Old 11-16-2020, 21:03   #1 (permalink)
Member: 2721034
Thanks Meter: 50
Oppo CPH1931 dead 9008 mode
I did all soldering safely phone connected via emmc and I performed Oppo reset successfully.
But I tapped on Frp Clear first tool got stuck like 10 secs then it said done but I tried to switch on the device failed now stuck in 9008 model.
CLK and CMD resistor ok nothing damaged. What can I do?
Sent from my SM-G770F using Tapatalk
Old 11-17-2020, 10:39   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
you need check hardware and check boot partiton for non-damage (sbl, tz, rpm, boot)
The Following User Says Thank You to layder For This Useful Post:
Old 11-17-2020, 21:03   #3 (permalink)
Member: 350571
Thanks Meter: 920
befor doing any operation You must take the backup
write the backup if you face any problem after done any operation
Old 11-18-2020, 18:50   #4 (permalink)
Member: 2721034
Thanks Meter: 50
If I make full flash on msm tool will it revive my device
You mean full emmc back up or I just write the ext. card.
Old 11-18-2020, 23:24   #5 (permalink)
Member: 350571
Thanks Meter: 920
before doing any operation,
You must backup Rom-1, Rom-2, Rom-3
do not try like.
if you not have backup then download full dumb file and write
If not solve the issue after written full dumb?.
Post full log,
will guide u.
Page generated in 0.14829 seconds with 9 queries
