Old 10-27-2017, 16:43   #76 (permalink)
Member: 2688944
Originally Posted by duncan99 View Post
G530H Dump+Pinout - Download - 4shared
This is for everyone who has been looking everywhere for this file just like me...
Finally i read from a working phone and uploaded...
Please Use the THANKS button..
this file for the emmc g530 is originally micron or samsung
Old 10-30-2017, 21:16   #77 (permalink)
nbaster's Avatar
Member: 428223
Sonork: 100.1578585
Thanks Meter: 115
help g530h repair
here is the log
---------- eMMC Device Information ----------
EMMC CID : FE014E50314A39354B139CC0CF3722BA
EMMC CSD : D06E01320F5913FFFFFFFFEF92400070
EMMC Manufacturer ID: 00FE , OEM ID: 014E
EMMC Date: 02/2015 Rev.0x13
EMMC NAME: P1J95K , S/N: 2629881655
EMMC NAME (HEX): 50314A39354B00
EMMC ROM1 (Main User Data) Capacity: 7456 MB
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: P1J95K_2629881655_20171030_2214.extcsd
Caution: invalid backup GPT header, but valid main header!
Warning! Main and backup partition tables differ!n
Warning! One or more CRCs don't match. You should repair the disk!
Partition table scan:
GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT.
Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB
Soft (Partitioned) Disk/Image size: E8FFBC sectors 7.3 GiB
Logical sector size: 0x200 bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
First usable sector: 34
Last usable sector: 15269854
Found Data areas (firmware parts) count is: 27
Partition info successfully found
P0 (APNHLOS) [0x400000 0xf00000] Size: 15.0MB
P1 (MODEM) [0x1300000 0x3970000] Size: 57.437MB
P2 (SBL1) [0x4c70000 0x80000] Size: 512.0KB
P3 (DDR) [0x4cf0000 0x8000] Size: 32.0KB
P4 (ABOOT) [0x4cf8000 0x200000] Size: 2.0MB
P5 (RPM) [0x4ef8000 0x80000] Size: 512.0KB
P6 (QSEE) [0x4f78000 0x80000] Size: 512.0KB
P7 (QHEE) [0x4ff8000 0x80000] Size: 512.0KB
P8 (FSG) [0x5078000 0x300000] Size: 3.0MB
P9 (SEC) [0x5378000 0x4000] Size: 16.0KB
P10 (PAD) [0x537c000 0xa84000] Size: 10.515MB
P11 (PARAM) [0x5e00000 0xa00000] Size: 10.0MB
P12 (EFS) [0x6800000 0xe00000] Size: 14.0MB
P13 (MODEMST1) [0x7600000 0x300000] Size: 3.0MB
P14 (MODEMST2) [0x7900000 0x300000] Size: 3.0MB
P15 (BOOT) [0x7c00000 0xd00000] Size: 13.0MB
P16 (RECOVERY) [0x8900000 0xf00000] Size: 15.0MB
P17 (FOTA) [0x9800000 0x500400] Size: 5.0MB
P18 (BACKUP) [0x9d00400 0x6fdc00] Size: 6.991MB
P19 (FSC) [0xa3fe000 0x300000] Size: 3.0MB
P20 (SSD) [0xa6fe000 0x2000] Size: 8.0KB
P21 (PERSIST) [0xa700000 0x800000] Size: 8.0MB
P22 (PERSDATA) [0xaf00000 0x900000] Size: 9.0MB
P23 (SYSTEM) [0xb800000 0x5d800000] Size: 1.460GB
P24 (CACHE) [0x69000000 0x12c00000] Size: 300.0MB
P25 (HIDDEN) [0x7bc00000 0xa00000] Size: 10.0MB
P26 (USERDATA) [0x7c600000 0x1559fb000] Size: 5.336GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x000B800000 (1.460GB)
Unable to read prop.plist , code 2
Done.
what to do ???
Old 10-31-2017, 08:06   #78 (permalink)
Member: 1630066
Sonork: 520074
Thanks Meter: 215
Write full dump avalabe in sport area
Old 11-01-2017, 12:13   #79 (permalink)
nbaster's Avatar
Member: 428223
Sonork: 100.1578585
Thanks Meter: 115
i did that not booting too same problem !!!
