11-11-2018, 05:44 | #18 (permalink) |
No Life Poster Join Date: Aug 2017 Location: India
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | Are you sure without emmc also phone connects to PC? because I have tried other phones, once emmc removed phones stop connection with PC. Nothing shows on PC without emmc. |
11-11-2018, 07:39 | #19 (permalink) | |
Freak Poster Join Date: Nov 2010 Location: Vice City
Member: 1436243 Status: Offline Thanks Meter: 99 | Quote:
if your driver/usb port good you can try,just try insert cable, and you will know mtk based phone will recognise as mtk usb port without emmc/emcp qc based phone will be 9008/9006 without emmc/emcp something like that, let me know the result dont forget to check vcc and vccq voltage, if all ok do testpoint to force edl mode, still not work? try replace/check dat0 resistor,last hardway solution try jumper cmd resistor to ground. some clue, if phone only vibrate or on/off led and recognize by pc as dignostic port (like 900E etc) change firmware same result... its CPU problem all you need is try not ask about SURE or NOT, hope it help | |
The Following User Says Thank You to mifluvcute For This Useful Post: |
11-11-2018, 08:53 | #20 (permalink) | |
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | Quote:
