Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 10-21-2016, 06:37   #496 (permalink)
Member: 2616899
Sonork: 1679560:AMC
Z3X EasyJtag Software ver. 2.4.1.0
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: 06005011DAE4AF43, ,FW Ver.: 01.55
CMD Pullup Level:2454 mV
CMD Active Level:2526 mV
Box IO Level:2800 mV
CLK Rate:14000 khz
HiPower mode is ON!
Can't init device, Reason: CMD Timeout Error
Done.
pless help
Old 11-01-2016, 08:35   #497 (permalink)
Member: 1549945
Thanks Meter: 2
Gt-s7562 samsung log and restarting issue fixed
Resolved by writing rcp files from support via JTAG method
Loading repair file: 'D:\Samsung\GT-S7270\Samsung GT-S7562_EFS_V1.00.rcp'
Repair File ver. : Easy Repair for Mfg: Samsung Model: GT-S7562, Ver.: 1.01
Repair file options. : NONE
Easy-Repair file load OK!
Using EasyRepair Mode...
Checking repair data...
EasyJtag Suite Classic ver.: 2.4.1.1 / wxWidgets 3.1.0-W-U started.
Operating system ver.: Windows 7 (build 7601, Service Pack
For support and updates visit EasyJtag ? most powerfull eMMC and JTAG tool on market. | EMMC BOX, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL
Check security...
OK
Initialising: Samsung GT-S7562 Config ver.:1.01
I/O Level set to : 2600 mV
Box S/N: 1212FE15A40537EF ,FW Ver.: 01.55
Connecting to Target...
JTAG device: MSM7225A
CPU IDCODE : 0x106230E1 Mfg.: 0x070, Part: 0x0623, Ver.: 0x1
CPU Manufacturer: QUALCOMM , CPU Name: MSM7227A
Halting CPU...
Initialize hardware...
Starting target communication...
Detecting emmc memory parameters of bank (0) ...
EMMC #0 : ID : 0x01000015 Name : JJS00A Size : 3.6 G , (7634944) Blocks
EMMC #1 : ID : 0x01000015 Name : JJS00A Size : 1.0 M , (2048) Blocks
eMMC flash device(s) found, Device ID : 0x00150000
NAND Writing MODEM...
eMMC Write OK! Elapsed time: 328.832977s (62.281 KiB/s)
NAND Writing MODEM_ST1...
eMMC Write OK! Elapsed time: 49.795288s (61.693 KiB/s)
NAND Writing MODEM_ST2...
eMMC Write OK! Elapsed time: 50.044888s (61.385 KiB/s)
All Done.
Old 11-01-2016, 09:17   #498 (permalink)
Member: 1580119
Sonork: baby
Thanks Meter: 7
CLK Rate:14000 khz
HiPower mode is ON!
Done.
pless help
i have some problem in easyjtag emmc plus v 1.0.0.37
Old 11-01-2016, 23:29   #499 (permalink)
Crazy Poster
Member: 65657
Thanks Meter: 6
Originally Posted by Dr_Wolodya View Post
Dead Samsung i9260 with emmc KMVTU000LM-B503. Log:
Z3X EasyJtag Software ver. 1.9.1.0
Box S/N: xxx, ,FW Ver.: 01.52
CMD Pullup Level:1990 mV
CMD Active Level:2175 mV
eMMC Device Information
EMMC CID : 1501003030303030305620110726589C
EMMC CSD : 902701320F5903FFF6DBFFEF8A404022
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 05/2005 Rev.0x56
EMMC NAME: 000000 , S/N: 537986854
EMMC NAME (HEX): 30303030303000
EMMC ROM1 (Main User Data) Capacity: 16384 MB
EMMC ROM2 (Boot Partition 1) Capacity: 512 kB
EMMC ROM3 (Boot Partition 2) Capacity: 512 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD rev 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
Backup saved: 000000_ 537986854_20150305_2042.extcsd
Done.
eMMC firmware update log:
Running:SAMSUNG: eMMC firmware update...
Confirmed eMMC Part Number: KMVTU000LM-B503
Box S/N: , ,FW Ver.: 01.52
CMD Pullup Level:2124 mV
CMD Active Level:2475 mV
Setup firmware update mode, wait 2..30 sec...
Success!
Sending eMMC firmware...
Success!
Verifying eMMC firmware...
Success!
Flashing eMMC firmware...
Success!
Repairing eMMC CID...
Success!
eMMC firmware is updated now!
Please reconnect all eMMC lines before next operation!
Please don't forget to repair extCSD from backup!
Please don't forget to configure BOOT sizes!
Done.
Log after firmware update:
CMD Pullup Level:2062 mV
CMD Active Level:2454 mV
EMMC CID : 15010056545530304DFC3D39868641FA
EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C
EMMC Date: 04/2014 Rev.0xFC
EMMC NAME: VTU00M , S/N: 1027180166
EMMC NAME (HEX): 56545530304D00
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
Extended CSD rev 1.6 (MMC 4.5)
Backup saved: VTU00M_1027180166_20150305_2057.extcsd
Done.
Repair extCSD from backup:
extCSD file...D:\Mobile\Z3X\EASYJTAG\Backups\VTU00M_1449093984_20150202_1345.extcsd
Running:Repair extCSD...
Skip loading eMMC Addon Firmware
Writing...
Done.
Change BOOT CONFIG to ROM1:
Running:Change BOOT CONFIG...
CMD Pullup Level:2041 mV
CMD Active Level:2351 mV
Writing eMMC Register...
Written: REG : 179 VAL :0
Done.
Box S/N: 0707FD0E00DF994B, ,FW Ver.: 01.52
CMD Pullup Level:2134 mV
CMD Active Level:2505 mV
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x00.
Backup saved: VTU00M_1027180166_20150305_2147.extcsd
Done.
