GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Easy-Jtag / Easy-Jtag Plus (https://forum.gsmhosting.com/vbb/f672/)
-   -   Post here succesfull JTAG and eMMC operations with Easy-Jtag: (https://forum.gsmhosting.com/vbb/f672/post-here-succesfull-jtag-emmc-operations-easy-jtag-1573139/)
blang 11-24-2012 16:24
Post here sucessfull operation with Easy-Jtag:
Easy-JTAG are best JTAG and eMMC box!
Dimidrolus 03-01-2013 10:44
Test search pinout and connect S5230...
Box Working Mode: JTAG Box.
Start Z3X Jtag Pin Finder...
Successefuly connected to box on COM706
Waiting for box reset...
Box S/N: 00000000********
Box Working Mode: JTAG Pin Finder.
Stage 1: Search TCK / TMS / TDI / TDO...
Try to get IDCODE...
JTAG Pinout Found: TCK: Pin 11 / TMS: Pin 1 / TDI: Pin 9 / TDO: Pin 7
Found device with IDCODE=0x7926F0F
Stage 2: Search TRST...
TRST Pin Found: TRST: Pin 13
Box S/N: 0D0DFF182DBE7A08
Box Working Mode: JTAG Box.        10:38:47
For support and updates visit http://easy-jtag.com
I/O Level set to : 3000 mV
Box S/N: 0D0D******,SW Ver.: 01.42
Connecting to Target...
JTAG device: BCM2133
CPU IDCODE detected: 0x07926F0F
Manufacturer: 0x787, Part: 0x7926, Version: 0x0
Halting CPU...
Starting target communication...
Detecting nand memory parameters of bank (0) ...
NAND flash device ID:00EC:00BA 'NAND 256MiB 1.8V 16-bit (Samsung)' found
NAND geometry: Blocks:00000800, Page size:2048 bytes , Block size:64 pages
Dimidrolus 03-01-2013 12:10
S5230 easy repair boot...
Checking repair data...
Box S/N: 0D0D******* ,SW Ver.: 01.42
Halting CPU...
NAND Writing BOOT...
NAND Write OK! Wrote up to offset 0x00080000 in 4,921875s (107,276 KiB/s)
Repair DONE! Restarting phone...
All Done.
Box are disconnected!
NoName® 03-01-2013 15:28
706SC Connection/Dump with UJK clip SAM-B ;-)
http://data2.floomby.com/files/previ...OTkPCITj9g.jpg
cycofcgb 03-01-2013 19:41
so when ? before the end of this year ?
Dimidrolus 03-02-2013 23:54
Programming s5830i ;)
http://s42.radikal.ru/i098/1303/91/0099f70f8f1b.jpg
Finder
Successefuly connected to box on COM68
Box S/N: 000000000*******
JTAG Pinout Found: TCK: Pin 11 / TMS: Pin 3 / TDI: Pin 9 / TDO: Pin 13
CPU IDCODE : 0x07B3617F Mfg.: 0x0bf, Part: 0x7b36, Ver.: 0x0
CPU Manufacturer: SST/Broadcom , CPU Name: BCM21553
Box S/N: **********
Dump 64Mb
Box S/N: **************,SW Ver.: 01.42
Warn: JTAG device: BCM21553
Warn: CPU Manufacturer: SST/Broadcom , CPU Name: BCM21553
Halting CPU...
Initialize hardware...
Detecting nand memory parameters ...
NAND flash device ID:00EC:0050 'NAND 4GiB 1.8V 16-bit (Samsung)' found
NAND geometry: Blocks:00002000, Page size:4096 bytes , Block size:64 pages
Accesing logical device region # 0
Working block has an 256 pages , allocating 135168 bytes of memory
Reading 04000000 bytes from NAND adress 00000000...
Dumped 69206016 bytes in 458,401215s (147,434 KiB/s) OK.
biswajit74 03-08-2013 16:10
Cofused
Were to buy easy jtag................
When u lonched easy jtag
Sniper_04 03-29-2013 17:37
Can i test your jtag box?LOL
I want to try it!!!
Dimidrolus 04-12-2013 21:09
i917 write fullflash succesfully done ;)
EasyJtag Suite ver. 1.0.18.2 started.
I/O Level set to : 2600 mV
Box S/N: ********** ,SW Ver.: 01.42
JTAG device: QSD8250.
CPU IDCODE : 0x1BA000E1 Mfg.: 0x070, Part: 0xba00, Ver.: 0x1
CPU Manufacturer: QUALCOMM , CPU Name: QSD8250 SLAVE
CPU IDCODE : 0x202400E1 Mfg.: 0x070, Part: 0x0240, Ver.: 0x2
NAND flash device ID:002C:00B3 'NAND 1GiB 1.8V 16-bit (Micron)' found
NAND geometry: Blocks:00002000, Page size:2048 bytes , Block size:64 pages
Writing NAND from file...D:\1GB_Z3X.bin
Lock file not found D:/1GB_Z3X.lock
NAND Write OK! Wrote up to offset 0x40000000 in 3846.583008s (281.118 KiB/s)
Ligalig 05-04-2013 04:08
Do we need to 1st buy box or can we use like z3x samsung box to beta test?
TestCard17 05-04-2013 04:36
can i aslo test your box willing to try Beta test here
bR
Yashbanswara 05-10-2013 17:47
Unlocking & Flashing Devices :: Z3x Easy JTAG with 3 Cables - iCables.in
NoName® 05-11-2013 13:41
I want to try it!!!
So go Buy and try ;-)
wx654242 05-12-2013 10:51
May be still need for speed !
Do JTAG job will cost so much time !
DO full flash ,oh dear ,a big job !
Multi-COM 05-14-2013 09:07
I9100 sucesfull JOB done using Easy JTAG
EasyJtag Suite ver. 1.0.24.0 started.
Successefuly connected to box on COM48
Box S/N: XXXXXXXXXXXXXXXXx, ,FW Ver.: 01.44
Z3X Card Serial : XXXXXXXXX
Z3X Card Version : 22
Z3X Card Activation [JTAG] : 1
Resources ver. : MainRC ver.OCD040Z001 (C)2012 z3x-team.com
Loading repair file: 'C:\Program Files\Z3X\EASYJTAG\Repair Files\Samsung GT-i9100.rcp'
Repair File ver. : Easy Repair for Mfg: SAMSUNG Model: GT-I9100, Ver.: 1.00
Easy-Repair file load OK!
Using EasyRepair Mode...
Initialising: SAMSUNG GT-I9100 Config ver.:1.00
I/O Level set to : 2800 mV
Box S/N: 10100007B9800571 ,FW Ver.: 01.44
JTAG device: S5PC210
CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4
CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9
Halting CPU...
Init target ...
Detecting emmc memory parameters of bank (0) ...
EMMC #0 : ID : 0x00010015 Name : VYL00M Size : 16 GB
EMMC #1 : ID : 0x00010015 Name : VYL00M Size : 524 kB
eMMC flash device(s) found, Device ID : 0x00150001
NAND Writing GPT...
eMMC Write OK! Elapsed time: 9.015625s (454.322 KiB/s)
NAND Writing SBL1...
eMMC Write OK! Elapsed time: 12.234375s (104.623 KiB/s)
NAND Writing SBL2...
eMMC Write OK! Elapsed time: 12.046875s (106.252 KiB/s)
NAND Writing PARAM...
eMMC Write OK! Elapsed time: 27.609375s (296.711 KiB/s)
NAND Writing ROM2...
eMMC Write OK! Elapsed time: 1.421875s (360.088 KiB/s)
All Done.
Page generated in 0.15786 seconds with 6 queries
