Old 09-01-2017, 15:27   #1 (permalink)
Member: 237150
Thanks Meter: 2
Problem Easy-jtag update card
Z3x Easy Jtag Card Update Issue
Recently i have purchased Z3x Easy Jtag from reseller GsmSolution
when trying to update not allowed (from 1.5 to 2.2)
Card SN: AAFXXFXX
Card Type:New Top Card
Card Version:1.5
Reseller:GSM Sources
Card Activated:01/09/2017
WHEN TRY TO UPGRADE SHOWS " Fail: max 3 unsuccessful attemp per day. /Too many attempts can damage your card AAFXXFXX)
Also be shure that correct card selected.
Please advice and help to solve
The Following User Says Thank You to shine71 For This Useful Post:
Old 09-01-2017, 23:17   #2 (permalink)
Member: 237150
Thanks Meter: 2
I tried now to update the card but now it says server not found. What's happening? I have another Z3X box enabled for samsung and LG and I've never had any problems. Who helps me?
Old 09-02-2017, 08:58   #3 (permalink)
Member: 237150
Thanks Meter: 2
Can not anyone help me? ..........
Old 09-02-2017, 11:48   #4 (permalink)
Member: 237150
Thanks Meter: 2
But is there a valid support for this box stage ????? over 90 views and no one to give me answers? I thought the Z3X team was one of the most valid but I have but I must think badly
Old 09-02-2017, 16:38   #5 (permalink)
Member: 1569669
Thanks Meter: 257
Hi,
Please, try to update Easy-Jtag card in the external card reader.
In some cases, card can stuck in some types of card readers, included box internal card reader.
We are trying to figure out this problem.
Best Regards
Old 09-02-2017, 16:43   #6 (permalink)
Member: 237150
Thanks Meter: 2
Thank you for having responded to me and dedicating you time. What card reader can I use?
Old 09-02-2017, 16:45   #7 (permalink)
Member: 237150
Thanks Meter: 2
I have a Z3X box enabled for samsung pro and lg can i use the card reader of this box?
Old 09-02-2017, 17:35   #8 (permalink)
royalnasim's Avatar
Member: 1037372
Thanks Meter: 557
Yes you can use card reader
Old 09-02-2017, 18:43   #9 (permalink)
royalnasim's Avatar
Member: 1037372
Thanks Meter: 557
I cañt send massage
shine71 has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her.
This error
Old 09-03-2017, 07:33   #10 (permalink)
Member: 2372304
I have the same! have solved a problem?
Old 09-03-2017, 10:07   #11 (permalink)
Member: 237150
Thanks Meter: 2
I tried using another sim reader and also changing operating system and using windows XP but the problem always remains "server not found"
Old 09-03-2017, 10:50   #12 (permalink)
Member: 2372304
shine71 has not been allowed to receive private messages. Therefore you can not send your message to him / her.
Closed access for messages from other users!
Old 09-03-2017, 10:53   #13 (permalink)
Member: 237150
Thanks Meter: 2
ok i try to see if i can edit message profile. But did you fix up with updating your card?
Old 09-03-2017, 11:06   #14 (permalink)
Member: 2372304
Не решил ! I can't update with 1.5> 2.2"server not found "
Old 09-03-2017, 17:03   #15 (permalink)
Member: 237150
Thanks Meter: 2
I did the tests and I list the results: I used the card of my z3x active box for lg and samsung in my easy jtag, at this point I ran the easy jtag Connectivyti Diag v1.0 software in the driver folder to this point I read the box and the card with this software getting all the data of both the easy jtag and the card.
Checking if JTAG present ...
Found EASY Jtag BOX "Easy Jtag Control Port (COM10)
Box HWID "USB \ VID_0325 & PID_0032 & REV_0100 & MI_00
Box Driver RegKey: {4d36e978-e325-11ce-bfc1-08002be10318} \ 0001
Box Driver Ver .:
Box Driver Date .:
Configuring for card and uart box ...
Searching card ... [215]
Card status: Card found
Card SN: FExx-xxxx
Card ver: 2.2
ver: 2.2
Card ver int: 16
*+ Lg activated
*+ Sams activated
Found command port "Easy Jtag Control Port (COM10)
Setting JTAG Mode
EASY Jtag BOX SN #: 0200xxxxxxxxxxxx
EASY Jtag BOX Firmware ver.:01.58
At this point, I did the same procedure using the easy jtag card I can not upgrade from version 1.5 to 2.2 to get this result:
Box Driver Ver .:
Box Driver Date .:
Searching card ... [1]
Card status: Card not found
now I wonder is a problem of my card or what?
Page generated in 0.26009 seconds with 8 queries
