Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 03-10-2020, 07:06   #721 (permalink)
jamohaki's Avatar
Member: 83397
Thanks Meter: 138
Originally Posted by .::the rock::. View Post
oppo a1k cph1923
pattern unlock
easy jtag
info or unlock log
z3x easyjtag software ver. 3.6.2.3
loading emmc gen1 firmware... Io: 3300 mv
box s/n: 0707031f7aa05fbd, ,fw ver.: 01.63
cmd pullup level:2052 mv
cmd active level:2970 mv
box io level:3300 mv
clk rate:21000 khz
bus width:1bit,sdr
hipower mode is on!
---------- emmc device information ----------
emmc cid : 150100514436334d4203781ede2fc592
emmc csd : D02701320f5903fff6dbffef8e40400c
emmc manufacturer id: 0015 , oem id: 0100
emmc date: 12/2018  rev.0x3
emmc name: Qd63mb , s/n: 2015288879
emmc name (hex): 514436334d42
emmc rom1 (main user data)   capacity: 29820 mb
emmc rom2 (boot partition 1) capacity: 4096 kb
emmc rom3 (boot partition 2) capacity: 4096 kb
emmc rpmb (replay protected memory block) capacity: 16384 kb
emmc rpmb is programmed and written 4441 times
emmc permanent write protection: No
emmc temporary write protection: No
emmc password locked: No
  extended csd rev 1.8 (mmc 5.1)
boot configuration [partition_config: 0x48] boot from:rom2 (boot partition 1)
boot bus config [177]: 0x02 , width 8bits  , partition config [179]: 0x48.
H/w reset function [rst_n_function]: 0x01
high-capacity wp group size [hc_wp_grp_size: 0x00004000]
partitioning support [partitioning_support]: 0x07
 device support partitioning feature
 device can have enhanced tech.
Partitioning setting [partition_setting_completed]: 0x00
backup saved: Qd63mb_2015288879_20200307_1514.extcsd
found valid gpt with protective mbr; using gpt.
Real (hardware) disk/image size: 3a3e000 sectors 29.1 gib
soft (partitioned) disk/image size: 3a3dfbc sectors 29.1 gib
disk identifier (guid): 00000000-0000-0000-0000-000000000000
logical sector size: 0x200  bytes ,first/last usable sector: 34,61071326
partition info successfully found
------ android information ------
detected linux(android) system : 0x0074800000 (4.687gb)
short ext fs info:
block size: 4.0kb
inode size: 256
inodes: 302512
short android info:
Unable to read prop.plist , code : 2
backup saved: Buildprop_20200307_1514.txt
detected userdata userdata : 0x01bb800000 (22.132gb)
unable to mount userdata , code : 95
userdata superblock contents::
 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000     ................................;
done.
Running:format frp partition...
Z3x easyjtag software ver. 3.6.2.3
cmd pullup level:2041 mv
cmd active level:3021 mv
clk rate:21000 khz
bus width:1bit,sdr
hipower mode is on!
emmc rom1 (main user data)   capacity: 29820 mb , 0x3a3e000 pages , 0x747c00000 bytes
formatting frp...
Detected linux(android) frp : 0x000be88000 (1.0mb) formatting...
Done.
Detected linux(android) cache : 0x01a0800000 (432.0mb) , formatting...
Done.
Detected linux(android) userdata : 0x01bb800000 (22.132gb) , formatting...
Done.
Done.
