10-27-2017, 16:43 | #76 (permalink) | |
Junior Member Join Date: Feb 2017
Member: 2688944 Status: Offline Thanks Meter: 1 | Quote:
10-30-2017, 21:16 | #77 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 428223 Status: Offline Sonork: 100.1578585 Thanks Meter: 115 | help g530h repair here is the log ---------- eMMC Device Information ---------- EMMC CID : FE014E50314A39354B139CC0CF3722BA EMMC CSD : D06E01320F5913FFFFFFFFEF92400070 EMMC Manufacturer ID: 00FE , OEM ID: 014E EMMC Date: 02/2015 Rev.0x13 EMMC NAME: P1J95K , S/N: 2629881655 EMMC NAME (HEX): 50314A39354B00 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: P1J95K_2629881655_20171030_2214.extcsd Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB Soft (Partitioned) Disk/Image size: E8FFBC sectors 7.3 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 15269854 Found Data areas (firmware parts) count is: 27 Partition info successfully found --------------------------------------------- P0 (APNHLOS) [0x400000 0xf00000] Size: 15.0MB P1 (MODEM) [0x1300000 0x3970000] Size: 57.437MB P2 (SBL1) [0x4c70000 0x80000] Size: 512.0KB P3 (DDR) [0x4cf0000 0x8000] Size: 32.0KB P4 (ABOOT) [0x4cf8000 0x200000] Size: 2.0MB P5 (RPM) [0x4ef8000 0x80000] Size: 512.0KB P6 (QSEE) [0x4f78000 0x80000] Size: 512.0KB P7 (QHEE) [0x4ff8000 0x80000] Size: 512.0KB P8 (FSG) [0x5078000 0x300000] Size: 3.0MB P9 (SEC) [0x5378000 0x4000] Size: 16.0KB P10 (PAD) [0x537c000 0xa84000] Size: 10.515MB P11 (PARAM) [0x5e00000 0xa00000] Size: 10.0MB P12 (EFS) [0x6800000 0xe00000] Size: 14.0MB P13 (MODEMST1) [0x7600000 0x300000] Size: 3.0MB P14 (MODEMST2) [0x7900000 0x300000] Size: 3.0MB P15 (BOOT) [0x7c00000 0xd00000] Size: 13.0MB P16 (RECOVERY) [0x8900000 0xf00000] Size: 15.0MB P17 (FOTA) [0x9800000 0x500400] Size: 5.0MB P18 (BACKUP) [0x9d00400 0x6fdc00] Size: 6.991MB P19 (FSC) [0xa3fe000 0x300000] Size: 3.0MB P20 (SSD) [0xa6fe000 0x2000] Size: 8.0KB P21 (PERSIST) [0xa700000 0x800000] Size: 8.0MB P22 (PERSDATA) [0xaf00000 0x900000] Size: 9.0MB P23 (SYSTEM) [0xb800000 0x5d800000] Size: 1.460GB P24 (CACHE) [0x69000000 0x12c00000] Size: 300.0MB P25 (HIDDEN) [0x7bc00000 0xa00000] Size: 10.0MB P26 (USERDATA) [0x7c600000 0x1559fb000] Size: 5.336GB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000B800000 (1.460GB) Unable to read prop.plist , code 2 --------------------------------------------- Done. what to do ??? |
11-03-2017, 18:23 | #80 (permalink) |
Insane Poster Join Date: Jun 2008
Member: 794019 Status: Offline Thanks Meter: 31 | G530H have 2 different chip. use dump accordingly, yours is micron, find micron dump and write it on new emmc. it will boot, you dont need fulldump. if it doesnt maybe clk or cmd resistors are damaged. just make sure you use a correct dump for G530H micron emmc. |
12-25-2017, 10:41 | #82 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Gsmhosting Age: 42
Member: 138809 Status: Offline Sonork: 100.99886 Thanks Meter: 79 | g530h emmc change still dead hi all got a phone with write failed conected with emmc emmc had erros was micron chip backuped all rom1 and rom 2 and user area 512mb replaced emmc with used samsung wrote all backup but fone still dead only 9008 mode here is log Code: HiPower mode is ON Frequence: 7 Mhz CMD Pullup Level: 103 mV CMD Active Level: 2475 mV EMMC Device Information : EMMC CID: 150100514E31534D4201924FD656C1FA EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture Name: SAMSUNG EMMC Manufacture ID: 0x15 , OEM ID: 0100 EMMC Manufacture Date: 12/2014 , Rev: 01 EMMC NAME: QN1SMB , S/N: 924FD656 , rev. 01 EMMC NAME (HEX): 514E31534D42 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN1SMB_924FD656_20171225_142007.extcsd EMMC Init completed. Operation: Write all eMMC Regions at once Writing to: ROM2 , start: 0x000000000000 , size: 0x000000200000 Filename: EMMC_ROM2_P1J95K_689486548_00000000_00200000.bin eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 359.74 Kb/s Writing to: ROM3 , start: 0x000000000000 , size: 0x000000200000 Filename: EMMC_ROM3_P1J95K_689486548_00000000_00200000.bin eMMC switching to ROM3 Writing partition... Done writing partition. Write speed: 357.64 Kb/s Writing to: ROM1 , start: 0x000000000000 , size: 0x000020000000 Filename: EMMC_ROM1_P1J95K_689486548_00000000_20000000.bin eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 802.75 Kb/s All done HiPower mode is ON Frequence: 7 Mhz CMD Pullup Level: 103 mV CMD Active Level: 2464 mV EMMC Device Information : EMMC CID: 150100514E31534D4201924FD656C1FA EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture Name: SAMSUNG EMMC Manufacture ID: 0x15 , OEM ID: 0100 EMMC Manufacture Date: 12/2014 , Rev: 01 EMMC NAME: QN1SMB , S/N: 924FD656 , rev. 01 EMMC NAME (HEX): 514E31534D42 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 KB (000000200000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QN1SMB_924FD656_20171225_143507.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: apnhlos, [000000400000 - 000001300000], size: 000000F00000 Partition: modem, [000001300000 - 000004C70000], size: 000003970000 Partition: sbl1, [000004C70000 - 000004CF0000], size: 000000080000 Partition: ddr, [000004CF0000 - 000004CF8000], size: 000000008000 Partition: aboot, [000004CF8000 - 000004EF8000], size: 000000200000 Partition: rpm, [000004EF8000 - 000004F78000], size: 000000080000 Partition: qsee, [000004F78000 - 000004FF8000], size: 000000080000 Partition: qhee, [000004FF8000 - 000005078000], size: 000000080000 Partition: fsg, [000005078000 - 000005378000], size: 000000300000 Partition: sec, [000005378000 - 00000537C000], size: 000000004000 Partition: pad, [00000537C000 - 000005E00000], size: 000000A84000 Partition: param, [000005E00000 - 000006800000], size: 000000A00000 Partition: efs, [000006800000 - 000007600000], size: 000000E00000 Partition: modemst1, [000007600000 - 000007900000], size: 000000300000 Partition: modemst2, [000007900000 - 000007C00000], size: 000000300000 Partition: boot, [000007C00000 - 000008900000], size: 000000D00000 Partition: recovery, [000008900000 - 000009800000], size: 000000F00000 Partition: fota, [000009800000 - 000009D00400], size: 000000500400 Partition: backup, [000009D00400 - 00000A3FE000], size: 0000006FDC00 Partition: fsc, [00000A3FE000 - 00000A6FE000], size: 000000300000 Partition: ssd, [00000A6FE000 - 00000A700000], size: 000000002000 Partition: persist, [00000A700000 - 00000AF00000], size: 000000800000 Partition: persdata, [00000AF00000 - 00000B800000], size: 000000900000 Partition: system, [00000B800000 - 000069000000], size: 00005D800000 Partition: cache, [000069000000 - 00007BC00000], size: 000012C00000 Partition: hidden, [00007BC00000 - 00007C600000], size: 000000A00000 Partition: userdata, [00007C600000 - 0001D1FFB000], size: 0001559FB000 GPT header successfully parsed Get firmware version Brand = samsung Model = SM-G530H Phone platform = msm8916 CPU Abi = armeabi-v7a Android release = 4.4.4 Firmware version = KTU84P.G530HXCU1AOA2 Firmware date = Wed Jan 14 16:05:33 KST 2015 |
01-14-2018, 04:38 | #88 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 42
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 264 | g530h cannot detect hi, i have g530h dead, can be detected on pc as Qualcomm HS-USB QDLoader 9008, so it means it is deadboot. i tried jtag but i cannot detect, checked with microscope the soldering of wires are good and okay, all settings on jtag software, still cannot detect. i used this adapter : and this is logs : Quote:
05-30-2018, 08:15 | #89 (permalink) | |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | Sm-g530h after flash dead ,write pit and bl by jtag but no download mode Quote:
05-30-2018, 08:58 | #90 (permalink) | |
Member: 2556542 Status: Offline Thanks Meter: 1,790 | still no download mode Quote:
