03-10-2019, 10:22 | #1 (permalink) |
Product Supporter Join Date: Feb 2015 Location: USA.INDIA,BD Age: 32
Member: 2348745 Status: Offline Sonork: 100.1611282 Thanks Meter: 396 | Samsung g316hu boot repair problem NEW VER ALSO ERROR OLD VER ALSO ERROR IS IT PROBLEM WITH DUMP OR OTHER Code: Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 24 Mhz CMD Pullup Level: 1801 mV CMD Active Level: 1878 mV EMMC Device Information : EMMC CID: 90014A48344732621101E3B3BCC112D5 EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D3 EMMC Manufacture Name: SKHYNIX , EMMC NAME: H4G2b , EMMC NAME (HEX): 483447326200 , S/N: E3B3BCC1 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 1/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: H4G2b_E3B3BCC1_20190310_151554.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Error writing at address: 000000000000 , error: 34 , 34 Unknown error ... Retry #1 Error writing at address: 000000000000 , error: 34 , 34 Unknown error ... Retry #2 Error writing at address: 000000000000 , error: 34 , 34 Unknown error ... Retry #3 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: spl.img Unpacking file: sboot.bin Unpacking file: sboot2.bin Unpacking file: param.lfs Partition name: BOOT Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 725.99 KB/s Partition name: SBOOT Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2673.68 KB/s Partition name: SBOOT2 Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2610.91 KB/s Partition name: PARAM Filename: param.lfs , Offset: 000002900000 , filesize: 634880 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2693.28 KB/s Partition HIDDEN : formatting as EXT4. Please wait ... Error: mkfs error (95) All done time: [00:00:06:116] |
03-10-2019, 13:47 | #2 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | you eMMC have bad cells at 0 sector. you can search at forum solution of this problem by words "Error writing at address: 000000000000" you can change eMMC, or try to create GP1 partition with 0 size to remap bad cells |
The Following 2 Users Say Thank You to layder For This Useful Post: |
