05-22-2016, 19:14 | #1 (permalink) |
No Life Poster Join Date: Oct 2002 Location: tunisia
Member: 16625 Status: Offline Sonork: 1578753 Thanks Meter: 161 | product supporter heeeelp : emmc odin not flashing anymore after update after loading pit and flash 4 files when i press on write emmc i get : EasyJTAG API v.1912 Setting IO Levels to 2.8V OpenUSB OK Power Controller returned=0 EasyJTAG Box Serial= i erased it EasyJTAG Box Firmware=01.55 eMMC Init returned=0 eMMC NAME = eMMC Size ROM1 (User)= 7634944 Blocks (3,6 GB) eMMC Size ROM2 (Boot1)= 8192 Blocks (4,0 MB) eMMC Size ROM3 (Boot2)= 8192 Blocks (4,0 MB) eMMC Size RPMB (Protected) = 8192 Blocks (4,0 MB) eMMC Init completed. program stuck there and become not responding !!! also as you see emmc has no name but with older emmc odin software it shows name!!!!!!! but same situation not flashing stuck (not responding) please help i am confused |
05-24-2016, 08:34 | #2 (permalink) |
Member: 16625 Status: Offline Sonork: 1578753 Thanks Meter: 161 | 1--i installed 2.0.8.3 and tried emmc odin before i downgrade firmware : it is not flashing just like in 2.1.1.1 (freezing and go in not responding)! 2--i downgraded firmware to 1.52 --> : - on 2.8 no emmc card are not detected !! - on 1.8v is flashing but with error popup saying chunk is unknown. tried othe flash files but same!! this is log of flashing process : Looking for EasyJTAG box... EasyJTAG API v.1910 Setting IO Levels to 1.8V OpenUSB returned=0 Power Controller returned=0 EasyJTAG Box Serial=11FFF021C39B7DF3 EasyJTAG Box Firmware=01.52 eMMC Init returned=0 eMMC NAME = H4G2b eMMC Size ROM1 (User)= 7634944 Blocks (3,6 GB) eMMC Size ROM2 (Boot1)= 8192 Blocks (4,0 MB) eMMC Size ROM3 (Boot2)= 8192 Blocks (4,0 MB) eMMC Size RPMB (Protected) = 8192 Blocks (4,0 MB) eMMC Init completed. ODIN: Writing PIT... Creating GPT-partitioninig Unpacking file spl.img and adding to image Offset for BOOT is 00000000 ODIN: Writing ROM2 <- spl.img - 0x00000009 blocks to eMMC offset 00000000 Offset for C:\ProgramData\Z3XAppsData\temp\spl.img is 00000000 ODIN: Filesize 32768 Blocks 64 ODIN: eMMC switching to ROM2 Done writing partition... Unpacking file j13g.pit and adding to image Offset for PIT is 00080000 ODIN: Writing ROM1 <- j13g.pit - 0x00000009 blocks to eMMC offset 00080000 Offset for C:\ProgramData\Z3XAppsData\temp\j13g.pit is 00080000 ODIN: Filesize 4880 Blocks 9 ODIN: Misalign 272 Bytes ODIN: FIX Filesize 5120 Blocks 10 ODIN: Now misalign is 0 Bytes ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file sboot.bin and adding to image Offset for SBOOT is 00400000 ODIN: Writing ROM1 <- sboot.bin - 0x00000009 blocks to eMMC offset 00400000 Offset for C:\ProgramData\Z3XAppsData\temp\sboot.bin is 00400000 ODIN: Filesize 1573888 Blocks 3074 ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file sboot2.bin and adding to image Offset for SBOOT2 is 00600000 ODIN: Writing ROM1 <- sboot2.bin - 0x00000009 blocks to eMMC offset 00600000 Offset for C:\ProgramData\Z3XAppsData\temp\sboot2.bin is 00600000 ODIN: Filesize 1573888 Blocks 3074 ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file nvitem.bin and adding to image Offset for WFIXNV2 is 00900000 ODIN: Writing ROM1 <- nvitem.bin - 0x00000009 blocks to eMMC offset 00900000 Offset for C:\ProgramData\Z3XAppsData\temp\nvitem.bin is 00900000 ODIN: Filesize 174864 Blocks 341 ODIN: Misalign 272 Bytes ODIN: FIX Filesize 175104 Blocks 342 ODIN: Now misalign is 0 Bytes ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file sprddsp.img and adding to image Offset for