07-18-2017, 12:30 | #542 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | Samsung i747 dead boot repair done EasyJtag Suite Classic ver.: 2.5.1.0 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1). Admin righ For support and updates visit EasyJtag ? most powerfull eMMC and JTAG tool on market. | EMMC BOX, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL Check security... OK Initialising: SAMSUNG SGH-I747 Config ver.:1.00 I/O Level set to : 2200 mV Box S/N: 14005017FD32FA96 ,FW Ver.: 01.58 Connecting to Target... JTAG device: MSM8960. CPU IDCODE : 0x4F1F0F0F Mfg.: 0x787, Part: 0xf1f0, Ver.: 0x4 CPU Manufacturer: Samsung , CPU Name: ARM7GEN JTAG device: MSM8960. CPU IDCODE : 0x406B50E1 Mfg.: 0x070, Part: 0x06b5, Ver.: 0x4 CPU Manufacturer: QUALCOMM , CPU Name: MSM8960 Rev 0.9 Halting CPU... Initialize hardware... Starting target communication... Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x00000015 Name : MAG4FB Size : 14.7 G , (30777344) Blocks EMMC #1 : ID : 0x00000015 Name : MAG4FB Size : 2.0 M , (4096) Blocks eMMC flash device(s) found, Device ID : 0x00150000 Loading repair file: 'D:\JTAG\i747 EASY JTAG\Samsung SGH-i747.rcp' Repair File ver. : Easy Repair for Mfg: SAMSUNG Model: SCH-I747, Ver.: 1.00 Error loading information! Easy-Repair file load OK! Using EasyRepair Mode... Checking repair data... EasyJtag Suite Classic ver.: 2.5.1.0 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1). Admin righ For support and updates visit EasyJtag ? most powerfull eMMC and JTAG tool on market. | EMMC BOX, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL Check security... OK Initialising: SAMSUNG SCH-I747 Config ver.:1.00 Connecting to Target... Done with error(s)... Using EasyRepair Mode... Checking repair data... EasyJtag Suite Classic ver.: 2.5.1.0 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1). Admin righ For support and updates visit EasyJtag ? most powerfull eMMC and JTAG tool on market. | EMMC BOX, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL Check security... OK Initialising: SAMSUNG SCH-I747 Config ver.:1.00 I/O Level set to : 2200 mV Box S/N: 14005017FD32FA96 ,FW Ver.: 01.58 Connecting to Target... JTAG device: MSM8960. CPU IDCODE : 0x4F1F0F0F Mfg.: 0x787, Part: 0xf1f0, Ver.: 0x4 CPU Manufacturer: Samsung , CPU Name: ARM7GEN JTAG device: MSM8960. CPU IDCODE : 0x406B50E1 Mfg.: 0x070, Part: 0x06b5, Ver.: 0x4 CPU Manufacturer: QUALCOMM , CPU Name: MSM8960 Rev 0.9 Halting CPU... Initialize hardware... Starting target communication... Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x00000015 Name : MAG4FB Size : 14.7 G , (30777344) Blocks EMMC #1 : ID : 0x00000015 Name : MAG4FB Size : 2.0 M , (4096) Blocks eMMC flash device(s) found, Device ID : 0x00150000 NAND Writing GPT, PIT, MD5... eMMC Write OK! Elapsed time: 18.703070s (219.001 KiB/s) NAND Writing SBL1... eMMC Write OK! Elapsed time: 1.224070s (104.569 KiB/s) NAND Writing SBL2... eMMC Write OK! Elapsed time: 2.140122s (119.619 KiB/s) NAND Writing SBL3... eMMC Write OK! Elapsed time: 4.526259s (113.118 KiB/s) NAND Writing ABOOT... eMMC Write OK! Elapsed time: 15.876908s (128.992 KiB/s) NAND Writing RPM... eMMC Write OK! Elapsed time: 3.158181s (162.119 KiB/s) NAND Writing TZ... eMMC Write OK! Elapsed time: 3.594206s (142.451 KiB/s) All Done. |