Old 11-03-2017, 18:23   #80 (permalink)
Member: 794019
Thanks Meter: 31
G530H have 2 different chip. use dump accordingly, yours is micron, find micron dump and write it on new emmc. it will boot, you dont need fulldump. if it doesnt maybe clk or cmd resistors are damaged. just make sure you use a correct dump for G530H micron emmc.
Old 11-21-2017, 06:10   #81 (permalink)
Member: 2615206
Thanks Meter: 3
thank
tested,,thanks bro,,,,,,,,,,
Old 12-25-2017, 10:41   #82 (permalink)
Member: 138809
Sonork: 100.99886
Thanks Meter: 79
g530h emmc change still dead
hi all
got a phone with write failed
conected with emmc
emmc had erros
was micron chip
backuped all rom1 and rom 2 and user area 512mb
replaced emmc with used samsung
wrote all backup
but fone still dead only 9008 mode
here is log
HiPower mode is ON
Frequence: 7 Mhz
CMD Pullup Level: 103 mV
CMD Active Level: 2475 mV
EMMC Device Information :
EMMC CID: 150100514E31534D4201924FD656C1FA
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacture Name: SAMSUNG
EMMC Manufacture ID: 0x15 , OEM ID: 0100
EMMC Manufacture Date: 12/2014 , Rev: 01
EMMC NAME: QN1SMB , S/N: 924FD656 , rev. 01
EMMC NAME (HEX): 514E31534D42
   EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
   EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000)
   EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000)
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QN1SMB_924FD656_20171225_142007.extcsd
EMMC Init completed.
Operation: Write all eMMC Regions at once
Writing to: ROM2 , start: 0x000000000000 , size: 0x000000200000
Filename: EMMC_ROM2_P1J95K_689486548_00000000_00200000.bin
eMMC switching to ROM2
Writing partition...
Done writing partition. Write speed: 359.74 Kb/s
Writing to: ROM3 , start: 0x000000000000 , size: 0x000000200000
Filename: EMMC_ROM3_P1J95K_689486548_00000000_00200000.bin
eMMC switching to ROM3
Done writing partition. Write speed: 357.64 Kb/s
Writing to: ROM1 , start: 0x000000000000 , size: 0x000020000000
Filename: EMMC_ROM1_P1J95K_689486548_00000000_20000000.bin
eMMC switching to ROM1
Done writing partition. Write speed: 802.75 Kb/s
All done
HiPower mode is ON
Frequence: 7 Mhz
CMD Active Level: 2464 mV
Backup saved: QN1SMB_924FD656_20171225_143507.extcsd
Scanning soft partitions
GPT header is found and is valid
Partition: apnhlos, [000000400000 - 000001300000], size: 000000F00000
Partition: modem, [000001300000 - 000004C70000], size: 000003970000
Partition: sbl1, [000004C70000 - 000004CF0000], size: 000000080000
Partition: ddr, [000004CF0000 - 000004CF8000], size: 000000008000
Partition: aboot, [000004CF8000 - 000004EF8000], size: 000000200000
Partition: rpm, [000004EF8000 - 000004F78000], size: 000000080000
Partition: qsee, [000004F78000 - 000004FF8000], size: 000000080000
Partition: qhee, [000004FF8000 - 000005078000], size: 000000080000
Partition: fsg, [000005078000 - 000005378000], size: 000000300000
Partition: sec, [000005378000 - 00000537C000], size: 000000004000
Partition: pad, [00000537C000 - 000005E00000], size: 000000A84000
Partition: param, [000005E00000 - 000006800000], size: 000000A00000
