Old 07-29-2018, 07:03   #661 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
Yureka Plus Dead Recover Repair Emmc Done
Micromax Yureka Plus-Yu5510A
Dead Received
Repair Emmc Set Alive Now
Logs
Set Alive Now
The Following 4 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 08-06-2018, 08:04   #662 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
Intex Aqua Power Stuck On Andriod Problem Solve
Intex Aqua Power Stuck On Andriod Logo
Solve With Repair Emmc
Log
Sucessfully Alive Handset
The Following 2 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 08-12-2018, 08:09   #663 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
Samsung J3 Stuck On Logo Solve Repair Emmc/All Opration Done
Samsung J3 Stuck On Logo Solve With Reapir Emmc
Emmc Repair
Read Dump
Set ALive Sucessfully
All Done
Old 09-21-2018, 08:06   #664 (permalink)
hanif007's Avatar
Member: 665441
Sonork: 100.1670531
Thanks Meter: 603
Motorola xt1706 dead recovered
eMMC_tool Suite ver. 1.4.9.0 (release date: 12.12.2017)
Microsoft Windows 7 (64 bit) build 7601 (6.1.7600.16385)
Looking for EasyJTAG box...
EasyJTAG API ver. 2022
EasyJTAG Box Serial = A7E0B62E74463E4F
Card Serial = AA0D-A0F2
EasyJTAG Box Firmware = 2.30
Changelog:
12.12.2017 (ver 1.4.9.0)
Fix: Bugs that have been found through your crash report
Fix: RandomVerify function
Fix: Creation of GPT for Samsung (write by vendor)
Fix: Failed to mount large Fat partitions (explorer)
Fix: Extraction from contact2.db (explorer)
Fix: Error in the "build.prop" parser
Fix: CID Parser
Add: Support for EasyJtag Plus Box
Add: Path for TempDir and InitialDir (option in settings)
Add: Unpack Lenovo QSB (utilities)
Add: Selecting a PIT file from CSC (write by vendor Samsung)
Add: Detect for encrypted dumps from GPG Box
Add: Detect for FullDiskEncryption Partition (explorer)
Add: LinearVerify of the Partition (read by vendor)
Add: Information base about emmc compatibility (thanks to phonemicrodb)
Add: Resizing the window (for small screen resolutions)
Add: Converting large partitions in SparseImage when reading by vendor (option in settings)
Add: Mounting SparseImage (explorer)
Add: Automatic backup of the EFS partition for Samsung (read by vendor)
Add: Formatting of EFS partition for Samsung on request (write by vendor)
Setting interface to EasyJtag2/E-Socket
Setting bus width to 4 Bit
Setting frequence to 42 Mhz
EMMC Device Information :
EMMC CID: 150100464531324D4206CF5A232C7141
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufacture Name: SAMSUNG , EMMC NAME: FE12MB , EMMC NAME (HEX): 464531324D42 , S/N: CF5A232C , rev. 0x06
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 7/2014
EMMC ROM 1 (Main User Data) Capacity: 14910 MB (0003A3E00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: FE12MB_CF5A232C_20180905_151912.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: proinfo, [000000080000 - 000000380000], size: 000000300000
Partition: nvram, [000000380000 - 000000880000], size: 000000500000
Partition: protect1, [000000880000 - 000001280000], size: 000000A00000
Partition: protect2, [000001280000 - 000001C80000], size: 000000A00000
Partition: lk, [000001C80000 - 000001D00000], size: 000000080000
Partition: para, [000001D00000 - 000001D80000], size: 000000080000
Partition: boot, [000001D80000 - 000002D80000], size: 000001000000
Partition: recovery, [000002D80000 - 000003D80000], size: 000001000000
Partition: logo, [000003D80000 - 000004580000], size: 000000800000
Partition: expdb, [000004580000 - 000004F80000], size: 000000A00000
Partition: seccfg, [000004F80000 - 000005000000], size: 000000080000
Partition: oemkeystore, [000005000000 - 000005200000], size: 000000200000
Partition: secro, [000005200000 - 000005800000], size: 000000600000
Partition: keystore, [000005800000 - 000006000000], size: 000000800000
Partition: tee1, [000006000000 - 000006500000], size: 000000500000
Partition: tee2, [000006500000 - 000006A00000], size: 000000500000
Partition: persist, [000006A00000 - 000009A00000], size: 000003000000