Write dump from support:
Checking NAND Image : D:\Mobile\Z3X\EASYJTAG\!Repair Files\Samsung\i9260\Samsung_GT-i9260_XXAMC3_16Gb_model_dump_rom1_1GB.bin
File successefuly loaded!
Processing file...D:\Mobile\Z3X\EASYJTAG\!Repair Files\Samsung\i9260\Samsung_GT-i9260_XXAMC3_16Gb_model_dump_rom1_1GB.bin
Input file : D:\Mobile\Z3X\EASYJTAG\!Repair Files\Samsung\i9260\Samsung_GT-i9260_XXAMC3_16Gb_model_dump_rom1_1GB.bin
Writing 0040000000 bytes to 00000000 ...ROM1 (USER ROM)
Done. Write Speed: 12813 kB/s
Flash from Odin!
Done.
Did you used the pinout from support? Because in my PCB the marked 1.8V is GND. So if I solder there it will be shorted to GND.
Thanks
Tybee
Old 11-05-2016, 14:23   #500 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 571
samsung i9300 emmc repair done
Z3X EasyJtag Software ver. 2.4.1.1
Loading eMMC Addon Firmware... IO: 3300 mV
Box S/N: 010070222EE63D88, ,FW Ver.: 01.55
CMD Pullup Level:752 mV
CMD Active Level:2145 mV
Box IO Level:3300 mV
CLK Rate:21000 khz
HiPower mode is ON!
---------- eMMC Device Information ----------
EMMC Password Locked: No
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: VTU00M_1027180166_20161105_1350.extcsd
Done.
Input file : E:\9300\EMMC_ROM2_00000000_00200000.bin
Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM)
Done. Write Speed: 1292 kB/s
Input file : E:\9300\EMMC_ROM1_00000000_20000000.bin
Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM)
Done. Write Speed: 6977 kB/s
CLK Rate:21000 khz
Written: REG : 179 VAL :48
Done.
Running:Change BOOT WIDTH...
CLK Rate:21000 khz
Written: REG : 177 VAL :1
Done.
CMD Pullup Level:763 mV
CMD Active Level:2423 mV
CLK Rate:21000 khz
HiPower mode is ON!
Backup saved: VTU00M_1027180166_20161105_1353.extcsd
Searching for partition tables...
Detected GPT over MBR...
Warning: Header Size = 512 (expected 92)
Medium UUID: 52444E41-494F-2044-4D4D-43204449534B
Warning: Entries Count = 128
MMCBLK0P0 (BOTA0) Range: [0X400000,0X7FFE00] ,Len: 400000
MMCBLK0P1 (BOTA1) Range: [0X800000,0XBFFE00] ,Len: 400000
MMCBLK0P2 (EFS) Range: [0XC00000,0X1FFFE00] ,Len: 1400000
MMCBLK0P3 (PARAM) Range: [0X2000000,0X27FFE00] ,Len: 800000
MMCBLK0P4 (BOOT) Range: [0X2800000,0X2FFFE00] ,Len: 800000
MMCBLK0P5 (RECOVERY) Range: [0X3000000,0X37FFE00] ,Len: 800000
MMCBLK0P6 (RADIO) Range: [0X3800000,0X57FFE00] ,Len: 2000000
MMCBLK0P7 (CACHE) Range: [0X5800000,0X457FFE00] ,Len: 40000000
MMCBLK0P8 (SYSTEM) Range: [0X45800000,0XA57FFE00] ,Len: 60000000
MMCBLK0P9 (HIDDEN) Range: [0XA5800000,0XC87FFE00] ,Len: 23000000
MMCBLK0P10 (OTA) Range: [0XC8800000,0XC8FFFE00] ,Len: 800000
MMCBLK0P11 (USERDATA) Range: [0XC9000000,0X3AAFFFE00] ,Len: 2E2000000
Done...Presets has been updated...
Done.
The Following User Says Thank You to umarmsn For This Useful Post:
Old 11-19-2016, 08:15   #501 (permalink)
gabiz_ro's Avatar
Member: 29006
Thanks Meter: 19
HTC M8S
0PKV10000
M8QL_UL
Hardly corrupted EMMC,Qualcomm 9008 in device manager only
Revived with dump from another one.
But problem now is locked to same operator (like dump donor) and no unlock code from operator,and HTC codes doesn't work on that operator.
Will be useful dump from unlocked phone.
Log from reading working phone.
Box S/N: ............, ,FW Ver.: 01.55
CMD Active Level:2619 mV
CLK Rate:7000 khz
HiPower mode is off!
