10-23-2016, 10:27 | #1 (permalink) |
Junior Member Join Date: Nov 2015
Member: 2482510 Status: Offline Thanks Meter: 3 | Repair EMMC SDM032 i try to write rom1 but i cant ...meesage error ...mybe because its Sandisk EMMC not Samsung>>>>>> Z3X EasyJtag Software ver. 2.4.0.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: -==============, ,FW Ver.: 01.55 CMD Pullup Level (299 mV) too low , check cables etc. CMD Active Level:2289 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 02000053444D30333290FFFFFFFF29BC EMMC CSD : 8C0F002A015981E9B6D9FC1F8A4040AA EMMC Manufacturer ID: 0002 , OEM ID: 0000 EMMC Date: 02/2006 Rev.0x90 EMMC NAME: SDM032 , S/N: 4294967295 EMMC NAME (HEX): 53444D30333200 EMMC ROM1 (Main User Data) Capacity: 30 MB EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.0 (MMC 4.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x00 Device NOT support partitioning feature Device cannot have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: SDM032_4294967295_20161014_1425.extcsd Done. |
