Old 04-14-2018, 18:45   #631 (permalink)
Crazy Poster
Member: 2733634
Thanks Meter: 9
I need files dump for LGLS770
Old 04-16-2018, 07:35   #632 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
Samsung J110H Boot Repair Done
The Following User Says Thank You to 4G Telecom For This Useful Post:
Old 04-27-2018, 07:43   #633 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
Htc D326g Dead Boot Repair Done
Htc Desire 326G Daul Sim Dead Recover
Change Emmc SamsungTo Samsung Done
Log
Set Alive
All Done
The Following 8 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 04-28-2018, 08:21   #634 (permalink)
nagesss's Avatar
Member: 2306223
Sonork: 1660968:1234
Thanks Meter: 117
How ABT the missing pins in the board
Log
Set Alive
All Done
Sent from my Redmi Note 4 using Tapatalk
The Following User Says Thank You to nagesss For This Useful Post:
Old 04-28-2018, 10:56   #635 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
I Think Missing pins NC (No Connections )
The Following 3 Users Say Thank You to 4G Telecom For This Useful Post:
Old 05-01-2018, 06:50   #636 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
All Data Recover Fully Burnd China Andriod Phone
Fully Burned Andriod China Phone
All Data Recovered Sucessfully
The Following 4 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 05-04-2018, 15:28   #637 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 2,363
Cool samsung j100h boot repair done
[IMG][/IMG]
eMMC_tool Suite ver. 1.4.9.0 (release date: 12.12.2017)
Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385)
Looking for EasyJTAG box...
EasyJTAG API ver. 2022
EasyJTAG Box Serial = 0900301095CE53A5
Card Serial = AAAA-6B50
EasyJTAG Box Firmware = 1.62
Changelog:
12.12.2017 (ver 1.4.9.0)
Fix: Bugs that have been found through your crash report
Fix: RandomVerify function
Fix: Creation of GPT for Samsung (write by vendor)
Fix: Failed to mount large Fat partitions (explorer)
Fix: Extraction from contact2.db (explorer)
Fix: Error in the "build.prop" parser
Fix: CID Parser
Add: Support for EasyJtag Plus Box
Add: Path for TempDir and InitialDir (option in settings)
Add: Unpack Lenovo QSB (utilities)
Add: Selecting a PIT file from CSC (write by vendor Samsung)
Add: Detect for encrypted dumps from GPG Box
Add: Detect for FullDiskEncryption Partition (explorer)
Add: LinearVerify of the Partition (read by vendor)
Add: Information base about emmc compatibility (thanks to phonemicrodb)
Add: Resizing the window (for small screen resolutions)
Add: Converting large partitions in SparseImage when reading by vendor (option in settings)
Add: Mounting SparseImage (explorer)
Add: Automatic backup of the EFS partition for Samsung (read by vendor)
Add: Formatting of EFS partition for Samsung on request (write by vendor)
Setting frequence to 14 Mhz
CMD Pullup Level: 3135 mV
CMD Active Level: 3217 mV
EMMC Device Information :
EMMC CID: 90014A48344732621101F291A9F26264
EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA
EMMC Manufacture Name: SKHYNIX , EMMC NAME: H4G2b , EMMC NAME (HEX): 483447326200 , S/N: F291A9F2 , rev. 0x01
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 6/2015
EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51)
Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
Backup saved: H4G2b_F291A9F2_20180504_183254.extcsd
EMMC Init completed.
CMD Pullup Level: 3145 mV
CMD Active Level: 3227 mV
Backup saved: H4G2b_F291A9F2_20180504_183330.extcsd
Opening file: SM-J100H_20-4-2018_17-27-5.pit
Pit: SM-J100H_20-4-2018_17-27-5.pit
Entry count: 29
The size of the last section has been updated
BL_J100HXXU0AQA1_CL1167865_QB12130539_REV01_user_l ow_ship.tar.md5
The list of files in the firmware:
spl.img
sboot.bin
sboot2.bin
param.lfs
CMD Active Level: 3238 mV
Backup saved: H4G2b_F291A9F2_20180504_183402.extcsd
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Writing PIT at address: 000000004400
GPT-partitioning done
Unpacking file: spl.img
Unpacking file: sboot.bin
Unpacking file: sboot2.bin
Unpacking file: param.lfs
Partition name: BOOT
Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes
eMMC switching to ROM2
Erasing partition...