EMMC CID : 150100523832314D4200CD1A56B7C16A
EMMC CSD : D02701320F5903FFF6DBFFEF92404008
EMMC Date: 12/2014  Rev.0x0
EMMC NAME: R821MB , S/N: 3441055415
EMMC NAME (HEX): 523832314D4200
EMMC ROM1 (Main User Data)   Capacity: 14910 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
  Extended CSD rev 1.7 (MMC 5.0)
H/W reset function [RST_N_FUNCTION]: 0x01
Backup saved: R821MB_3441055415_20161103_2251.extcsd
Card Supported Command sets [S_CMD_SET: 0x01]
HPI Features [HPI_FEATURE: 0x01]:
implementation based on CMD13
Background operations support [BKOPS_SUPPORT: 0x01]
Max Packet Read Cmd [MAX_PACKED_READS: 0x3f]
Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f]
Data TAG support [DATA_TAG_SUPPORT: 0x01]
Data TAG Unit Size [TAG_UNIT_SIZE: 0x04]
Tag Resources Size [TAG_RES_SIZE: 0x00]
Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05]
Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07]
Extended partition attribute support [EXT_SUPPORT: 0x03]
Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a]
Power off notification [POWER_OFF_LONG_TIME: 0x3c]
Cache Size [CACHE_SIZE] is 65536 KiB
Background operations status [BKOPS_STATUS: 0x00]
1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x1e]
Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00]
Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00]
Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00]
Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00]
Minimum Performance for 8bit at 52MHz in DDR mode:
 [MIN_PERF_DDR_W_8_52: 0x00]
 [MIN_PERF_DDR_R_8_52: 0x00]
TRIM Multiplier [TRIM_MULT: 0x02]
Secure Feature support [SEC_FEATURE_SUPPORT: 0x55]
Boot Information [BOOT_INFO: 0x07]
 Device supports alternative boot method
 Device supports dual data rate during boot
 Device supports high speed timing during boot
Boot partition size [BOOT_SIZE_MULTI: 0x20]
Access size [ACC_SIZE: 0x06]
High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01]
High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01]
Reliable write sector count [REL_WR_SEC_C: 0x01]
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10]
Sleep current (VCC) [S_C_VCC: 0x07]
Sleep current (VCCQ) [S_C_VCCQ: 0x07]
Sleep/awake timeout [S_A_TIMEOUT: 0x11]
Sector Count [SEC_COUNT: 0x01d1f000]
Minimum Write Performance for 8bit:
 [MIN_PERF_W_8_52: 0x00]
 [MIN_PERF_R_8_52: 0x00]
 [MIN_PERF_W_8_26_4_52: 0x00]
 [MIN_PERF_R_8_26_4_52: 0x00]
Minimum Write Performance for 4bit:
 [MIN_PERF_W_4_26: 0x00]
 [MIN_PERF_R_4_26: 0x00]
Power classes registers:
 [PWR_CL_26_360: 0x00]
 [PWR_CL_52_360: 0x00]
 [PWR_CL_26_195: 0x00]
 [PWR_CL_52_195: 0x00]
Partition switching timing [PARTITION_SWITCH_TIME: 0x01]
Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05]
I/O Driver Strength [DRIVER_STRENGTH: 0x1f]
Card Type [CARD_TYPE: 0x57]
CSD structure version [CSD_STRUCTURE: 0x02]
Command set [CMD_SET: 0x00]
Command set revision [CMD_SET_REV: 0x00]
Power class [POWER_CLASS: 0x00]
High-speed interface timing [HS_TIMING: 0x00]
Erased memory content [ERASED_MEM_CONT: 0x00]
Boot configuration bytes [PARTITION_CONFIG: 0x00]
 Not boot enabled
 No access to boot partition
Boot config protection [BOOT_CONFIG_PROT: 0x00]
Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00]
High-density erase group definition [ERASE_GROUP_DEF: 0x00]
Boot write protection status registers [BOOT_WP_STATUS]: 0x00
Boot Area Write protection [BOOT_WP]: 0x00
Power ReadOnly locking: possible
Permanent ReadOnly locking: possible
Read Only lock status: not locked
User area write protection register [USER_WP]: 0x00
FW configuration [FW_CONFIG]: 0x00
RPMB Size [RPMB_SIZE_MULT]: 0x20
Write reliability setting register [WR_REL_SET]: 0x1f
Write reliability parameter register [WR_REL_PARAM]: 0x04
Enable background operations handshake [BKOPS_EN]: 0x01
HPI management [HPI_MGMT]: 0x00
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x00026d
Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00
General Purpose Partition Size
 [GP_SIZE_MULT_4]: 0x000000
 [GP_SIZE_MULT_3]: 0x000000
 [GP_SIZE_MULT_2]: 0x000000
 [GP_SIZE_MULT_1]: 0x000000
Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000
Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000
Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00
Periodic Wake-up [PERIODIC_WAKEUP]: 0x00
Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[127]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[126]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[125]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[124]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[123]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[122]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[121]]: 0x21
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[120]]: 0x19
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[119]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[118]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[117]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[116]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[115]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[114]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[113]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[112]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[111]]: 0x1d
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[110]]: 0x7d
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[109]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[108]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[107]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[106]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[105]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[104]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[103]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[102]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[101]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[100]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[99]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[98]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[97]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[96]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[95]]: 0x14
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[94]]: 0x14
