Old 01-01-2024, 10:45   #1 (permalink)
Member: 1813139
Thanks Meter: 45
problem emmc dump
EasyJtag Suite Classic ver.: 3.8.0.6 / wxWidgets 3.2.3-W-U started.
OS ver.: Windows 10 (build 19045), 64-bit edition. Admin rights FAIL
Easy JTAG Autorun Agentver:1.0.0.0
CrashSender library ver:1.4.0.3
Curl binary ver:7.56.1.0
EasyJTAG binary ver:3.8.0.6
EasyJTAG SPI Plugin ver:1.1.1.13
LibUSB Library ver:1.2.6.0
WinFSP SDK ver:1.12.22301.0
Setting box Pinout ...
Box Drivers version: 10.0.19041.3636
Z3X Card Serial : AA25-CBEC , ver: 22
Z3X Card Activation [JTAGPLUS] : ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
For more information press F1 to open local help or visit our wiki
Found 1 serial devices
COM3 USB\VID_1781&PID_AAAC&REV_0100&MI_00 USB Serial Device (COM3)
Selected pinout: GEN2 ISP Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.8.0.6
Loading eMMC GEN2 Firmware... IO: 1800 mV
Box S/N: 0FC1CA12ECED70AA, ,FW Ver.: 02.53
CMD Pullup Level:1854 mV
CMD Active Level:1855 mV
Box IO Level:1800 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
HiPower mode is ON!
---------- eMMC Device Information ----------
eMMC CID : 15010044563644424200CBC1D47139CB
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 03/2006 Rev.0x0
eMMC NAME: DV6DBB , S/N: 3418477681
eMMC NAME (HEX): 445636444242
EMMC ROM1 (Main User Data) Capacity: 119280 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 5743 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1).
Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: DV6DBB_3418477681_20240101_1136.extcsd
Warning! One or more CRCs don't match. You should repair the disk!
Caution: Found protective or hybrid MBR and corrupt GPT.
Real (Hardware) Disk/Image size: E8F8000 sectors 116.5 GiB
Soft (Partitioned) Disk/Image size: E8F7FBC sectors 116.5 GiB
Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,244285406
Partition info successfully found
------ Detected 49 partitions ------
P0 (EFS) [0x400000 0xc00000] Size: 0x800000 (8.0MB)
P1 (SEC_EFS) [0xc00000 0x1400000] Size: 0x800000 (8.0MB)
P2 (STEADY) [0x1400000 0x1800000] Size: 0x400000 (4.0MB)
P3 (NVRAM) [0x1800000 0x5800000] Size: 0x4000000 (64.0MB)
P4 (SPMFW) [0x5800000 0x5900000] Size: 0x100000 (1.0MB)
P5 (SCP1) [0x5900000 0x5a00000] Size: 0x100000 (1.0MB)
P6 (SSPM_1) [0x5a00000 0x5b00000] Size: 0x100000 (1.0MB)
P7 (UH) [0x5b00000 0x5d00000] Size: 0x200000 (2.0MB)
P8 (TEE1) [0x5d00000 0x5f00000] Size: 0x200000 (2.0MB)
P9 (TZAR) [0x5f00000 0x6300000] Size: 0x400000 (4.0MB)
P10 (GZ1) [0x6300000 0x7300000] Size: 0x1000000 (16.0MB)
P11 (LK) [0x7300000 0x7500000] Size: 0x200000 (2.0MB)
P12 (DTBO) [0x7500000 0x7d00000] Size: 0x800000 (8.0MB)
P13 (VBMETA) [0x7d00000 0x7d10000] Size: 0x10000 (64.0KB)
P14 (BTD) [0x7d10000 0x8000000] Size: 0x2f0000 (2.937MB)
P15 (PROTECT1) [0x8000000 0x8800000] Size: 0x800000 (8.0MB)
P16 (PROTECT2) [0x8800000 0x9000000] Size: 0x800000 (8.0MB)
