Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 04-08-2019, 16:36   #1 (permalink)
Member: 2636476
Thanks Meter: 50
Redmi 4x emmc replacement process need
and what is diffrence between csd file
i seen both emmc csd is different need to know
layder sir replay plz
4x emmc log
eMMC CID : 150100525831424D4207E692D45DC3DB
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 12/2016  Rev.0x7
eMMC NAME: RX1BMB , S/N: 3868382301
eMMC NAME (HEX): 525831424D42
EMMC ROM1 (Main User Data)   Capacity: 29820 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
  Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit  , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
 Device support partitioning feature
 Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: RX1BMB_3868382301_20190407_1627.extcsd
Partition table scan:
 GPT: present
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Logical sector size: 0x200  bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
First usable sector: 34
Last usable sector: 61071326
Partition info successfully found
Found Data areas (firmware parts) count is: 49
P0 (MODEM) [0x4000000 0x5400000] Size: 84.0MB
P1 (FSC) [0xc000000 0x400] Size: 1.0KB
P2 (SSD) [0xc000400 0x2000] Size: 8.0KB
P3 (SBL1) [0xc002400 0x80000] Size: 512.0KB
P4 (SBL1BAK) [0xc082400 0x80000] Size: 512.0KB
P5 (RPM) [0xc102400 0x80000] Size: 512.0KB
P6 (RPMBAK) [0xc182400 0x80000] Size: 512.0KB
P7 (TZ) [0xc202400 0x200000] Size: 2.0MB
P8 (TZBAK) [0xc402400 0x200000] Size: 2.0MB
P9 (DEVCFG) [0xc602400 0x40000] Size: 256.0KB
P10 (DEVCFGBAK) [0xc642400 0x40000] Size: 256.0KB
P11 (DSP) [0xc682400 0x1000000] Size: 16.0MB
P12 (MODEMST1) [0xd682400 0x180000] Size: 1.500MB
P13 (MODEMST2) [0xd802400 0x180000] Size: 1.500MB
P14 (DDR) [0x10000000 0x8000] Size: 32.0KB
P15 (FSG) [0x10008000 0x180000] Size: 1.500MB
P16 (SEC) [0x10188000 0x4000] Size: 16.0KB
P17 (SPLASH) [0x14000000 0xb00000] Size: 11.0MB
P18 (ABOOT) [0x18000000 0x100000] Size: 1.0MB
P19 (ABOOTBAK) [0x18100000 0x100000] Size: 1.0MB
P20 (BOOT) [0x18200000 0x4000000] Size: 64.0MB
P21 (RECOVERY) [0x1c200000 0x4000000] Size: 64.0MB
P22 (DEVINFO) [0x20200000 0x100000] Size: 1.0MB
P23 (SYSTEM) [0x20300000 0xc0000000] Size: 3.0GB
P24 (CACHE) [0xe4000000 0x10000000] Size: 256.0MB
P25 (PERSIST) [0xf4000000 0x2000000] Size: 32.0MB
P26 (MISC) [0xf6000000 0x100000] Size: 1.0MB
P27 (KEYSTORE) [0xf6100000 0x80000] Size: 512.0KB
P28 (CONFIG) [0xf6180000 0x8000] Size: 32.0KB
P29 (OEM) [0xf6188000 0x10000000] Size: 256.0MB
P30 (LIMITS) [0x108000000 0x8000] Size: 32.0KB
P31 (MOTA) [0x10c000000 0x80000] Size: 512.0KB
P32 (DIP) [0x10c080000 0x100000] Size: 1.0MB
P33 (MDTP) [0x10c180000 0x2000000] Size: 32.0MB
P34 (SYSCFG) [0x10e180000 0x80000] Size: 512.0KB
P35 (MCFG) [0x10e200000 0x400000] Size: 4.0MB
P36 (LKSECAPP) [0x110000000 0x20000] Size: 128.0KB
P37 (LKSECAPPBAK) [0x110020000 0x20000] Size: 128.0KB
P38 (CMNLIB) [0x110040000 0x40000] Size: 256.0KB
P39 (CMNLIBBAK) [0x110080000 0x40000] Size: 256.0KB
P40 (CMNLIB64) [0x1100c0000 0x40000] Size: 256.0KB
P41 (CMNLIB64BAK) [0x110100000 0x40000] Size: 256.0KB
P42 (KEYMASTER) [0x110140000 0x40000] Size: 256.0KB
P43 (KEYMASTERBAK) [0x110180000 0x40000] Size: 256.0KB
P44 (APDP) [0x114000000 0x40000] Size: 256.0KB
P45 (MSADP) [0x114040000 0x40000] Size: 256.0KB
P46 (DPO) [0x114080000 0x2000] Size: 8.0KB
P47 (CUST) [0x114082000 0x34000000] Size: 832.0MB
P48 (USERDATA) [0x148082000 0x5ffb79e00] Size: 23.995GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x0020300000 (3.0GB)
Unable to mount SYSTEM , code : 95
Done.