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[93]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[92]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[91]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[90]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[89]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[88]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[87]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[86]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[85]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[84]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[83]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[82]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[81]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[80]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[79]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[78]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[77]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[76]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[75]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[74]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[73]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[72]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[71]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[70]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[69]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[68]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[67]]: 0x01
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[66]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[65]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[64]]: 0x1f
Native sector size [NATIVE_SECTOR_SIZE]: 0x00
Sector size emulation [USE_NATIVE_SECTOR]: 0x00
Sector size [DATA_SECTOR_SIZE]: 0x00
1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00
Class 6 commands control [CLASS_6_CTRL]: 0x00
Number of addressed group to be released[DYNCAP_NEEDED]: 0x00
Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000
Exception events status[EXCEPTION_EVENTS_STATUS]: 0x0000
Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000
Context configuration [CONTEXT_CONF[51]]: 0x00
Context configuration [CONTEXT_CONF[50]]: 0x00
Context configuration [CONTEXT_CONF[49]]: 0x00
Context configuration [CONTEXT_CONF[48]]: 0x00
Context configuration [CONTEXT_CONF[47]]: 0x00
Context configuration [CONTEXT_CONF[46]]: 0x00
Context configuration [CONTEXT_CONF[45]]: 0x00
Context configuration [CONTEXT_CONF[44]]: 0x00
Context configuration [CONTEXT_CONF[43]]: 0x00
Context configuration [CONTEXT_CONF[42]]: 0x00
Context configuration [CONTEXT_CONF[41]]: 0x00
Context configuration [CONTEXT_CONF[40]]: 0x00
Context configuration [CONTEXT_CONF[39]]: 0x00
Context configuration [CONTEXT_CONF[38]]: 0x00
Context configuration [CONTEXT_CONF[37]]: 0x00
Packed command status [PACKED_COMMAND_STATUS]: 0x00
Packed command failure index [PACKED_FAILURE_INDEX]: 0x00
Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00
Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00
Medium UUID: 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Warning: Entries Count = 52
MMCBLK0P0 (BOARD_INFO) Range:	[0X4400,0X8200] ,Len: 4000
MMCBLK0P1 (PG1FS) Range:	[0X8400,0X408200] ,Len: 400000
MMCBLK0P2 (SBL1) Range:	[0X408400,0X508200] ,Len: 100000
MMCBLK0P3 (RESERVE_1) Range:	[0X508400,0XFFFE00] ,Len: AF7C00
MMCBLK0P4 (MFG) Range:	[0X1000000,0X103FE00] ,Len: 40000
MMCBLK0P5 (PG2FS) Range:	[0X1040000,0X27EFA00] ,Len: 17AFC00
MMCBLK0P6 (RPM) Range:	[0X27EFC00,0X286FA00] ,Len: 80000
MMCBLK0P7 (TZ) Range:	[0X286FC00,0X2A6FA00] ,Len: 200000
MMCBLK0P8 (HYP) Range:	[0X2A6FC00,0X2C6FA00] ,Len: 200000
MMCBLK0P9 (HBOOT) Range:	[0X2C6FC00,0X306FA00] ,Len: 400000
MMCBLK0P10 (TOOL_DIAG) Range:	[0X306FC00,0X346FA00] ,Len: 400000
MMCBLK0P11 (SP1) Range:	[0X346FC00,0X396FA00] ,Len: 500000
MMCBLK0P12 (DDR) Range:	[0X396FC00,0X3977A00] ,Len: 8000
MMCBLK0P13 (WCNSS) Range:	[0X3977C00,0X3E77A00] ,Len: 500000
MMCBLK0P14 (RFG_0) Range:	[0X3E77C00,0X3F77A00] ,Len: 100000
MMCBLK0P15 (RFG_1) Range:	[0X3F77C00,0X4077A00] ,Len: 100000
MMCBLK0P16 (RFG_2) Range:	[0X4077C00,0X4177A00] ,Len: 100000
MMCBLK0P17 (RFG_3) Range:	[0X4177C00,0X4277A00] ,Len: 100000
MMCBLK0P18 (RFG_4) Range:	[0X4277C00,0X4377A00] ,Len: 100000
MMCBLK0P19 (RFG_5) Range:	[0X4377C00,0X4477A00] ,Len: 100000
MMCBLK0P20 (RFG_6) Range:	[0X4477C00,0X4577A00] ,Len: 100000
MMCBLK0P21 (RFG_7) Range:	[0X4577C00,0X4677A00] ,Len: 100000
MMCBLK0P22 (FSG) Range:	[0X4677C00,0X47F7A00] ,Len: 180000
MMCBLK0P23 (RADIO) Range:	[0X47F7C00,0X82F7E00] ,Len: 3B00400
MMCBLK0P24 (RESERVE_2) Range:	[0X82F8000,0X8FFFE00] ,Len: D08000
MMCBLK0P25 (MISC) Range:	[0X9000000,0X90FFE00] ,Len: 100000
MMCBLK0P26 (MODEM_ST1) Range:	[0X9100000,0X927FE00] ,Len: 180000
MMCBLK0P27 (MODEM_ST2) Range:	[0X9280000,0X93FFE00] ,Len: 180000
MMCBLK0P28 (FATALDEVLOG) Range:	[0X9400000,0XA7FFE00] ,Len: 1400000
MMCBLK0P29 (DEVLOG) Range:	[0XA800000,0XC5FFE00] ,Len: 1E00000
MMCBLK0P30 (PDATA) Range:	[0XC600000,0XC63FE00] ,Len: 40000
MMCBLK0P31 (CONTROL) Range:	[0XC640000,0XC643E00] ,Len: 4000
MMCBLK0P32 (LOCAL) Range:	[0XC644000,0XC784200] ,Len: 140400
MMCBLK0P33 (EXTRA) Range:	[0XC784400,0XC794200] ,Len: 10000
MMCBLK0P34 (CDMA_RECORD) Range:	[0XC794400,0XC894200] ,Len: 100000
MMCBLK0P35 (FSC) Range:	[0XC894400,0XC894600] ,Len: 400
MMCBLK0P36 (SSD) Range:	[0XC894800,0XC896600] ,Len: 2000
MMCBLK0P37 (SENSOR_HUB) Range:	[0XC896800,0XC916600] ,Len: 80000
MMCBLK0P38 (BACKUP_HBOOT) Range:	[0XC916800,0XCE16600] ,Len: 500000
MMCBLK0P39 (FRP) Range:	[0XCE16800,0XCE93600] ,Len: 7D000
MMCBLK0P40 (RESERVE) Range:	[0XCE93800,0XCFFFE00] ,Len: 16C800
MMCBLK0P41 (CACHE) Range:	[0XD000000,0X1CFFFE00] ,Len: 10000000
MMCBLK0P42 (BOOT) Range:	[0X1D000000,0X1EFFFE00] ,Len: 2000000
MMCBLK0P43 (RECOVERY) Range:	[0X1F000000,0X20FFFE00] ,Len: 2000000
MMCBLK0P44 (SYSTEM) Range:	[0X21000000,0X120FFFE00] ,Len: 100000000
MMCBLK0P45 (CARRIER) Range:	[0X121000000,0X1228FFE00] ,Len: 1900000
MMCBLK0P46 (BATTERY) Range:	[0X122900000,0X1232FFE00] ,Len: A00000
MMCBLK0P47 (APPPRELOAD) Range:	[0X123300000,0X1363FFE00] ,Len: 13100000
MMCBLK0P48 (COTA) Range:	[0X136400000,0X139FFFE00] ,Len: 3C00000
MMCBLK0P49 (USERDATA) Range:	[0X13A000000,0X3A1FFFE00] ,Len: 268000000
MMCBLK0P50 (ABSOLUTE) Range:	[0X3A2000000,0X3A2FFFE00] ,Len: 1000000
Done.
