10-08-2019, 08:04 | #1 (permalink) | |
No Life Poster Join Date: Jan 2010
Member: 1212133 Status: Offline Thanks Meter: 58 | RPMB - questions Not supported yet ... What do I wrong? Next question I read http://forum.gsmhosting.com/vbb/f672...at-do-2587891/ and there is a text Quote:
how can I find out the status of RPMB partition? Thanks | |
10-08-2019, 10:14 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
may be you use old software you need use latest software | |
10-08-2019, 10:33 | #3 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | I use eMMC tool suite ver. 1.6.2.0 release date 30.06.2019. Is this the latest version? In eMMC General tab I choose ROM to access there RPMB ( Protected Data Block) and when I click on Read eMMC, I receive Not supported yet ... in the log window. Is there any other method for RPMB ? Thanks |
10-08-2019, 10:49 | #5 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | we did not add reading RPMB to eMMC tool shuite, because it carries no practical value |
The Following 2 Users Say Thank You to layder For This Useful Post: |
10-09-2019, 17:21 | #6 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | Thanks for your reply. I have EMMC Device Information : EMMC CID: 450100444134303634013D6D55043582 EMMC CSD: D00F00328F5903FFFFFFFFEF8A404022 EMMC Manufacture : SANDISK , EMMC NAME: DA4064 , HEX: 444134303634 , S/N: 3D6D5504 , rev. 0x01 EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2018 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 309 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 So, does it mean that RPMB is not empty and I can not replace that eMMC with a new eMMC because I can not write RPMB? Or why is the counter NOT zero?Does it mean the operating systen checks if the eMMC is original? |
10-09-2019, 18:41 | #7 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | I explained everything quite clearly in the thread: http://forum.gsmhosting.com/vbb/f672...at-do-2587891/ it clearly says that we cannot write RPMB without a key, and it says that the RPMB counter increases when each block is written. RPMB can not be erased - only written with key (and it is increace the counter) |
The Following 4 Users Say Thank You to layder For This Useful Post: |
10-10-2019, 20:30 | #8 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | Thanks for the reply. So, if the Counter is positive like this RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 309 , Response: Not Clean it means CPU wrote to RPMB. Does it mean that if the Counter is positive , the old eMMC can not be replaced with a new eMMC, because I can not read the RPMB from the old eMMC and write to RPMB of the new eMMC? |
The Following User Says Thank You to Jane1 For This Useful Post: |
10-10-2019, 22:26 | #9 (permalink) | |
Some brands/firmware not needed Clean RPMB, when eMMC is replaced (some Qualcomm) Some brands/firmware not started/freezed on boot if RPMB not CLean at new eMMC (Exynos-Samsung) Some brands/firmware not started/freezed on boot if RPMB no have security info (Xiaomi) | |
The Following 7 Users Say Thank You to layder For This Useful Post: |
10-10-2019, 22:47 | #10 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | UFI team is declared read-writed RPMB area one-two years ago. Out team can't hack RPMB key at eMMC and replace it to some new I can't help you more then this |
The Following 5 Users Say Thank You to layder For This Useful Post: |
10-11-2019, 06:46 | #11 (permalink) |
Member: 1212133 Status: Offline Thanks Meter: 58 | Thanks for the reply. But is there any way ,how to know: if Exynos-Samsung based phone does not start that it is a result of not CLean RPMB problem and not something else? Is there any list such Exynos-Samsung based phones that needs clean RPMB? if Xiaomi does not start it is security info problem and not something else? |
10-11-2019, 09:39 | #12 (permalink) | |
We add info about RPMB status for this Xiaomi Qualcom bootloader check data at RPMB, and freezed on boot if eMMC change | |
