMC Init completed. Operation: Write by vendor (MediaTek) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0003A3DF7E00 GPT-partitioning done Partition name: preloader Filename: preloader_rlk6737m_35g_n.bin , Offset: 000000000000 , filesize: 126300 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 722.34 KB/s Writing DL_Info... Writing DL_Info done Writing eMMC Register ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 All done time: [00:00:05:386] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 Mhz CMD Pullup Level: 2750 mV CMD Active Level: 2808 mV EMMC Device Information : EMMC CID: 150100514536334D42031C0DD007B48F EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: 1C0DD007 , rev. 0x03 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2017 EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_1C0DD007_20181111_204500.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: proinfo, [000000080000 - 000000380000], size: 000000300000 (3.00 MB) Partition: nvram, [000000380000 - 000000880000], size: 000000500000 (5.00 MB) Partition: protect1, [000000880000 - 000001280000], size: 000000A00000 (10.0 MB) Partition: protect2, [000001280000 - 000001C80000], size: 000000A00000 (10.0 MB) Partition: lk, [000001C80000 - 000001D00000], size: 000000080000 (512. KB) Partition: para, [000001D00000 - 000001D80000], size: 000000080000 (512. KB) Partition: boot, [000001D80000 - 000002D80000], size: 000001000000 (16.0 MB) Partition: recovery, [000002D80000 - 000003D80000], size: 000001000000 (16.0 MB) Partition: logo, [000003D80000 - 000004580000], size: 000000800000 (8.00 MB) Partition: expdb, [000004580000 - 000004F80000], size: 000000A00000 (10.0 MB) Partition: seccfg, [000004F80000 - 000005000000], size: 000000080000 (512. KB) Partition: oemkeystore, [000005000000 - 000005200000], size: 000000200000 (2.00 MB) Partition: secro, [000005200000 - 000005800000], size: 000000600000 (6.00 MB) Partition: keystore, [000005800000 - 000006000000], size: 000000800000 (8.00 MB) Partition: tee1, [000006000000 - 000006500000], size: 000000500000 (5.00 MB) Partition: tee2, [000006500000 - 000006A00000], size: 000000500000 (5.00 MB) Partition: frp, [000006A00000 - 000006B00000], size: 000000100000 (1.00 MB) Partition: nvdata, [000006B00000 - 000008B00000], size: 000002000000 (32.0 MB) Partition: metadata, [000008B00000 - 00000B000000], size: 000002500000 (37.0 MB) Partition: system, [00000B000000 - 00010B000000], size: 000100000000 (4.00 GB) Partition: cache, [00010B000000 - 000124000000], size: 000019000000 (400. MB) Partition: userdata, [000124000000 - 0003A2D80000], size: 00027ED80000 (9.98 GB) Partition: flashinfo, [0003A2D80000 - 0003A3D80000], size: 000001000000 (16.0 MB) GPT header successfully parsed Get firmware version Brand = TECNO Manufacturer = TECNO Model = TECNO K8 Phone platform = mt6737m CPU Abi = armeabi-v7a Mediatek platform = MT6737W Android release = 7.0 Firmware version = K8-H3722ABCDE-N-180205V108 Firmware date = Mon Feb 5 17:27:05 CST 2018 |
The Following 3 Users Say Thank You to Nasir Mobiles For This Useful Post: |
11-25-2018, 10:28 | #675 (permalink) |
Member: 355782 Status: Offline Thanks Meter: 1,265 | HTC Butterfly 2 (B810x) - (Encryption Unsuccessful) Repaired. Code: Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 Mhz CMD Pullup Level: 2220 mV CMD Active Level: 3054 mV EMMC Device Information : EMMC CID: 45010053454D3136471C21166EDF11CD EMMC CSD: D00F00320F5903FFFFFFFFFF8A40407F EMMC Manufacture : SANDISK , EMMC NAME: SEM16G , HEX: 53454D313647 , S/N: 21166EDF , rev. 0x1C EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2014 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x05 Device supports partitioning features Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: SEM16G_21166EDF_20181125_133727.extcsd EMMC Init completed. Operation: Write by vendor (Qualcomm/HiSilicon) Partition name: userdata Filename: userdata.bin , Offset: 0000E8000000 , filesize: 73400320 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2618.24 KB/s Check BootConfig for the selected vendor All done time: [00:03:54:412] |
The Following 4 Users Say Thank You to Nasir Mobiles For This Useful Post: |