Partition: efuse, [000009A00000 - 000009A80000], size: 000000080000
Partition: frp, [000009A80000 - 000009B80000], size: 000000100000
Partition: nvdata, [000009B80000 - 00000BB80000], size: 000002000000
Partition: metadata, [00000BB80000 - 00000DB80000], size: 000002000000
Partition: preload, [00000DB80000 - 000015800000], size: 000007C80000
Partition: system, [000015800000 - 000075800000], size: 000060000000
Partition: cache, [000075800000 - 00008E800000], size: 000019000000
Partition: userdata, [00008E800000 - 0003A0280000], size: 000311A80000
Partition: otp, [0003A0280000 - 0003A2D80000], size: 000002B00000
Partition: flashinfo, [0003A2D80000 - 0003A3D80000], size: 000001000000
GPT header successfully parsed
Get firmware version
Brand = motorola
Manufacturer = motorola
Model = XT1706
Phone platform = mt6735m
CPU Abi = armeabi-v7a
Mediatek platform = MT6735
Android release = 6.0
Firmware version = XT1706_S151_180706_ROW
Firmware date = 2018? 07? 06? ??? 11:39:10 CST
The Following 2 Users Say Thank You to hanif007 For This Useful Post:
Old 10-01-2018, 12:04   #665 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
Samsung G7102 Dead Recovered Done
The Following User Says Thank You to 4G Telecom For This Useful Post:
Old 10-09-2018, 17:38   #666 (permalink)
durgesh4rbl's Avatar
Member: 1525102
Sonork: 100.1626123
Thanks Meter: 159
sam i9060 hang on logo flash error oidn setup conecton
sam i9060 hang on logo flashing failed show error setuo conection error
first update emmc firmware then write dum file from support
flash again odin
set is working fine
Old 10-09-2018, 17:56   #667 (permalink)
Member: 1525102
Sonork: 100.1626123
Thanks Meter: 159
sam i9192 qualcom mode only
first conect isp pinouts give error cmd time out error remove emmc conect emmc soket same error find emmc srap board lava x1 16gb reprograme emmc put it board set alive but blank screen raboll pm ic job done
08-10-2018 21:28:24> Looking for EasyJTAG box...
08-10-2018 21:28:24> EasyJTAG API ver. 2100
08-10-2018 21:28:24> Setting IO Levels to 2.8V
08-10-2018 21:28:24> Setting frequence to 36 Mhz
08-10-2018 21:28:24> EasyJTAG Box Serial = 6B197AB34F228236
08-10-2018 21:28:24> EasyJTAG Box Firmware = 2.30
08-10-2018 21:28:24> Setting interface to EasyJtag2/ISP
08-10-2018 21:28:24> Setting bus width to 1 Bit
08-10-2018 21:28:25> Setting frequence to 36 Mhz
08-10-2018 21:28:25> CMD Pullup Level: 2033 mV
08-10-2018 21:28:25> CMD Active Level: 2487 mV
08-10-2018 21:28:25> eMMC Init returned = 0
08-10-2018 21:28:25> EMMC Device Information :
08-10-2018 21:28:25> EMMC CID: 150100564E5730304D006F5E42D7A039
08-10-2018 21:28:25> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
08-10-2018 21:28:25> EMMC Manufacture : SAMSUNG , EMMC NAME: VNW00M , HEX: 564E5730304D , S/N: 6F5E42D7 , rev. 0x00
08-10-2018 21:28:25> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 10/2013
08-10-2018 21:28:25> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
08-10-2018 21:28:25> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
08-10-2018 21:28:25> EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000)
08-10-2018 21:28:25> EMMC Permanent Write Protection: No
08-10-2018 21:28:25> EMMC Temporary Write Protection: No
08-10-2018 21:28:25> Extended CSD Information :
08-10-2018 21:28:25> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
08-10-2018 21:28:25> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
08-10-2018 21:28:25> Boot Bus Config: 0x00 , width 1bit
08-10-2018 21:28:25> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
08-10-2018 21:28:25> Supported partition features [PARTITIONING_SUPPORT]: 0x07
08-10-2018 21:28:25> Device supports partitioning features
08-10-2018 21:28:25> Device can have enhanced technological features in partitions and user data area
08-10-2018 21:28:25> Device can have extended partitions attribute
08-10-2018 21:28:25> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
08-10-2018 21:28:25> Backup saved: VNW00M_6F5E42D7_20181008_212825.extcsd
08-10-2018 21:28:25> EMMC Init completed.
08-10-2018 21:28:26> Scanning soft partitions
08-10-2018 21:28:26> GPT header is found and is valid
08-10-2018 21:28:26> Partition: modem, [000000400000 - 000004000000], size: 000003C00000 (60.0 MB)
08-10-2018 21:28:26> Partition: sbl1, [000004000000 - 000004020000], size: 000000020000 (128. KB)
08-10-2018 21:28:26> Partition: sbl2, [000004020000 - 000004060000], size: 000000040000 (256. KB)
08-10-2018 21:28:26> Partition: sbl3, [000004060000 - 0000040E0000], size: 000000080000 (512. KB)
08-10-2018 21:28:26> Partition: aboot, [0000040E0000 - 0000042E0000], size: 000000200000 (2.00 MB)
08-10-2018 21:28:26> Partition: rpm, [0000042E0000 - 000004360000], size: 000000080000 (512. KB)
08-10-2018 21:28:26> Partition: tz, [000004360000 - 0000043E0000], size: 000000080000 (512. KB)
08-10-2018 21:28:26> Partition: pad, [0000043E0000 - 000005060000], size: 000000C80000 (12.5 MB)
08-10-2018 21:28:26> Partition: param, [000005060000 - 000005860000], size: 000000800000 (8.00 MB)
08-10-2018 21:28:26> Partition: efs, [000005860000 - 000006600000], size: 000000DA0000 (13.6 MB)
08-10-2018 21:28:26> Partition: modemst1, [000006600000 - 000006900000], size: 000000300000 (3.00 MB)
08-10-2018 21:28:26> Partition: modemst2, [000006900000 - 000006C00000], size: 000000300000 (3.00 MB)
08-10-2018 21:28:26> Partition: boot, [000006C00000 - 000007600000], size: 000000A00000 (10.0 MB)
08-10-2018 21:28:26> Partition: recovery, [000007600000 - 000008000000], size: 000000A00000 (10.0 MB)
08-10-2018 21:28:26> Partition: fota, [000008000000 - 000008A00000], size: 000000A00000 (10.0 MB)
08-10-2018 21:28:26> Partition: backup, [000008A00000 - 0000090FE000], size: 0000006FE000 (6.99 MB)
08-10-2018 21:28:26> Partition: fsg, [0000090FE000 - 0000093FE000], size: 000000300000 (3.00 MB)
08-10-2018 21:28:26> Partition: ssd, [0000093FE000 - 000009400000], size: 000000002000 (8.00 KB)
08-10-2018 21:28:26> Partition: persist, [000009400000 - 000009C00000], size: 000000800000 (8.00 MB)
08-10-2018 21:28:26> Partition: persdata, [000009C00000 - 00000A800000], size: 000000C00000 (12.0 MB)
08-10-2018 21:28:26> Partition: system, [00000A800000 - 000068400000], size: 00005DC00000 (1.46 GB)
08-10-2018 21:28:26> Partition: cache, [000068400000 - 000074C00000], size: 00000C800000 (200. MB)
08-10-2018 21:28:26> Partition: hidden, [000074C00000 - 000077000000], size: 000002400000 (36.0 MB)
08-10-2018 21:28:26> Partition: userdata, [000077000000 - 0001D1FFBC00], size: 00015AFFBC00 (5.42 GB)
08-10-2018 21:28:26> GPT header successfully parsed
08-10-2018 21:28:26> Get firmware version
08-10-2018 21:28:27> Brand = samsung
08-10-2018 21:28:27> Manufacturer = samsung
08-10-2018 21:28:27> Model = GT-I9192