07-29-2017, 11:34 | #543 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | oppo 831k emmc repaire done Z3X EasyJtag Software ver. 2.5.1.0 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 010070222EE63D88, ,FW Ver.: 01.58 CMD Pullup Level:2248 mV CMD Active Level:2444 mV Box IO Level:2800 mV CLK Rate:21000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A4834473164040509A168A071D0 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 07/2014 Rev.0x5 EMMC NAME: H4G1d , S/N: 161573024 EMMC NAME (HEX): 48344731642000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G1d _ 161573024_20170729_1308.extcsd Found Data areas (firmware parts) count is: 4 Partition info successfully found --------------------------------------------- P1 (PARTITION_P83) [0x900000 0xa00000] Size: 10.0MB P2 (PARTITION_P83) [0x1300000 0xa00000] Size: 10.0MB P3 (PARTITION_P83) [0x2d80000 0x600000] Size: 6.0MB ------ Android information ------ --------------------------------------------- Done. |
09-04-2017, 01:38 | #549 (permalink) | |
Insane Poster Join Date: Jun 2008 Location: UK-PL
Member: 796570 Status: Offline Thanks Meter: 26 | Quote:
Firstly need explain You something ! Most people here spending hours... months even can say most life to achieve something what can do only small percentage of GSMhosting users ! And I asked You right now.... DID YOU CHECK OFFICIAL WEBSITE of product what You asked for ? Coz if You could take a look at website in some "free time" You could get know..... Z3X Team release: -Z3X Pro box (has USB and RJ45 socket but mostly use microUSB cable) -Z3X EasyJtag box (has JTAG interface and can "resurrect" bootloader) When purchase box You will get SmartCard with unique SN number (usually with activated LG or Samsung or Samsung Pro activation Different is there is no need to buy easy jtag activation if has only Z3X Pro box but always can purchase EasyJtag box without smart card and "upgrade" egsisting one ! As far (please correct me if Im wrong) as I know once purchased activation no need to extending any more... of course some other benefits like unlocking VIA sesrver (need purchase credits) may appear but usually it is in reasonable price ! I had activated as follow: - LG - Samsung Pro - Easy jtag And honestly can say (with some dose of basic knowledge) its almost "self-repairing" box which can give rest of mind ! If cant resurrect device its in 90% hardware issue and in 99% in eMMC/NAND/NOR module problem which need replacing ... and than box is "matterhacker" priceless Please .... use search button at google first !! When You write post You could find solution at lest twice | |
09-06-2017, 00:31 | #550 (permalink) |
Freak Poster Join Date: Jul 2013 Location: CAIRO.EGYPT
Member: 1981679 Status: Offline Thanks Meter: 86 | Samsung sm-j100h boot repaired successfuly bu ahmed koukou. AT FIRST MAKE TEST WRITE AND FINAL WRITE : Code: HiPower mode is ON Frequence: 14 Mhz CMD Pullup Level: 2547 mV CMD Active Level: 2722 mV EMMC Device Information : EMMC CID: 90014A48344732621101B5C5199E2244 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: B5C5199E , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Backup saved: H4G2b_B5C5199E_20170905_233619.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig <<<<<<<<<<<< THIS ERROR BEFOR IDO TEST WRITE AND FINAL WRITE . Error writing at address: 000000000000 ... Retry #1 Error writing at address: 000000000000 ... Retry #2 Error writing at address: 000000000000 ... Retry #3 Too many errors. Writing has been stopped HiPower mode is ON Frequence: 14 Mhz CMD Pullup Level: 2547 mV CMD Active Level: 2753 mV EMMC Device Information : EMMC CID: 90014A48344732621101B5C5199E2244 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: B5C5199E , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Backup saved: H4G2b_B5C5199E_20170905_233630.extcsd EMMC Init completed. Operation: Changing GP sizes (test mode) ... GP1 size: 0 MB , WR_REL: 1 , ENH 0 GP1 size: 0 MB , WR_REL: 1 , ENH 0 GP1 size: 0 MB , WR_REL: 