Done.
thank you for the superb logs
The Following User Says Thank You to jamohaki For This Useful Post:
Old 03-13-2020, 07:13   #722 (permalink)
.::THE ROCK::.'s Avatar
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 1,969
Realme c1 cph1811 pattern unlock easy jtag
REALME C1 CPH1811
PATTERN UNLOCK
EASY JTAG
INFO OR UNLOCK LOGS
Z3X EasyJtag Software ver. 3.6.2.3
Loading eMMC GEN1 Firmware... IO: 3300 mV
Box S/N: 0707031F7AA05FBD, ,FW Ver.: 01.63
CMD Pullup Level:2093 mV
CMD Active Level:2547 mV
Box IO Level:3300 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 150100514536334D42064277077F85EE
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 08/2018  Rev.0x6
eMMC NAME: QE63MB , S/N: 1115096959
eMMC NAME (HEX): 514536334D42
IC Name: Samsung , KMQE60013M-B318/16GB @BGA221
EMMC ROM1 (Main User Data)   Capacity: 14910 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 83630 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
  Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit  , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
 Device support partitioning feature
 Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QE63MB_1115096959_20200312_2201.extcsd
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB
Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200  bytes ,First/Last usable sector: 34,30535646
Partition info successfully found
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0042800000 (3.352GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 216432
Short Android info:
Backup saved: BuildProp_20200312_2201.txt
Detected USERDATA USERDATA : 0x015B800000 (9.129GB)
Unable to mount USERDATA , code : 95
Userdata Superblock contents::
 F4B54915 9BE56FE5 05B758EA 747E07C1 E1F60180 3AAA29BB 3E5A5720 36A4CD2C     I.o.Xt~...:)>ZW 6,;
 AD6A5F8D E7A5D1B6 5E176140 C4BC927B 993F0B8C A52ED75F C15E4C35 DDA92C6E     *j_.Ѷ^[email protected]ļ{.?.._^L5ݩ,n;
 A55BA401 49163CA8 67996E54 AA8F03A6 35F76CE7 67DBE2CC 7C43E92F 1DFBC463     [.I.<g.nT..5lg|C/.c;
 5952B4E7 C1B08BA8 5D70BC7C 8F30D840 7E5CC19D 5609162F 91C94161 0A0FFE8E     YR]p|.0@~\.V    ./Aa..;
 970D7C78 131C6037 A13279AE 499D16F4 77549AFE 7B061B59 653FB149 AE35A585     .|x..`72yI..wT{..Ye?I5;
 320ED2EB 20B5AD09 5B42983C BD926B35 9F2B4BD6 8B3EE764 FCE35DF9 AD8EF77C     2. *    [B.<k5+K֋>d]*|;
 060A7747 BAEAC061 BF26A73A B5F703DC EBEAAEF5 CEB98A10 1CE91128 D263BEB3     ..wGa&:.ι...(c;
 CCE56DC5 D9C0D633 D38093AB 017301BF 178C4891 6470C8A2 74FB5E73 442F3DB7     m3..s..HdpȢt^sD/=;
Done.
Running:Format FRP Partition...
CMD Pullup Level:2103 mV
CMD Active Level:3042 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
EMMC ROM1 (Main User Data)   Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes
Formatting FRP...
Detected LINUX(Android) CACHE : 0x001F300000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) CONFIG : 0x002F480000 (32.0KB) formatting...
Done.
Detected LINUX(Android) USERDATA : 0x015B800000 (9.129GB) , formatting...
Done.
Done.
Done.