Selected eMMC Interface
i have y1 emmc is it comfortable in 4x
y1 emmc log
eMMC CID : 150100474436424D42015742D0D9B403
eMMC Date: 11/2017 Rev.0x1
eMMC NAME: GD6BMB , S/N: 1463996633
eMMC NAME (HEX): 474436424D42
Backup saved: GD6BMB_1463996633_20190407_1630.extcsd
GPT: present
Found Data areas (firmware parts) count is: 48
P36 (CMNLIB) [0x110000000 0x40000] Size: 256.0KB
P37 (CMNLIBBAK) [0x110040000 0x40000] Size: 256.0KB
P38 (CMNLIB64) [0x110080000 0x40000] Size: 256.0KB
P39 (CMNLIB64BAK) [0x1100c0000 0x40000] Size: 256.0KB
P40 (KEYMASTER) [0x110100000 0x40000] Size: 256.0KB
P41 (KEYMASTERBAK) [0x110140000 0x40000] Size: 256.0KB
P42 (APDP) [0x114000000 0x40000] Size: 256.0KB
P43 (MSADP) [0x114040000 0x40000] Size: 256.0KB
P44 (DPO) [0x114080000 0x2000] Size: 8.0KB
P45 (LOGDUMP) [0x114082000 0x4000000] Size: 64.0MB
P46 (CUST) [0x11c000000 0x34000000] Size: 832.0MB
P47 (USERDATA) [0x150000000 0x5f7c00000] Size: 23.871GB
Build ID: N2G47H
Display Build ID: N2G47H
Release Incremental ID: V9.2.1.0.NDKMIEK
Release Base ID: 7.1.2
Device Model: Redmi Note 5A
Device Name: ugg
Architecture ABI: arm64-v8a
Device Platform: msm8937
Product ID: ugg
Build Description: ugg-user 7.1.2 N2G47H V9.2.1.0.NDKMIEK release-keys
Device manufacturer: Xiaomi
Done.
Old 04-08-2019, 20:41   #2 (permalink)
Member: 13148
Thanks Meter: 1,199
for most new xiaomi, you need flash service firmware after replacement eMMC.
without service firmware phones newest after Redmi 4x is freezing at boot
The Following User Says Thank You to layder For This Useful Post:
Old 04-08-2019, 20:48   #3 (permalink)
Member: 2298369
Thanks Meter: 373
sir plz tell about more about service firmware and from we get it ?
Old 04-08-2019, 20:59   #4 (permalink)
Member: 2298369
Thanks Meter: 373
is service firmware is different from those firmware from which we flash mi handsets ?
Old 04-08-2019, 21:20   #5 (permalink)
Member: 13148
Thanks Meter: 1,199
service firrmware are avalable at official service center (ASC) special for replacement eMMC procedure
Old 04-09-2019, 06:00   #6 (permalink)
Member: 2636476
Thanks Meter: 50
Sir i have service firmware
Aftet write service firmware via vender set is not on
That's why i need to know what mistake
Both emmc excsd is different is it issue
What is excsd explain plz
Old 04-09-2019, 09:30   #7 (permalink)
Member: 13148
Thanks Meter: 1,199
if you have service firmare for eMMC replace, all will be ok
you need to appeal to those from whom you took it.
we are not a Xiaomi Autorized Service Center and we do not know all the features of their use
Old 04-09-2019, 10:11   #8 (permalink)
Member: 2636476
Thanks Meter: 50
I m taking what is excsd
Both emmc is excsd is different
Old 04-09-2019, 10:53   #9 (permalink)
Member: 13148
Thanks Meter: 1,199
extcsd - emmc register backup file
Old 04-09-2019, 11:24   #10 (permalink)
Member: 2636476
Thanks Meter: 50
Sir 4x damaged emmc excsd
Y1 ok emmc excsd
Both is different excsd
I want to known can i put y1 emmc in 4x board
Old 04-09-2019, 15:56   #11 (permalink)
Member: 13148
Thanks Meter: 1,199
extсsd - is a individual eMMC data
you should not be worried that they are different,
they do not have to be the same.
The Following 4 Users Say Thank You to layder For This Useful Post:
Old 04-11-2019, 10:59   #12 (permalink)
Member: 2250995
Thanks Meter: 33
Factory Firmware For Your Model ,Blank Yur eMCP AND Instal by UMT Recommended
Mido = https://drive.google.com/file/d/10sq...ZFmr4PIuVk0iXo
Santoni = https://drive.google.com/file/d/18cJ...Cl5atgo9w4QN_Q
Pass =SIX Time Space
The Following 5 Users Say Thank You to najrazlug For This Useful Post:
Old 04-24-2019, 08:26   #13 (permalink)
Member: 2111301
Sonork: 1651880:UzjavaAzizbek
Thanks Meter: 28
Working SIX Time Space
Old 08-09-2019, 15:53   #14 (permalink)
Member: 2915484
password not working
Old 08-11-2019, 08:30   #15 (permalink)
Member: 13148
Thanks Meter: 1,199
password is press <Space> Six times
Page generated in 0.44451 seconds with 7 queries
