08-20-2017, 23:31 | #1 (permalink) |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,100 | SAMSUNG Dump eMMC Firmware error(s) with Message Please power cycle eMMC chip... EMMC CID : 150100464E58324D4201601DC2B714B0 EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2017 Rev.0x1 EMMC NAME: FNX2MB , S/N: 1612563127 EMMC NAME (HEX): 464E58324D4200 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: FNX2MB_1612563127_20170821_0358.extcsd Done. Firmware file...C:\Users\BABU\Desktop\eMMC_Firmware.bin Running:SAMSUNG: MoviNAND Firmware extraction... Z3X EasyJtag Software ver. 2.6.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1763 mV CMD Active Level:1845 mV Box IO Level:1850 mV CLK Rate:1000 khz --- EasyJTAG Samsung eMMC Backup Tool --- EMMC CID : 150100464E58324D4201601DC2B714B0 EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2017 Rev.0x1 EMMC NAME: FNX2MB , S/N: 1612563127 EMMC Part Number: Unknown EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1/2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB Reading eMMC Boot Identification Data... EMMC FW Read Failed, Reason: CARD Data FIFO Timeout Error Done. Done with error(s) |
The Following User Says Thank You to Pijush Das For This Useful Post: |
03-14-2022, 21:58 | #4 (permalink) |
Freak Poster Join Date: May 2017 Location: Africa, Uganda
Member: 2721034 Status: Offline Thanks Meter: 50 | I face same issue Turns out some of the emmc firmware are not in the tool nor the support. Please add new emmc for current chips. |
The Following User Says Thank You to shooster For This Useful Post: |