08-10-2018 21:28:27> Phone platform = msm8960
08-10-2018 21:28:27> CPU Abi = armeabi-v7a
08-10-2018 21:28:27> Android release = 4.4.2
08-10-2018 21:28:27> Firmware version = KOT49H.I9192XXUCOA2
08-10-2018 21:28:27> Firmware date = Thu Jan 29 21:28:57 KST 2015
The Following 2 Users Say Thank You to durgesh4rbl For This Useful Post:
Old 10-10-2018, 11:14   #668 (permalink)
nagesss's Avatar
Member: 2306223
Sonork: 1660968:1234
Thanks Meter: 117
how.did it work with all those pins missing....allof them cant be nc pin...please explain
Sent from my Redmi Note 4 using Tapatalk
Old 10-10-2018, 12:33   #669 (permalink)
Member: 1525102
Sonork: 100.1626123
Thanks Meter: 159
not necessary to all pin only need main point ihave data sheet
The Following 3 Users Say Thank You to durgesh4rbl For This Useful Post:
Old 10-21-2018, 16:36   #670 (permalink)
Member: 1525102
Sonork: 100.1626123
Thanks Meter: 159
lyf 4503 Data Recovery Done
Lyf 4503 board crack Rmove emmc Put emmc socket contact and other files recover done
Old 10-21-2018, 19:03   #671 (permalink)
Member: 1525102
Sonork: 100.1626123
Thanks Meter: 159
mmx q372 hang on logo after flash set gone dead
Change emmc h9tp65a8jdac same scarab board a106 replace and programme job done
The Following User Says Thank You to durgesh4rbl For This Useful Post:
Old 11-11-2018, 18:08   #672 (permalink)
Nasir Mobiles's Avatar
Member: 355782
Thanks Meter: 1,265
Tecno K8 Dead Boot repaired
CMD Pullup Level: 2749 mV
CMD Active Level: 2808 mV
EMMC CID: 150100514536334D42031C0DD007B48F
EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: 1C0DD007 , rev. 0x03
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2017
Extended CSD rev: 1.8 (MMC 5.1)
Backup saved: QE63MB_1C0DD007_20181111_204411.extcsd
Opening file: MT6737M_Android_scatter.txt
The new format of scatter
config_version: V1.1.2
platform: MT6737M
preloader_rlk6737m_35g_n.bin
Found 4 supported eMMC CID:
name = 'FE62MB'     hex = 0x464536324D42     [SAMSUNG]
name = 'EHAEE8'     hex = 0x454841454538     [KINGSTONE]
name = 'QE63MB'     hex = 0x514536334D42     [SAMSUNG]
name = 'HAG4a2'     hex = 0x484147346132     [SKHYNIX]
H9TQ17ABJTACUR/16GB @BGA221
The size of the last section has been updated
Backup saved: QE63MB_1C0DD007_20181111_204431.extcsd
Operation: Write by vendor (MediaTek)
Creating GPT-partitioninig
Writing PrimaryGPT at address: 000000000000
Writing BackupGPT at address: 0003A3DF7E00
GPT-partitioning done
Partition name: preloader
Filename: preloader_rlk6737m_35g_n.bin , Offset: 000000000000 , filesize: 126300 bytes
eMMC switching to ROM2
Erasing partition...
Writing partition...
Done writing partition. Write speed: 722.34 KB/s
Writing DL_Info...
Writing DL_Info done
Writing eMMC Register ...
