08-21-2019, 11:47 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ropar
Member: 358277 Status: Offline Thanks Meter: 476 | real me c2 pattren & frp done easy jtag. eMMC CID : 150100514536334D420322BE901856BF eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 05/2019 Rev.0x3 eMMC NAME: QE63MB , S/N: 582914072 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 723 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 First usable sector: 34 Last usable sector: 30535646 Partition info successfully found ------ Android information ------ Detected LINUX(Android) CACHE : 0x0146800000 (328.0MB) Erasing... Done. Detected LINUX(Android) USERDATA : 0x015B000000 (9.80GB) Erasing... Done. --------------------------------------------- Done. this is frp log eMMC CID : 150100514536334D420322BE901856BF eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 05/2019 Rev.0x3 eMMC NAME: QE63MB , S/N: 582914072 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 723 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------Partition table scan: GPT: present Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 First usable sector: 34 Last usable sector: 30535646 Partition info successfully found Formatting FRP... Detected LINUX(Android) FRP : 0x000BE88000 (1.0MB) formatting... Done. Detected LINUX(Android) CACHE : 0x0146800000 (328.0MB) , formatting... Done. Detected LINUX(Android) USERDATA : 0x015B000000 (9.80GB) , formatting... Done. Done. Done. ------------------------------- |