1 , ENH 0 GP1 size: 0 MB , WR_REL: 1 , ENH 0 Successfully Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0] to cancel the changes HiPower mode is ON Frequence: 14 Mhz CMD Pullup Level: 2650 mV CMD Active Level: 2712 mV Can't init device. Reason: CMD Timeout Error HiPower mode is ON Frequence: 14 Mhz CMD Pullup Level: 2536 mV CMD Active Level: 2722 mV EMMC Device Information : EMMC CID: 90014A48344732621101B5C5199E2244 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: B5C5199E , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Backup saved: H4G2b_B5C5199E_20170905_233703.extcsd EMMC Init completed. Operation: Changing GP sizes (final write) ... GP1 size: 0 MB , WR_REL: 1 , ENH 0 GP1 size: 0 MB , WR_REL: 1 , ENH 0 GP1 size: 0 MB , WR_REL: 1 , ENH 0 GP1 size: 0 MB , WR_REL: 1 , ENH 0 Successfully Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0] to finalize operation After reconnect, make sure that the size of ROM1 has been changed. HiPower mode is ON Frequence: 14 Mhz CMD Pullup Level: 2660 mV CMD Active Level: 2732 mV Can't init device. Reason: CMD Timeout Error HiPower mode is ON Frequence: 14 Mhz CMD Pullup Level: 2536 mV CMD Active Level: 2722 mV EMMC Device Information : EMMC CID: 90014A48344732621101B5C5199E2244 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: B5C5199E , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Backup saved: H4G2b_B5C5199E_20170905_233748.extcsd EMMC Init completed. Opening file: H4G2b_samsung.pit Pit: H4G2b_samsung.pit Entry count: 28 The size of the last section has been updated HiPower mode is ON Frequence: 14 Mhz CMD Pullup Level: 2547 mV CMD Active Level: 2732 mV Can't init device. Reason: CMD Timeout Error HiPower mode is ON Frequence: 14 Mhz CMD Pullup Level: 2547 mV CMD Active Level: 2722 mV EMMC Device Information : EMMC CID: 90014A48344732621101B5C5199E2244 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: B5C5199E , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Backup saved: H4G2b_B5C5199E_20170905_233759.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PIT at address: 000000004400 GPT-partitioning done Partition name: BOOTLOADER_ROM2 Filename: bootloader_rom2.bin , Offset: 000000000000 , filesize: 4194304 bytes eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 304.36 Kb/s Partition name: SBOOT Filename: SBOOT.bin , Offset: 000000400000 , filesize: 2097152 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 546.43 Kb/s Partition name: SBOOT2 Filename: SBOOT2.bin , Offset: 000000600000 , filesize: 2097152 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 541.44 Kb/s Partition name: WFIXNV1 Filename: wfixnv1.bin , Offset: 000000800000 , filesize: 1048576 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 630.58 Kb/s Partition name: WFIXNV2 Filename: wfixnv2.bin , Offset: 000000900000 , filesize: 1048576 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 626.66 Kb/s Partition name: TDFIXNV1 Filename: tdfixnv1.bin , Offset: 000000A00000 , filesize: 1048576 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 652.43 Kb/s Partition name: TDFIXNV2 Filename: tdfixnv2.bin , Offset: 000000B00000 , filesize: 1048576 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 647.23 Kb/s Partition name: WDSP Filename: WDSP.bin , Offset: 000000C00000 , filesize: 4194304 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 593.00 Kb/s Partition name: MODEM Filename: MODEM.bin , Offset: 000001000000 , filesize: 8388608 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 381.72 Kb/s Partition name: MODEM2 Filename: MODEM2.bin , Offset: 000001800000 , filesize: 8388608 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 