10-24-2019, 10:53 | #1 (permalink) |
No Life Poster Join Date: Aug 2017 Location: India
Member: 2746336 Status: Offline Sonork: NULL Thanks Meter: 47 | redmi note 4 dead boot repair done with magical easy jtag phone problem was after flash with mi tool successfully still dead.... recovery done...... EasyJTAG Box Firmware = 2.48 10/23/2019 6:38:03 PM> Setting interface to EasyJtag2/ISP_HiPower 10/23/2019 6:38:03 PM> Setting bus width to 1 Bit 10/23/2019 6:38:03 PM> HiPower mode is ON 10/23/2019 6:38:04 PM> Setting frequence to 18 Mhz 10/23/2019 6:38:04 PM> CMD Pullup Level: 1777 mV 10/23/2019 6:38:04 PM> CMD Active Level: 1878 mV 10/23/2019 6:38:04 PM> eMMC Init returned = 0 10/23/2019 6:38:04 PM> EMMC Device Information : 10/23/2019 6:38:04 PM> EMMC CID: 90014A484247346132A53573863E7493 10/23/2019 6:38:04 PM> EMMC CSD: D02701328F5903FFFFFFFFE78A400017 10/23/2019 6:38:04 PM> EMMC Manufacture Name: SKHYNIX , EMMC NAME: HBG4a2 , EMMC NAME (HEX): 484247346132 , S/N: 3573863E , rev. 0xA5 10/23/2019 6:38:04 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 7/2017 10/23/2019 6:38:04 PM> EMMC ROM 1 (Main User Data) Capacity: 29812 MB (000747400000) 10/23/2019 6:38:04 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 10/23/2019 6:38:04 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 10/23/2019 6:38:04 PM> EMMC GP1 (GP Partition 1) Capacity: 4 MB , ENH , WR_REL (000000400000) 10/23/2019 6:38:04 PM> EMMC Permanent Write Protection: No 10/23/2019 6:38:04 PM> EMMC Temporary Write Protection: No 10/23/2019 6:38:04 PM> Extended CSD Information : 10/23/2019 6:38:04 PM> Extended CSD rev: 1.8 (MMC 5.1) 10/23/2019 6:38:04 PM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) 10/23/2019 6:38:04 PM> Boot Bus Config: 0x00 , width 1bit 10/23/2019 6:38:04 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 10/23/2019 6:38:04 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 10/23/2019 6:38:04 PM> Device supports partitioning features 10/23/2019 6:38:04 PM> Device can have enhanced technological features in partitions and user data area 10/23/2019 6:38:04 PM> Device can have extended partitions attribute 10/23/2019 6:38:04 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 10/23/2019 6:38:04 PM> Backup saved: HBG4a2_3573863E_20191023_183804.extcsd 10/23/2019 6:38:04 PM> EMMC Init completed. EasyJTAG Box Firmware = 2.48 10/23/2019 6:39:33 PM> Setting interface to EasyJtag2/ISP_HiPower 10/23/2019 6:39:33 PM> Setting bus width to 1 Bit 10/23/2019 6:39:33 PM> HiPower mode is ON 10/23/2019 6:39:33 PM> Setting frequence to 18 Mhz 10/23/2019 6:39:33 PM> CMD Pullup Level: 1771 mV 10/23/2019 6:39:33 PM> CMD Active Level: 1878 mV 10/23/2019 6:39:33 PM> eMMC Init returned = 0 10/23/2019 6:39:33 PM> EMMC Device Information : 10/23/2019 6:39:33 PM> EMMC CID: 90014A484247346132A53573863E7493 10/23/2019 6:39:33 PM> EMMC CSD: D02701328F5903FFFFFFFFE78A400017 10/23/2019 6:39:33 PM> EMMC Manufacture Name: SKHYNIX , EMMC NAME: HBG4a2 , EMMC NAME (HEX): 484247346132 , S/N: 3573863E , rev. 0xA5 10/23/2019 6:39:33 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 7/2017 10/23/2019 6:39:33 PM> EMMC ROM 1 (Main User Data) Capacity: 29812 MB (000747400000) 10/23/2019 6:39:33 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 10/23/2019 6:39:33 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 10/23/2019 6:39:33 PM> EMMC GP1 (GP