problem wit eMMC program after replacement Hi! I have a Huawei S7-721U and I have replace eMMC with new one, before I replace the eMMC I have programmed it by Easy JTAG Plus but the device cannot boot and detect at qloader 9008 and current consumption is fix at 50mA . What can I do ???? I tried to replace many eMMCs But none of them Ok!!:confused::confused::confused::confused::confu sed::confused: This is my box log EasyJtag Suite Classic ver.: 3.4.0.3 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 10 (build 17763), 64-bit edition. Admin rights FAIL Android Explorer ver:1.0.0.13 Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 eMMC Odin ver:1.0.0.6 QUALCOMM Direct ver:1.0.6671.7138 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 10.0.17763.1 Z3X Card Serial : AA9B-184F , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Found 1 serial devices COM3 USB\VID_1781&PID_AAAC&REV_0100&MI_00 USB Serial Device (COM3) Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Compression if OFF Z3X EasyJtag Software ver. 3.4.0.3 Loading eMMC GEN2 Firmware... IO: 2800 mV Initial pull results: clock: 1927mV pin connected ok command: 1933mV pin connected ok data0: 1931mV pin connected ok data1: 1928mV pin connected ok data2: 1933mV pin connected ok data3: 1933mV pin connected ok data4: 1933mV pin connected ok data5: 1932mV pin connected ok data6: 1932mV pin connected ok data7: 1934mV pin connected ok Box S/N: A4B0560B5B4D628B, ,FW Ver.: 02.31 Box IO Level:2800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A4834473164048601044DCC40D1 eMMC CSD : D02701320F5903FFFFFFFFE78A4040E3 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 04/2013 Rev.0x86 eMMC NAME: H4G1d , S/N: 17059276 eMMC NAME (HEX): 483447316420 EMMC ROM1 (Main User Data) Capacity: 3696 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G1d _ 17059276_20190414_1235.extcsd Partition info not found Done. Selected eMMC Interface Failed to load partition Checking security ... Z3X EasyJtag Software ver. 3.4.0.3 Skip loading eMMC Addon Firmware Box IO Level:2800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR Erasing 400000000 bytes from 00000000 ...ROM1 Full Verify Enabled! Erase Length has been corrected to 0x0000E7000000 bytes... Erase Done. Checking security ... Z3X EasyJtag Software ver. 3.4.0.3 Skip loading eMMC Addon Firmware Box IO Level:2800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR Erasing 400000000 bytes from 00000000 ...ROM2 Full Verify Enabled! Erase Length has been corrected to 0x000000200000 bytes... Erase Done. Checking security ... Z3X EasyJtag Software ver. 3.4.0.3 Skip loading eMMC Addon Firmware Box IO Level:2800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR Erasing 400000000 bytes from 00000000 ...ROM3 Full Verify Enabled! Erase Length has been corrected to 0x000000200000 bytes... Erase Done. Checking NAND Image : F:\diskbackup\download\Huawei_S7-721U_emmc_direct_dump_512MB\Huawei_S7-721U_emmc_direct_dump_512MB\EMMC_ROM1_H8G2d_609439 77_00000000_20000000.bin Autodetected RAW data Partition info successfully found Linux partitions is not found in image... File successefuly loaded! Checking NAND Image : F:\diskbackup\download\Huawei_S7-721U_emmc_direct_dump_512MB\Huawei_S7-721U_emmc_direct_dump_512MB\EMMC_ROM1_H8G2d_609439 77_00000000_20000000.bin Autodetected RAW data Partition info successfully found Linux partitions is not found in image... File successefuly loaded! Found ROM2 and automatically selected. Found ROM3 and automatically selected. Found EXT CSD and automatically selected. Processing file...F:\diskbackup\download\Huawei_S7-721U_emmc_direct_dump_512MB\Huawei_S7-721U_emmc_direct_dump_512MB\H8G2d_03A1EE69_2017040 3_190813.extcsd Processing file...F:\diskbackup\download\Huawei_S7-721U_emmc_direct_dump_512MB\Huawei_S7-721U_emmc_direct_dump_512MB\EMMC_ROM1_H8G2d_609439 77_00000000_20000000.bin Processing file...F:\diskbackup\download\Huawei_S7-721U_emmc_direct_dump_512MB\Huawei_S7-721U_emmc_direct_dump_512MB\EMMC_ROM2_H8G2d_609439 77_00000000_00400000.bin Processing file...F:\diskbackup\download\Huawei_S7-721U_emmc_direct_dump_512MB\Huawei_S7-721U_emmc_direct_dump_512MB\EMMC_ROM3_H8G2d_609439 77_00000000_00400000.bin Checking security ... Running:Repair extCSD... Z3X EasyJtag Software ver. 3.4.0.3 Skip loading eMMC Addon Firmware Box IO Level:2800 mV CLK Rate:42000 kHz ------------Parsing extCSD------------ ============================================= Extended CSD rev 1.6 (MMC 4.5) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x03]: implementation based on CMD12 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x08] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x08] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x00] Tag Resources Size [TAG_RES_SIZE: 0x06] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x78] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x01] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x64] Power off notification [POWER_OFF_LONG_TIME: 0x64] Cache Size [CACHE_SIZE] is 