P17 (SECCFG) [0x9000000 0x9800000] Size: 0x800000 (8.0MB)
P18 (BOTA) [0x9800000 0xc580000] Size: 0x2d80000 (45.500MB)
P19 (BOOT_PARA) [0xc580000 0xdf80000] Size: 0x1a00000 (26.0MB)
P20 (PARA) [0xdf80000 0xe000000] Size: 0x80000 (512.0KB)
P21 (MISC) [0xe000000 0xe080000] Size: 0x80000 (512.0KB)
P22 (EXPDB) [0xe080000 0xf480000] Size: 0x1400000 (20.0MB)
P23 (FRP) [0xf480000 0xf580000] Size: 0x100000 (1.0MB)
P24 (NVCFG) [0xf580000 0x11580000] Size: 0x2000000 (32.0MB)
P25 (NVDATA) [0x11580000 0x15580000] Size: 0x4000000 (64.0MB)
P26 (METADATA) [0x15580000 0x17580000] Size: 0x2000000 (32.0MB)
P27 (KEYREFUGE) [0x17580000 0x18580000] Size: 0x1000000 (16.0MB)
P28 (KEYDATA) [0x18580000 0x19580000] Size: 0x1000000 (16.0MB)
P29 (MD_UDC) [0x19580000 0x1ac1a000] Size: 0x169a000 (22.601MB)
P30 (PERSISTENT) [0x1ac1a000 0x1ac9a000] Size: 0x80000 (512.0KB)
P31 (PROINFO) [0x1ac9a000 0x1af9a000] Size: 0x300000 (3.0MB)
P32 (MD1IMG) [0x1af9a000 0x22f9a000] Size: 0x8000000 (128.0MB)
P33 (PARAM) [0x22f9a000 0x2339a000] Size: 0x400000 (4.0MB)
P34 (UP_PARAM) [0x2339a000 0x2379a000] Size: 0x400000 (4.0MB)
P35 (BOOT) [0x2379a000 0x2579a000] Size: 0x2000000 (32.0MB)
P36 (RECOVERY) [0x2579a000 0x2779a000] Size: 0x2000000 (32.0MB)
P37 (VBMETA_SYSTEM) [0x2779a000 0x277aa000] Size: 0x10000 (64.0KB)
P38 (VBMETA_VENDOR) [0x277aa000 0x277ba000] Size: 0x10000 (64.0KB)
P39 (EFUSE) [0x277ba000 0x2783a000] Size: 0x80000 (512.0KB)
P40 (RESERVED) [0x2783a000 0x28000000] Size: 0x7c6000 (7.773MB)
P41 (SEC1) [0x28000000 0x28800000] Size: 0x800000 (8.0MB)
P42 (SUPER) [0x28800000 0x1fc000000] Size: 0x1d3800000 (7.304GB)
sp (system) Size: 0x128d43000 (4.637GB)
(system_region_0) [0x28900000 0x14b500000] Size: 0x122c00000 (4.542GB)
(system_region_1) [0x14f400000 0x150000000] Size: 0xc00000 (12.0MB)
(system_region_2) [0x1bd100000 0x1bed00000] Size: 0x1c00000 (28.0MB)
(system_region_3) [0x1c1c00000 0x1c5500000] Size: 0x3900000 (57.0MB)
(system_region_4) [0x1c6f00000 0x1c6f43000] Size: 0x43000 (268.0KB)
sp (vendor) Size: 0x30f5e000 (783.367MB)
(vendor_region_0) [0x150000000 0x17d500000] Size: 0x2d500000 (725.0MB)
(vendor_region_1) [0x1bed00000 0x1bee00000] Size: 0x100000 (1.0MB)
(vendor_region_2) [0x1c9900000 0x1cc900000] Size: 0x3000000 (48.0MB)
(vendor_region_3) [0x14b500000 0x14bd00000] Size: 0x800000 (8.0MB)
(vendor_region_4) [0x1c5500000 0x1c565e000] Size: 0x15e000 (1.367MB)
sp (product) Size: 0x4ea53000 (1.228GB)
(product_region_0) [0x17d500000 0x1bcc00000] Size: 0x3f700000 (1015.0MB)
(product_region_1) [0x1bee00000 0x1c1c00000] Size: 0x2e00000 (46.0MB)
(product_region_2) [0x1cd500000 0x1d3f00000] Size: 0x6a00000 (106.0MB)
(product_region_3) [0x1c7900000 0x1c8600000] Size: 0xd00000 (13.0MB)
(product_region_4) [0x14bd00000 0x14f400000] Size: 0x3700000 (55.0MB)
(product_region_5) [0x1c5700000 0x1c6e53000] Size: 0x1753000 (23.324MB)