Partition 1) Capacity: 4 MB , ENH , WR_REL (000000400000) 10/23/2019 6:39:33 PM> EMMC Permanent Write Protection: No 10/23/2019 6:39:33 PM> EMMC Temporary Write Protection: No 10/23/2019 6:39:33 PM> Extended CSD Information : 10/23/2019 6:39:33 PM> Extended CSD rev: 1.8 (MMC 5.1) 10/23/2019 6:39:33 PM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) 10/23/2019 6:39:33 PM> Boot Bus Config: 0x00 , width 1bit 10/23/2019 6:39:33 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 10/23/2019 6:39:33 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 10/23/2019 6:39:33 PM> Device supports partitioning features 10/23/2019 6:39:33 PM> Device can have enhanced technological features in partitions and user data area 10/23/2019 6:39:33 PM> Device can have extended partitions attribute 10/23/2019 6:39:33 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 10/23/2019 6:39:33 PM> Backup saved: HBG4a2_3573863E_20191023_183933.extcsd 10/23/2019 6:39:33 PM> EMMC Init completed. 10/23/2019 6:39:33 PM> 10/23/2019 6:39:34 PM> Operation: Write by vendor (Qualcomm/HiSilicon) 10/23/2019 6:39:34 PM> 10/23/2019 6:39:34 PM> Creating GPT-partitioninig 10/23/2019 6:39:34 PM> GPT-partitioning done 10/23/2019 6:39:34 PM> 10/23/2019 6:39:34 PM> Partition name: modem 10/23/2019 6:39:34 PM> Filename: NON-HLOS.bin , Offset: 000004000000 , filesize: 88080384 bytes 10/23/2019 6:39:34 PM> eMMC switching to ROM1 10/23/2019 6:39:34 PM> Erasing partition... 10/23/2019 6:39:37 PM> Writing partition... 10/23/2019 6:40:20 PM> Done writing partition. Write speed: 2030.22 KB/s 10/23/2019 6:40:20 PM> Partition name: sbl1 10/23/2019 6:40:20 PM> Filename: sbl1.mbn , Offset: 00000C002400 , filesize: 370144 bytes 10/23/2019 6:40:20 PM> eMMC switching to ROM1 10/23/2019 6:40:20 PM> Erasing partition... 10/23/2019 6:40:21 PM> Writing partition... 10/23/2019 6:40:21 PM> Done writing partition. Write speed: 603.94 KB/s 10/23/2019 6:40:21 PM> Partition name: sbl1bak 10/23/2019 6:40:21 PM> Filename: sbl1.mbn , Offset: 00000C082400 , filesize: 370144 bytes 10/23/2019 6:40:21 PM> eMMC switching to ROM1 10/23/2019 6:40:23 PM> Erasing partition... 10/23/2019 6:40:23 PM> Writing partition... 10/23/2019 6:40:23 PM> Done writing partition. Write speed: 1793.03 KB/s 10/23/2019 6:40:23 PM> Partition name: rpm 10/23/2019 6:40:23 PM> Filename: rpm.mbn , Offset: 00000C102400 , filesize: 174468 bytes 10/23/2019 6:40:23 PM> eMMC switching to ROM1 10/23/2019 6:40:24 PM> Erasing partition... 10/23/2019 6:40:24 PM> Writing partition... 10/23/2019 6:40:24 PM> Done writing partition. Write speed: 896.37 KB/s 10/23/2019 6:40:24 PM> Partition name: rpmbak 10/23/2019 6:40:24 PM> Filename: rpm.mbn , Offset: 00000C182400 , filesize: 174468 bytes 10/23/2019 6:40:24 PM> eMMC switching to ROM1 10/23/2019 6:40:30 PM> Erasing partition... 10/23/2019 6:40:30 PM> Writing partition... 10/23/2019 6:40:31 PM> Done writing partition. Write speed: 1580.54 KB/s 10/23/2019 6:40:31 PM> Partition name: tz 10/23/2019 6:40:31 PM> Filename: tz.mbn , Offset: 00000C202400 , filesize: 1481984 bytes 10/23/2019 6:40:31 PM> eMMC switching to ROM1 10/23/2019 6:40:31 PM> Erasing partition... 10/23/2019 6:40:31 PM> Writing partition... 10/23/2019 6:40:32 PM> Done writing partition. Write speed: 1940.91 KB/s 10/23/2019 6:40:32 PM> Partition name: tzbak 10/23/2019 6:40:32 PM> Filename: tz.mbn , Offset: 00000C402400 , filesize: 1481984 bytes 10/23/2019 6:40:32 PM> eMMC switching to ROM1 10/23/2019 6:40:32 PM> Erasing partition... 