Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 11-23-2019, 13:56   #1 (permalink)
ChandruChiyyan's Avatar
Member: 660093
Sonork: 100.1602344
Thanks Meter: 271
Realme 5(Rmx1911) not detect
i tryed to connect Realme 5 RMX1911 Modal on easy jtag allways not detect this modal i'm using v2 box this modal not supported on Easy jtag? thank's .
log:
EasyJtag Suite Classic ver.: 3.6.1.15 / wxWidgets 3.1.2-W-U started.
OS ver.: Windows 7 (build 7601, Service Pack 1). Admin rights OK
Android Explorer ver:1.0.0.13
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
eMMC Odin ver:1.0.0.6
QUALCOMM Direct ver:1.0.6936.8894
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 3.0.0.0
Z3X Card Serial : AA47-2A8F , ver: 22
Z3X Card Activation [JTAGPLUS] : ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Found 4 serial devices
COM69 root\rimports RIM Virtual Serial Port v2 (COM69)
COM70 root\rimports RIM Virtual Serial Port v2 (COM70)
COM1 ACPI\PNP0501 Communications Port (COM1)
COM16 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM16)
Selected pinout: GEN2 ISP Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.6.1.15
Loading eMMC GEN2 Firmware... IO: 2800 mV
Box S/N: F3579B4B4211DD77, ,FW Ver.: 02.48
CMD Pullup Level:2102 mV
CMD Active Level:2690 mV
Box IO Level:2800 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
Can't init device, Reason: CMD Timeout Error
Done.
CMD Active Level:2691 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
Done.
Old 11-23-2019, 17:47   #2 (permalink)
Member: 13148
Thanks Meter: 1,588
Use Hi-PowerCLK mode, adn normal IO level
Old 02-03-2020, 09:56   #3 (permalink)
Member: 784847
Thanks Meter: 44
this model is not connect
Old 05-15-2020, 14:35   #4 (permalink)
Member: 920138
Thanks Meter: 86
i encounter this issue too..easy jtag not connected but when i try to medusa its working fine..
Old 05-15-2020, 16:25   #5 (permalink)
Member: 2925752
First use lastest setup
And upgrade your firmware then check
Page generated in 0.22513 seconds with 7 queries
