Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 04-14-2019, 17:06   #1 (permalink)
Member: 2359454
Thanks Meter: 7
problem wit eMMC program after replacement
Hi!
I have a Huawei S7-721U and I have replace eMMC with new one, before I replace the eMMC I have programmed it by Easy JTAG Plus
but the device cannot boot and detect at qloader 9008 and current consumption is fix at 50mA . What can I do ???? I tried to replace many eMMCs But none of them Ok!!:confu sed:
This is my box log
EasyJtag Suite Classic ver.: 3.4.0.3 / wxWidgets 3.1.0-W-U started.
OS ver.: Windows 10 (build 17763), 64-bit edition. Admin rights FAIL
Android Explorer ver:1.0.0.13
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
eMMC Odin ver:1.0.0.6
QUALCOMM Direct ver:1.0.6671.7138
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 10.0.17763.1
Z3X Card Serial : AA9B-184F , ver: 22
Z3X Card Activation [JTAGPLUS] : ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Found 1 serial devices
COM3 USB\VID_1781&PID_AAAC&REV_0100&MI_00 USB Serial Device (COM3)
Selected pinout: GEN2 High Speed Pinout
Change EasyJTAG Pinout OK
Compression if OFF
Z3X EasyJtag Software ver. 3.4.0.3
Loading eMMC GEN2 Firmware... IO: 2800 mV
Initial pull results:
clock: 1927mV pin connected ok
command: 1933mV pin connected ok
data0: 1931mV pin connected ok
data1: 1928mV pin connected ok
data2: 1933mV pin connected ok
data3: 1933mV pin connected ok
data4: 1933mV pin connected ok
data5: 1932mV pin connected ok
data6: 1932mV pin connected ok
data7: 1934mV pin connected ok
Box S/N: A4B0560B5B4D628B, ,FW Ver.: 02.31
Box IO Level:2800 mV
CLK Rate:42000 kHz
Bus Width:8bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 90014A4834473164048601044DCC40D1
eMMC CSD : D02701320F5903FFFFFFFFE78A4040E3
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 04/2013 Rev.0x86
eMMC NAME: H4G1d , S/N: 17059276
eMMC NAME (HEX): 483447316420
EMMC ROM1 (Main User Data) Capacity: 3696 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x03
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H4G1d _ 17059276_20190414_1235.extcsd
Partition info not found
Done.
Selected eMMC Interface
Failed to load partition
Checking security ...
Skip loading eMMC Addon Firmware
CLK Rate:42000 kHz
Bus Width:8bit,SDR
Erasing 400000000 bytes from 00000000 ...ROM1
Full Verify Enabled!
Erase Length has been corrected to 0x0000E7000000 bytes...
Erase Done.
CLK Rate:42000 kHz
Bus Width:8bit,SDR
Erasing 400000000 bytes from 00000000 ...ROM2
Erase Length has been corrected to 0x000000200000 bytes...
Erase Done.
CLK Rate:42000 kHz
Bus Width:8bit,SDR
Erasing 400000000 bytes from 00000000 ...ROM3
Erase Done.
Checking NAND Image : F:\diskbackup\download\Huawei_S7-721U_emmc_direct_dump_512MB\Huawei_S7-721U_emmc_direct_dump_512MB\EMMC_ROM1_H8G2d_609439 77_00000000_20000000.bin
Autodetected RAW data
Partition info successfully found
Linux partitions is not found in image...
File successefuly loaded!
Found ROM2 and automatically selected.
Found ROM3 and automatically selected.
Found EXT CSD and automatically selected.
Processing file...F:\diskbackup\download\Huawei_S7-721U_emmc_direct_dump_512MB\Huawei_S7-721U_emmc_direct_dump_512MB\H8G2d_03A1EE69_2017040 3_190813.extcsd
Processing file...F:\diskbackup\download\Huawei_S7-721U_emmc_direct_dump_512MB\Huawei_S7-721U_emmc_direct_dump_512MB\EMMC_ROM1_H8G2d_609439 77_00000000_20000000.bin
Processing file...F:\diskbackup\download\Huawei_S7-721U_emmc_direct_dump_512MB\Huawei_S7-721U_emmc_direct_dump_512MB\EMMC_ROM2_H8G2d_609439 77_00000000_00400000.bin
Processing file...F:\diskbackup\download\Huawei_S7-721U_emmc_direct_dump_512MB\Huawei_S7-721U_emmc_direct_dump_512MB\EMMC_ROM3_H8G2d_609439 77_00000000_00400000.bin
Running:Repair extCSD...
