11-24-2012, 16:24 | #1 (permalink) |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,554 | Post here succesfull JTAG and eMMC operations with Easy-Jtag: Easy-JTAG are best JTAG and eMMC box! Last edited by NoName®; 05-27-2014 at 23:02. |
The Following 10 Users Say Thank You to blang For This Useful Post: |
03-01-2013, 10:44 | #2 (permalink) |
Freak Poster Join Date: Sep 2010 Location: Ukraine, Ivano-Frankivsk Age: 31
Member: 1397329 Status: Offline Thanks Meter: 73 | Test search pinout and connect S5230... Code: Box Working Mode: JTAG Box. Start Z3X Jtag Pin Finder... Successefuly connected to box on COM706 Waiting for box reset... Box S/N: 00000000******** Box Working Mode: JTAG Pin Finder. Start Z3X Jtag Pin Finder... Stage 1: Search TCK / TMS / TDI / TDO... Try to get IDCODE... JTAG Pinout Found: TCK: Pin 11 / TMS: Pin 1 / TDI: Pin 9 / TDO: Pin 7 Found device with IDCODE=0x7926F0F Stage 2: Search TRST... TRST Pin Found: TRST: Pin 13 Box S/N: 0D0DFF182DBE7A08 Box Working Mode: JTAG Box. 10:38:47 For support and updates visit http://easy-jtag.com I/O Level set to : 3000 mV Box S/N: 0D0D******,SW Ver.: 01.42 Connecting to Target... JTAG device: BCM2133 CPU IDCODE detected: 0x07926F0F Manufacturer: 0x787, Part: 0x7926, Version: 0x0 Halting CPU... Starting target communication... Detecting nand memory parameters of bank (0) ... NAND flash device ID:00EC:00BA 'NAND 256MiB 1.8V 16-bit (Samsung)' found NAND geometry: Blocks:00000800, Page size:2048 bytes , Block size:64 pages |
The Following 6 Users Say Thank You to Dimidrolus For This Useful Post: |
03-01-2013, 12:10 | #3 (permalink) |
Member: 1397329 Status: Offline Thanks Meter: 73 | S5230 easy repair boot... Code: Checking repair data... For support and updates visit http://easy-jtag.com I/O Level set to : 3000 mV Box S/N: 0D0D******* ,SW Ver.: 01.42 Connecting to Target... JTAG device: BCM2133 CPU IDCODE detected: 0x07926F0F Manufacturer: 0x787, Part: 0x7926, Version: 0x0 Halting CPU... Starting target communication... Detecting nand memory parameters of bank (0) ... NAND flash device ID:00EC:00BA 'NAND 256MiB 1.8V 16-bit (Samsung)' found NAND geometry: Blocks:00000800, Page size:2048 bytes , Block size:64 pages NAND Writing BOOT... NAND Write OK! Wrote up to offset 0x00080000 in 4,921875s (107,276 KiB/s) Repair DONE! Restarting phone... All Done. Box are disconnected! |
The Following 4 Users Say Thank You to Dimidrolus For This Useful Post: |
03-02-2013, 23:54 | #6 (permalink) |
Member: 1397329 Status: Offline Thanks Meter: 73 | Programming s5830i Finder Code: Start Z3X Jtag Pin Finder... Successefuly connected to box on COM68 Waiting for box reset... Box S/N: 000000000******* Box Working Mode: JTAG Pin Finder. Start Z3X Jtag Pin Finder... Stage 1: Search TCK / TMS / TDI / TDO... Try to get IDCODE... JTAG Pinout Found: TCK: Pin 11 / TMS: Pin 3 / TDI: Pin 9 / TDO: Pin 13 CPU IDCODE : 0x07B3617F Mfg.: 0x0bf, Part: 0x7b36, Ver.: 0x0 CPU Manufacturer: SST/Broadcom , CPU Name: BCM21553 Stage 2: Search TRST... TRST Pin Found: TRST: Pin 1 Box S/N: ********** Box Working Mode: JTAG Box. Dump 64Mb Code: For support and updates visit http://easy-jtag.com I/O Level set to : 3000 mV Box S/N: **************,SW Ver.: 01.42 Connecting to Target... Warn: JTAG device: BCM21553 CPU IDCODE : 0x07B3617F Mfg.: 0x0bf, Part: 0x7b36, Ver.: 0x0 Warn: CPU Manufacturer: SST/Broadcom , CPU Name: BCM21553 Halting CPU... Initialize hardware... Starting target communication... Detecting nand memory parameters ... NAND flash device ID:00EC:0050 'NAND 4GiB 1.8V 16-bit (Samsung)' found NAND geometry: Blocks:00002000, Page size:4096 bytes , Block size:64 pages Accesing logical device region # 0 Working block has an 256 pages , allocating 135168 bytes of memory Reading 04000000 bytes from NAND adress 00000000... Dumped 69206016 bytes in 458,401215s (147,434 KiB/s) OK. Last edited by NoName®; 03-04-2013 at 20:41. |
