Old 11-24-2012, 16:24   #1 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,554
Post here succesfull JTAG and eMMC operations with Easy-Jtag:
Post here sucessfull operation with Easy-Jtag:
Easy-JTAG are best JTAG and eMMC box!
The Following 10 Users Say Thank You to blang For This Useful Post:
Old 03-01-2013, 10:44   #2 (permalink)
Member: 1397329
Thanks Meter: 73
Test search pinout and connect S5230...
Box Working Mode: JTAG Box.
Start Z3X Jtag Pin Finder...
Successefuly connected to box on COM706
Waiting for box reset...
Box S/N: 00000000********
Box Working Mode: JTAG Pin Finder.
Stage 1: Search TCK / TMS / TDI / TDO...
Try to get IDCODE...
JTAG Pinout Found: TCK: Pin 11 / TMS: Pin 1 / TDI: Pin 9 / TDO: Pin 7
Found device with IDCODE=0x7926F0F
Stage 2: Search TRST...
TRST Pin Found: TRST: Pin 13
Box S/N: 0D0DFF182DBE7A08
Box Working Mode: JTAG Box.	10:38:47
For support and updates visit http://easy-jtag.com
I/O Level set to : 3000 mV
Box S/N: 0D0D******,SW Ver.: 01.42
Connecting to Target...
JTAG device: BCM2133
CPU IDCODE detected: 0x07926F0F
Manufacturer: 0x787, Part: 0x7926, Version: 0x0
Halting CPU...
Starting target communication...
Detecting nand memory parameters of bank (0) ...
NAND flash device ID:00EC:00BA 'NAND 256MiB 1.8V 16-bit (Samsung)' found
NAND geometry: Blocks:00000800, Page size:2048 bytes , Block size:64 pages
The Following 6 Users Say Thank You to Dimidrolus For This Useful Post:
Old 03-01-2013, 12:10   #3 (permalink)
Member: 1397329
Thanks Meter: 73
S5230 easy repair boot...
Checking repair data...
Box S/N: 0D0D******* ,SW Ver.: 01.42
Halting CPU...
NAND Writing BOOT...
NAND Write OK! Wrote up to offset 0x00080000 in 4,921875s (107,276 KiB/s)
Repair DONE! Restarting phone...
All Done.
Box are disconnected!
The Following 4 Users Say Thank You to Dimidrolus For This Useful Post:
Old 03-01-2013, 15:28   #4 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
706SC Connection/Dump with UJK clip SAM-B ;-)
The Following User Says Thank You to NoName® For This Useful Post:
Old 03-01-2013, 19:41   #5 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
Thanks Meter: 444
so when ? before the end of this year ?
The Following User Says Thank You to cycofcgb For This Useful Post:
Old 03-02-2013, 23:54   #6 (permalink)
Member: 1397329
Thanks Meter: 73
Programming s5830i
Finder
Successefuly connected to box on COM68
Box S/N: 000000000*******
JTAG Pinout Found: TCK: Pin 11 / TMS: Pin 3 / TDI: Pin 9 / TDO: Pin 13
CPU IDCODE : 0x07B3617F Mfg.: 0x0bf, Part: 0x7b36, Ver.: 0x0
CPU Manufacturer: SST/Broadcom , CPU Name: BCM21553
Box S/N: **********
Dump 64Mb
Box S/N: **************,SW Ver.: 01.42
Warn: JTAG device: BCM21553
Warn: CPU Manufacturer: SST/Broadcom , CPU Name: BCM21553
Halting CPU...
Initialize hardware...
Detecting nand memory parameters ...
NAND flash device ID:00EC:0050 'NAND 4GiB 1.8V 16-bit (Samsung)' found
NAND geometry: Blocks:00002000, Page size:4096 bytes , Block size:64 pages
Accesing logical device region # 0
Working block has an 256 pages , allocating 135168 bytes of memory
Reading 04000000 bytes from NAND adress 00000000...
Dumped 69206016 bytes in 458,401215s (147,434 KiB/s) OK.
The Following 7 Users Say Thank You to Dimidrolus For This Useful Post:
Old 03-08-2013, 16:10   #7 (permalink)
biswajit74's Avatar
Member: 900306
Thanks Meter: 36
Cofused
Were to buy easy jtag................
When u lonched easy jtag
The Following 2 Users Say Thank You to biswajit74 For This Useful Post:
Old 03-29-2013, 17:37   #8 (permalink)
Sniper_04's Avatar
Member: 704097
Sonork: 100.1607742
Thanks Meter: 820
Can i test your jtag box?LOL
I want to try it!!!
