03-07-2020, 10:35 | #2 (permalink) |
Freak Poster Join Date: Jun 2013 Location: mexico
Member: 1958094 Status: Offline Thanks Meter: 57 | Z3X EasyJtag Software ver. 3.6.2.3 UFS Socket Info. Serial: 0123C74841FBxxxxxx Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 11.01.20 Identify UFS Chip. UFS Chip Voltage: High Check ISP connect. Calibrate ISP for BGA153. VCC: 3303mV VCCQ2: 1932mV Chip Info: Manufacturer: SAMSUNG ProductName: KLUDG4U1EA-B0C1 SerialNumber: 0x181CC5EC860D7EE7E33A1379F281533554504430305931 OemID: SAMSUNG_OEM_ID UFS Version: 2.1 Maximum Number of LUs: 8 Number of LUs found: 5 LUN 0: Block size: 0x1000 Size: 0x1DCA000000 / 119,160,000,000B / 119GB LUN 1 (Boot A): Block size: 0x1000 Size: 0x400000 / 0,004,000,000B / 4MB LUN 2 (Boot B): Block size: 0x1000 Size: 0x400000 / 0,004,000,000B / 4MB LUN 3: Block size: 0x1000 Size: 0x800000 / 0,008,000,000B / 8MB LUN 4: Block size: 0x1000 Size: 0x800000 / 0,008,000,000B / 8MB Number of W-LUs found: 1 W-LUN 0xC4 (REPORT LUNS): Block size: 0x100 Size: 0x1000000 / 0,016,000,000B / 16MB Full size: 0x1DCC800000 / 119,200,000,000B / 119GB Health: Device life time method A: 0%-10% Device life time method B: 0%-10% Used less then 80% of reserved blocks Chip config is OTP Checking LU for partitioning LUN0 Have 21 partitions LUN1 Have no partitions LUN2 Have no partitions LUN3 Have 1 partitions LUN4 Have no partitions ------ Detected 22 partitions ------ LUN0 (BOTA0) [0x400000 0x400000] Size: 4.0MB LUN0 (BOTA1) [0x800000 0x800000] Size: 8.0MB LUN0 (EFS) [0x1000000 0x1400000] Size: 20.0MB LUN0 (PARAM) [0x2400000 0x800000] Size: 8.0MB LUN0 (UP_PARAM) [0x2c00000 0x800000] Size: 8.0MB LUN0 (BOTA2) [0x3400000 0x800000] Size: 8.0MB LUN0 (BOOT) [0x3c00000 0x2800000] Size: 40.0MB LUN0 (RECOVERY) [0x6400000 0x2e00000] Size: 46.0MB LUN0 (RADIO) [0x9200000 0x2a00000] Size: 42.0MB LUN0 (NAD_REFER) [0xbc00000 0x100000] Size: 1.0MB LUN0 (PERSISTENT) [0xbd00000 0x80000] Size: 512.0KB LUN0 (MISC) [0xbd80000 0x100000] Size: 1.0MB LUN0 (STEADY) [0xbe80000 0x400000] Size: 4.0MB LUN0 (DQMDBG) [0xc280000 0x1000000] Size: 16.0MB LUN0 (SYSTEM) [0xd280000 0x140000000] Size: 5.0GB LUN0 (CACHE) [0x14d280000 0x25800000] Size: 600.0MB LUN0 (HIDDEN) [0x172a80000 0xa00000] Size: 10.0MB LUN0 (OMR) [0x173480000 0x3200000] Size: 50.0MB LUN0 (CP_DEBUG) [0x176680000 0x500000] Size: 5.0MB LUN0 (NAD_FW) [0x176b80000 0x1400000] Size: 20.0MB LUN0 (USERDATA) [0x177f80000 0x1c51c00000] Size: 113.277GB LUN3 (CPEFS) [0x6000 0x600000] Size: 6.0MB ------------------------------------ Done. UFS Socket Info. Serial: 0123C74841FBxxxxxxx Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 11.01.20 Can't open link, Code: -56, Reason: BOX: Chip not connected Z3X EasyJtag Software ver. 3.6.2.3 UFS Socket Info. Serial: 0123C74841FBxxxxxx Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 11.01.20 Can't open link, Code: -56, Reason: BOX: Chip not connected Done. |
03-07-2020, 21:42 | #3 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | I can not help you with this. I did not have this adapter, I did not test it. and did not encounter such problems. you need to contact @Blang, @NoName |
03-09-2020, 07:00 | #5 (permalink) |
