Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 06-02-2018, 01:48   #646 (permalink)
Member: 1881220
Sonork: tae
Were to buy easy jtag
Old 06-03-2018, 16:01   #647 (permalink)
Member: 2047179
Thanks Meter: 24
Originally Posted by Deepesh Sharma View Post
Zen M72 Dead Handset
Emmc Relace kingSton To Samsung
Set Alive Sucessfully
Log
set Recover
how to identify kingston to samsung also how to identify emmc problem
i am new in emmc repair please help me
The Following User Says Thank You to harpindersingh For This Useful Post:
Old 06-07-2018, 06:12   #648 (permalink)
Member: 2130616
Thanks Meter: 3
always write error in skyhynix emmc pls solve this .....
eMMC_tool Suite ver. 1.5.0.0 (release date: 16.04.2018)
Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015)
Looking for EasyJTAG box...
EasyJTAG API ver. 2100
EasyJTAG Box Serial = 8346817BEE03BC25
Card Serial = AABB9E0D
EasyJTAG Box Firmware = 2.23
Changelog:
17.04.2018 (ver 1.5.0.0)
Fix: Bugs that have been found through your crash report
Add: Showing Connected Pins for a Socket (Emmc check)
Add: Automatic search and write 8xxx_msimage and BootConfig (write by vendor)
Add: SmartReport for Sandisk
Add: Vendor Sony
Add: Automatic backup of the TrimArea partition for Sony (read by vendor)
Add: Grouping of extracted messages by sender (Explorer)
Add: Extract Calendar (Explorer)
Add: Checking FullDiskEncryption from Boot (Explorer)
Add: Scan FullFlash from devices with UFS-memory (Explorer)
Add: Converting EFS to Z3X-Samsung format (read by vendor Samsung)
Add: Ext4 formatting is completely rewritten (write by vendor)
Add: Reading files with emmc errors (Explorer)
Add: Skipping for existing files while saving (Explorer)
Add: Write protection for ROM 2/3
Setting interface to EasyJtag2/ISP_HiPower
Setting bus width to 4 Bit
HiPower mode is ON
Setting frequence to 24 Mhz
CMD Pullup Level: 797 mV
CMD Active Level: 1856 mV
EMMC Device Information :
EMMC CID: 90014A48344732621101722348CD82D1
EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DB
EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: 722348CD , rev. 0x01
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 8/2015
EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51)
Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H4G2b_722348CD_20180607_103452.extcsd
EMMC Init completed.
Error: BusWidth is automatically set to 1 Bit
Scanning soft partitions
Partition table not found
Get firmware version
Firmware info not found
Setting bus width to 1 Bit
HiPower mode is ON
CMD Pullup Level: 1809 mV
CMD Active Level: 1866 mV
Backup saved: H4G2b_722348CD_20180607_103615.extcsd
Opening file: J13G.pit
Pit: J13G.pit
Entry count: 29
The size of the last section has been updated
BL_J100HXXU0AOA1_CL333157_QB3542504_REV01_user_low _ship.tar.md5
The list of files in the firmware:
spl.img
sboot.bin
sboot2.bin
param.lfs
HiPower mode is ON
CMD Pullup Level: 1810 mV
CMD Active Level: 1867 mV
Backup saved: H4G2b_722348CD_20180607_103622.extcsd
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Writing PrimaryGPT at address: 000000000000
Error writing at address: 000000000000 , error: 34 , 34 Unknown error ... Retry #1
Error writing at address: 000000000000 , error: 34 , 34 Unknown error ... Retry #2
Error writing at address: 000000000000 , error: 34 , 34 Unknown error ... Retry #3
Too many errors. Writing has been stopped
Old 06-12-2018, 13:32   #649 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 689
Smile Samsung Galaxy S Duos 3-VE (SM-G316HU) dead boot repair done
[IMG][/IMG]
Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385)
EasyJTAG Box Serial = 0900301095CE53A5
Card Serial = AAAA6B50
EasyJTAG Box Firmware = 1.62
Changelog:
Add: Vendor Sony
Setting frequence to 14 Mhz
CMD Pullup Level: 3155 mV
CMD Active Level: 2021 mV
Can't init device. Reason: CMD Timeout Error
CMD Pullup Level: 3176 mV
CMD Active Level: 3227 mV
EMMC CID: 90014A48344732621101E713B4123204
EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA
EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: E713B412 , rev. 0x01
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 3/2015
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
Backup saved: H4G2b_E713B412_20180612_132331.extcsd
Opening file: VIVALTO_SWA_4GB_20140828.pit
Pit: VIVALTO_SWA_4GB_20140828.pit
Entry count: 29
BL_G316HUJVU0ANL3_CL282615_QB3501571_REV02_user_lo w_ship.tar.md5
spl.img
sboot.bin
sboot2.bin
param.lfs
CMD Active Level: 3217 mV
Backup saved: H4G2b_E713B412_20180612_132341.extcsd
Writing BackupGPT at address: 0000E8FFBE00
Writing PIT at address: 000000004400
GPT-partitioning done
Unpacking file: spl.img
Unpacking file: sboot.bin
Unpacking file: sboot2.bin
Unpacking file: param.lfs
Partition name: BOOT
Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes
eMMC switching to ROM2
Erasing partition...
