Old 06-29-2019, 11:58   #121 (permalink)
Member: 2902578
Thanks Meter: 151
There are two types of boards , check you Board "rev" download dump according to your board and Post result.
Old 06-29-2019, 12:59   #122 (permalink)
Member: 2362072
Thanks Meter: 46
Sm G530H_rev0.4b
2014.10.20
Pls help me detail
Old 06-29-2019, 13:29   #123 (permalink)
Member: 2362072
Thanks Meter: 46
I already download G530H_REV0.4B_OK file. Pls tell me how to write.
Old 06-29-2019, 14:51   #124 (permalink)
Member: 2902578
Thanks Meter: 151
Please post your phone history, show me the log of connected IC, not some writing partitions LOG .
Old 06-30-2019, 07:23   #125 (permalink)
Member: 2362072
Thanks Meter: 46
G530h dump file write ok but flash fail
Samsung g530h dump fileG530H_REV0.4B_OK) write ok. Phone power ok. But hang on logo.
When i try to full flash than show flash fail.
Pls give me solution.
EasyJtag Suite Classic ver.: 3.6.1.3 / wxWidgets 3.1.2-W-U started.
OS ver.: Windows 7 (build 7600). Admin rights OK
Android Explorer ver:1.0.0.13
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
eMMC Odin ver:1.0.0.6
QUALCOMM Direct ver:1.0.6936.8894
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 3.0.0.0, are OK
Z3X Card Serial : AA43-C247 , ver: 22
Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Found 4 serial devices
COM48 USB\VID_0325&PID_0032&REV_0100&MI_00 Easy Jtag Control Port (COM48)
COM46 USB\VID_05C6&PID_9008&REV_0000 Qualcomm HS-USB QDLoader 9008 (COM46)
COM39 FTDIBUS\COMPORT&VID_0403&PID_6001 USB Serial Port (COM39)
COM1 ACPI\PNP0501 Communications Port (COM1)
Selected pinout: EasyJTAG GEN1 ISP Pinout
Change EasyJTAG Pinout OK
Checking NAND Image : C:\Users\HelloMobile\Desktop\g530h\G530H_REV0.4B_O K\EMMC_P1J95K_ROM1_000000000000_000010000000.bin
Autodetected RAW data
Partition info successfully found
Linux partitions is not found in image...
File successefuly loaded!
Found ROM2 and automatically selected.
Found ROM3 and automatically selected.
Found EXT CSD and automatically selected.
Processing file...C:\Users\HelloMobile\Desktop\g530h\G530H_RE V0.4B_OK\P1J95K_469C1181_20170508_195335.extcsd
Processing file...C:\Users\HelloMobile\Desktop\g530h\G530H_RE V0.4B_OK\EMMC_P1J95K_ROM1_000000000000_00001000000 0.bin
Processing file...C:\Users\HelloMobile\Desktop\g530h\G530H_RE V0.4B_OK\EMMC_P1J95K_ROM2_000000000000_00000020000 0.bin
Processing file...C:\Users\HelloMobile\Desktop\g530h\G530H_RE V0.4B_OK\EMMC_P1J95K_ROM3_000000000000_00000020000 0.bin
Running:Repair extCSD...
Z3X EasyJtag Software ver. 3.6.1.3
Loading eMMC Addon Firmware...
CMD Pullup Level:2031 mV
CMD Active Level:2444 mV
Box IO Level:2800 mV
CLK Rate:14000 kHz
------------Parsing extCSD------------
Extended CSD rev 1.6 (MMC 4.5)
Card Supported Command sets [S_CMD_SET: 0x01]
HPI Features [HPI_FEATURE: 0x03]:
implementation based on CMD12
Background operations support [BKOPS_SUPPORT: 0x01]
Max Packet Read Cmd [MAX_PACKED_READS: 0x3c]
Max Packet Write Cmd [MAX_PACKED_WRITES: 0x20]
Data TAG support [DATA_TAG_SUPPORT: 0x01]
Data TAG Unit Size [TAG_UNIT_SIZE: 0x03]
Tag Resources Size [TAG_RES_SIZE: 0x00]
Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05]
Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07]
Extended partition attribute support [EXT_SUPPORT: 0x03]
Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x19]
Power off notification [POWER_OFF_LONG_TIME: 0xff]
Cache Size [CACHE_SIZE] is 256 KiB
Background operations status [BKOPS_STATUS: 0x00]
1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x32]
Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x04]
Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x09]
Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x09]
Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00]
Minimum Performance for 8bit at 52MHz in DDR mode:
[MIN_PERF_DDR_W_8_52: 0x00]
[MIN_PERF_DDR_R_8_52: 0x00]
TRIM Multiplier [TRIM_MULT: 0x03]
Secure Feature support [SEC_FEATURE_SUPPORT: 0x55]
Boot Information [BOOT_INFO: 0x07]
Device supports alternative boot method
Device supports dual data rate during boot
Device supports high speed timing during boot
Boot partition size [BOOT_SIZE_MULTI: 0x10]
Access size [ACC_SIZE: 0x07]
High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x10]
High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01]
Reliable write sector count [REL_WR_SEC_C: 0x01]
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x01]
Sleep current (VCC) [S_C_VCC: 0x06]
Sleep current (VCCQ) [S_C_VCCQ: 0x0a]
Sleep/awake timeout [S_A_TIMEOUT: 0x10]
Sector Count [SEC_COUNT: 0x00e90000]