Reg: 179  Value: 0x48
Reg: 177  Value: 0x00
Reg: 162  Value: 0x01
All done   time: [00:00:05:386]
CMD Pullup Level: 2750 mV
Backup saved: QE63MB_1C0DD007_20181111_204500.extcsd
Partition: proinfo, [000000080000 - 000000380000], size: 000000300000 (3.00 MB)
Partition: nvram, [000000380000 - 000000880000], size: 000000500000 (5.00 MB)
Partition: protect1, [000000880000 - 000001280000], size: 000000A00000 (10.0 MB)
Partition: protect2, [000001280000 - 000001C80000], size: 000000A00000 (10.0 MB)
Partition: lk, [000001C80000 - 000001D00000], size: 000000080000 (512. KB)
Partition: para, [000001D00000 - 000001D80000], size: 000000080000 (512. KB)
Partition: boot, [000001D80000 - 000002D80000], size: 000001000000 (16.0 MB)
Partition: recovery, [000002D80000 - 000003D80000], size: 000001000000 (16.0 MB)
Partition: logo, [000003D80000 - 000004580000], size: 000000800000 (8.00 MB)
Partition: expdb, [000004580000 - 000004F80000], size: 000000A00000 (10.0 MB)
Partition: seccfg, [000004F80000 - 000005000000], size: 000000080000 (512. KB)
Partition: oemkeystore, [000005000000 - 000005200000], size: 000000200000 (2.00 MB)
Partition: secro, [000005200000 - 000005800000], size: 000000600000 (6.00 MB)
Partition: keystore, [000005800000 - 000006000000], size: 000000800000 (8.00 MB)
Partition: tee1, [000006000000 - 000006500000], size: 000000500000 (5.00 MB)
Partition: tee2, [000006500000 - 000006A00000], size: 000000500000 (5.00 MB)
Partition: frp, [000006A00000 - 000006B00000], size: 000000100000 (1.00 MB)
Partition: nvdata, [000006B00000 - 000008B00000], size: 000002000000 (32.0 MB)
Partition: metadata, [000008B00000 - 00000B000000], size: 000002500000 (37.0 MB)
Partition: system, [00000B000000 - 00010B000000], size: 000100000000 (4.00 GB)
Partition: cache, [00010B000000 - 000124000000], size: 000019000000 (400. MB)
Partition: userdata, [000124000000 - 0003A2D80000], size: 00027ED80000 (9.98 GB)
Partition: flashinfo, [0003A2D80000 - 0003A3D80000], size: 000001000000 (16.0 MB)
Brand = TECNO
Manufacturer = TECNO
Model = TECNO K8
Phone platform = mt6737m
Mediatek platform = MT6737W
Android release = 7.0
Firmware version = K8-H3722ABCDE-N-180205V108
Firmware date = Mon Feb  5 17:27:05 CST 2018
The Following 3 Users Say Thank You to Nasir Mobiles For This Useful Post:
Old 11-13-2018, 10:01   #673 (permalink)
Member: 22054
Thanks Meter: 8
How repairing just reading Rom1?
Originally Posted by omi17 View Post
MOTO X PLAY XT1562 OTA dead repair done
http://www.youtube.com/watch?v=t7ZzeRGOoEw
You mean that just need read rom1 256mb, and just that? Nothing else in Jtag?
Old 11-14-2018, 18:43   #674 (permalink)
Member: 2623135
Thanks Meter: 8
lenovo a6000 plus emmc change jib done
Sent from my Redmi 5 using Tapatalk
Old 11-25-2018, 10:28   #675 (permalink)
Member: 355782
Thanks Meter: 1,265
HTC Butterfly 2 (B810x) - (Encryption Unsuccessful) Repaired.
Setting frequence to 24 Mhz
CMD Pullup Level: 2220 mV
CMD Active Level: 3054 mV
EMMC CID: 45010053454D3136471C21166EDF11CD
EMMC CSD: D00F00320F5903FFFFFFFFFF8A40407F
EMMC Manufacture : SANDISK , EMMC NAME: SEM16G , HEX: 53454D313647 , S/N: 21166EDF , rev. 0x1C
EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 1/2014
   EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000)
Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51)
Supported partition features [PARTITIONING_SUPPORT]: 0x05
Backup saved: SEM16G_21166EDF_20181125_133727.extcsd
Operation: Write by vendor (Qualcomm/HiSilicon)
Partition name: userdata
Filename: userdata.bin , Offset: 0000E8000000 , filesize: 73400320 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 2618.24 KB/s
Check BootConfig for the selected vendor
All done   time: [00:03:54:412]
The Following 4 Users Say Thank You to Nasir Mobiles For This Useful Post:
Page generated in 0.17763 seconds with 9 queries