10/23/2019 6:40:33 PM> Writing partition... 10/23/2019 6:40:34 PM> Done writing partition. Write speed: 1955.52 KB/s 10/23/2019 6:40:34 PM> Partition name: devcfg 10/23/2019 6:40:34 PM> Filename: devcfg.mbn , Offset: 00000C602400 , filesize: 37732 bytes 10/23/2019 6:40:34 PM> eMMC switching to ROM1 10/23/2019 6:40:34 PM> Erasing partition... 10/23/2019 6:40:48 PM> Writing partition... 10/23/2019 6:40:48 PM> Done writing partition. Write speed: 998.43 KB/s 10/23/2019 6:40:48 PM> Partition name: devcfgbak 10/23/2019 6:40:48 PM> Filename: devcfg.mbn , Offset: 00000C642400 , filesize: 37732 bytes 10/23/2019 6:40:48 PM> eMMC switching to ROM1 10/23/2019 6:40:48 PM> Erasing partition... 10/23/2019 6:40:49 PM> Writing partition... 10/23/2019 6:40:49 PM> Done writing partition. Write speed: 1040.26 KB/s 10/23/2019 6:40:49 PM> Partition name: dsp 10/23/2019 6:40:49 PM> Filename: adspso.bin , Offset: 00000C682400 , filesize: 16777216 bytes 10/23/2019 6:40:49 PM> eMMC switching to ROM1 10/23/2019 6:40:49 PM> Erasing partition... 10/23/2019 6:40:50 PM> Writing partition... 10/23/2019 6:40:58 PM> Done writing partition. Write speed: 2032.67 KB/s 10/23/2019 6:40:58 PM> Partition name: fsg 10/23/2019 6:40:58 PM> Filename: fs_image.tar.gz.mbn.img , Offset: 000010008000 , filesize: 140584 bytes 10/23/2019 6:40:58 PM> eMMC switching to ROM1 10/23/2019 6:40:58 PM> Erasing partition... 10/23/2019 6:40:59 PM> Writing partition... 10/23/2019 6:40:59 PM> Done writing partition. Write speed: 1405.04 KB/s 10/23/2019 6:40:59 PM> Partition name: sec 10/23/2019 6:40:59 PM> Filename: sec.dat , Offset: 000010188000 , filesize: 80 bytes 10/23/2019 6:40:59 PM> eMMC switching to ROM1 10/23/2019 6:40:59 PM> Erasing partition... 10/23/2019 6:41:00 PM> Writing partition... 10/23/2019 6:41:00 PM> Done writing partition. Write speed: 5.41 KB/s 10/23/2019 6:41:00 PM> Partition name: splash 10/23/2019 6:41:00 PM> Filename: splash.img , Offset: 000014000000 , filesize: 673348 bytes 10/23/2019 6:41:00 PM> eMMC switching to ROM1 10/23/2019 6:41:00 PM> Erasing partition... 10/23/2019 6:41:01 PM> Writing partition... 10/23/2019 6:41:01 PM> Done writing partition. Write speed: 1842.83 KB/s 10/23/2019 6:41:01 PM> Partition name: aboot 10/23/2019 6:41:01 PM> Filename: emmc_appsboot.mbn , Offset: 000018000000 , filesize: 589560 bytes 10/23/2019 6:41:01 PM> eMMC switching to ROM1 10/23/2019 6:41:01 PM> Erasing partition... 10/23/2019 6:41:02 PM> Writing partition... 10/23/2019 6:41:02 PM> Done writing partition. Write speed: 1750.86 KB/s 10/23/2019 6:41:02 PM> Partition name: abootbak 10/23/2019 6:41:02 PM> Filename: emmc_appsboot.mbn , Offset: 000018100000 , filesize: 589560 bytes 10/23/2019 6:41:02 PM> eMMC switching to ROM1 10/23/2019 6:41:02 PM> Erasing partition... 10/23/2019 6:41:03 PM> Writing partition... 10/23/2019 6:41:03 PM> Done writing partition. Write speed: 1812.95 KB/s 10/23/2019 6:41:03 PM> Partition name: boot 10/23/2019 6:41:03 PM> Filename: boot.img , Offset: 000018200000 , filesize: 25963850 bytes 10/23/2019 6:41:03 PM> eMMC switching to ROM1 10/23/2019 6:41:03 PM> Erasing partition... 10/23/2019 6:41:06 PM> Writing partition... 10/23/2019 6:41:18 PM> Done writing partition. Write speed: 2031.98 KB/s 10/23/2019 6:41:18 PM> Partition name: recovery 10/23/2019 6:41:18 PM> Filename: recovery.img , Offset: 00001C200000 , filesize: 27766094 bytes 10/23/2019 6:41:18 PM> eMMC switching to ROM1 10/23/2019 6:41:18 PM> Erasing partition... 10/23/2019 6:41:21 PM> Writing partition... 10/23/2019 6:41:34 PM> Done writing partition. Write speed: 2032.31 KB/s 10/23/2019 6:41:34 PM> Partition name: lksecapp 10/23/2019 6:41:34 PM> Filename: lksecapp.mbn , Offset: 000110000000 , filesize: 57352 bytes 10/23/2019 6:41:34 PM> eMMC switching to ROM1 10/23/2019 6:41:34 PM> Erasing partition... 10/23/2019 6:41:35 PM> Writing partition... 10/23/2019 6:41:35 PM> Done writing partition. Write speed: 1286.32 KB/s 10/23/2019 6:41:35 PM> Partition name: lksecappbak 10/23/2019 6:41:35 PM> Filename: lksecapp.mbn , Offset: 000110020000 , filesize: 57352 bytes 10/23/2019 6:41:35 PM> eMMC switching to ROM1 10/23/2019 6:41:35 PM> Erasing partition... 10/23/2019 6:41:36 PM> Writing partition... 10/23/2019 6:41:36 PM> Done writing partition. Write speed: 1270.02 KB/s 10/23/2019 6:41:36 PM> Partition name: cmnlib 10/23/2019 6:41:36 PM> Filename: cmnlib.mbn , Offset: 000110040000 , filesize: 201280 bytes 10/23/2019 6:41:36 PM> eMMC switching to ROM1 10/23/2019 6:41:36 PM> Erasing partition... 10/23/2019 6:41:37 PM> Writing partition... 10/23/2019 6:41:37 PM> Done writing partition. Write speed: 1477.04 KB/s 10/23/2019 6:41:37 PM> Partition name: cmnlibbak 10/23/2019 6:41:37 PM> Filename: cmnlib.mbn , Offset: 000110080000 , filesize: 201280 bytes 10/23/2019 6:41:37 PM> eMMC switching to ROM1 10/23/2019 6:41:37 PM> Erasing partition... 10/23/2019 6:41:37 PM> Writing partition... 10/23/2019 6:41:37 PM> Done writing partition. Write speed: 1792.94 KB/s 10/23/2019 6:41:38 PM> Partition name: cmnlib64 10/23/2019 6:41:38 PM> Filename: cmnlib64.mbn , Offset: 0001100C0000 , filesize: 255936 bytes 10/23/2019 6:41:38 PM> eMMC switching to ROM1 10/23/2019 6:41:38 PM> Erasing partition... 10/23/2019 6:41:38 PM> Writing partition... 10/23/2019 6:41:38 PM> Done writing partition. Write speed: 1605.96 KB/s 10/23/2019 6:41:38 PM> Partition name: cmnlib64bak 10/23/2019 6:41:38 PM> Filename: cmnlib64.mbn , Offset: 000110100000 , filesize: 255936 bytes 10/23/2019 6:41:38 PM> eMMC switching to ROM1 10/23/2019 6:41:39 PM> Erasing partition... 10/23/2019 6:41:39 PM> Writing partition... 10/23/2019 6:41:39 PM> Done writing partition. Write speed: 1737.60 KB/s 10/23/2019 6:41:39 PM> Partition name: keymaster 10/23/2019 6:41:39 PM> Filename: keymaster.mbn , Offset: 000110140000 , filesize: 226008 bytes 10/23/2019 6:41:39 PM> eMMC switching to ROM1 10/23/2019 6:41:39 PM> Erasing partition... 10/23/2019 6:41:40 PM> Writing partition... 10/23/2019 6:41:40 PM> Done writing partition. Write speed: 1654.45 KB/s 10/23/2019 6:41:40 PM> Partition name: keymasterbak 10/23/2019 6:41:40 PM> Filename: keymaster.mbn , Offset: 000110180000 , filesize: 226008 bytes 10/23/2019 6:41:40 PM> eMMC switching to ROM1 10/23/2019 6:41:40 PM> Erasing partition... 10/23/2019 6:41:41 PM> Writing partition... 10/23/2019 6:41:41 PM> Done writing partition. Write speed: 1814.71 KB/s 10/23/2019 6:41:41 PM> Partition name: userdata 10/23/2019 6:41:41 PM> Filename: userdata.img , Offset: 000148082000 , filesize: 433101996 bytes 10/23/2019 6:41:41 PM> eMMC switching to ROM1 10/23/2019 6:41:41 PM> Erasing partition... 