CLK Rate:7000 khz
Reading 0x000020000000 bytes from 0x000000000000 ...ROM1 ( USER ROM)
Output file :E:\GSM\Z3X\Downloads\HTC_OneM8S\EMMC_ROM1_R821MB_3441055415_00000000_20000000.bin
Done. Read Speed: 730 kB/s
Pinouts.
The Following User Says Thank You to gabiz_ro For This Useful Post:
Old 11-19-2016, 11:05   #502 (permalink)
Member: 180874
Thanks Meter: 17
Sm-t525 file need urgently!!
IM FACING A PROBLEM THAT I AFTER CHANGED SAMSUNG SM-T525 EMMC FILE ,SO I NEED 4 FILES TO SOLVE MY PROBLEM
SM-T525 BOOT 1,
SM-T525 BOOT 2,
SM-T525 EXTCSD ,
SM-T525 USERAREA FILE .
ANY MASTER CAN HELP ME??
Old 12-06-2016, 08:38   #503 (permalink)
Member: 1656416
Thanks Meter: 19
Philips w6610 repair sucess
Directly eMMC. Replacement, format, resize, write.
eMMC_tool Suite  ver. 1.0.0.40
Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.23403)
Looking for EasyJTAG box...
EasyJTAG API ver. 2007
Setting IO Levels to 3.3V
Setting frequence to 14 Mhz
HiPower mode is OFF
EasyJTAG Box Serial = xxxxxxxxxxxxxx
Card Serial = xxxxxxxxxxxxxx
EasyJTAG Box Firmware = 01.56
HiPower mode is OFF
CMD Pullup Level: 3176 mV
CMD Active Level: 3258 mV
EMMC Device Information :
EMMC CID: 1501004B4A5330304D036C1A3FBDBF48
EMMC CSD: D02701320F5903FFF6DBFFE78A404056
EMMC Manufacture Name: SAMSUNG
EMMC NAME: KJS00M , S/N: 6C1A3FBD , rev. 03
EMMC NAME (HEX): 4B4A5330304D
   EMMC ROM 1 (Main User Data) Capacity: 3716 MB (0000E8400000)
   EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000)
   EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000)
Backup saved: KJS00M_6C1A3FBD_20161205_173054.extcsd
EMMC Init completed.
Opening file: MT6582_Android_scatter.txt
The new format of scatter
config_version: V1.1.1
platform: MT6582
preloader_sangfei82_we_jb5.bin
Found 2 supported eMMC CID:
name = 'SEM04G'     hex = 0x53454D303447     [SANDISK]
name = 'H4G1d'     hex = 0x483447316404     [SKHYNIX]
The size of the last section has been updated
HiPower mode is OFF
CMD Pullup Level: 3186 mV
Backup saved: KJS00M_6C1A3FBD_20161205_173104.extcsd
Success! Now Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0] to finalize CID Patch !
HiPower mode is OFF
EMMC CID: 45010053454D30344D036C1A3FBDB1F2
EMMC Manufacture Name: SANDISK
EMMC NAME: SEM04M , S/N: 6C1A3FBD , rev. 03
EMMC NAME (HEX): 53454D30344D
Backup saved: SEM04M_6C1A3FBD_20161205_173126.extcsd
HiPower mode is OFF
CMD Active Level: 3269 mV
Backup saved: SEM04M_6C1A3FBD_20161205_173145.extcsd
Partition name: PRELOADER
Filename: preloader_sangfei82_we_jb5.bin , Offset: 000000000000 , filesize: 113816 bytes
eMMC switching to ROM2
Erasing partition...
Writing partition...
Done writing partition. Write speed: 133,01 Kb/s
Partition name: MBR
Filename: MBR , Offset: 000000C00000 , filesize: 512 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 46,84 Kb/s
Partition name: EBR1
Filename: EBR1 , Offset: 000000C80000 , filesize: 512 bytes
Done writing partition. Write speed: 37,50 Kb/s
Partition name: UBOOT
Filename: lk.bin , Offset: 000002920000 , filesize: 267448 bytes
Done writing partition. Write speed: 718,95 Kb/s
Partition name: BOOTIMG
Filename: boot.img , Offset: 000002980000 , filesize: 4661248 bytes
Done writing partition. Write speed: 929,56 Kb/s
Partition name: RECOVERY
Filename: recovery.img , Offset: 000002F80000 , filesize: 5181440 bytes
Done writing partition. Write speed: 934,93 Kb/s
Partition name: SEC_RO
Filename: secro.img , Offset: 000003580000 , filesize: 135168 bytes
Done writing partition. Write speed: 1230,86 Kb/s
Partition name: LOGO
Filename: logo.bin , Offset: 000003C00000 , filesize: 273091 bytes
Done writing partition. Write speed: 769,94 Kb/s
Partition name: EBR2
Filename: EBR2 , Offset: 000003F00000 , filesize: 512 bytes
Done writing partition. Write speed: 97,10 Kb/s
Partition name: ANDROID
Filename: system.img , Offset: 000004980000 , filesize: 590226632 bytes
Sparse image found v.1.0  Total chunks: 1465
Done writing partition. Write speed: 867,12 Kb/s
Partition name: CACHE
Filename: cache.img , Offset: 000030580000 , filesize: 6316180 bytes
Sparse image found v.1.0  Total chunks: 10
Done writing partition. Write speed: 1510,85 Kb/s
Partition name: USRDATA
Filename: userdata.img , Offset: 000038380000 , filesize: 56480276 bytes
Sparse image found v.1.0  Total chunks: 42
Done writing partition. Write speed: 1052,71 Kb/s
Writing DL_Info...
Writing DL_Info done
Writing eMMC Register ...
