Old 02-19-2018, 16:19   #1 (permalink)
Crazy Poster
Member: 2642997
Thanks Meter: 4
Repair GPT table partition
Hi easy jtag team
i have this message when reading EMMC of SM-J100H with
GPT Table not present ,how can i solve this issue with easy jtag?
Old 02-19-2018, 17:58   #2 (permalink)
Yashbanswara's Avatar
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Just flash With Latest BL File if problem Not Solve Write Latest Latest Flash File With BL, AP, CP, CSC if problem Not Solve Contact Me On Sonork
Old 02-19-2018, 20:47   #3 (permalink)
Crazy Poster
Member: 2642997
Thanks Meter: 4
i try to make JTAG operation because the phone is dead in flash operation,but the log info shows that the GPT partition is not present so how can i restore the GPT partion table?
Old 02-20-2018, 00:53   #4 (permalink)
Member: 2554174
Thanks Meter: 3
Write rom dump files ,then flash the device with a firmware by easy jtag plus
Old 02-20-2018, 11:25   #5 (permalink)
Crazy Poster
Member: 2642997
Thanks Meter: 4
i don't have easy jtag plus a have only easy jtag
Old 02-20-2018, 11:34   #6 (permalink)
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Bro You Can Use Old Easy Jtag Plus Setup Try With This Setup easyjtag_emmc_plus_1.4.9.0.exe
Old 02-20-2018, 13:38   #7 (permalink)
Crazy Poster
Member: 2642997
Thanks Meter: 4
thank you verry much i've download it but still have this error
i flash pit file but the issue is not solved
Operation: Try to read table from emmc
Vendor: Samsung
Searching GPT ...
GPT header is not found
Partition table not found
any suggestion please?
Old 02-20-2018, 19:47   #8 (permalink)
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
Vendor: Samsung
Searching GPT ...
& Give Full Info With Screen Shot
Old 02-20-2018, 21:07   #9 (permalink)
Crazy Poster
Member: 2642997
Thanks Meter: 4
Here is the full log:
eMMC_tool Suite ver. 1.4.8.0
Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385)
Looking for EasyJTAG box...
EasyJTAG API ver. 2008
Setting IO Levels to 2.8V
Setting frequence to 14 Mhz
HiPower mode is OFF
EasyJTAG Box Serial = 01FFE00D8FE1587C
Card Serial = AAA5-808E
EasyJTAG Box Firmware = 01.62
Changelog:
08.08.2017 (ver 1.4.8.0)
Fix: Bugs that have been found through your crash report
Fix: Saving VCF for contacts
Add: Multiple file selection for Samsung firmware
Add: Write full Extcsd or write only the boot configuration ("Repair Extcsd" button)
Add: Intel vendor (for easy read/write ROM2/ROM3/GP1)
Add: "Pinouts" tab (taken from the catalog of classic software)
Add: Checker for Sony TrimArea
Add: Speed graph for "Random verify emmc"
Add: Fat16/Fat32/exFat support (Explorer)
HiPower mode is OFF
Frequence: 14 Mhz
CMD Pullup Level: 1773 mV
CMD Active Level: 2516 mV
EMMC Device Information :
EMMC CID: 90014A483447326211014467811652F6
EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA
EMMC Manufacture Name: SKHYNIX
EMMC Manufacture ID: 0x90 , OEM ID: 014A
EMMC Manufacture Date: 5/2015 , Rev: 01
EMMC NAME: H4G2b , S/N: 44678116 , rev. 01
EMMC NAME (HEX): 483447326211
EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51)
Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H4G2b_44678116_20180220_194142.extcsd
EMMC Init completed.
Opening file: J13G.pit
Pit: J13G.pit
Entry count: 29
The size of the last section has been updated
J100HXXU0AOA1_J100HLUX0AOA1_J100HXXU0AOA2_Home.tar .md5
The list of files in the firmware:
spl.img
sboot.bin
sboot2.bin
boot.img
recovery.img
system.img
sprdcp.img
sprddsp.img
cache.img
hidden.img
HiPower mode is OFF
Frequence: 14 Mhz
Backup saved: H4G2b_44678116_20180220_194156.extcsd
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Error writing at address: 000000000000 ... Retry #1
Error writing at address: 000000000000 ... Retry #2
Error writing at address: 000000000000 ... Retry #3
Writing PIT at address: 000000080000
GPT-partitioning done
Unpacking file: spl.img
Unpacking file: sboot.bin
Unpacking file: sboot2.bin
Unpacking file: sprddsp.img
Unpacking file: sprdcp.img
Unpacking file: boot.img
Unpacking file: recovery.img
Unpacking file: cache.img
Unpacking file: system.img
Unpacking file: hidden.img
Partition name: BOOT
Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes
eMMC switching to ROM2
Erasing partition...
