03-17-2014, 22:32 | #5 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 52
Member: 169616 Status: Offline Thanks Meter: 20 | Successfully connected to box on COM2 Box S/N: 11110519D47D5C49, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.104.0 Loading eMMC Addon Firmware... Warning: CMD Pullup Level (1124 mV) too low , check cables etc.!!! CMD Active Level:1619 mV EMMC CID 15010056545530304DF1D8146CD57F6F EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 3625217237 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_3625217237_20140201_2336.extcsd Done. Running:SAMSUNG: Smart Factory Reset + Format... Successfully connected to box on COM2 Box S/N: 11110519D47D5C49, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.104.0 Loading eMMC Addon Firmware... Warning: CMD Pullup Level (1113 mV) too low , check cables etc.!!! CMD Active Level:1629 mV EMMC CID 15010056545530304DF1D8146CD57F6F EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 3625217237 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_3625217237_20140201_2337.extcsd Sending Smart Wipe Request... Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! Running:SAMSUNG: MoviNAND Format... Successfully connected to box on COM2 Box S/N: 11110519D47D5C49, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.104.0 Loading eMMC Addon Firmware... Warning: CMD Pullup Level (1124 mV) too low , check cables etc.!!! CMD Active Level:1639 mV EMMC CID 15010056545530304DF1D8146CD57F6F EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 3625217237 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_3625217237_20140201_2340.extcsd Sending Internal Reconfiguration Request... Waiting configuration Apply!!! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it!!! Done. Please don't forget to repair extCSD from backup!!! extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_3625217237_20140 201_2336.extcsd Running:Repair extCSD... Successfully connected to box on COM2 Box S/N: 11110519D47D5C49, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.104.0 Loading eMMC Addon Firmware... Warning: CMD Pullup Level (1134 mV) too low , check cables etc.!!! CMD Active Level:1629 mV EMMC CID 15010056545530304DF1D8146CD57F6F EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 3625217237 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing... eMMC ACK Error !!! eMMC ACK Error !!! eMMC ACK Error !!! Done! extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_3625217237_20140 201_2340.extcsd Running:Repair extCSD... Successfully connected to box on COM2 Box S/N: 11110519D47D5C49, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.104.0 Loading eMMC Addon Firmware... Warning: CMD Pullup Level (1134 mV) too low , check cables etc.!!! CMD Active Level:1629 mV EMMC CID 15010056545530304DF1D8146CD57F6F EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 3625217237 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing... eMMC ACK Error !!! eMMC ACK Error !!! eMMC ACK Error !!! Done! Writing file...D:\EASYJTAG\dump\N7100\N7100_ROM2_Alive_Boo t\EMMC_00000000_00200000.bin Successfully connected to box on COM2 Box S/N: 11110519D47D5C49, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.104.0 Loading eMMC Addon Firmware... Warning: CMD Pullup Level (1103 mV) too low , check cables etc.!!! CMD Active Level:1639 mV EMMC CID 15010056545530304DF1D8146CD57F6F EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 3625217237 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000000200000 bytes to 00000000 ...ROM2 Write Speed: 220 kB/s Done !!! Writing file...D:\EASYJTAG\dump\N7100\N7100_Rom1_Alive_Dum p_BN\N7100_Rom1_Alive_Dump_BN.bin Successfully connected to box on COM2 Box S/N: 11110519D47D5C49, ,FW Ver.: 01.48 Z3X EasyJtag Software ver. 1.0.104.0 Loading eMMC Addon Firmware... Warning: CMD Pullup Level (1124 mV) too low , check cables etc.!!! CMD Active Level:1619 mV EMMC CID 15010056545530304DF1D8146CD57F6F EMMC CSD D02701320F5903FFF6DBFFFF8E40406D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 FW rev.0xf1 EMMC NAME: VTU00M , S/N: 3625217237 EMMC ROM1 (Main User Data) Capacity: 15028 MB (High Density Card) EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Writing 000020000000 bytes to 00000000 ...ROM1 Write Speed: 303 kB/s Done !!! |