Reg: 179  Value: 0x00
Reg: 177  Value: 0x48
All done
Old 12-10-2016, 15:32   #504 (permalink)
Member: 1314806
Sonork: 100.1000
Thanks Meter: 74
LG D375 purple screen. done
thanks team
The Following User Says Thank You to kopito For This Useful Post:
Old 12-19-2016, 06:15   #505 (permalink)
Member: 2040192
Sonork: 100.1660527
best thanks for your answers
Old 12-21-2016, 12:51   #506 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 13,776
Samsung Galaxy S Duos 2 S7582 Boot Repair Done
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post:
Old 01-10-2017, 06:08   #507 (permalink)
hanif007's Avatar
Member: 665441
Sonork: 100.1670531
Thanks Meter: 593
n7100 dead emmc repair successfully
Z3X EasyJtag Software ver. 2.0.6.6
Box S/N: 0C007015319CF9D5, ,FW Ver.: 01.56
CMD Pullup Level:1144 mV
CMD Active Level:1577 mV
Can't init device, Reason: CMD CRC Error
Done.
CMD Pullup Level:2650 mV
CMD Active Level:2743 mV
Done.
CMD Pullup Level:2640 mV
CMD Active Level:2732 mV
EMMC NAME: <b>000000</b> , S/N:  537986854
Backup saved: 000000_ 537986854_20170109_1821.extcsd
Done.
CMD Pullup Level:3135 mV
CMD Active Level:3238 mV
Backup saved: 000000_ 537986854_20170109_1822.extcsd
Partitioning not detected...
Done.
CMD Pullup Level:3145 mV
Can't setup firmware normal update mode, Reason: CARD Status Error
Done.
CMD Active Level:3217 mV
Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD]
Done.
CMD Active Level:3227 mV
Done.
EMMC ROM1 (Main User Data)   Capacity: 2095982 MB
EMMC ROM2 (Boot Partition 1) Capacity: 0 kB
EMMC ROM3 (Boot Partition 2) Capacity: 0 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB
Backup saved: 000000_ 537986854_20170109_1823.extcsd
Done.
Success!
Success!
Success!
Success!
Success!
<font color="green">eMMC firmware is updated now! </font>
<font color="green">Please reconnect all eMMC lines before next operation!</font>
<font color="green">Please don't forget to repair <b>extCSD</b> from backup!</font>
<font color="green">Please don't forget to configure <b>BOOT</b> sizes!</font>
Done.
Running:SAMSUNG: MoviNAND Factory Reset...
Sending Smart Wipe Request...
Wiping Card... Please do not touch it!
<font color="red">Please don't forget to repair extCSD from backup!</font>
Done.
Running:SAMSUNG: MoviNAND Reset + Format...
EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB
Sending Internal Reconfiguration Request...
Waiting configuration Apply!
Restoring configuration...
Done.
Writing...
Done.
EMMC CID : 1501005654553030300C20138686416E
EMMC Date: 04/2014  Rev.0xC
EMMC NAME: <b>VTU000</b> , S/N:  538150534
EMMC NAME (HEX): 56545530303000
Backup saved: VTU000_ 538150534_20170109_1825.extcsd
Done.
Input file : D:\beckup old laptop data\n7100 tested hanif\N7100 BOOT1.bin
Done. Write Speed: 1256 kB/s
Input file : D:\beckup old laptop data\n7100 tested hanif\N7100 USERAREA.bin
Writing 0001000000 bytes to 00000000 ...ROM1 (USER ROM)
Done. Write Speed: 1321 kB/s
Backup saved: VTU000_ 538150534_20170109_1826.extcsd
MMCBLK0P3 (M9KEFS1) Range:	[0X2000000,0X23FFE00] ,Len: 400000
MMCBLK0P4 (M9KEFS2) Range:	[0X2400000,0X27FFE00] ,Len: 400000
MMCBLK0P5 (M9KEFS3) Range:	[0X2800000,0X2BFFE00] ,Len: 400000
MMCBLK0P6 (PARAM) Range:	[0X2C00000,0X33FFE00] ,Len: 800000
MMCBLK0P7 (BOOT) Range:	[0X3400000,0X3BFFE00] ,Len: 800000
MMCBLK0P8 (RECOVERY) Range:	[0X3C00000,0X43FFE00] ,Len: 800000
MMCBLK0P9 (RADIO) Range:	[0X4400000,0X9BFFE00] ,Len: 5800000
MMCBLK0P10 (TOMBSTONES) Range:	[0X9C00000,0X9FFFE00] ,Len: 400000
MMCBLK0P11 (CACHE) Range:	[0XA000000,0X5F7FFE00] ,Len: 55800000
MMCBLK0P12 (SYSTEM) Range:	[0X5F800000,0XDF7FFE00] ,Len: 80000000
MMCBLK0P13 (HIDDEN) Range:	[0XDF800000,0X1027FFE00] ,Len: 23000000
MMCBLK0P14 (OTA) Range:	[0X102800000,0X102FFFE00] ,Len: 800000
MMCBLK0P15 (USERDATA) Range:	[0X103000000,0X3AAFFFE00] ,Len: 2A8000000
Done.
Done.
Old 01-11-2017, 05:17   #508 (permalink)
Moderator
Deepesh Sharma's Avatar
Member: 1301233
Sonork: 100.1614172
Thanks Meter: 8,801
Samsung Galaxy S Duos-2 Dead Boot Reapir
Samsung Galaxy S Duos-2 Dead Boot Reapir(S-7582)
The Following 5 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 02-01-2017, 19:34   #509 (permalink)
Member: 1981679
Thanks Meter: 65
Lg g3 d855 32g,3g emmc replaced and repaired by easy jtag
1-KNOW DAMAGED EMMC INFORMATION AND MAKE A BACKUP.
2-CHANGE EMMC BY DIGING CARFULLY.