The Following 7 Users Say Thank You to Dimidrolus For This Useful Post: |
04-12-2013, 21:09 | #9 (permalink) |
Member: 1397329 Status: Offline Thanks Meter: 73 | i917 write fullflash succesfully done Code: EasyJtag Suite ver. 1.0.18.2 started. For support and updates visit http://easy-jtag.com I/O Level set to : 2600 mV Box S/N: ********** ,SW Ver.: 01.42 Connecting to Target... JTAG device: QSD8250. CPU IDCODE : 0x1BA000E1 Mfg.: 0x070, Part: 0xba00, Ver.: 0x1 CPU Manufacturer: QUALCOMM , CPU Name: QSD8250 SLAVE JTAG device: QSD8250. CPU IDCODE : 0x202400E1 Mfg.: 0x070, Part: 0x0240, Ver.: 0x2 CPU Manufacturer: QUALCOMM , CPU Name: QSD8250 Initialize hardware... Starting target communication... Detecting nand memory parameters ... NAND flash device ID:002C:00B3 'NAND 1GiB 1.8V 16-bit (Micron)' found NAND geometry: Blocks:00002000, Page size:2048 bytes , Block size:64 pages Writing NAND from file...D:\1GB_Z3X.bin Lock file not found D:/1GB_Z3X.lock NAND Write OK! Wrote up to offset 0x40000000 in 3846.583008s (281.118 KiB/s) |
05-04-2013, 04:36 | #11 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Shadow Clone
Member: 1357650 Status: Offline Sonork: 100.1611843 Thanks Meter: 123 | can i aslo test your box willing to try Beta test here bR |
The Following User Says Thank You to TestCard17 For This Useful Post: |
05-10-2013, 17:47 | #12 (permalink) | |
No Life Poster Join Date: Oct 2009 Location: Rajasthan INDIA
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Quote:
Unlocking & Flashing Devices :: Z3x Easy JTAG with 3 Cables - iCables.in | |
The Following 2 Users Say Thank You to Yashbanswara For This Useful Post: |
05-14-2013, 09:07 | #15 (permalink) |
No Life Poster Join Date: Nov 2003 Location: Poland Age: 46
Member: 43823 Status: Offline Thanks Meter: 308 | I9100 sucesfull JOB done using Easy JTAG Code: EasyJtag Suite ver. 1.0.24.0 started. Successefuly connected to box on COM48 Box S/N: XXXXXXXXXXXXXXXXx, ,FW Ver.: 01.44 Box Working Mode: JTAG Box. Z3X Card Serial : XXXXXXXXX Z3X Card Version : 22 Z3X Card Activation [JTAG] : 1 Resources ver. : MainRC ver.OCD040Z001 (C)2012 z3x-team.com Loading repair file: 'C:\Program Files\Z3X\EASYJTAG\Repair Files\Samsung GT-i9100.rcp' Repair File ver. : Easy Repair for Mfg: SAMSUNG Model: GT-I9100, Ver.: 1.00 Easy-Repair file load OK! Using EasyRepair Mode... Checking repair data... EasyJtag Suite ver. 1.0.24.0 started. For support and updates visit http://easy-jtag.com Initialising: SAMSUNG GT-I9100 Config ver.:1.00 I/O Level set to : 2800 mV Box S/N: 10100007B9800571 ,FW Ver.: 01.44 Connecting to Target... JTAG device: S5PC210 CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4 CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9 Halting CPU... Init target ... Starting target communication... Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x00010015 Name : VYL00M Size : 16 GB EMMC #1 : ID : 0x00010015 Name : VYL00M Size : 524 kB eMMC flash device(s) found, Device ID : 0x00150001 NAND Writing GPT... eMMC Write OK! Elapsed time: 9.015625s (454.322 KiB/s) NAND Writing SBL1... eMMC Write OK! Elapsed time: 12.234375s (104.623 KiB/s) NAND Writing SBL2... eMMC Write OK! Elapsed time: 12.046875s (106.252 KiB/s) NAND Writing PARAM... eMMC Write OK! Elapsed time: 27.609375s (296.711 KiB/s) NAND Writing ROM2... eMMC Write OK! Elapsed time: 1.421875s (360.088 KiB/s) All Done. |
The Following 8 Users Say Thank You to Multi-COM For This Useful Post: |