Member: 1958094 Status: Offline Thanks Meter: 57 | Identify UFS Chip. UFS Chip Voltage: High Check ISP connect. Socket already calibrate for BGA254. VCC: 3302mV VCCQ2: 1931mV Chip Info: Manufacturer: SAMSUNG ProductName: KM2V7001CM-B706 SerialNumber: 0x37DB8A94F61C7EC824756B09E38158423139374134514B32 OemID: SAMSUNG_OEM_ID UFS Version: 2.1 Maximum Number of LUs: 8 Number of LUs found: 4 LUN 0: Block size: 0x1000 Size: 0x1DC5C00000 / 119,092,000,000B / 119GB LUN 1 (Boot A): Block size: 0x1000 Size: 0x800000 / 0,008,000,000B / 8MB LUN 2 (Boot B): Block size: 0x1000 Size: 0x800000 / 0,008,000,000B / 8MB LUN 3: Block size: 0x1000 Size: 0x3C00000 / 0,060,000,000B / 60MB Number of W-LUs found: 1 W-LUN 0xC4 (REPORT LUNS): Block size: 0x100 Size: 0x1000000 / 0,016,000,000B / 16MB Full size: 0x1DCC800000 / 119,200,000,000B / 119GB Health: Device life time method A: 0%-10% Device life time method B: 0%-10% Used less then 80% of reserved blocks Chip config is OTP Checking LU for partitioning LUN0 Have 29 partitions LUN1 Have 2 partitions LUN2 Have 2 partitions LUN3 Have 28 partitions ------ Detected 61 partitions ------ LUN0 (MODEMST1) [0x108000 0x200000] Size: 2.0MB LUN0 (MODEMST2) [0x308000 0x200000] Size: 2.0MB LUN0 (FSC) [0x508000 0x1000] Size: 4.0KB LUN0 (SSD) [0x509000 0x2000] Size: 8.0KB LUN0 (PERSIST) [0x50b000 0x2000000] Size: 32.0MB LUN0 (EFS) [0x250b000 0x1400000] Size: 20.0MB LUN0 (PARAM) [0x390b000 0xc00000] Size: 12.0MB LUN0 (DEBUG) [0x450b000 0xa00000] Size: 10.0MB LUN0 (SEC_EFS) [0x4f0b000 0x1400000] Size: 20.0MB LUN0 (MISC) [0x630b000 0x100000] Size: 1.0MB LUN0 (KEYSTORE) [0x640b000 0x80000] Size: 512.0KB LUN0 (BOTA) [0x648b000 0x2800000] Size: 40.0MB LUN0 (FOTA) [0x8c8b000 0x1500000] Size: 21.0MB LUN0 (PERSISTENT) [0xa18b000 0x80000] Size: 512.0KB LUN0 (STEADY) [0xa20b000 0x400000] Size: 4.0MB LUN0 (DQMDBG) [0xa60b000 0x1000000] Size: 16.0MB LUN0 (APNHLOS) [0xb60b000 0x5f00000] Size: 95.0MB LUN0 (MODEM) [0x1150b000 0x5500000] Size: 85.0MB LUN0 (DSP) [0x16a0b000 0x2000000] Size: 32.0MB LUN0 (DTBO) [0x18a0b000 0xa00000] Size: 10.0MB LUN0 (BOOT) [0x1940b000 0x4000000] Size: 64.0MB LUN0 (RECOVERY) [0x1d40b000 0x4efd000] Size: 78.988MB LUN0 (SYSTEM) [0x22308000 0x157c00000] Size: 5.371GB LUN0 (VENDOR) [0x179f08000 0x3e800000] Size: 1000.0MB LUN0 (PRODUCT) [0x1b8708000 0x25800000] Size: 600.0MB LUN0 (CACHE) [0x1ddf08000 0x19000000] Size: 400.0MB LUN0 (HIDDEN) [0x1f6f08000 0xa00000] Size: 10.0MB LUN0 (OMR) [0x1f7908000 0x3200000] Size: 50.0MB LUN0 (USERDATA) [0x1fab08000 0x1bcb0d7000] Size: 111.171GB LUN1 (XBL) [0x6000 0x400000] Size: 4.0MB LUN1 (XBL_CONFIG) [0x406000 0x3d9000] Size: 3.847MB LUN2 (XBL) [0x6000 0x400000] Size: 4.0MB LUN2 (XBL_CONFIG) [0x406000 0x3d9000] Size: 3.847MB LUN3 (DDR) [0x6000 0x100000] Size: 1.0MB LUN3 (TZ) [0x106000 0x400000] Size: 4.0MB LUN3 (FSG) [0x506000 0x200000] Size: 2.0MB LUN3 (AOP) [0x706000 0x80000] Size: 512.0KB LUN3 (ABL) [0x786000 0x400000] Size: 4.0MB LUN3 (DEVINFO) [0xb86000 0x1000] Size: 4.0KB LUN3 (BLUETOOTH) [0xb87000 0x100000] Size: 1.0MB LUN3 (BKSECAPP) [0xc87000 0x60000] Size: 384.0KB LUN3 (KEYMASTER) [0xce7000 0x80000] Size: 512.0KB LUN3 (CMNLIB) [0xd67000 0x80000] Size: 512.0KB LUN3 (CMNLIB64) [0xde7000 0x80000] Size: 512.0KB LUN3 (APDP) [0xe67000 0x40000] Size: 256.0KB LUN3 (MSADP) [0xea7000 0x40000] Size: 256.0KB LUN3 (DPO) [0xee7000 0x1000] Size: 4.0KB LUN3 (LIMITS) [0xee8000 0x1000] Size: 4.0KB LUN3 (LOGFS) [0xee9000 0x800000] Size: 8.0MB LUN3 (DEVCFG) [0x16e9000 0x20000] Size: 128.0KB LUN3 (STORSEC) [0x1709000 0x80000] Size: 512.0KB LUN3 (VBMETA) [0x1789000 0x10000] Size: 64.0KB LUN3 (QUPFW) [0x1799000 0x20000] Size: 128.0KB LUN3 (SECDATA) [0x17b9000 0x8000] Size: 32.0KB LUN3 (VK) [0x17c1000 0x200000] Size: 2.0MB LUN3 (BTD) [0x19c1000 0x200000] Size: 2.0MB LUN3 (HYP) [0x1bc1000 0x100000] Size: 1.0MB LUN3 (PMIC) [0x1cc1000 0x80000] Size: 512.0KB LUN3 (EM) [0x1d41000 0x200000] Size: 2.0MB LUN3 (UEFISECAPP) [0x1f41000 0x200000] Size: 2.0MB LUN3 (PAD) [0x2141000 0x1a9e000] Size: 26.617MB ------------------------------------ Selected UFS Interface Done. Failed to load partition |