3-CHOSE SUITABLE EMMC IC {I CHOSED Z2 EMMC IC}.
4-FLASH PHONE WHITH ANY ROM AFTER RESTORE THE BACKUP.
https://drive.google.com/open?id=0Bw...lnSGp6VEExUklR
https://drive.google.com/open?id=0Bw...RYcVFsZjZic2Nj
https://drive.google.com/open?id=0Bw...lPMnE5ZGxzSzlR
https://drive.google.com/open?id=0Bw...g4akl3X3hSS09R
https://drive.google.com/open?id=0Bw...FiRlYwTFA3c0ZB
https://drive.google.com/open?id=0Bw...25hWkdyeENyd1k
https://drive.google.com/open?id=0Bw...kM0VmM5c3lseFk
Box S/N: 0101301C205B2E88, ,FW Ver.: 01.58
CMD Pullup Level:2021 mV
CLK Rate:7000 khz
HiPower mode is ON!
EMMC CID : 110100303332474534040DD906A011EE
EMMC CSD : D05E00320F5903FFFFFFFFEF924000D2
EMMC Manufacturer ID: 0011 , OEM ID: 0100
EMMC Date: 01/2014 Rev.0x4
EMMC NAME: 032GE4 , S/N: 232326816
EMMC NAME (HEX): 30333247453400
EMMC ROM1 (Main User Data) Capacity: 29820 MB
Backup saved: 032GE4_ 232326816_20170131_1615.extcsd
Warning: Entries Count = 44
MMCBLK0P0 (SBL1) Range: [0X4400,0X104200] ,Len: 100000
MMCBLK0P1 (PG1FS) Range: [0X104400,0X2104200] ,Len: 2000000
MMCBLK0P2 (BOARD_INFO) Range: [0X2104400,0X2108200] ,Len: 4000
MMCBLK0P3 (RESERVE_1) Range: [0X2108400,0X2FFFE00] ,Len: EF7C00
MMCBLK0P4 (MFG) Range: [0X3000000,0X303FE00] ,Len: 40000
MMCBLK0P5 (PG2FS) Range: [0X3040000,0X47EFA00] ,Len: 17AFC00
MMCBLK0P6 (SBL1_UPDATE) Range: [0X47EFC00,0X482FA00] ,Len: 40000
MMCBLK0P7 (RPM) Range: [0X482FC00,0X486FA00] ,Len: 40000
MMCBLK0P8 (TZ) Range: [0X486FC00,0X4A6FA00] ,Len: 200000
MMCBLK0P9 (SDI) Range: [0X4A6FC00,0X4A77A00] ,Len: 8000
MMCBLK0P10 (HBOOT) Range: [0X4A77C00,0X4E77A00] ,Len: 400000
MMCBLK0P11 (SP1) Range: [0X4E77C00,0X5377A00] ,Len: 500000
MMCBLK0P12 (WIFI) Range: [0X5377C00,0X5477A00] ,Len: 100000
MMCBLK0P13 (DDR) Range: [0X5477C00,0X547FA00] ,Len: 8000
MMCBLK0P14 (DSPS) Range: [0X547FC00,0X557FA00] ,Len: 100000
MMCBLK0P15 (ADSP) Range: [0X557FC00,0X917FE00] ,Len: 3C00400
MMCBLK0P16 (WCNSS) Range: [0X9180000,0X967FE00] ,Len: 500000
MMCBLK0P17 (RADIO_CONFIG) Range: [0X9680000,0X9E7FE00] ,Len: 800000
MMCBLK0P18 (FSG) Range: [0X9E80000,0X9FFFE00] ,Len: 180000
MMCBLK0P19 (RADIO) Range: [0XA000000,0XEB00200] ,Len: 4B00400
MMCBLK0P20 (TOOL_DIAG) Range: [0XEB00400,0XEF00200] ,Len: 400000
MMCBLK0P21 (CUSTDATA) Range: [0XEF00400,0XF900200] ,Len: A00000
MMCBLK0P22 (RESERVE_2) Range: [0XF900400,0XFFFFE00] ,Len: 6FFC00
MMCBLK0P23 (MISC) Range: [0X10000000,0X100FFE00] ,Len: 100000
MMCBLK0P24 (MODEM_ST1) Range: [0X10100000,0X1027FE00] ,Len: 180000
MMCBLK0P25 (MODEM_ST2) Range: [0X10280000,0X103FFE00] ,Len: 180000
MMCBLK0P26 (FATALDEVLOG) Range: [0X10400000,0X117FFE00] ,Len: 1400000
MMCBLK0P27 (DEBUG_CONFIG) Range: [0X11800000,0X11800E00] ,Len: 1000
MMCBLK0P28 (PDATA) Range: [0X11801000,0X11840E00] ,Len: 40000
MMCBLK0P29 (CONTROL) Range: [0X11841000,0X11844E00] ,Len: 4000
MMCBLK0P30 (LOCAL) Range: [0X11845000,0X11985200] ,Len: 140400
MMCBLK0P31 (EXTRA) Range: [0X11985400,0X11995200] ,Len: 10000
MMCBLK0P32 (CDMA_RECORD) Range: [0X11995400,0X11A95200] ,Len: 100000
MMCBLK0P33 (FSC) Range: [0X11A95400,0X11A95600] ,Len: 400
MMCBLK0P34 (SSD) Range: [0X11A95800,0X11A97600] ,Len: 2000
MMCBLK0P35 (SKYLINK) Range: [0X11A97800,0X11AD7600] ,Len: 40000
MMCBLK0P36 (CARRIER) Range: [0X11AD7800,0X133D7600] ,Len: 1900000
MMCBLK0P37 (DEVLOG) Range: [0X133D7800,0X151D7600] ,Len: 1E00000
MMCBLK0P38 (RESERVE) Range: [0X151D7800,0X15FFFE00] ,Len: E28800
MMCBLK0P39 (BOOT) Range: [0X16000000,0X16FFFE00] ,Len: 1000000
MMCBLK0P40 (RECOVERY) Range: [0X17000000,0X17FFFE00] ,Len: 1000000
MMCBLK0P41 (CACHE) Range: [0X18000000,0X28FFFE00] ,Len: 11000000
MMCBLK0P42 (SYSTEM) Range: [0X29000000,0XC8FFFE00] ,Len: A0000000
MMCBLK0P43 (USERDATA) Range: [0XC9000000,0X1D0FFFE00] ,Len: 108000000
Done.
