09-08-2020, 16:07 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Tg Mures (Romania)
Member: 246926 Status: Offline Thanks Meter: 107 | Easy Jtag plus read and write speed problem Look at log . Max speed is about 970Kb/s and in isp mode is same . Can tell me anybody where is problem?Hardware, maybe my box?thanks! On socket i never read before ....This is first time. the emmc is new. Tried 2 laptops with win 7 ,32bit. Thanks! https://ibb.co/S5TNBwM https://ibb.co/wKQzj2K Here is find same problem :https://forum.gsmhosting.com/vbb/f67...d-box-2520964/ |
09-09-2020, 19:22 | #3 (permalink) | |
Member: 246926 Status: Offline Thanks Meter: 107 | Quote:
Thanks for interest! Look at pictures what socket used. https://ibb.co/9g360N9 https://ibb.co/x2252dN https://ibb.co/C1rgPnt https://ibb.co/9rGZZcz https://ibb.co/SJCZCmq I put another 2 USB box cable,another usb com port,(don't have USB3.0) My laptop is Dell latitude D630.But also tried another laptop ACER Aspire 5349. | |
09-09-2020, 19:42 | #4 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
It's a strange problem | |
09-23-2020, 20:15 | #5 (permalink) |
Member: 246926 Status: Offline Thanks Meter: 107 | I sent my box with my emmc ,emmc socket,usb cable to a friend who tested my cable ,my socket with my emmc .He has another easy jtag plus box but his working properly. He is reading with 12433kb/s and my box is reading with 990kb/s the same emmc with same emmc socket adapter,on same laptop. It seems my box is defective. Somebody know what is the problem or how to fix it?Thanks! |
09-24-2020, 04:26 | #6 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
https://ibb.co/SJCZCmq with this error i confirm need change port with this warning message this port speed too slow in any opration with any box clean USB port or resold port box fine ic fine cable fine problem is port | |
The Following User Says Thank You to sneha For This Useful Post: |
09-24-2020, 07:05 | #7 (permalink) | |
Thanks for the reply ,maybe you are right,but as i say i sent my box to a friend and he tested with another laptop and also same problem.So usb port is nothing do with my problem. Question ,if i have the Z3X v1.0 6in1 socket for emmc look here: https://ibb.co/wL50SV2 ,must connect directly to my box or must use the e socket adaptor? like this:https://ibb.co/Vg8DBjR Thanks! | |
09-24-2020, 07:56 | #8 (permalink) |
Member: 246926 Status: Offline Thanks Meter: 107 | Another thing ,my laptop has 4 usb ports,and i tried every port.same message appear:this device can perform faster if conect to high speed usb port or something like this.. |
09-24-2020, 09:11 | #9 (permalink) | |
if you solved this problem this device can perform faster if conect to high speed usb port then your all problem solve about speed check usb port clean it or check from motherboard and don`t search any other solution for speed | |
09-24-2020, 09:12 | #10 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | I can assume that this is a possible low-quality manufacturing of the box board at the factory. here is the option to send under warranty or try to solder the main 2 chips in the box. |
09-24-2020, 12:53 | #11 (permalink) | |
Thanks again but in my friend laptop not appear this message ,and still not read just in low speed as i say.And my friend box read OK.understand now? The message appear only in my laptop.that's why i send only box to my friend to test it. | |
10-05-2020, 19:22 | #12 (permalink) |
Member: 246926 Status: Offline Thanks Meter: 107 | Hi! I solved this problem:this device can perform faster if conect to high speed usb port This message not appear anymore,and problem was in my box.User Sneha was right,but problem is not the usb port,i cleaned contacts .I resoldered the 2 chip pins with hot air station.No succes. How solved? I buyed another box without card and i put card from old easy jtag plus box to new one. as i say no message appear and speed is now aprox 24000 kb/sec. But the big question what is the real problem in my old box?? Only the manufacturer can tell me.... Thanks anyway to members who helped me. I am still wondering what is the real problem with my first box. Last edited by attilaa0; 10-05-2020 at 19:27. |
10-05-2020, 19:57 | #13 (permalink) |
Member: 246926 Status: Offline Thanks Meter: 107 | Hi again! I found the problem in my first box. The rezistor R9 is missing!!! I measured in new box and it is 6K8 . I put 10K for test and it seems to be OK!OK!OK! So no more message appear! Maybe help someone else! |
The Following User Says Thank You to attilaa0 For This Useful Post: |