10/23/2019 6:42:17 PM> 10/23/2019 6:42:17 PM> Stopped by User request... EasyJTAG Box Firmware = 2.48 10/23/2019 6:42:21 PM> Setting interface to EasyJtag2/ISP_HiPower 10/23/2019 6:42:21 PM> Setting bus width to 1 Bit 10/23/2019 6:42:21 PM> HiPower mode is ON 10/23/2019 6:42:22 PM> Setting frequence to 18 Mhz 10/23/2019 6:42:22 PM> CMD Pullup Level: 1772 mV 10/23/2019 6:42:22 PM> CMD Active Level: 1877 mV 10/23/2019 6:42:22 PM> eMMC Init returned = 0 10/23/2019 6:42:22 PM> EMMC Device Information : 10/23/2019 6:42:22 PM> EMMC CID: 90014A484247346132A53573863E7493 10/23/2019 6:42:22 PM> EMMC CSD: D02701328F5903FFFFFFFFE78A400017 10/23/2019 6:42:22 PM> EMMC Manufacture Name: SKHYNIX , EMMC NAME: HBG4a2 , EMMC NAME (HEX): 484247346132 , S/N: 3573863E , rev. 0xA5 10/23/2019 6:42:22 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 7/2017 10/23/2019 6:42:22 PM> EMMC ROM 1 (Main User Data) Capacity: 29812 MB (000747400000) 10/23/2019 6:42:22 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 10/23/2019 6:42:22 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 10/23/2019 6:42:22 PM> EMMC GP1 (GP Partition 1) Capacity: 4 MB , ENH , WR_REL (000000400000) 10/23/2019 6:42:22 PM> EMMC Permanent Write Protection: No 10/23/2019 6:42:22 PM> EMMC Temporary Write Protection: No 10/23/2019 6:42:22 PM> Extended CSD Information : 10/23/2019 6:42:22 PM> Extended CSD rev: 1.8 (MMC 5.1) 10/23/2019 6:42:22 PM> Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) 10/23/2019 6:42:22 PM> Boot Bus Config: 0x00 , width 1bit 10/23/2019 6:42:22 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 10/23/2019 6:42:22 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 10/23/2019 6:42:22 PM> Device supports partitioning features 10/23/2019 6:42:22 PM> Device can have enhanced technological features in partitions and user data area 10/23/2019 6:42:22 PM> Device can have extended partitions attribute 10/23/2019 6:42:22 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 10/23/2019 6:42:22 PM> Backup saved: HBG4a2_3573863E_20191023_184222.extcsd 10/23/2019 6:42:22 PM> EMMC Init completed. 10/23/2019 6:42:22 PM> 10/23/2019 6:42:22 PM> Scanning soft partitions 10/23/2019 6:42:22 PM> GPT header is found and is valid 10/23/2019 6:42:22 PM> Partition: modem, [000004000000 - 000009400000], size: 000005400000 10/23/2019 6:42:22 PM> Partition: fsc, [00000C000000 - 00000C000400], size: 000000000400 10/23/2019 6:42:22 PM> Partition: ssd, [00000C000400 - 00000C002400], size: 000000002000 10/23/2019 6:42:22 PM> Partition: sbl1, [00000C002400 - 00000C082400], size: 000000080000 10/23/2019 6:42:22 PM> Partition: sbl1bak, [00000C082400 - 00000C102400], size: 000000080000 10/23/2019 6:42:22 PM> Partition: rpm, [00000C102400 - 00000C182400], size: 000000080000 10/23/2019 6:42:22 PM> Partition: rpmbak, [00000C182400 - 00000C202400], size: 000000080000 10/23/2019 6:42:22 PM> Partition: tz, [00000C202400 - 00000C402400], size: 000000200000 10/23/2019 6:42:22 PM> Partition: tzbak, [00000C402400 - 00000C602400], size: 000000200000 10/23/2019 6:42:22 PM> Partition: devcfg, [00000C602400 - 00000C642400], size: 000000040000 10/23/2019 6:42:22 PM> Partition: devcfgbak, [00000C642400 - 00000C682400], size: 000000040000 10/23/2019 6:42:22 PM> Partition: dsp, [00000C682400 - 00000D682400], size: 000001000000 10/23/2019 6:42:22 PM> Partition: modemst1, [00000D682400 - 00000D802400], size: 