Old 03-16-2020, 07:42   #723 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 1,969
Oppo a3s pattern unlock easy jtag
OPPO A3S PATTERN UNLOCK EASY JTAG
INFO OR UNLOCK LOGS
CMD Pullup Level:2083 mV
CMD Active Level:3104 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
eMMC CID : 150100514536334D420388C60782251A
eMMC Date: 02/2018  Rev.0x3
eMMC NAME: QE63MB , S/N: 2294679426
EMMC RPMB is programmed and written 120380 times
Backup saved: QE63MB_2294679426_20200316_1153.extcsd
Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 216432
Short Android info:
Build ID:  OPM1.171019.026
Release Base ID:  8.1.0
Security Path:  2019-07-05
Architecture ABI:  arm64-v8a
Device manufacturer:  OPPO
Build Description:  msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20190717.054518 release-keys
Backup saved: BuildProp_20200316_1153.txt
Detected USERDATA USERDATA : 0x0158000000 (9.184GB)
 1E56A73E ACA60293 4887AC8D C466DC20 1BEFBF3A 652A67E9 6C9BA44D 62A31918     .V>.H.f .:e*glMb..;
 5971B3F2 EBC30286 ACB7ACDD E44478E8 D800E57A B41837FD 380106E3 B066AA38     Yq.Dx.z.78..f8;
 A5C9C7FA 23FDA5F0 1C2EB9DD AF8BA529 5C7A42E2 AA609C88 77BA096A D03AAD83     #..ݯ)\zB`.w    j:*;
 43BC6585 634053A6 F6C91753 D646FB63 FCF5C947 ECFDAE42 47218097 FD605F52     Ce[email protected].SFcGBG!.`_R;
 083C0832 CB20690C B161CC54 78E97760 47CBD9BC 321CBA00 6F6E2597 83C93526     .<.2 i.aTxw`Gټ2..on%5&;
 F4B53644 17AB6F70 54C0383F 266EC532 FAFC9E2F 5B00A36A F03E50D7 EB2F8F89     6D.opT8?&n2/[.j>P/.;
 3AFDCD5D 3140E08F 8FE53E78 CEE5299C F807BDCF 04E96B2D 17DCAA0E 430CA940     :][email protected]..>x)..k-.ܪ.C.@;
 BAA11FD8 F8F58278 7ECA2355 3C2F0982 7DD70884 95AF461C 02993DA5 47F0DFFD     .x~#U</    }.F...=G;
Done.
CMD Active Level:3093 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
Formatting FRP...
Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) CONFIG : 0x002FC80000 (32.0KB) formatting...
Done.
Detected LINUX(Android) USERDATA : 0x0158000000 (9.184GB) , formatting...
Done.
Done.
Done.
Old 03-17-2020, 02:40   #724 (permalink)
Member: 1766019
Thanks Meter: 6
oppo a1k cph1923 Remove passwork done
Old 03-20-2020, 14:59   #725 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 1,969
Realme 2 pro rmx1801 pattern unlock easy jtag
REALME 2 PRO RMX1801 PATTERN UNLOCK
EASY JTAG
INFO OR UNLOCK LOGS
CMD Pullup Level:2041 mV
CMD Active Level:2866 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
eMMC CID : 150100444836444142025F74C224A5A2
eMMC Date: 10/2018  Rev.0x2
eMMC NAME: DH6DAB , S/N: 1601487396
eMMC NAME (HEX): 444836444142
EMMC ROM1 (Main User Data)   Capacity: 59640 MB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 19302 times
Backup saved: DH6DAB_1601487396_20200320_1758.extcsd
Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB
Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB
Disk identifier (GUID): E3048BDF-6E09-4A80-1CB0-70A72E4FD7BB
Logical sector size: 0x200  bytes ,First/Last usable sector: 34,122142686
Detected LINUX(Android) SYSTEM : 0x0041000000 (5.250GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 339360
Short Android info:
Backup saved: BuildProp_20200320_1758.txt
Detected USERDATA USERDATA : 0x0201800000 (50.217GB)
 7A1F08A2 14B333F0 BB684CC3 E95AC216 D96B2A4D 8489AD28 90CB13DB CC0FB9B1     z...3hLZ.k*M*(...;
 9F9AE415 3BFA4A3C FF9ED4B1 B2958C7F 08C824E4 0C796431 C38C690A 14258DAB     .;J<Ա..$.yd1Ìi..%.;
 AFCC6B78 A44A6543 8FC728B2 3CDC6362 96C44762 10149727 BB8731AB 07EF2C73     kxJeC.(<cbGb..'1.,s;
 6EDCC001 C42941D9 001A28BB 788E7F64 0D5C0213 00EED537 5F5257C5 DC1FA78E     n.)A..(x.d.\...7_RW.;
 A6550B8E 17DBB8A7 5181B33C 7021ECE6 2BE26B55 5723A10B 78455930 5B07D180     U..۸Q.<p!+kUW#.xEY0[..;
 5F6AB38B 44B13836 D0C621AA 6A401B73 741CC2D6 27AE9420 293E5518 877168ED     _jD86![email protected]' )>U.qh;
 1978A5E9 3E138D46 E191E9CA 2E3D79E7 BC101564 8C22BFFD F2BD9E9B 052218E8     .x>..F.=y..d"򽞛.".;
 BB59147B 5DDA4FD5 1D89F6D1 B14E1995 DCFB81C8 92B6DD91 49B4B329 41D1736F     Y.{]O.ѱN..ȒݑI)Aso;
Done.
