12-11-2017, 12:19 | #1 (permalink) |
Freak Poster Join Date: Dec 2014 Location: nepal,lalitpur
Member: 2306223 Status: Offline Sonork: 1660968:1234 Thanks Meter: 117 | samsung emmc cant read,cant write EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2005 Rev.0x56 EMMC NAME: 000000 , S/N: 538117397 EMMC NAME (HEX): 30303030303000 EMMC ROM1 (Main User Data) Capacity: 8384 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 000000_ 538117397_20171211_1659.extcsd mmc_read_blocks(0x0 , 1 ), Reason: CARD Data FIFO Timeout Error mmc_read_blocks(0x1 , 1 ), Reason: CARD Data FIFO Timeout Error mmc_read_blocks(0x105FFFF , 1 ), Reason: CARD Data FIFO Timeout Error Partition table scan: GPT: not present Done. Z3X EasyJtag Software ver. 2.6.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1753 mV CMD Active Level:1825 mV Box IO Level:1850 mV CLK Rate:21000 kHz Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Z3X EasyJtag Software ver. 2.6.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1000 mV CMD Active Level:1763 mV Box IO Level:1850 mV CLK Rate:21000 kHz Reading 0x000020000000 bytes from 0x000000000000 ...ROM1 ( USER ROM) Output file :F:\panot31\EMMC_ROM1_000000_538117397_00000000_20 000000.bin Read Check Failed, Reason: CARD Data FIFO Timeout Error Done. Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 1850 mV Box S/N: 0500801DBB914D6B, ,FW Ver.: 01.60 CMD Pullup Level:1753 mV CMD Active Level:1825 mV Box IO Level:1850 mV CLK Rate:21000 khz HiPower mode is off! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 1850 mV Box S/N: 0500801DBB914D6B, ,FW Ver.: 01.60 CMD Pullup Level:1000 mV CMD Active Level:1763 mV Box IO Level:1850 mV CLK Rate:21000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 15010030303030303056201305155880 EMMC CSD : 902701320F5903FFF6DBFFEF8A404022 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2005 Rev.0x56 EMMC NAME: 000000 , S/N: 538117397 EMMC NAME (HEX): 30303030303000 EMMC ROM1 (Main User Data) Capacity: 8384 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x03 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: 000000_ 538117397_20171211_1700.extcsd mmc_read_blocks(0x0 , 1 ), Reason: CARD Data FIFO Timeout Error mmc_read_blocks(0x1 , 1 ), Reason: CARD Data FIFO Timeout Error mmc_read_blocks(0x105FFFF , 1 ), Reason: CARD Data FIFO Timeout Error Partition table scan: GPT: not present Done. Z3X EasyJtag Software ver. 2.6.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1753 mV CMD Active Level:1835 mV Box IO Level:1850 mV CLK Rate:21000 kHz Reading 0x000020000000 bytes from 0x000000000000 ...ROM1 ( USER ROM) Output file :F:\panot31\EMMC_ROM1_000000_538117397_00000000_20 000000.bin Read Check Failed, Reason: CARD Data FIFO Timeout Error Done. .....................is this emmc damaged |
