Old 12-25-2013, 13:55   #196 (permalink)
Member: 1635037
Sonork: 1590479
Thanks Meter: 41
Originally Posted by .::M Irfan::. View Post
its very easy to repair boot with easy jtag!
done boot repair easy with easy jtag:
EasyJtag Suite ver.: 1.0.70.0 started.
Operating system ver.: Windows XP (build 2600, Service Pack 3).
Successefuly connected to box on COM21
Box S/N: **************, ,FW Ver.: 01.47
Box Working Mode: JTAG Box.
Box Drivers version: 3.0.0.0, are OK
Z3X Card Serial : AA7A-2A3A
Z3X Card Version : 22
Z3X Card Activation [JTAG] : 1
Resources ver. : MainRC ver.OCD040Z001 (C)2012 z3x-team.com
Loading repair file: 'E:\BOX DATA\Easy Jtag\SAMSUNG\GT-I9000\Samsung-GT-i9000.rcp'
Repair File ver. : Easy Repair for Mfg: SAMSUNG Model: GT-I9000, Ver.: 1.00
Error loading information!
Easy-Repair file load OK!
Using EasyRepair Mode...
Checking repair data...
For support and updates visit EasyJtag , just better ? - New powerful JTAG unbrick device.
Initialising: SAMSUNG GT-I9000 Config ver.:1.00
I/O Level set to : 2800 mV
Box S/N: ****************6 ,FW Ver.: 01.47
Connecting to Target...
JTAG device: S5PC110
CPU IDCODE : 0x1BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x1
CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A8
Halting CPU...
Initialize hardware...
Starting target communication...
Detecting nand memory parameters ...
NAND flash device ID:00EC:0050 'NAND 512MB 1.8V 16-bit (Samsung)' found
NAND geometry: Blocks:00000800, Page size:1024 bytes , Block size:256 pages
NAND Writing BOOT...
NAND Write OK! Elapsed time: 2.421875s (109.006 KiB/s)
NAND Writing PIT...
NAND Write OK! Elapsed time: 1.156250s (228.324 KiB/s)
NAND Writing SBL1...
NAND Write OK! Elapsed time: 17.296875s (76.314 KiB/s)
NAND Writing SBL2...
NAND Write OK! Elapsed time: 15.843750s (83.314 KiB/s)
NAND Writing UPCH...
NAND Write OK! Elapsed time: 1.015625s (1039.754 KiB/s)
All Done.
plz shar pinout.... i canot found pinout .easy jtag give i9000m pinout but not cont
Old 12-28-2013, 14:36   #197 (permalink)
mccm's Avatar
Member: 173565
Thanks Meter: 71
any instruction please
Old 12-28-2013, 14:46   #198 (permalink)
Member: 253510
Sonork: 100.1672352
Thanks Meter: 3,534
These instruction from software i just copy and paste it here!
Put Repair File in Easy Repair Tab.
JTAG pinout :
For pinout info press Show Pinouts button in Easy Repair tab in EasyJTAG Suite
3. Hardware Connection :
Solder TRST, TDI, TMS, TCK, TDO, SRST, GND Lines from Box port to phone PCB carefully.
Connect USB Cable to Phone and PC. In this case phone is automatically powered on.
Battery Presence is required.
If everything soldered ok , phone is ready for JTAG operations.
Wires must be solder correctly.
Regards
.::M Irfan::.
Old 12-30-2013, 05:12   #199 (permalink)
Member: 762819
Thanks Meter: 232
I8190 successfully done with Easy Jtag, but I had to use the download mode jag for it.
Old 01-02-2014, 21:21   #200 (permalink)
sikandar.mehdi's Avatar
Member: 2080403
Sonork: 100.1645596
Thanks Meter: 52
I9070 Dead Boot don by Easy JTag
EasyJtag Suite ver.: 1.0.93.0 started.
Operating system ver.: Windows 7 (build 7600).
Initialising: SAMSUNG GT-I9070 Config ver.:1.01
I/O Level set to : 2600 mV
Box S/N: 131304193Dxxxxxx ,FW Ver.: 01.47
U8500 Connection Fail
Please, install U8500 USB ROM driver, check power and USB connection !!!
U8500 USB BOOTROM : device 04CC:8500 opened
success: set configuration #1
success: claim_interface #0
Sending XLOADER...
success: bulk read 4 bytes
Done.
JTAG device: U8500
CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4
CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9
JTAG device: U8500
CPU IDCODE : 0x62286041 Mfg.: 0x020, Part: 0x2286, Ver.: 0x6
CPU Manufacturer: SGS/Thomson , CPU Name: NOVATHOR U8500 JRC
Halting CPU...