000000180000 10/23/2019 6:42:22 PM> Partition: modemst2, [00000D802400 - 00000D982400], size: 000000180000 10/23/2019 6:42:22 PM> Partition: DDR, [000010000000 - 000010008000], size: 000000008000 10/23/2019 6:42:22 PM> Partition: fsg, [000010008000 - 000010188000], size: 000000180000 10/23/2019 6:42:22 PM> Partition: sec, [000010188000 - 00001018C000], size: 000000004000 10/23/2019 6:42:22 PM> Partition: splash, [000014000000 - 000014B00000], size: 000000B00000 10/23/2019 6:42:22 PM> Partition: aboot, [000018000000 - 000018100000], size: 000000100000 10/23/2019 6:42:22 PM> Partition: abootbak, [000018100000 - 000018200000], size: 000000100000 10/23/2019 6:42:22 PM> Partition: boot, [000018200000 - 00001C200000], size: 000004000000 10/23/2019 6:42:22 PM> Partition: recovery, [00001C200000 - 000020200000], size: 000004000000 10/23/2019 6:42:22 PM> Partition: devinfo, [000020200000 - 000020300000], size: 000000100000 10/23/2019 6:42:22 PM> Partition: system, [000020300000 - 0000E0300000], size: 0000C0000000 10/23/2019 6:42:22 PM> Partition: cache, [0000E4000000 - 0000F4000000], size: 000010000000 10/23/2019 6:42:22 PM> Partition: persist, [0000F4000000 - 0000F6000000], size: 000002000000 10/23/2019 6:42:22 PM> Partition: misc, [0000F6000000 - 0000F6100000], size: 000000100000 10/23/2019 6:42:22 PM> Partition: keystore, [0000F6100000 - 0000F6180000], size: 000000080000 10/23/2019 6:42:22 PM> Partition: config, [0000F6180000 - 0000F6188000], size: 000000008000 10/23/2019 6:42:22 PM> Partition: oem, [0000F6188000 - 000106188000], size: 000010000000 10/23/2019 6:42:22 PM> Partition: limits, [000108000000 - 000108008000], size: 000000008000 10/23/2019 6:42:22 PM> Partition: mota, [00010C000000 - 00010C080000], size: 000000080000 10/23/2019 6:42:22 PM> Partition: dip, [00010C080000 - 00010C180000], size: 000000100000 10/23/2019 6:42:22 PM> Partition: mdtp, [00010C180000 - 00010E180000], size: 000002000000 10/23/2019 6:42:22 PM> Partition: syscfg, [00010E180000 - 00010E200000], size: 000000080000 10/23/2019 6:42:22 PM> Partition: mcfg, [00010E200000 - 00010E600000], size: 000000400000 10/23/2019 6:42:22 PM> Partition: lksecapp, [000110000000 - 000110020000], size: 000000020000 10/23/2019 6:42:22 PM> Partition: lksecappbak, [000110020000 - 000110040000], size: 000000020000 10/23/2019 6:42:22 PM> Partition: cmnlib, [000110040000 - 000110080000], size: 000000040000 10/23/2019 6:42:22 PM> Partition: cmnlibbak, [000110080000 - 0001100C0000], size: 000000040000 10/23/2019 6:42:22 PM> Partition: cmnlib64, [0001100C0000 - 000110100000], size: 000000040000 10/23/2019 6:42:22 PM> Partition: cmnlib64bak, [000110100000 - 000110140000], size: 000000040000 10/23/2019 6:42:22 PM> Partition: keymaster, [000110140000 - 000110180000], size: 000000040000 10/23/2019 6:42:22 PM> Partition: keymasterbak, [000110180000 - 0001101C0000], size: 000000040000 10/23/2019 6:42:22 PM> Partition: apdp, [000114000000 - 000114040000], size: 000000040000 10/23/2019 6:42:22 PM> Partition: msadp, [000114040000 - 000114080000], size: 000000040000 10/23/2019 6:42:22 PM> Partition: dpo, [000114080000 - 000114082000], size: 000000002000 10/23/2019 6:42:22 PM> Partition: cust, [000114082000 - 000148082000], size: 000034000000 10/23/2019 6:42:22 PM> Partition: userdata, [000148082000 - 0007473FBE00], size: 0005FF379E00 10/23/2019 6:42:22 PM> GPT header successfully parsed |
