Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 07-04-2019, 06:21   #691 (permalink)
Member: 2442914
Thanks Meter: 8
16.1.9.........................................:co nfused:
Old 07-05-2019, 06:14   #692 (permalink)
4star's Avatar
Member: 1596162
Sonork: 100.1616391
Thanks Meter: 78
Easy jtag new version 3.6.1.9
https://groundslife.com/FNtVX
Old Yesterday, 16:33   #693 (permalink)
Member: 628369
Sonork: 100.1609794
Thanks Meter: 42
Vivo Y95 pattern frp successfully done with easyjtag
Z3X EasyJtag Software ver. 3.5.0.1
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 0C00200394B8F938, ,FW Ver.: 01.63
CMD Pullup Level:2072 mV
CMD Active Level:2640 mV
Box IO Level:2800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 90014A484347386134A24D552014A508
eMMC CSD : D02701328F5903FFFFFFFFEF8A400026
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 10/2018 Rev.0xA2
eMMC NAME: HCG8a4 , S/N: 1297424404
eMMC NAME (HEX): 484347386134
EMMC ROM1 (Main User Data) Capacity: 59640 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 63482 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: HCG8a4_1297424404_20190715_2005.extcsd
Done.
Running:Reset PIN/PASS/GESTURE Locks
CMD Pullup Level:2052 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
EMMC ROM1 (Main User Data) Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes
EMMC RPMB is not yet programmed (clear) or NO Error
Partition table scan:
GPT: present
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB
Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
First usable sector: 34
Last usable sector: 122142686
Partition info successfully found
------ Android information ------
Detected LINUX(Android) USERDATA : 0x01B3282000 (51.442GB)
Mount EXT4 fs...
Unable to mount USER , code : 95
Done.
CMD Pullup Level:2062 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
GPT: present
Detected LINUX(Android) CACHE : 0x018B000000 (256.0MB)
Erasing...
Done.
Erasing...
Done.
Done.
Running:Format FRP Partition...
CMD Active Level:2382 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
GPT: present
Formatting FRP...
Detected LINUX(Android) CACHE : 0x018B000000 (256.0MB) , formatting...
Detected LINUX(Android) CONFIG : 0x019D180000 (32.0KB) formatting...
Detected LINUX(Android) USERDATA : 0x01B3282000 (51.442GB) , formatting...
Done.
Done.
Page generated in 0.12865 seconds with 8 queries