Partition: efs, [000006800000 - 000007600000], size: 000000E00000
Partition: modemst1, [000007600000 - 000007900000], size: 000000300000
Partition: modemst2, [000007900000 - 000007C00000], size: 000000300000
Partition: boot, [000007C00000 - 000008900000], size: 000000D00000
Partition: recovery, [000008900000 - 000009800000], size: 000000F00000
Partition: fota, [000009800000 - 000009D00400], size: 000000500400
Partition: backup, [000009D00400 - 00000A3FE000], size: 0000006FDC00
Partition: fsc, [00000A3FE000 - 00000A6FE000], size: 000000300000
Partition: ssd, [00000A6FE000 - 00000A700000], size: 000000002000
Partition: persist, [00000A700000 - 00000AF00000], size: 000000800000
Partition: persdata, [00000AF00000 - 00000B800000], size: 000000900000
Partition: system, [00000B800000 - 000069000000], size: 00005D800000
Partition: cache, [000069000000 - 00007BC00000], size: 000012C00000
Partition: hidden, [00007BC00000 - 00007C600000], size: 000000A00000
Partition: userdata, [00007C600000 - 0001D1FFB000], size: 0001559FB000
GPT header successfully parsed
Get firmware version
Brand = samsung
Model = SM-G530H
Phone platform = msm8916
CPU Abi = armeabi-v7a
Android release = 4.4.4
Firmware version = KTU84P.G530HXCU1AOA2
Firmware date = Wed Jan 14 16:05:33 KST 2015
Old 12-25-2017, 13:23   #83 (permalink)
Member: 1630066
Sonork: 520074
Thanks Meter: 215
Write extcsd from backup
Old 12-25-2017, 20:22   #84 (permalink)
Member: 138809
Sonork: 100.99886
Thanks Meter: 79
Did that
Sent from my iPhone using Tapatalk
Old 12-26-2017, 03:46   #85 (permalink)
Sniper_04's Avatar
Member: 704097
Sonork: 100.1607742
Thanks Meter: 820
what board rev.?
4 or 4b?
Old 12-26-2017, 06:36   #86 (permalink)
Member: 138809
Sonork: 100.99886
Thanks Meter: 79
Originally Posted by Sniper_04 View Post
what board rev.?
4 or 4b?
Rev 4b
Tried to write dump
But after dump no gpt
And same dead
Isp connections are ok
Any further
Old 01-09-2018, 19:25   #87 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
And the pinout is ???
Old 01-14-2018, 04:38   #88 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 264
g530h cannot detect
hi, i have g530h dead, can be detected on pc as Qualcomm HS-USB QDLoader 9008, so it means it is deadboot.
i tried jtag but i cannot detect, checked with microscope the soldering of wires are good and okay, all settings on jtag software, still cannot detect.
i used this adapter :
and
this is logs :
Z3X EasyJtag Software ver. 2.9.0.0
Loading eMMC GEN1 Firmware... IO: 1850 mV
Box S/N: 12FF9016CE5F1172, ,FW Ver.: 01.62
CMD Pullup Level:1691 mV
CMD Active Level:11830 mV
Box IO Level:1850 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD]
Done.
Loading eMMC GEN1 Firmware... IO: 1800 mV
CMD Pullup Level:1670 mV
CMD Active Level:1711 mV
Box IO Level:1800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Can't init device, Reason: CMD Timeout Error
Done.
CMD Active Level:1701 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Done.
Old 05-30-2018, 08:15   #89 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
Sm-g530h after flash dead ,write pit and bl by jtag but no download mode
Writing BootConfig ...
