02-07-2014, 16:52 | #1 (permalink) |
Insane Poster Join Date: Jan 2014 Age: 41
Member: 2105989 Status: Offline Thanks Meter: 10 | problem repair boot sensation xe i have sensation xe PG58130 IS DEAD then repair easy repair with easy jtag but not sloved problem and still dead Code: EasyJtag Suite ver.: 1.0.100.0 started. Operating system ver.: Windows XP (build 2600, Service Pack 3). Successefuly connected to box on COM12 Box S/N: 17000016394C73F7, ,FW Ver.: 01.48 Box Working Mode: JTAG Box. Box Drivers version: 3.0.0.0, are OK Z3X Card Serial : AA80-BA4C , ver: 22 Loading repair file: 'I:\box\easy-jtag\repair\htc\HTC SENSATION XE Z715E PG58130 V1.00.rcp' Repair File ver. : Easy Repair for Mfg: HTC Model: Z710e Sensation (PG58130), Ver.: 1.00 Repair file options. : NONE Easy-Repair file load OK! Using EasyRepair Mode... Checking repair data... EasyJtag Suite ver.: 1.0.100.0 started. Operating system ver.: Windows XP (build 2600, Service Pack 3). For support and updates visit http://easy-jtag.com Initialising: HTC Z710e Sensation (PG58130) Config ver.:1.00 I/O Level set to : 2200 mV Box S/N: 17000016394C73F7 ,FW Ver.: 01.48 Connecting to Target... JTAG device: MSM8260. CPU IDCODE : 0x4F1F0F0F Mfg.: 0x787, Part: 0xf1f0, Ver.: 0x4 CPU Manufacturer: Samsung , CPU Name: ARM7GEN JTAG device: MSM8260. CPU IDCODE : 0x104210E1 Mfg.: 0x070, Part: 0x0421, Ver.: 0x1 CPU Manufacturer: QUALCOMM , CPU Name: MSM8260 Halting CPU... Using EasyRepair Mode... Checking repair data... EasyJtag Suite ver.: 1.0.100.0 started. Operating system ver.: Windows XP (build 2600, Service Pack 3). For support and updates visit http://easy-jtag.com Initialising: HTC Z710e Sensation (PG58130) Config ver.:1.00 I/O Level set to : 2200 mV Box S/N: 17000016394C73F7 ,FW Ver.: 01.48 Connecting to Target... JTAG device: MSM8260. CPU IDCODE : 0x4F1F0F0F Mfg.: 0x787, Part: 0xf1f0, Ver.: 0x4 CPU Manufacturer: Samsung , CPU Name: ARM7GEN JTAG device: MSM8260. CPU IDCODE : 0x104210E1 Mfg.: 0x070, Part: 0x0421, Ver.: 0x1 CPU Manufacturer: QUALCOMM , CPU Name: MSM8260 Halting CPU... Initialize hardware... Starting target communication... Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x004A0090 Name : HYNIX Size : 2.3 G , (4718592) Blocks eMMC flash device(s) found, Device ID : 0x0090004a NAND Writing MBR... eMMC Write OK! Elapsed time: 0.015625s (32.000 KiB/s) NAND Writing SBL1... eMMC Write OK! Elapsed time: 2.046875s (62.534 KiB/s) NAND Writing SBL2... eMMC Write OK! Elapsed time: 2.437500s (105.026 KiB/s) NAND Writing ID... eMMC Write OK! Elapsed time: 0.812500s (19.692 KiB/s) NAND Writing WLAN... eMMC Write OK! Elapsed time: 2.296875s (111.456 KiB/s) NAND Writing SBL3... eMMC Write OK! Elapsed time: 11.531250s (88.802 KiB/s) NAND Writing RPM... eMMC Write OK! Elapsed time: 2.359375s (108.503 KiB/s) NAND Writing TZ... eMMC Write OK! Elapsed time: 13.671875s (149.797 KiB/s) NAND Writing HBOOT... eMMC Write OK! Elapsed time: 13.812500s (74.136 KiB/s) NAND Writing SPLASH1... eMMC Write OK! Elapsed time: 46.187500s (133.023 KiB/s) NAND Writing MISC... eMMC Write OK! Elapsed time: 1.656250s (154.566 KiB/s) NAND Writing HTC... eMMC Write OK! Elapsed time: 51.671875s (158.510 KiB/s) NAND Writing BOOT... eMMC Write OK! Elapsed time: 131.281250s (124.801 KiB/s) NAND Writing RECOVERY... eMMC Write OK! Elapsed time: 144.968750s (113.011 KiB/s) All Done. |
02-07-2014, 17:40 | #3 (permalink) |
Member: 2105989 Status: Offline Thanks Meter: 10 | thanks jtag with riff box Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [HTC Sensation (PG5813000) V1.0.4557.1879] Connecting to the dead body...OK Detected dead body ID: 0x104210E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0090/0x004A (HYNIX, 0x000090000000 Bytes = 2.25 GB) Flashing the dead body...OK ERROR: DCC Loader has reported Error Code = 0x35 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x35 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x35 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x35 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x35 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x35 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x35 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x35 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x35 (0x000000). Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x35 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x35 (0x000000). Trying to recover...OK Resurrection complete! i think problem is ic flash can i repair ic flash with easy jtag??? |