sp (odm) Size: 0x426000 (4.148MB)
(odm_region_0) [0x1bcc00000 0x1bd026000] Size: 0x426000 (4.148MB)
P43 (PRISM) [0x1fc000000 0x233000000] Size: 0x37000000 (880.0MB)
P44 (OPTICS) [0x233000000 0x234800000] Size: 0x1800000 (24.0MB)
P45 (CACHE) [0x234800000 0x241000000] Size: 0xc800000 (200.0MB)
P46 (OMR) [0x241000000 0x244200000] Size: 0x3200000 (50.0MB)
P47 (SPU) [0x244200000 0x247400000] Size: 0x3200000 (50.0MB)
P48 (USERDATA) [0x247400000 0x1d1ec00000] Size: 0x1ad7800000 (107.367GB)
------ Android information ------
Detected LINUX(Android) system : 0x0028803400 (4.637GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 6512
Short Android info:
Device Brand: samsung
Device Name B: a32
Device Manufacturer: samsung
Device Model: SM-A325F
Device Name A: a32xx
Build ID: TP1A.220624.014
Display Build ID: TP1A.220624.014.A325FXXU5DWE3
Release Incremental ID: A325FXXU5DWE3
Release Base ID: 13
Security Path: 2023-06-01
Architecture ABI: arm64-v8a
Product ID: a32
Build Description: a32xx-user 13 TP1A.220624.014 A325FXXU5DWE3 release-keys
PDA ver.: A325FXXU5DWE3
MTK Branch: alps-mp-t0.mssi1.tc10sp
MTK Version: alps-mp-t0.mp1.tc10sp-V1.74
Backup saved: BuildProp_20240101_1136.txt
Detected USERDATA USERDATA : 0x0247400000 (107.367GB)
Unable to mount USERDATA , code : 95
Userdata Superblock contents::
Done.
Running:SAMSUNG: eMMC firmware dump...
Init OK...
Firmware file...C:\Users\Meran\OneDrive\Desktop\NADEEM A325F\FFU\new ok clean\New folder\eMMC_Firmware_Unknown.bin
Checking security ...
Running:SAMSUNG: MoviNAND Firmware extraction...
Skip loading eMMC Addon Firmware
CLK Rate:14000 kHz
Checking eMMC BootROM mode
CMD Pullup Level:1853 mV
CLK Rate:14000 kHz
--- EasyJTAG Samsung eMMC Backup Tool ---
EMMC CID : 15010044563644424200CBC1D47139CB
EMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 03/2006 Rev.0x0
EMMC NAME: DV6DBB , S/N: 3418477681
EMMC Part Number: Unknown
EMMC ROM2 (Boot Partition 1/2) Capacity: 4096 kB
Setup firmware read mode, wait 2..30 sec...
Reading eMMC NAND...
Trying Block 100000
Trying Block 80000
Trying Block 40000
Trying Block 60000
Trying Block 40000
Trying Block 50000
Trying Block 40000
Trying Block 48000
Trying Block 40000
Trying Block 38000
Trying Block 30000
Trying Block 28000
Trying Block 20000
Trying Block 18000
Trying Block 10000
Trying Block 8000
Trying Block 4000
Trying Block 2000
Trying Block 1000
Trying Block 800
Read Block 800
Coarse eMMC Firmware end reached, length 800
Fine eMMC Firmware end reached, length 0
Done result= 0
Firmware Hash41D8CD98F00B204E9800998ECF8427E
Saving eMMC CID Data...
You are lucky and found unique FFU file, please contact support ;-)
Processing firmware data...
Reading eMMC NAND Done.
Old 01-04-2024, 06:36   #2 (permalink)
Member: 3012436
Thanks Meter: 6
Try 4 bit mode.
Make backup.
Try to repair GPT from update or factory firmware.
Page generated in 0.16865 seconds with 8 queries
