Old 10-23-2016, 10:27   #1 (permalink)
Member: 2482510
Thanks Meter: 3
Repair EMMC SDM032
help me i write full flash by Direct eMMC Samsung Flasher ... nothing change.
i try to write rom1 but i cant ...meesage error ...mybe because its Sandisk EMMC not Samsung>>>>>>
Z3X EasyJtag Software ver. 2.4.0.0
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: -==============, ,FW Ver.: 01.55
CMD Pullup Level (299 mV) too low , check cables etc.
CMD Active Level:2289 mV
Box IO Level:2800 mV
CLK Rate:14000 khz
HiPower mode is off!
---------- eMMC Device Information ----------
EMMC CID : 02000053444D30333290FFFFFFFF29BC
EMMC CSD : 8C0F002A015981E9B6D9FC1F8A4040AA
EMMC Manufacturer ID: 0002 , OEM ID: 0000
EMMC Date: 02/2006 Rev.0x90
EMMC NAME: SDM032 , S/N: 4294967295
EMMC NAME (HEX): 53444D30333200
EMMC ROM1 (Main User Data) Capacity: 30 MB
EMMC ROM2 (Boot Partition 1) Capacity: 0 kB
EMMC ROM3 (Boot Partition 2) Capacity: 0 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.0 (MMC 4.0)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x00
Device NOT support partitioning feature
Device cannot have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: SDM032_4294967295_20161014_1425.extcsd
Done.
Old 10-23-2016, 18:48   #2 (permalink)
expenaticx's Avatar
Member: 1298419
Sonork: 100.1672105
Thanks Meter: 69
Dead eMMc chip change it with samsung one.
Old 10-24-2016, 00:00   #3 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
Hi bro , there is no solution for SDM032 by Sandisk. You need replace it!
Old 10-23-2017, 16:05   #4 (permalink)
Member: 1313184
Thanks Meter: 14
hi brother emmc damage and no solution for repaire emmc only replace it .
Old 10-27-2017, 11:43   #5 (permalink)
NoName®'s Avatar
Member: 129885
Sonork: 100:1603514
Thanks Meter: 6,202
No solutions at the moment.
Old 10-27-2017, 16:44   #6 (permalink)
Member: 961313
Sonork: 100.1625300
Thanks Meter: 35
I have toshiba 32gb and 16gb and sandisk 64gb ok ;;;; but just killed by direct write or just read
emmc 5.1 or 5.0 version
Page generated in 0.17652 seconds with 8 queries