Detecting emmc memory parameters of bank (0) ...
EMMC #0 : ID : 0x00000045 Name : SEM08G Size : 7.3 G , (15269888) Blocks
EMMC #1 : ID : 0x00000045 Name : SEM08G Size : 2.0 M , (4096) Blocks
eMMC flash device(s) found, Device ID : 0x00450000
EMMC Writing GPT...
eMMC Write OK! Elapsed time: 4.470255s (28.634 KiB/s)
EMMC Writing XLOADER...
eMMC Write OK! Elapsed time: 2.583148s (148.656 KiB/s)
EMMC Writing PIT...
eMMC Write OK! Elapsed time: 4.106235s (249.377 KiB/s)
EMMC Writing STE MEM INIT...
eMMC Write OK! Elapsed time: 1.904109s (268.892 KiB/s)
EMMC Writing PWR MGT...
eMMC Write OK! Elapsed time: 2.922168s (175.212 KiB/s)
EMMC Writing SBL...
eMMC Write OK! Elapsed time: 12.309704s (166.373 KiB/s)
EMMC Writing SBL2...
eMMC Write OK! Elapsed time: 13.752786s (148.915 KiB/s)
EMMC Writing PARAM...
eMMC Write OK! Elapsed time: 10.427596s (98.201 KiB/s)
EMMC Writing IPL MODEM...
eMMC Write OK! Elapsed time: 8.781502s (233.218 KiB/s)
All Done.
Old 01-03-2014, 12:12   #201 (permalink)
Member: 1205573
Sonork: asifraza66911
how to solve boot image s2
Old 01-03-2014, 14:41   #202 (permalink)
Member: 2080403
Sonork: 100.1645596
Thanks Meter: 52
i9003 don by easy jtag
Successefuly connected to box on COM3
Box S/N: 131304193xxxxxxxx ,FW Ver.: 01.47
Z3X Card Serial : AAAD-30FF , ver: 22
Loading repair file: 'D:\Box Installer\Z3X\9. Easy Jtag files\Samsung\GT-I9003\Repair\Samsung GT-i9003.rcp'
Repair File ver. : Easy Repair for Mfg: SAMSUNG Model: GT-I9003, Ver.: 1.00
Initialising: SAMSUNG GT-I9003 Config ver.:1.00
Box S/N: 131304193DD5E9C2 ,FW Ver.: 01.47
JTAG device: OMAP3430
CPU IDCODE : 0x0B6D602F Mfg.: 0x017, Part: 0xb6d6, Ver.: 0x0
CPU IDCODE : 0x2B89102F Mfg.: 0x017, Part: 0xb891, Ver.: 0x2
Halting CPU...
NAND geometry: Blocks:00000800, Page size:4096 bytes , Block size:64 pages
NAND Write OK! Elapsed time: 1.489085s (177.290 KiB/s)
NAND Writing PIT...
NAND Write OK! Elapsed time: 0.493028s (535.467 KiB/s)
NAND Write OK! Elapsed time: 10.135580s (130.234 KiB/s)
NAND Write OK! Elapsed time: 10.167582s (129.824 KiB/s)
NAND Write OK! Elapsed time: 1.472084s (717.350 KiB/s)
All Done.
The Following User Says Thank You to sikandar.mehdi For This Useful Post:
Old 01-05-2014, 20:30   #203 (permalink)
sirnavid2010's Avatar
Member: 777729
Sonork: 100.1616470
Thanks Meter: 824
m110S REPAIR DEAD BOOT DONE
Box.
Z3X Card Serial : AA1XXXXXXXXX5 , ver: 22
Loading C:\Users\navid\Desktop\Samsung SHW-M110S.rcp
Loading repair file: 'C:\Users\navid\Desktop\Samsung SHW-M110S.rcp'
Repair File ver. : Easy Repair for Mfg: SAMSUNG Model: SHW-M110S, Ver.: 1.00
EasyJtag Suite ver.: 1.0.95.1 started.
Operating system ver.: Windows 7 (build 7600), 64-bit edition.
Initialising: SAMSUNG SHW-M110S Config ver.:1.00
Box S/N: 1010000A04CECCB5 ,FW Ver.: 01.48
Done with error(s)...
Halting CPU...
NAND Write OK! Elapsed time: 1.194069s (221.093 KiB/s)
NAND Writing PIT...
NAND Write OK! Elapsed time: 0.225013s (1173.266 KiB/s)
NAND Write OK! Elapsed time: 8.531488s (154.721 KiB/s)
NAND Write OK! Elapsed time: 1.062061s (1242.867 KiB/s)
NAND Write OK! Elapsed time: 0.864049s (1222.153 KiB/s)
All Done.