10-13-2019, 12:18 | #13 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 1175 , Response: Not Clean or EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean or EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean LYDER SIR U GIVE THIS THREE LOG, PLZ CLEAR WHEN I READ ANY LOG AND RPMB SHOW NOT CLEAN, MAYBE NOT CLEAN THEN CAN I USE THIS EMMC OR NOT PLZ CLEAR THIS. |
10-26-2019, 11:01 | #15 (permalink) |
Member: 2298369 Status: Offline Thanks Meter: 440 | LYDER SIR WHY CPU WRITE DATA IN RPMB PARTITIONS, WHEN U NOT GIVEN LOGS IN OLD VERSION WE HAVE NO IDEA TO CHECK RPMB PARTITION BUT NOW WE ARE WATCHING VERY FEW IC CLEAN OTHERWISE MAXIMUM IC ARE WASTE NO ENOUGH STOCK TO RECOVER HANDSETS I HAVE ONE HANDSET LYF LS-5010 HANG ON LOGO WHEN I TRY TO FLASH IT GIVE ERROR IN LAST SO FINALLY WHEN I CHECK EMMC IT SHOW RPMB NOT CLEAN- After reconnect, make sure that the size of ROM1 has been changed. Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 42 MHz EMMC Device Information : EMMC CID: 150100463732324D420058BFE00BB251 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: F722MB , HEX: 463732324D42 , S/N: 58BFE00B , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2015 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000) Counter: 25 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: F722MB_58BFE00B_20191026_152307.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: fsg, [000004000000 - 000004180000], size: 000000180000 (1.50 MB) Partition: sbl1, [000008000000 - 000008080000], size: 000000080000 (512. KB) Partition: aboot, [000008080000 - 000008180000], size: 000000100000 (1.00 MB) Partition: rpm, [000008180000 - 000008200000], size: 000000080000 (512. KB) Partition: tz, [000008200000 - 000008280000], size: 000000080000 (512. KB) Partition: hyp, [000008280000 - 000008300000], size: 000000080000 (512. KB) Partition: pad, [000008300000 - 000008400000], size: 000000100000 (1.00 MB) Partition: modemst1, [000008400000 - 000008580000], size: 000000180000 (1.50 MB) Partition: modemst2, [000008580000 - 000008700000], size: 000000180000 (1.50 MB) Partition: misc, [000008700000 - 000008800000], size: 000000100000 (1.00 MB) Partition: fsc, [000008800000 - 000008800400], size: 000000000400 (1.00 KB) Partition: ssd, [000008800400 - 000008802400], size: 000000002000 (8.00 KB) Partition: splash, [000008802400 - 000009202400], size: 000000A00000 (10.0 MB) Partition: keystore, [000009202400 - 000009282400], size: 000000080000 (512. KB) Partition: config, [000009282400 - 000009302400], size: 000000080000 (512. KB) Partition: oem, [000009302400 - 00000D302400], size: 000004000000 (64.0 MB) Partition: sbl1bak, [00000D302400 - 00000D382400], size: 000000080000 (512. KB) Partition: rpmbak, [00000D382400 - 00000D402400], size: 000000080000 (512. KB) Partition: tzbak, [00000D402400 - 00000D482400], size: 000000080000 (512. KB) Partition: hypbak, [00000D482400 - 00000D502400], size: 000000080000 (512. KB) Partition: abootbak, [000010000000 - 000010100000], size: 000000100000 (1.00 MB) Partition: modem, [000010100000 - 000014100000], size: 000004000000 (64.0 MB) Partition: DDR, [000014100000 - 000014108000], size: 000000008000 (32.0 KB) Partition: sec, [000014108000 - 00001410C000], size: 000000004000 (16.0 KB) Partition: boot, [00001410C000 - 00001610C000], size: 000002000000 (32.0 MB) Partition: system, [00001610C000 - 00009610C000], size: 000080000000 (2.00 GB) Partition: persist, [00009610C000 - 00009810C000], size: 000002000000 (32.0 MB) Partition: cache, [00009810C000 - 0000A810C000], size: 000010000000 (256. MB) Partition: recovery, [0000A810C000 - 0000AA10C000], size: 000002000000 (32.0 MB) Partition: userdata, [0000AA10C000 - 0001D1FFBE00], size: 000127EEFE00 (4.62 GB) GPT header successfully parsed Get firmware version Brand = LYF Manufacturer = JSR Device = LS-5010 Model = LS-5010 Phone platform = msm8916 CPU Abi = arm64-v8a Android release = 5.1.1 Firmware version = LYF_LS-5010_01_05_15 Firmware date = Sun May 15 00:31:35 CST 2016 I TRY TO MAKE GP PARTITIONS BUT ALL SAME AS BEFORE THIS IS NEW TROUBLE FOR US TO REPAIR EMMC. |
The Following 3 Users Say Thank You to galaxycompue For This Useful Post: |