451.82 Kb/s Partition name: TDDSP Filename: TDDSP.bin , Offset: 000002000000 , filesize: 4194304 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 530.70 Kb/s Partition name: FOTA_SIG Filename: FOTA_SIG.bin , Offset: 000002400000 , filesize: 1048576 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 652.91 Kb/s Partition name: WRUNTIMENV1 Filename: wruntimenv1.bin , Offset: 000002500000 , filesize: 1048576 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 626.71 Kb/s Partition name: WRUNTIMENV2 Filename: wruntimenv2.bin , Offset: 000002600000 , filesize: 1048576 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 624.90 Kb/s Partition name: TDRUNTIMENV1 Filename: tdruntimenv1.bin , Offset: 000002700000 , filesize: 1048576 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 646.40 Kb/s Partition name: TDRUNTIMENV2 Filename: tdruntimenv2.bin , Offset: 000002800000 , filesize: 1048576 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 649.50 Kb/s Partition name: PARAM Filename: PARAM.bin , Offset: 000002900000 , filesize: 2097152 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 518.78 Kb/s Partition name: EFS Filename: EFS.bin , Offset: 000002B00000 , filesize: 20971520 bytes eMMC switching to ROM1 Writing partition... Error writing at address: 000003E00000 ... Retry #1 Error writing at address: 000003E00000 ... Retry #2 Error writing at address: 000003E00000 ... Retry #3 Error writing at address: 000003E80000 ... Retry #1 Done writing partition. Write speed: 596.77 Kb/s Partition name: PRODNV Filename: PRODNV.bin , Offset: 000003F00000 , filesize: 5242880 bytes eMMC switching to ROM1 Writing partition... Error writing at address: 000004100000 ... Retry #1 Done writing partition. Write speed: 582.18 Kb/s Partition name: RESERVED2 Filename: RESERVED2.bin , Offset: 000004400000 , filesize: 1048576 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 620.82 Kb/s Partition name: KERNEL Filename: KERNEL.bin , Offset: 000004500000 , filesize: 16777216 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 512.48 Kb/s Partition name: RECOVERY Filename: RECOVERY.bin , Offset: 000005500000 , filesize: 16777216 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 231.28 Kb/s Partition name: PERSDATA Filename: PERSDATA.bin , Offset: 000006500000 , filesize: 9437184 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 619.81 Kb/s Partition name: CSC Filename: CSC.bin , Offset: 000006E00000 , filesize: 209715200 bytes BEST REGARDS, AHMED ABDEL KHALIK Last edited by ahmed koukou; 09-06-2017 at 00:38. |
The Following 3 Users Say Thank You to ahmed koukou For This Useful Post: |
09-10-2017, 06:40 | #554 (permalink) |
No Life Poster Join Date: Feb 2011 Location: ( United States Of Islam ) Age: 35
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | lg ls991 dead boot repair don LG LS 991 DEAD BOOT REPAIR DON Code: EasyJtag Suite Classic ver.: 2.6.0.1 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 10 (build 15063). Admin rights OK undefined Android Explorer ver.: 1.0.0.23 eMMC ODIN ver.: 1.0.11.2 Successfully connected to box on COM6 Box S/N: 0C00901642DED224, ,FW Ver.: 01.60 Box Working Mode: JTAG Box. Box Drivers version: 10.0.15063.0, are OK Z3X Card Serial : AA2B-14E1 , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0C00901642DED224, ,FW Ver.: 01.60 CMD Pullup Level:2062 mV CMD Active Level:2825 mV Box IO Level:3300 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 11010030333247373400488FADB66260 EMMC CSD : D02700320F5903FFFFFFFFE78640009A EMMC Manufacturer ID: 0011 , OEM ID: 0100 EMMC Date: 06/2015 Rev.0x0 EMMC NAME: 032G74 , S/N: 1217375670 EMMC NAME (HEX): 30333247373400 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 032G74_1217375670_20170910_0934.extcsd Done. Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0C00901642DED224, ,FW Ver.: 01.60 CMD Pullup Level:2041 mV CMD Active Level:2949 mV Box IO Level:3300 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 11010030333247373400488FADB66260 EMMC CSD : D02700320F5903FFFFFFFFE78640009A EMMC Manufacturer ID: 0011 , OEM ID: 0100 EMMC Date: 06/2015 Rev.0x0 EMMC NAME: 032G74 , S/N: 1217375670 EMMC NAME (HEX): 30333247373400 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 032G74_1217375670_20170910_0934.extcsd Done. Checking NAND Image : D:\Z3X BOX\EasyJtag\pinout\LG POINT\LS991\LS991_ZVC_OK_ROM1_032G74_232104821_00000000_17D200000_UPTO_USERDATA.bin Autodetected RAW data Warning! Disk size is smaller than the main header indicates! Loading Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Partition info successfully found Detected LINUX(Android) SYSTEM : 0x0020000000 (4.251GB) Build ID: MRA58K Display Build ID: MRA58K Release ID: 6.0 Device Model: LGLS991 Device Name: p1_spr_us Architecture ABI: arm64-v8a Device manufacturer: LGE Device Platform: msm8992 Product ID: p1 Build Description: p1_spr_us-user 6.0 MRA58K 1616419005540 release-keys File successefuly loaded! Real (Hardware) Disk/Image size: BE8FFF sectors 6.0 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 61071326 Processing file...D:\Z3X BOX\EasyJtag\pinout\LG POINT\LS991\LS991_ZVC_OK_ROM1_032G74_232104821_00000000_17D200000_UPTO_USERDATA.bin Writing as RAW data Z3X EasyJtag Software ver. 2.6.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:2041 mV CMD Active Level:2949 mV Input file : D:\Z3X BOX\EasyJtag\pinout\LG POINT\LS991\LS991_ZVC_OK_ROM1_032G74_232104821_00000000_17D200000_UPTO_USERDATA.bin Writing 017D200000 bytes to 0000000000... ROM1 (USER ROM) Writing flash page stopped by user request Done. Done with error(s) Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0C00901642DED224, ,FW Ver.: 01.60 CMD Pullup Level:2041 mV CMD Active Level:2970 mV Box IO Level:3300 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 11010030333247373400488FADB66260 EMMC CSD : D02700320F5903FFFFFFFFE78640009A EMMC Manufacturer ID: 0011 , OEM ID: 0100 EMMC Date: 06/2015 Rev.0x0 EMMC NAME: 032G74 , S/N: 1217375670 EMMC NAME (HEX): 30333247373400 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 032G74_1217375670_20170910_0952.extcsd Done. Checking NAND Image : D:\Z3X BOX\EasyJtag\pinout\LG POINT\LS991\LG_LS991_ZVB_512Mb_TESTED_OK.bin Autodetected RAW data Warning! Disk size is smaller than the main header indicates! Loading Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Partition info successfully found Linux partitions is not found in image... File successefuly loaded! Real (Hardware) Disk/Image size: 100000 sectors 512.0 MiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 61071326 Processing file...D:\Z3X BOX\EasyJtag\pinout\LG POINT\LS991\LG_LS991_ZVB_512Mb_TESTED_OK.bin Writing as RAW data Z3X EasyJtag Software ver. 2.6.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:2041 mV CMD Active Level:2970 mV Input file : D:\Z3X BOX\EasyJtag\pinout\LG POINT\LS991\LG_LS991_ZVB_512Mb_TESTED_OK.bin Writing 0020000000 bytes to 0000000000... ROM1 (USER ROM) Done. Write Speed: 723 kB/s |
09-11-2017, 18:48 | #555 (permalink) |
No Life Poster Join Date: Aug 2015 Location: KATHMANDU,NEPAL
Member: 2438408 Status: Offline Thanks Meter: 380 | J100h successfully dead boot repair complete sucessfully write pit and bl file but phone not power on same case .. |
The Following User Says Thank You to alexid For This Useful Post: |