Old 04-12-2013, 21:09   #9 (permalink)
Member: 1397329
Thanks Meter: 73
i917 write fullflash succesfully done
EasyJtag Suite ver. 1.0.18.2 started.
I/O Level set to : 2600 mV
Box S/N: ********** ,SW Ver.: 01.42
JTAG device: QSD8250.
CPU IDCODE : 0x1BA000E1 Mfg.: 0x070, Part: 0xba00, Ver.: 0x1
CPU Manufacturer: QUALCOMM , CPU Name: QSD8250 SLAVE
CPU IDCODE : 0x202400E1 Mfg.: 0x070, Part: 0x0240, Ver.: 0x2
NAND flash device ID:002C:00B3 'NAND 1GiB 1.8V 16-bit (Micron)' found
NAND geometry: Blocks:00002000, Page size:2048 bytes , Block size:64 pages
Writing NAND from file...D:\1GB_Z3X.bin
Lock file not found D:/1GB_Z3X.lock
NAND Write OK! Wrote up to offset 0x40000000 in 3846.583008s (281.118 KiB/s)
Old 05-04-2013, 04:08   #10 (permalink)
Ligalig's Avatar
Member: 1079935
Thanks Meter: 511
Do we need to 1st buy box or can we use like z3x samsung box to beta test?
The Following User Says Thank You to Ligalig For This Useful Post:
Old 05-04-2013, 04:36   #11 (permalink)
TestCard17's Avatar
Member: 1357650
Sonork: 100.1611843
Thanks Meter: 123
can i aslo test your box willing to try Beta test here
bR
The Following User Says Thank You to TestCard17 For This Useful Post:
Old 05-10-2013, 17:47   #12 (permalink)
Yashbanswara's Avatar
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Unlocking & Flashing Devices :: Z3x Easy JTAG with 3 Cables - iCables.in
The Following 2 Users Say Thank You to Yashbanswara For This Useful Post:
Old 05-11-2013, 13:41   #13 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
I want to try it!!!
So go Buy and try ;-)
Old 05-12-2013, 10:51   #14 (permalink)
Registered User
Member: 507223
Thanks Meter: 80
May be still need for speed !
Do JTAG job will cost so much time !
DO full flash ,oh dear ,a big job !
The Following User Says Thank You to wx654242 For This Useful Post:
Old 05-14-2013, 09:07   #15 (permalink)
Multi-COM's Avatar
Member: 43823
Thanks Meter: 308
I9100 sucesfull JOB done using Easy JTAG
EasyJtag Suite ver. 1.0.24.0 started.
Successefuly connected to box on COM48
Box S/N: XXXXXXXXXXXXXXXXx, ,FW Ver.: 01.44
Z3X Card Serial : XXXXXXXXX
Z3X Card Version : 22
Z3X Card Activation [JTAG] : 1
Resources ver. : MainRC ver.OCD040Z001 (C)2012 z3x-team.com
Loading repair file: 'C:\Program Files\Z3X\EASYJTAG\Repair Files\Samsung GT-i9100.rcp'
Repair File ver. : Easy Repair for Mfg: SAMSUNG Model: GT-I9100, Ver.: 1.00
Easy-Repair file load OK!
Using EasyRepair Mode...
Initialising: SAMSUNG GT-I9100 Config ver.:1.00
I/O Level set to : 2800 mV
Box S/N: 10100007B9800571 ,FW Ver.: 01.44
JTAG device: S5PC210
CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4
CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9
Halting CPU...
Init target ...
Detecting emmc memory parameters of bank (0) ...
EMMC #0 : ID : 0x00010015 Name : VYL00M Size : 16 GB
EMMC #1 : ID : 0x00010015 Name : VYL00M Size : 524 kB
eMMC flash device(s) found, Device ID : 0x00150001
NAND Writing GPT...
eMMC Write OK! Elapsed time: 9.015625s (454.322 KiB/s)
NAND Writing SBL1...
eMMC Write OK! Elapsed time: 12.234375s (104.623 KiB/s)
NAND Writing SBL2...
eMMC Write OK! Elapsed time: 12.046875s (106.252 KiB/s)
NAND Writing PARAM...
eMMC Write OK! Elapsed time: 27.609375s (296.711 KiB/s)
NAND Writing ROM2...
eMMC Write OK! Elapsed time: 1.421875s (360.088 KiB/s)
All Done.
The Following 8 Users Say Thank You to Multi-COM For This Useful Post:
Page generated in 0.14132 seconds with 9 queries