CLK Rate:42000 kHz
------------Parsing extCSD------------
Extended CSD rev 1.6 (MMC 4.5)
Card Supported Command sets [S_CMD_SET: 0x01]
HPI Features [HPI_FEATURE: 0x03]:
implementation based on CMD12
Background operations support [BKOPS_SUPPORT: 0x01]
Max Packet Read Cmd [MAX_PACKED_READS: 0x08]
Max Packet Write Cmd [MAX_PACKED_WRITES: 0x08]
Data TAG support [DATA_TAG_SUPPORT: 0x01]
Data TAG Unit Size [TAG_UNIT_SIZE: 0x00]
Tag Resources Size [TAG_RES_SIZE: 0x06]
Context Management Capabilities [CONTEXT_CAPABILITIES: 0x78]
Large Unit Size [LARGE_UNIT_SIZE_M1: 0x01]
Extended partition attribute support [EXT_SUPPORT: 0x03]
Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x64]
Power off notification [POWER_OFF_LONG_TIME: 0x64]
Cache Size [CACHE_SIZE] is 512 KiB
Background operations status [BKOPS_STATUS: 0x00]
1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a]
Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00]
Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00]
Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00]
Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00]
Minimum Performance for 8bit at 52MHz in DDR mode:
[MIN_PERF_DDR_W_8_52: 0x00]
[MIN_PERF_DDR_R_8_52: 0x00]
TRIM Multiplier [TRIM_MULT: 0x01]
Secure Feature support [SEC_FEATURE_SUPPORT: 0x55]
Boot Information [BOOT_INFO: 0x07]
Device supports alternative boot method
Device supports dual data rate during boot
Device supports high speed timing during boot
Boot partition size [BOOT_SIZE_MULTI: 0x20]
Access size [ACC_SIZE: 0x06]
High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01]
High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02]
Reliable write sector count [REL_WR_SEC_C: 0x01]
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10]
Sleep current (VCC) [S_C_VCC: 0x07]
Sleep current (VCCQ) [S_C_VCCQ: 0x07]
Sleep/awake timeout [S_A_TIMEOUT: 0x13]
Sector Count [SEC_COUNT: 0x00e90000]
Minimum Write Performance for 8bit:
[MIN_PERF_W_8_52: 0x08]
[MIN_PERF_R_8_52: 0x08]
[MIN_PERF_W_8_26_4_52: 0x08]
[MIN_PERF_R_8_26_4_52: 0x08]
Minimum Write Performance for 4bit:
[MIN_PERF_W_4_26: 0x08]
[MIN_PERF_R_4_26: 0x08]
Power classes registers:
[PWR_CL_26_360: 0x00]
[PWR_CL_52_360: 0x00]
[PWR_CL_26_195: 0x00]
[PWR_CL_52_195: 0x00]
Partition switching timing [PARTITION_SWITCH_TIME: 0x03]
Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x02]
I/O Driver Strength [DRIVER_STRENGTH: 0x01]
Card Type [CARD_TYPE: 0x17]
CSD structure version [CSD_STRUCTURE: 0x02]
Command set [CMD_SET: 0x00]
Command set revision [CMD_SET_REV: 0x00]
Power class [POWER_CLASS: 0x00]
High-speed interface timing [HS_TIMING: 0x00]
Erased memory content [ERASED_MEM_CONT: 0x00]
Boot configuration bytes [PARTITION_CONFIG: 0x38]
No access to boot partition
Boot config protection [BOOT_CONFIG_PROT: 0x00]
Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00]
High-density erase group definition [ERASE_GROUP_DEF: 0x00]
Boot write protection status registers [BOOT_WP_STATUS]: 0x00
Boot Area Write protection [BOOT_WP]: 0x00
Power ReadOnly locking: possible
Permanent ReadOnly locking: possible
Read Only lock status: not locked
User area write protection register [USER_WP]: 0x00
FW configuration [FW_CONFIG]: 0x00
RPMB Size [RPMB_SIZE_MULT]: 0x20
Write reliability setting register [WR_REL_SET]: 0x1f
Write reliability parameter register [WR_REL_PARAM]: 0x05
Enable background operations handshake [BKOPS_EN]: 0x00
H/W reset function [RST_N_FUNCTION]: 0x00
HPI management [HPI_MGMT]: 0x00
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0001d2
Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00
General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000
[GP_SIZE_MULT_3]: 0x000000
[GP_SIZE_MULT_2]: 0x000000
[GP_SIZE_MULT_1]: 0x000000
Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000
Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000
Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00
Periodic Wake-up [PERIODIC_WAKEUP]: 0x00
Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x00
Native sector size [NATIVE_SECTOR_SIZE]: 0x01
Sector size emulation [USE_NATIVE_SECTOR]: 0x00
Sector size [DATA_SECTOR_SIZE]: 0x00
1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a
Class 6 commands control [CLASS_6_CTRL]: 0x00
Number of addressed group to be released[DYNCAP_NEEDED]: 0x00
Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000
Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000
Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000
Packed command status [PACKED_COMMAND_STATUS]: 0x00
Packed command failure index [PACKED_FAILURE_INDEX]: 0x00
Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00
Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00
------------Done parsing------------
Writing as extCSD 4.41
Done.