Writing partition...
Done writing partition. Write speed: 315,79 Kb/s
Partition name: SBOOT
Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes
eMMC switching to ROM1
Done writing partition. Write speed: 1157,70 Kb/s
Partition name: SBOOT2
Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes
Done writing partition. Write speed: 1154,50 Kb/s
Partition name: WDSP
Filename: sprddsp.img , Offset: 000000C00000 , filesize: 1968128 bytes
Done writing partition. Write speed: 1225,55 Kb/s
Partition name: MODEM
Filename: sprdcp.img , Offset: 000001000000 , filesize: 7375844 bytes
Done writing partition. Write speed: 869,46 Kb/s
Partition name: KERNEL
Filename: boot.img , Offset: 000004500000 , filesize: 5663744 bytes
Done writing partition. Write speed: 876,16 Kb/s
Partition name: RECOVERY
Filename: recovery.img , Offset: 000005500000 , filesize: 6994944 bytes
Done writing partition. Write speed: 879,27 Kb/s
Partition name: CSC
Filename: cache.img , Offset: 000006500000 , filesize: 19312912 bytes
Sparse image found v.1.0 Total chunks: 15
Done writing partition. Write speed: 1017,59 Kb/s
Partition name: SYSTEM
Filename: system.img , Offset: 000012D00000 , filesize: 955488064 bytes
Sparse image found v.1.0 Total chunks: 1650
Error writing at address: 00002F988000 ... Retry #1
Error writing at address: 0000447DA000 ... Retry #1
Error writing at address: 00004B382000 ... Retry #1
Done writing partition. Write speed: 839,38 Kb/s
Partition name: HIDDEN
Filename: hidden.img , Offset: 000053D00000 , filesize: 7762160 bytes
Sparse image found v.1.0 Total chunks: 13
Done writing partition. Write speed: 1195,02 Kb/s
All done
Old 02-21-2018, 06:26   #10 (permalink)
Member: 1147254
Sonork: 100.1620677
Thanks Meter: 639
HiPower mode is OFF
Changelog:
HiPower mode is OFF
Frequence: 14 Mhz
Pit: J13G.pit
Entry count: 29
spl.img
sboot.bin
sboot2.bin
boot.img
recovery.img
system.img
sprdcp.img
sprddsp.img
cache.img
hidden.img
HiPower mode is OFF
Frequence: 14 Mhz
Partition name: CSC
All done
After Write All Files Give Detect Info
Old 06-11-2021, 22:09   #11 (permalink)
Member: 22284
Thanks Meter: 81
Me too i have the same message on a8 2018 SM-A530FD 32GB
Setting interface to EasyJtag2/ISP
Setting bus width to 1 Bit
Setting frequence to 24 MHz
CMD Pullup Level: 434 mV
CMD Active Level: 1370 mV
EMMC CID: 150100424A54443452000684ECE174F9
EMMC CSD: 902701320F5903FFF6DB7FE08A40403B
EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 0684ECE1 , rev. 0x00
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2017
EMMC ROM 1 (Main User Data) Capacity: 29804 MB (000746C00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 0 KB (000000000000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 0 KB (000000000000) Counter: 0 , Response: Maybe not clean
EMMC GP1 (GP Partition 1) Capacity: 8 MB , WR_REL (000000800000)
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x01 , width 4bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
Backup saved: BJTD4R_0684ECE1_20210611_230553.extcsd
Scanning soft partitions
Error reading at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #1
Error reading at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #2
Error reading at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #3
Error reading at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #4
Error reading at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #5
Too many errors. Reading has been stopped
File Type: jpg emmc tool 2.jpg (157 Bytes, 333 views)
Old 06-12-2021, 08:47   #12 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
you chip may be dead
try to reflash eMMC firmware, it may be work some time
Old 06-12-2021, 09:53   #13 (permalink)
Member: 22284
Thanks Meter: 81
Where to get the eMMC firmware,Below is my chip info ,if anybody has send me Please
SEC 846
R041
KLMBG2JETD
S7RT5AZTE
I have the backup for this this phone but i do not know which file is ROM 1,ROM2,ROM3 and GP1 if anyone can identify from the this picture attached i would appreciate
Old 06-12-2021, 16:26   #14 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
SEC 846
R041
KLMBG2JETD
S7RT5AZTE
you can read it from same or this IC
Old 06-12-2021, 17:43   #15 (permalink)
Member: 22284
Thanks Meter: 81
i read that data i have before i messed up and now i want to rewrite but i do not know which file to load as Rom 1,2,3 plus GP1 that is why am asking from the attached which are those files?
May check this attachment and see what am asking
Page generated in 0.41253 seconds with 9 queries