WDSP is 00C00000 ODIN: Writing ROM1 <- sprddsp.img - 0x00000009 blocks to eMMC offset 00C00000 Offset for C:\ProgramData\Z3XAppsData\temp\sprddsp.img is 00C00000 ODIN: Filesize 1967104 Blocks 3842 ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file sprdcp.img and adding to image Offset for MODEM is 01000000 ODIN: Writing ROM1 <- sprdcp.img - 0x00000009 blocks to eMMC offset 01000000 Offset for C:\ProgramData\Z3XAppsData\temp\sprdcp.img is 01000000 ODIN: Filesize 7493440 Blocks 14635 ODIN: Misalign 320 Bytes ODIN: FIX Filesize 7493632 Blocks 14636 ODIN: Now misalign is 0 Bytes ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file param.lfs and adding to image Offset for PARAM is 02900000 ODIN: Writing ROM1 <- param.lfs - 0x00000009 blocks to eMMC offset 02900000 Offset for C:\ProgramData\Z3XAppsData\temp\param.lfs is 02900000 ODIN: Filesize 634880 Blocks 1240 ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file boot.img and adding to image Offset for KERNEL is 04500000 ODIN: Writing ROM1 <- boot.img - 0x00000009 blocks to eMMC offset 04500000 Offset for C:\ProgramData\Z3XAppsData\temp\boot.img is 04500000 ODIN: Filesize 5688320 Blocks 11110 ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file recovery.img and adding to image Offset for RECOVERY is 05500000 ODIN: Writing ROM1 <- recovery.img - 0x00000009 blocks to eMMC offset 05500000 Offset for C:\ProgramData\Z3XAppsData\temp\recovery.img is 05500000 ODIN: Filesize 7019520 Blocks 13710 ODIN: eMMC switching to ROM1 Done writing partition... Unpacking file cache.img and adding to image Offset for CSC is 06500000 ODIN: Writing ROM1 <- cache.img - 0x00000009 blocks to eMMC offset 06500000 Offset for C:\ProgramData\Z3XAppsData\temp\cache.img is 06500000 ODIN: Filesize 21655824 Blocks 42296 ODIN: eMMC switching to ROM1 Sparse image found v. 00000001.00000000 Sparse header size : 00000020 Chunk header size : 00000010 Data Block size : 00001000 8 pages Total blocks : 51200 Total chunks : 15 Image CRC32 : 00000000 ------------------------------ Chunk type : 0000 Reserved data : 0000 Output data size : 0000CAC1 Total data size: 00000001 Chunk Type is Unknown... Done writing partition... Unpacking file system.img and adding to image Offset for SYSTEM is 12D00000 ODIN: Writing ROM1 <- system.img - 0x00000009 blocks to eMMC offset 12D00000 Offset for C:\ProgramData\Z3XAppsData\temp\system.img is 12D00000 ODIN: Filesize 961128288 Blocks 1877203 ODIN: eMMC switching to ROM1 Sparse image found v. 00000001.00000000 Sparse header size : 00000020 Chunk header size : 00000010 Data Block size : 00001000 8 pages Total blocks : 266240 Total chunks : 1652 Image CRC32 : 00000000 ------------------------------ Chunk type : 0000 Reserved data : 0000 Output data size : 0000CAC1 Total data size: 00000001 Chunk Type is Unknown... Done writing partition... Unpacking file hidden.img and adding to image Offset for HIDDEN is 53D00000 ODIN: Writing ROM1 <- hidden.img - 0x00000009 blocks to eMMC offset 53D00000 Offset for C:\ProgramData\Z3XAppsData\temp\hidden.img is 53D00000 ODIN: Filesize 7762160 Blocks 15160 ODIN: eMMC switching to ROM1 Sparse image found v. 00000001.00000000 Sparse header size : 00000020 Chunk header size : 00000010 Data Block size : 00001000 8 pages Total blocks : 10240 Total chunks : 13 Image CRC32 : 00000000 ------------------------------ Chunk type : 0000 Reserved data : 0000 Output data size : 0000CAC1 Total data size: 00000001 Chunk Type is Unknown... Done writing partition... All Done! please tell me what is wrong and what to do |