Running:eMMC: Factory Format...
Z3X EasyJtag Software ver. 2.5.0.6
CLK Rate:7000 khz
Formatting eMMC card, please wait up to 3 min...
Setting Service Mode...
eMMC Format Done.
Done.
CMD Pullup Level:2010 mV
CMD Active Level:2330 mV
CLK Rate:7000 khz
HiPower mode is ON!
Done.
Processing file...D:\emmc\LG D855 EMMC 32GB 3GB RAM\SDW32G_19EE4338_20170114_231841.extcsd
ROM1 Are not selected , skip writing ROM1
Processing file...D:\emmc\LG D855 EMMC 32GB 3GB RAM\EMMC_SDW32G_ROM2_000000000000_000000400000.bin
Processing file...D:\emmc\LG D855 EMMC 32GB 3GB RAM\EMMC_SDW32G_ROM3_000000000000_000000400000.bin
CLK Rate:7000 khz
Writing...
Done.
Input file : D:\emmc\LG D855 EMMC 32GB 3GB RAM\EMMC_SDW32G_ROM2_000000000000_000000400000.bin
Writing 0000400000 bytes to 00000000 ...ROM2 (BOOT1 ROM)
Full Verify Enabled!
Done. Write Speed: 385 kB/s
Writing 0000400000 bytes to 00000000 ...ROM3 (BOOT2 ROM)
Done. Write Speed: 388 kB/s
CMD Active Level:2340 mV
CLK Rate:7000 khz
HiPower mode is ON!
Backup saved: 032GE4_ 232326816_20170131_1616.extcsd
Done.
Checking NAND Image : D:\emmc\LG D855 EMMC 32GB 3GB RAM\EMMC_SDW32G_ROM1_000000000000_000020000000.bin
Processing file...D:\emmc\LG D855 EMMC 32GB 3GB RAM\EMMC_SDW32G_ROM1_000000000000_000020000000.bin
Input file : D:\emmc\LG D855 EMMC 32GB 3GB RAM\EMMC_SDW32G_ROM1_000000000000_000020000000.bin
Writing flash page stopped by user request
Done.
Old 02-08-2017, 13:43   #510 (permalink)
Member: 2672131
Thanks Meter: 17
Another n7100 emmc repair done
Backup saved: VTU00M_1027180166_20170208_1853.extcsd
Done.
Running:SAMSUNG: Read S.M.A.R.T Report...
CMD Pullup Level:1330 mV
CMD Active Level:2681 mV
Reading S.M.A.R.T
S.M.A.R.T Ver. 0 , Card Error mode : Normal
Super Block size : 0x00800000 (8388608 bytes)
Super Page size : 0x00004000 (16384 bytes)
Optimal Write size : 0x00010000 (65536 bytes)
Read Reclaim count : 12
Optimal TRIM size : 0x00002000 (8192 bytes)
Total Number of banks : 4
Initial bad blocks per bank : 2,3,1,2
Runtime bad blocks per bank : 3,3,1,5
Reserved blocks left per bank : 46,45,49,45
All Erase counts (min,avg,max): 1,18,1504
SLC Erase counts (min,avg,max): 3,209,1504
MLC Erase counts (min,avg,max): 1,8,25
S.M.A.R.T Report Done.
EMMC NAME: VTU00M
CMD Active Level:2670 mV
Success!
Success!
Success!
Success!
Success!
Done.
EMMC NAME: VTU000
CMD Pullup Level:1320 mV
Success!
Success!
Success!
Success!
Success!
Done.
CMD Pullup Level:1340 mV
EMMC NAME: VTU000 , S/N: 538150534
Backup saved: VTU000_ 538150534_20170208_1857.extcsd
Done.
Done.
Done.
extCSD file...D:\EMMC REPAIR\n7100 tested hanif\N7100 EXTCSD\N7100 EXTCSD.extcsd
Writing...
Done.
Checking NAND Image : D:\EMMC REPAIR\n7100 tested hanif\N7100 BOOT1\N7100 BOOT1.bin
Processing file...D:\EMMC REPAIR\n7100 tested hanif\N7100 BOOT1\N7100 BOOT1.bin
Input file : D:\EMMC REPAIR\n7100 tested hanif\N7100 BOOT1\N7100 BOOT1.bin
Done. Write Speed: 1268 kB/s
Checking NAND Image : D:\EMMC REPAIR\n7100 tested hanif\N7100 USERAREA.bin
Processing file...D:\EMMC REPAIR\n7100 tested hanif\N7100 USERAREA.bin
Input file : D:\EMMC REPAIR\n7100 tested hanif\N7100 USERAREA.bin
Done. Write Speed: 1272 kB/s
CMD Active Level:2660 mV
Backup saved: VTU000_ 538150534_20170208_1859.extcsd
Done.
Reading S.M.A.R.T
Read Reclaim count : 0
Initial bad blocks per bank : 6,6,2,6
Runtime bad blocks per bank : 0,0,0,0
Reserved blocks left per bank : 45,45,49,45
All Erase counts (min,avg,max): 0,0,2
SLC Erase counts (min,avg,max): 0,0,2
MLC Erase counts (min,avg,max): 0,0,2
Page generated in 0.30122 seconds with 8 queries
