Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 03-07-2019, 20:37   #1 (permalink)
Member: 389266
Thanks Meter: 14
Problem nand iphone 5s, help me
PROBLEM NAND IPHONE 5S, HELP ME
Hello friends
I got an iphone 5s in recovery mode, I try to flash with itunes with error 4013 result, rebuilt tracks where they break the screws and the same problem comes out
I desoldo the nand, clean, reballing and connect to the easy jtag plus, here the log:
Z3X EasyJtag Software ver. 3.4.0.2
Identify NAND Chip.
It's PPN NAND
Extended id: 0xAD8260242102
apple bus capability: x32 x64
Name: H2JTDG8UD1BMS ( eye mine is H2JTDG8UD1BMR)
Vendor: Hynix
FW version: 050260P_HYX_BD16
Full page size: 0x4040
Page data size: 0x4040
Page spare size: 0x0
Layout:
*number of CS: 2
*number of LUNs per CS: 1
*number of Plans per LUN: 2
*number of Blocks per Plane: 1064
*number of Pages per Block: 256
*number of Pages per SLC Block: 128
Flash size: 0x42C280000 / 16,706,512,000B / 16GB
Donate
Identify NAND Chip.
It's PPN NAND
Vendor: Hynix
Layout:
*number of CS: 2
Prepare to iConfig works.
Bad block skipping is disable
Auto addressing is disable
Using physical addressing
Blocks ordered by LUN
Skip empty blocks is disable
PPN NAND does not use Spare as common understanding. Spare and ECC settings are abolished
iConfig mode 0, type x32
Read CE0, serial block number: 0
Error reading, CE0 sector address 0x841F000000 block address 0x841F000000, block number 2110. Error Code: -202 Reason: Status fail
Read CE1, serial block number: 0
Error reading, CE1 sector address 0x8C20000000 block address 0x8C20000000, block number 2113. Error Code: -202 Reason: Status fail
iConfig mode 1, type x64
Can not parse Serial block: iConfig block not found
Read CE0, serial block number: 1
**serial number: xxxPLCVHFFG8
**model: ME432
**sub model: A1457
**area: CI / A
**color: not found
**board: FJ651130CC8FGFDE
**WiFi mac: xxx72CAA8B00
**bluetooth mac: xxx72CAA8B01
**GICl: 01000000881300000000000000000000
**AICl: 02000000C0070000F401000000000000
**BLCl: 000100006D15204E3002000000000000
Read CE1, serial block number: 1
**model: ME432
**sub model: A1457
**area: CI / A
**color: not found
**board: 0000000000031206
Donate
despues de
1-Erase NAND [General Tab]
2-Select Device Like 5S [iConfig Tab]
3-Write iConfig For Selective Device
4-Write Original Numbers [SN MAC ETC]
5-Click WRITE ICONFIG FOR SELECTED DEVICE
Then I Resoldered NAND
But When I Try To Restore VIA iTunes
restores without errors excellent
but it does not let me activate the iphone, because it has another serial than the original one, when giving in the logo (i) it can be seen in the screen of the iphone already restored
I desoldo again the nand and I connect to the box and here the logo:
**serial number: DNQL96T4F888
**model: ME305
**sub model: A1533
**area: ZP / A
**color: not found
**board: F3X33520942FGCC6
**WiFi mac: 6476BA151965
**bluetooth mac: 6476BA151966
**GICl: 010000007B140000000000000000000000
**AICl: 020000008C070000F401000000000000
**BLCl: 000100007C15204E0902000000000000
**model: ME432
**sub model: A1457
**area: CI / A
**color: not found
Donate
the information is corrupted or altered compare the 2 logs
questions
1-why is this new sn: DNQL96T4F888 on the display of the iphone, wrong original data does not let me activate iphone
2- my nand is exactly H2JTDG8UD1BMR is not supported?
this same process I have done in two iphone 6 without any failure total success
thanks for advance
luck
The Following User Says Thank You to engendro For This Useful Post:
Old 03-09-2019, 10:46   #2 (permalink)
Member: 13148
Thanks Meter: 793
try to write config via this test version
https://smartjtagbox.com/owncloud/in...x7r5a324cJ5xLJ
sete "Erase User data" when Write config, also select correct mode (x64)
The Following 2 Users Say Thank You to layder For This Useful Post:
Old 03-12-2019, 20:55   #3 (permalink)
Member: 389266
Thanks Meter: 14
full test 100%
veryyyyyyyyyy thanks layder
thanks team easy jtag
luck
Page generated in 0.30542 seconds with 7 queries