Writing partition...
Done writing partition. Write speed: 223.39 KB/s
Partition name: SBOOT
Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 559.82 KB/s
Partition name: SBOOT2
Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes
Done writing partition. Write speed: 751.05 KB/s
Partition name: PARAM
Filename: param.lfs , Offset: 000002900000 , filesize: 634880 bytes
Done writing partition. Write speed: 744.09 KB/s
Partition EFS : formatting as EXT4. Please wait ...
Formatting completed
Partition HIDDEN : formatting as EXT4. Please wait ...
Partition USERDATA : formatting as EXT4. Please wait ...
Check BOOT_PARTITION_EN for the selected vendor
All done time: [00:00:53:084]
The Following User Says Thank You to pintu_das For This Useful Post:
Old 06-12-2018, 16:48   #650 (permalink)
4star's Avatar
Member: 1596162
Sonork: 100.1616391
Thanks Meter: 56
Setting interface to EasyJtag2/E-Socket
Setting frequence to 42 Mhz
Can't init device. Reason: Command Index Error
please help
Old 06-13-2018, 17:40   #651 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 579
[IMG][/IMG]
Changelog:
Add: Vendor Sony
Entry count: 29
spl.img
sboot.bin
sboot2.bin
param.lfs
if give error after what i do
any thing need to select for boot config?
it is spd cpu so does not need i think but if it samsung ic then ?
Old 06-14-2018, 09:01   #652 (permalink)
Moderator
Deepesh Sharma's Avatar
Member: 1301233
Sonork: 100.1614172
Thanks Meter: 8,859
Swipe Konnect 5.1 Eco Stuck On Only Swipe Recover Done Change Emmc
Swipe Konnect 5.1Eco
Stuck On Swipe Logo Only
Emmc Change Samsung To Kingstone
Image-1
Log
Sucessfully Recovered Set
My First Opration Emmc Samsung TO Kingstone
__________________
Always Follow Forum's Rules
Save Forum Space From Useless Size Of Image Visit Here
Do Not Send Me Pm For Any File Request' Use Forum For It.
Use Thanks Button's For Avoid Spam.
Wbr-
Deepesh Sharma
The Following 2 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 06-20-2018, 07:57   #653 (permalink)
Moderator
Member: 1301233
Sonork: 100.1614172
Thanks Meter: 8,859
lyf jio keypaid f81e stuck on logo solve wit change emmc
Lyf Keypaid Mobile
F81e
Stuck On Logo Solve
Change Emmc Skhynix To Kingstone
Log
REcover Done
__________________
Wbr-
Deepesh Sharma
The Following 4 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 06-21-2018, 00:18   #654 (permalink)
Member: 1520712
Thanks Meter: 3
please add sony E2303 i have one and after identify with setoolbox2 says that boot1 is mising.
i need isp solution
thanks in advance and for your time!!!!
Page generated in 0.27550 seconds with 8 queries