512 KiB Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x64] Power off notification [POWER_OFF_LONG_TIME: 0x64] Cache Size [CACHE_SIZE] is 512 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x01] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x13] Sector Count [SEC_COUNT: 0x00e90000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x08] [MIN_PERF_R_8_52: 0x08] [MIN_PERF_W_8_26_4_52: 0x08] [MIN_PERF_R_8_26_4_52: 0x08] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x08] [MIN_PERF_R_4_26: 0x08] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x03] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x02] I/O Driver Strength [DRIVER_STRENGTH: 0x01] Card Type [CARD_TYPE: 0x17] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x38] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0001d2 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x00 Native sector size [NATIVE_SECTOR_SIZE]: 0x01 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 ------------Done parsing------------ Writing as extCSD 4.41 Done. Checking security ... Z3X EasyJtag Software ver. 3.4.0.3 Skip loading eMMC Addon Firmware Input file : F:\diskbackup\download\Huawei_S7-721U_emmc_direct_dump_512MB\Huawei_S7-721U_emmc_direct_dump_512MB\EMMC_ROM1_H8G2d_609439 77_00000000_20000000.bin Writing 0020000000 bytes to 0000000000... ROM1 (USER ROM) Full Verify Enabled! Done, time taken: 85 sec. Average Write Speed: 6295 kB/s Checking security ... Z3X EasyJtag Software ver. 3.4.0.3 Skip loading eMMC Addon Firmware Input file : F:\diskbackup\download\Huawei_S7-721U_emmc_direct_dump_512MB\Huawei_S7-721U_emmc_direct_dump_512MB\EMMC_ROM2_H8G2d_609439 77_00000000_00400000.bin Writing 0000200000 bytes to 0000000000 ...ROM2 (BOOT1 ROM) Full Verify Enabled! Done, time taken: 0.340 sec. Average Write Speed: 6114 kB/s Checking security ... Compression if OFF Z3X EasyJtag Software ver. 3.4.0.3 Loading eMMC GEN2 Firmware... IO: 2800 mV Initial pull results: clock: 1923mV pin connected ok command: 1929mV pin connected ok data0: 1927mV pin connected ok data1: 1925mV pin connected ok data2: 1929mV pin connected ok data3: 1929mV pin connected ok data4: 1928mV pin connected ok data5: 1929mV pin connected ok data6: 1925mV pin connected ok data7: 1929mV pin connected ok Box S/N: A4B0560B5B4D628B, ,FW Ver.: 02.31 Box IO Level:2800 mV CLK Rate:42000 kHz Bus Width:8bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A4834473164048601044DCC40D1 eMMC CSD : D02701320F5903FFFFFFFFE78A4040E3 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 04/2013 Rev.0x86 eMMC NAME: H4G1d , S/N: 17059276 eMMC NAME (HEX): 483447316420 EMMC ROM1 (Main User Data) Capacity: 3696 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G1d _ 17059276_20190414_1249.extcsd Partition info successfully found Found Data areas (firmware parts) count is: 27 --------------------------------------------- P0 (SBL1) [0x4400 0x80000] Size: 512.0KB P1 (SDI) [0x84400 0x8000] Size: 32.0KB P2 (DDR) [0x400000 0x8000] Size: 32.0KB P3 (RPM) [0x800000 0x7d000] Size: 500.0KB P4 (TZ) [0x87d000 0x7d000] Size: 500.0KB P5 (ABOOT) [0x8fa000 0x576000] Size: 5.460MB P6 (PAD) [0xe70000 0x100000] Size: 1.0MB P7 (OEMINFO) [0xf70000 0x4000000] Size: 64.0MB P8 (MODEMST1) [0x4f70000 0x400000] Size: 4.0MB P9 (MODEMST2) [0x5370000 0x400000] Size: 4.0MB P10 (MODEM) [0x5800000 0x6000000] Size: 96.0MB P11 (FSG) [0xb800000 0x400000] Size: 4.0MB P12 (FSC) [0xbc00000 0x400] Size: 1.0KB P13 (SSD) [0xbc00400 0x2000] Size: 8.0KB P14 (LOG) [0xbc02400 0x2000000] Size: 32.0MB P15 (BKBOOTUP) [0xe000000 0x4000000] Size: 64.0MB P16 (PERSIST) [0x12000000 0x800000] Size: 8.0MB P17 (BOOT) [0x12800000 0xc00000] Size: 12.0MB P18 (RECOVERY) [0x13400000 0x1000000] Size: 16.0MB P19 (CUST) [0x14400000 0x20000000] Size: 512.0MB P20 (CACHE) [0x34400000 0x10000000] Size: 256.0MB P21 (MISC) [0x44400000 0x400000] Size: 4.0MB P22 (SYSTEM) [0x44800000 0x20000000] Size: 512.0MB P23 (TMPDATA) [0x64800000 0x1000000] Size: 16.0MB P24 (VRCB) [0x65800000 0x400000] Size: 4.0MB P25 (RESERVE) [0x65c00000 0x1000000] Size: 16.0MB P26 (DATA) [0x66c00000 0x16b3fbe00] Size: 5.674GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0044800000 (512.0MB) Unable to mount SYSTEM , code : 95 --------------------------------------------- Done. Selected eMMC Interface |
What a bad support !!! Easy JTAG team please answer the question !!!! |
He does not have telepathic abilities, and does not know whether you have chosen the replacement eMMC correctly and he does not know how your tablet behaves, it is determined by the computer or not. Try using another eMMC and check if you have other problems unrelated to eMMC. |
I have worked hardware repairing for 10 years and I have a mobile repairing academy ! So my eMMC replacement is OK The tablet is detect by PC as Hs-qloader 9008 and I think when eMMC could read and Write ,it is OK !isn't it? I have posted my box log ! so I think the support can tell me if I do the correct way or not! please help me . |
how can I read the info ? |
