Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 11-24-2012, 15:24   #1 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Post here succesfull operations with Easy-Jtag:
Post here sucessfull operation with Easy-Jtag:
The Following 2 Users Say Thank You to blang For This Useful Post:
Old 03-01-2013, 09:44   #2 (permalink)
Member: 1397329
Test search pinout and connect S5230...
Box Working Mode: JTAG Box.
Start Z3X Jtag Pin Finder...
Successefuly connected to box on COM706
Waiting for box reset...
Box S/N: 00000000********
Box Working Mode: JTAG Pin Finder.
Stage 1: Search TCK / TMS / TDI / TDO...
Try to get IDCODE...
JTAG Pinout Found: TCK: Pin 11 / TMS: Pin 1 / TDI: Pin 9 / TDO: Pin 7
Found device with IDCODE=0x7926F0F
Stage 2: Search TRST...
TRST Pin Found: TRST: Pin 13
Box S/N: 0D0DFF182DBE7A08
Box Working Mode: JTAG Box.	10:38:47
For support and updates visit http://easy-jtag.com
I/O Level set to : 3000 mV
Box S/N: 0D0D******,SW Ver.: 01.42
Connecting to Target...
JTAG device: BCM2133
CPU IDCODE detected: 0x07926F0F
Manufacturer: 0x787, Part: 0x7926, Version: 0x0
Halting CPU...
Starting target communication...
Detecting nand memory parameters of bank (0) ...
NAND flash device ID:00EC:00BA 'NAND 256MiB 1.8V 16-bit (Samsung)' found
NAND geometry: Blocks:00000800, Page size:2048 bytes , Block size:64 pages
Old 03-01-2013, 11:10   #3 (permalink)
Member: 1397329
S5230 easy repair boot...
Checking repair data...
Box S/N: 0D0D******* ,SW Ver.: 01.42
Halting CPU...
NAND Writing BOOT...
NAND Write OK! Wrote up to offset 0x00080000 in 4,921875s (107,276 KiB/s)
Repair DONE! Restarting phone...
All Done.
Box are disconnected!
Old 03-01-2013, 14:28   #4 (permalink)
NoName®'s Avatar
Member: 129885
706SC Connection/Dump with UJK clip SAM-B ;-)
Old 03-01-2013, 18:41   #5 (permalink)
cycofcgb's Avatar
Member: 1388004
Sonork: 100.1637034
so when ? before the end of this year ?
Old 03-02-2013, 22:54   #6 (permalink)
Member: 1397329
Programming s5830i
Finder
Successefuly connected to box on COM68
Box S/N: 000000000*******
JTAG Pinout Found: TCK: Pin 11 / TMS: Pin 3 / TDI: Pin 9 / TDO: Pin 13
CPU IDCODE : 0x07B3617F Mfg.: 0x0bf, Part: 0x7b36, Ver.: 0x0
CPU Manufacturer: SST/Broadcom , CPU Name: BCM21553
Box S/N: **********
Dump 64Mb
Box S/N: **************,SW Ver.: 01.42
Warn: JTAG device: BCM21553
Warn: CPU Manufacturer: SST/Broadcom , CPU Name: BCM21553
Halting CPU...
Initialize hardware...
Detecting nand memory parameters ...
NAND flash device ID:00EC:0050 'NAND 4GiB 1.8V 16-bit (Samsung)' found
NAND geometry: Blocks:00002000, Page size:4096 bytes , Block size:64 pages
Accesing logical device region # 0
Working block has an 256 pages , allocating 135168 bytes of memory
Reading 04000000 bytes from NAND adress 00000000...
Dumped 69206016 bytes in 458,401215s (147,434 KiB/s) OK.
The Following User Says Thank You to Dimidrolus For This Useful Post:
Old 03-08-2013, 15:10   #7 (permalink)
biswajit74's Avatar
Member: 900306
Cofused
Were to buy easy jtag................
When u lonched easy jtag
Old 03-29-2013, 17:37   #8 (permalink)
Sniper_04's Avatar
Member: 704097
Sonork: 100.1607742
Can i test your jtag box?LOL
I want to try it!!!