Reg: 179 Value: 0x00
Reg: 177 Value: 0x00
Reg: 162 Value: 0x00
Done
Filename: EMMC_QNW00M_ROM2_000000000000_000000400000.bin
Done writing partition. Write speed: 197.76 KB/s
Filename: EMMC_QNW00M_ROM3_000000000000_000000400000.bin
Done writing partition. Write speed: 158.23 KB/s
Writing to: ROM1 , start: 0x000000000000 , size: 0x000010000000
Filename: EMMC_QNW00M_ROM1_000000000000_000010000000.bin
Done writing partition. Write speed: 882.09 KB/s
All done time: [01:49:53:047]
Old 05-30-2018, 08:58   #90 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
still no download mode
Opening file: FORTUNA3G_EUR_OPEN.pit
Pit: FORTUNA3G_EUR_OPEN.pit
Entry count: 31
The size of the last section has been updated
Setting frequence to 21 Mhz
CMD Pullup Level: 2000 mV
CMD Active Level: 2299 mV
Can't init device. Reason: -15 Unknown error
G530HXXS2BPK1_G530HOLB2BPE3_G530HXXU2BPB2_HOME.tar .md5
The list of files in the firmware:
aboot.mbn
sbl1.mbn
rpm.mbn
tz.mbn
hyp.mbn
non-hlos.bin
sec.dat
boot.img
recovery.img
system.img.ext4
modem.bin
cache.img.ext4
hidden.img.ext4
EMMC CID: FE014E50314A39354B1371ECF38C32C4
EMMC CSD: D06E01320F5913FFFFFFFFEF92400070
EMMC Manufacture : MICRON , EMMC NAME: P1J95K , HEX: 50314A39354B , S/N: 71ECF38C , rev. 0x13
EMMC Manufacture ID: 0xFE , OEM ID: 0x4E , Device Type: BGA (Discrete embedded) , Date: 3/2015
Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51)
Backup saved: P1J95K_71ECF38C_20180530_120635.extcsd
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Writing PrimaryGPT at address: 000000000000
Writing BackupGPT at address: 0001D1FFBE00
Writing PIT at address: 000000004400
GPT-partitioning done
Unpacking file: non-hlos.bin
Unpacking file: modem.bin
Unpacking file: sbl1.mbn
Unpacking file: aboot.mbn
Unpacking file: rpm.mbn
Unpacking file: tz.mbn
Unpacking file: hyp.mbn
Unpacking file: sec.dat
Unpacking file: boot.img
Unpacking file: recovery.img
Unpacking file: system.img.ext4
Unpacking file: cache.img.ext4
Unpacking file: hidden.img.ext4
Partition name: APNHLOS
Filename: non-hlos.bin , Offset: 000000400000 , filesize: 13911808 bytes
Erasing partition...
Done writing partition. Write speed: 859.41 KB/s
Partition name: MODEM
Filename: modem.bin , Offset: 000001300000 , filesize: 44615424 bytes
Done writing partition. Write speed: 899.45 KB/s
Partition name: SBL1
Filename: sbl1.mbn , Offset: 000004C70000 , filesize: 280720 bytes
Done writing partition. Write speed: 800.93 KB/s
Partition name: ABOOT
Filename: aboot.mbn , Offset: 000004CF8000 , filesize: 1105828 bytes
Done writing partition. Write speed: 897.41 KB/s
Partition name: RPM
Filename: rpm.mbn , Offset: 000004EF8000 , filesize: 187764 bytes
Done writing partition. Write speed: 879.74 KB/s
Partition name: QSEE
Filename: tz.mbn , Offset: 000004F78000 , filesize: 520588 bytes
Done writing partition. Write speed: 897.84 KB/s
Partition name: QHEE
Filename: hyp.mbn , Offset: 000004FF8000 , filesize: 90368 bytes
Done writing partition. Write speed: 785.35 KB/s
Partition name: SEC
Filename: sec.dat , Offset: 000005378000 , filesize: 684 bytes
Done writing partition. Write speed: 58.46 KB/s
Partition name: BOOT
Filename: boot.img , Offset: 000007C00000 , filesize: 11174160 bytes
Done writing partition. Write speed: 899.71 KB/s
Partition name: RECOVERY
Filename: recovery.img , Offset: 000008900000 , filesize: 11856144 bytes
Done writing partition. Write speed: 888.77 KB/s
Partition name: SYSTEM
Filename: system.img.ext4 , Offset: 00000B800000 , filesize: 1331336040 bytes
Sparse image found v.1.0 Total chunks: 2801
Done writing partition. Write speed: 871.38 KB/s
Partition name: CACHE
Filename: cache.img.ext4 , Offset: 000069000000 , filesize: 43933940 bytes
Sparse image found v.1.0 Total chunks: 18
Done writing partition. Write speed: 905.02 KB/s
Partition name: HIDDEN
Filename: hidden.img.ext4 , Offset: 00007BC00000 , filesize: 7479492 bytes
Sparse image found v.1.0 Total chunks: 14
Done writing partition. Write speed: 887.21 KB/s
Partition USERDATA : formatting as EXT4. Please wait ...
Formatting completed
Check BOOT_PARTITION_EN for the selected vendor
All done time: [00:30:12:015]
Page generated in 0.32995 seconds with 8 queries