The Following User Says Thank You to sirnavid2010 For This Useful Post:
Old 01-10-2014, 19:17   #204 (permalink)
Member: 1859706
Sonork: 100.1648492
Thanks Meter: 28
S5670B
The Following User Says Thank You to lunno For This Useful Post:
Old 01-15-2014, 21:52   #205 (permalink)
Member: 2080403
Sonork: 100.1645596
Thanks Meter: 52
I9100G boot repair don
EasyJtag Suite ver.: 1.0.97.0 started.
Initialising: SAMSUNG GT-I9100G Config ver.:1.00
Box S/N: 131304193xxxxxxx ,FW Ver.: 01.48
Box S/N: 131304193xxxxxxxx ,FW Ver.: 01.48
JTAG device: OMAP4430
CPU IDCODE : 0x3BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x3
CPU IDCODE : 0x6B95C02F Mfg.: 0x017, Part: 0xb95c, Ver.: 0x6
Halting CPU...
EMMC #0 : ID : 0x00150100 Name : M00LYV Size : 14.7 G , (30777344) Blocks
EMMC #1 : ID : 0x00150100 Name : M00LYV Size : 512.0 K , (1024) Blocks
eMMC flash device(s) found, Device ID : 0x00000015
EMMC Writing SBL1...
eMMC Write OK! Elapsed time: 77.787453s (26.328 KiB/s)
eMMC Write OK! Elapsed time: 77.390427s (26.463 KiB/s)
eMMC Write OK! Elapsed time: 292.910767s (27.968 KiB/s)
All Done.
Old 01-19-2014, 04:57   #206 (permalink)
Member: 1741973
Thanks Meter: 115
GT-S5300 galaxy packet No downlode mode,black screen and always asking for usb driver if USB cable connect to pc in normal way.
here is my post asking for help...
http://forum.gsmhosting.com/vbb/f672...-help-1767175/
S5300 Deadboot done repair easy
after repair phone is alive and time to flash in Odin
no ss of phone. tnx for my z3x jtag even it is not a normal box but it works fine..
Old 01-20-2014, 20:25   #207 (permalink)
.::intel32::.'s Avatar
Member: 350719
Sonork: 100.1623850
Thanks Meter: 157
Thumbs down I9505 boot repair done
I9505 boot repair successfully done
EasyJtag Suite ver.: 1.0.98.0 started.
Initialising: SAMSUNG GT-I9505 Config ver.:1.00
I/O Level set to : 2200 mV
Box S/N: xxxxxxxxxxxxxxx7 ,FW Ver.: 01.48
JTAG device: APQ8064T.
CPU IDCODE : 0x4F1F0F0F Mfg.: 0x787, Part: 0xf1f0, Ver.: 0x4
CPU Manufacturer: Samsung , CPU Name: ARM7GEN
CPU IDCODE : 0x2071B0E1 Mfg.: 0x070, Part: 0x071b, Ver.: 0x2
CPU Manufacturer: QUALCOMM , CPU Name: APQ8064T
Halting CPU...
EMMC #0 : ID : 0x00000015 Name : AFEABB Size : 14.7 G , (30777344) Blocks
EMMC #1 : ID : 0x00000015 Name : AFEABB Size : 4.0 M , (8192) Blocks
eMMC flash device(s) found, Device ID : 0x00150000
NAND Writing PGPT, PIT, MD5, P4...
eMMC Write OK! Elapsed time: 31.375000s (130.550 KiB/s)
eMMC Write OK! Elapsed time: 1.187500s (107.789 KiB/s)
eMMC Write OK! Elapsed time: 2.828125s (90.519 KiB/s)
NAND Writing SBL3...
eMMC Write OK! Elapsed time: 5.843750s (87.615 KiB/s)
NAND Writing ABOOT...
eMMC Write OK! Elapsed time: 15.062500s (84.979 KiB/s)
NAND Writing RPM...
eMMC Write OK! Elapsed time: 1.703125s (112.734 KiB/s)
NAND Writing TZ...
eMMC Write OK! Elapsed time: 2.453125s (104.357 KiB/s)
NAND Writing SGPT...
eMMC Write OK! Elapsed time: 0.203125s (81.231 KiB/s)
All Done.
thanks. blang
Old 01-21-2014, 02:55   #208 (permalink)
Member: 1897850
Sonork: R4!n8ow
Kee it up bro
Thz for sharing
Old 01-21-2014, 14:20   #209 (permalink)
Member: 1243420
Sonork: 100.1652460
Thanks Meter: 3
can't download file need help
Old 01-22-2014, 04:20   #210 (permalink)
Member: 2111670
this is the answer what i need thanks
Page generated in 0.21975 seconds with 9 queries