Writing partition...
Done writing partition. Write speed: 185.48 KB/s
Partition name: SBOOT
Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 486.72 KB/s
Partition name: SBOOT2
Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes
Done writing partition. Write speed: 485.16 KB/s
Partition name: PARAM
Filename: param.lfs , Offset: 000002900000 , filesize: 634880 bytes
Done writing partition. Write speed: 477.94 KB/s
Partition HIDDEN : formatting as EXT4. Please wait ...
Formatting completed
Partition EFS : formatting as EXT4. Please wait ...
All done time: [00:00:27:227]
thanks jtag team
The Following 2 Users Say Thank You to pintu_das For This Useful Post:
Old 05-05-2018, 08:20   #638 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 2,363
Smile sony xperia Z3+ (E6553) dead recovery done
[IMG][/IMG]
Changelog:
Fix: CID Parser
CMD Pullup Level: 3083 mV
EMMC CID: 15010042474E44335201570F53BB5256
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacture Name: SAMSUNG , EMMC NAME: BGND3R , EMMC NAME (HEX): 42474E443352 , S/N: 570F53BB , rev. 0x01
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 5/2015
EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000)
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: BGND3R_570F53BB_20180505_110135.extcsd
CMD Pullup Level: 3073 mV
Backup saved: BGND3R_570F53BB_20180505_110150.extcsd
Operation: Write Dump
Writing to: ROM1 , start: 0x000000000000 , size: 0x00001BC00000
Input file: G:\Z3x\jtag\dump\sony\e\SONY_E6553_emmc_dump_ROM1_ 444MB\SONY_E6553_emmc_dump_ROM1_444MB\SONY_E6553_e mmc_dump_ROM1.bin
Done writing partition. Write speed: 488.85 KB/s
All done time: [00:15:29:766]
The Following 4 Users Say Thank You to pintu_das For This Useful Post:
Old 05-10-2018, 09:18   #639 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
Samsung J700F Fix SEC S5PC210 TestB/D
Again Sec S5p Fixed by Me
Still No Any One Till Date
Sec S5P Problem
This Time Change Emmc Also Bec Its Currpt
New Emmc Reprogramme
After SucessFully recovered Set Dead From Alive Done
Image-1
The Following 14 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 05-12-2018, 15:32   #640 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
YU5510A Dead Repair Done
First Remove error
Warning: Health report is very BAD
Device Life Time Estimation (MLC) [269]: 0x0B   Exceeded its maximum estimated device life time
Device Life Time Estimation (SLC) [268]: 0x01   0% - 10% device life time used
Pre EOL information [267]: 0x01   Normal
Old 05-13-2018, 11:37   #641 (permalink)
Member: 2438408
Thanks Meter: 380
First Remove error
you have dump file this phone?????????
Old 05-15-2018, 05:51   #642 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
No, no have dump
USE File YU5510A 8675_I02
Old 05-15-2018, 11:47   #643 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
MICROMAX D321 DED BOOT FIX(eMMC READ ONLY)
MicroMAx D321 Dead Set
Emmc read Only
Sucessfully recover with change emmc
skhynixxxxx to Skhynixxxxx
emmc read only
emmc re programming
set sucessfully recovered
Old 05-29-2018, 11:41   #644 (permalink)
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
Zen M72 Smart Dead recover With Change Emmc To Samsung
Zen M72 Dead Handset
Emmc Relace kingSton To Samsung
Set Alive Sucessfully
Log
set Recover
The Following 2 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 06-02-2018, 01:48   #645 (permalink)
Member: 1881220
Sonork: tae
Were to buy easy jtag
Page generated in 0.18433 seconds with 10 queries