Old 04-12-2013, 21:09   #9 (permalink)
Member: 1397329
i917 write fullflash succesfully done
EasyJtag Suite ver. 1.0.18.2 started.
I/O Level set to : 2600 mV
Box S/N: ********** ,SW Ver.: 01.42
JTAG device: QSD8250.
CPU IDCODE : 0x1BA000E1 Mfg.: 0x070, Part: 0xba00, Ver.: 0x1
CPU Manufacturer: QUALCOMM , CPU Name: QSD8250 SLAVE
CPU IDCODE : 0x202400E1 Mfg.: 0x070, Part: 0x0240, Ver.: 0x2
NAND flash device ID:002C:00B3 'NAND 1GiB 1.8V 16-bit (Micron)' found
NAND geometry: Blocks:00002000, Page size:2048 bytes , Block size:64 pages
Writing NAND from file...D:\1GB_Z3X.bin
Lock file not found D:/1GB_Z3X.lock
NAND Write OK! Wrote up to offset 0x40000000 in 3846.583008s (281.118 KiB/s)
Old 05-04-2013, 04:08   #10 (permalink)
rayvee's Avatar
Member: 1079935
Do we need to 1st buy box or can we use like z3x samsung box to beta test?
Old 05-04-2013, 04:36   #11 (permalink)
TestCard17's Avatar
Member: 1357650
Sonork: 100.1611843
can i aslo test your box willing to try Beta test here
bR
Old 05-10-2013, 17:47   #12 (permalink)
Yashbanswara's Avatar
Member: 1147254
Sonork: 100.1620677
Unlocking & Flashing Devices :: Z3x Easy JTAG with 3 Cables - iCables.in
Old 05-11-2013, 13:41   #13 (permalink)
NoName®'s Avatar
Member: 129885
I want to try it!!!
So go Buy and try ;-)
Old 05-12-2013, 10:51   #14 (permalink)
Member: 507223
May be still need for speed !
Do JTAG job will cost so much time !
DO full flash ,oh dear ,a big job !
Old 05-14-2013, 09:07   #15 (permalink)
Multi-COM's Avatar
Member: 43823
I9100 sucesfull JOB done using Easy JTAG
EasyJtag Suite ver. 1.0.24.0 started.
Successefuly connected to box on COM48
Box S/N: XXXXXXXXXXXXXXXXx, ,FW Ver.: 01.44
Z3X Card Serial : XXXXXXXXX
Z3X Card Version : 22
Z3X Card Activation [JTAG] : 1
Resources ver. : MainRC ver.OCD040Z001 (C)2012 z3x-team.com
Loading repair file: 'C:\Program Files\Z3X\EASYJTAG\Repair Files\Samsung GT-i9100.rcp'
Repair File ver. : Easy Repair for Mfg: SAMSUNG Model: GT-I9100, Ver.: 1.00
Easy-Repair file load OK!
Using EasyRepair Mode...
Initialising: SAMSUNG GT-I9100 Config ver.:1.00
I/O Level set to : 2800 mV
Box S/N: 10100007B9800571 ,FW Ver.: 01.44
JTAG device: S5PC210
CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4
CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9
Halting CPU...
Init target ...
Detecting emmc memory parameters of bank (0) ...
EMMC #0 : ID : 0x00010015 Name : VYL00M Size : 16 GB
EMMC #1 : ID : 0x00010015 Name : VYL00M Size : 524 kB
eMMC flash device(s) found, Device ID : 0x00150001
NAND Writing GPT...
eMMC Write OK! Elapsed time: 9.015625s (454.322 KiB/s)
NAND Writing SBL1...
eMMC Write OK! Elapsed time: 12.234375s (104.623 KiB/s)
NAND Writing SBL2...
eMMC Write OK! Elapsed time: 12.046875s (106.252 KiB/s)
NAND Writing PARAM...
eMMC Write OK! Elapsed time: 27.609375s (296.711 KiB/s)
NAND Writing ROM2...
eMMC Write OK! Elapsed time: 1.421875s (360.088 KiB/s)
All Done.
The Following 4 Users Say Thank You to Multi-COM For This Useful Post:
Page generated in 0.21880 seconds with 10 queries