CMD Active Level:2877 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
EMMC ROM1 (Main User Data)   Capacity: 59640 MB , 0x747C000 pages , 0xE8F800000 bytes
Formatting FRP...
Detected LINUX(Android) FRP : 0x0021383000 (512.0KB) formatting...
Done.
Detected LINUX(Android) CACHE : 0x0031000000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) USERDATA : 0x0201800000 (50.217GB) , formatting...
Done.
Done.
Done.
forensic anthropology crime
Old 03-21-2020, 15:54   #726 (permalink)
Member: 1617868
Sonork: 100.1625996
Thanks Meter: 1,969
Oppo a3s pattern unlock no data format media file easy jtag
OPPO A3S
PATTERN UNLOCK
NO DATA FORMAT MEDIA FILE
EASY JTAG
INFO OR UNLOCK LOGS CLICK>>>> RESET OPPO
CMD Pullup Level:2052 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
eMMC CID : 90014A484247346132A5C702A8636524
eMMC CSD : D02701328F5903FFFFFFFFE78A400016
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 06/2018  Rev.0xA5
eMMC NAME: HBG4a2 , S/N: 3338840163
eMMC NAME (HEX): 484247346132
EMMC ROM1 (Main User Data)   Capacity: 29820 MB
EMMC RPMB is programmed and written 52252 times
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000]
Backup saved: HBG4a2_3338840163_20200321_1931.extcsd
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Logical sector size: 0x200  bytes ,First/Last usable sector: 34,61071326
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 216432
Short Android info:
Security Path:  2020-01-05
Build Description:  msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20191225.101315 release-keys
Backup saved: BuildProp_20200321_1931.txt
Detected USERDATA USERDATA : 0x0158000000 (23.745GB)
 7724D89D 3B28A043 47AEA020 7E12E12D C2497D39 76E0D20D A8517811 9D49E4D2     w$.;( CG  ~.-I}9v.Qx..I;
 58D12DBC FF14A7FE E73EC41E A4CD2694 4A66B7FB B336CAD7 4198962A A79005B9     X-.>.&Jf6A.*..;
 C6AA6E36 FC457C1D F78CC2AA E03289A7 B54FCF48 640179EB 5141BC41 33BFE980     ƪn6E|.ª2OHd.yQAA3.;
 E9DBE13D 4132A2FC 4CEAAB17 8C0A1E29 734CF947 C657A152 68F7EA57 99046668     =A2L...)sLGWRhW..fh;
 15865EA1 05000976 1A0295CB 7804C9BB 4ACF69CD 5B901233 04CF391D E9DA8D5C     .^..    v..x.ɻJi[..3.9..\;
 1E2DDE85 CAC62807 D3EA73CB 9FFCB06E 9ADAE4AA CF0BBFA4 65A5522F 4FA61264     .-ޅ(.s˟n.eR/O.d;
 8B75C85D 74CF8584 9E622CBD 82E21D39 3A837AC4 5BB1F372 74D07D0C 0BAA4AA3     u]tυb,.9:z[rt}..J;
 ACDEBA85 33FFA868 FEE0F18F 8AEEFC35 D800A503 70DC4253 A74021FD 7F8B450D     ޺3h.5..pBS@!.E.;
Done.
CMD Active Level:3083 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
EMMC ROM1 (Main User Data)   Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes
Writing Recovery Command to MISC (35)
Done.
free image uploader
Page generated in 0.38107 seconds with 8 queries