Input file : F:\diskbackup\download\Huawei_S7-721U_emmc_direct_dump_512MB\Huawei_S7-721U_emmc_direct_dump_512MB\EMMC_ROM1_H8G2d_609439 77_00000000_20000000.bin
Writing 0020000000 bytes to 0000000000... ROM1 (USER ROM)
Done, time taken: 85 sec. Average Write Speed: 6295 kB/s
Input file : F:\diskbackup\download\Huawei_S7-721U_emmc_direct_dump_512MB\Huawei_S7-721U_emmc_direct_dump_512MB\EMMC_ROM2_H8G2d_609439 77_00000000_00400000.bin
Writing 0000200000 bytes to 0000000000 ...ROM2 (BOOT1 ROM)
Done, time taken: 0.340 sec. Average Write Speed: 6114 kB/s
Compression if OFF
clock: 1923mV pin connected ok
command: 1929mV pin connected ok
data0: 1927mV pin connected ok
data1: 1925mV pin connected ok
data2: 1929mV pin connected ok
data3: 1929mV pin connected ok
data4: 1928mV pin connected ok
data5: 1929mV pin connected ok
data6: 1925mV pin connected ok
data7: 1929mV pin connected ok
CLK Rate:42000 kHz
Bus Width:8bit,SDR
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
Backup saved: H4G1d _ 17059276_20190414_1249.extcsd
Found Data areas (firmware parts) count is: 27
P0 (SBL1) [0x4400 0x80000] Size: 512.0KB
P1 (SDI) [0x84400 0x8000] Size: 32.0KB
P2 (DDR) [0x400000 0x8000] Size: 32.0KB
P3 (RPM) [0x800000 0x7d000] Size: 500.0KB
P4 (TZ) [0x87d000 0x7d000] Size: 500.0KB
P5 (ABOOT) [0x8fa000 0x576000] Size: 5.460MB
P6 (PAD) [0xe70000 0x100000] Size: 1.0MB
P7 (OEMINFO) [0xf70000 0x4000000] Size: 64.0MB
P8 (MODEMST1) [0x4f70000 0x400000] Size: 4.0MB
P9 (MODEMST2) [0x5370000 0x400000] Size: 4.0MB
P10 (MODEM) [0x5800000 0x6000000] Size: 96.0MB
P11 (FSG) [0xb800000 0x400000] Size: 4.0MB
P12 (FSC) [0xbc00000 0x400] Size: 1.0KB
P13 (SSD) [0xbc00400 0x2000] Size: 8.0KB
P14 (LOG) [0xbc02400 0x2000000] Size: 32.0MB
P15 (BKBOOTUP) [0xe000000 0x4000000] Size: 64.0MB
P16 (PERSIST) [0x12000000 0x800000] Size: 8.0MB
P17 (BOOT) [0x12800000 0xc00000] Size: 12.0MB
P18 (RECOVERY) [0x13400000 0x1000000] Size: 16.0MB
P19 (CUST) [0x14400000 0x20000000] Size: 512.0MB
P20 (CACHE) [0x34400000 0x10000000] Size: 256.0MB
P21 (MISC) [0x44400000 0x400000] Size: 4.0MB
P22 (SYSTEM) [0x44800000 0x20000000] Size: 512.0MB
P23 (TMPDATA) [0x64800000 0x1000000] Size: 16.0MB
P24 (VRCB) [0x65800000 0x400000] Size: 4.0MB
P25 (RESERVE) [0x65c00000 0x1000000] Size: 16.0MB
P26 (DATA) [0x66c00000 0x16b3fbe00] Size: 5.674GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0044800000 (512.0MB)
Unable to mount SYSTEM , code : 95
Done.
Old 04-16-2019, 11:55   #2 (permalink)
Member: 2359454
Thanks Meter: 7
What a bad support !!! Easy JTAG team please answer the question !!!!
Old 04-16-2019, 14:14   #3 (permalink)
Member: 13148
Thanks Meter: 881
I also think that support is bad.
He does not have telepathic abilities, and does not know whether you have chosen the replacement eMMC correctly and he does not know how your tablet behaves, it is determined by the computer or not.
Try using another eMMC and check if you have other problems unrelated to eMMC.
Page generated in 0.16308 seconds with 7 queries