Minimum Write Performance for 8bit:
[MIN_PERF_W_8_52: 0x08]
[MIN_PERF_R_8_52: 0x08]
[MIN_PERF_W_8_26_4_52: 0x08]
[MIN_PERF_R_8_26_4_52: 0x08]
Minimum Write Performance for 4bit:
[MIN_PERF_W_4_26: 0x08]
[MIN_PERF_R_4_26: 0x08]
Power classes registers:
[PWR_CL_26_360: 0x02]
[PWR_CL_52_360: 0x02]
[PWR_CL_26_195: 0x05]
[PWR_CL_52_195: 0x05]
Partition switching timing [PARTITION_SWITCH_TIME: 0x03]
Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x0a]
I/O Driver Strength [DRIVER_STRENGTH: 0x0f]
Card Type [CARD_TYPE: 0x17]
CSD structure version [CSD_STRUCTURE: 0x02]
Command set [CMD_SET: 0x00]
Command set revision [CMD_SET_REV: 0x00]
Power class [POWER_CLASS: 0x00]
High-speed interface timing [HS_TIMING: 0x00]
Erased memory content [ERASED_MEM_CONT: 0x00]
Boot configuration bytes [PARTITION_CONFIG: 0x00]
Not boot enabled
No access to boot partition
Boot config protection [BOOT_CONFIG_PROT: 0x00]
Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00]
High-density erase group definition [ERASE_GROUP_DEF: 0x00]
Boot write protection status registers [BOOT_WP_STATUS]: 0x00
Boot Area Write protection [BOOT_WP]: 0x00
Power ReadOnly locking: possible
Permanent ReadOnly locking: possible
Read Only lock status: not locked
User area write protection register [USER_WP]: 0x00
FW configuration [FW_CONFIG]: 0x00
RPMB Size [RPMB_SIZE_MULT]: 0x10
Write reliability setting register [WR_REL_SET]: 0x1f
Write reliability parameter register [WR_REL_PARAM]: 0x05
Enable background operations handshake [BKOPS_EN]: 0x00
H/W reset function [RST_N_FUNCTION]: 0x00
HPI management [HPI_MGMT]: 0x00
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0001d2
Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000
[GP_SIZE_MULT_3]: 0x000000
[GP_SIZE_MULT_2]: 0x000000
[GP_SIZE_MULT_1]: 0x000000
Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000
Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000
Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00
Periodic Wake-up [PERIODIC_WAKEUP]: 0x00
Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01
Native sector size [NATIVE_SECTOR_SIZE]: 0x00
Sector size emulation [USE_NATIVE_SECTOR]: 0x00
Sector size [DATA_SECTOR_SIZE]: 0x00
1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a
Class 6 commands control [CLASS_6_CTRL]: 0x00
Number of addressed group to be released[DYNCAP_NEEDED]: 0x00
Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000
Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000
Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000
Packed command status [PACKED_COMMAND_STATUS]: 0x00
Packed command failure index [PACKED_FAILURE_INDEX]: 0x00
Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00
Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00
------------Done parsing------------
Writing as extCSD 5.0
Done.
Skip loading eMMC Addon Firmware
Input file : C:\Users\HelloMobile\Desktop\g530h\G530H_REV0.4B_O K\EMMC_P1J95K_ROM1_000000000000_000010000000.bin
Writing 0010000000 bytes to 0000000000... ROM1 (USER ROM)
Done, time taken: 310 sec. Average Write Speed: 863 kB/s
Input file : C:\Users\HelloMobile\Desktop\g530h\G530H_REV0.4B_O K\EMMC_P1J95K_ROM2_000000000000_000000200000.bin
Writing 0000200000 bytes to 0000000000 ...ROM2 (BOOT1 ROM)
Done, time taken: 3 sec. Average Write Speed: 685 kB/s
Input file : C:\Users\HelloMobile\Desktop\g530h\G530H_REV0.4B_O K\EMMC_P1J95K_ROM3_000000000000_000000200000.bin
Writing 0000200000 bytes to 0000000000 ...ROM3 (BOOT2 ROM)
Done, time taken: 3 sec. Average Write Speed: 682 kB/s
Old 06-30-2019, 07:34   #126 (permalink)
Member: 2362072
Thanks Meter: 46
When i try to flash re-partition operation fail
Old 06-30-2019, 07:59   #127 (permalink)
Member: 2362072
Thanks Meter: 46
When i write pit and bl than phone again dead.
Need solution
eMMC_tool Suite ver. 1.5.3.0 (release date: 28.12.2018)
Microsoft Windows 7 (32 bit) build 7600 (6.1.7600.16385)
Looking for EasyJTAG box...
EasyJTAG API ver. 2201
EasyJTAG Box Serial = 0EFF901ADE07A5AB
Card Serial = AA43C247
EasyJTAG Box Firmware = 1.63
Changelog:
28.12.2018 (ver 1.5.3.0)
Fix: Bugs that have been found through your crash report
Fix: Scatter file processing (MTK)
Fix: Contact Extractor
Fix: Preloader parser
Fix: FAT partitions mounting
Fix: Minor interface changes
Add: Explorer: Work with Qualcomm HS-USB QDLoader 9008 interface
Add: Reset FRP via Qualcomm HS-USB QDLoader 9008 interface (General - Advanced - Remove FRP)
Add: Remove Android locks via Qualcomm HS-USB QDLoader 9008 interface (General - Advanced - Remove Android Locks)
Add: Auto/Manual loaders select for Qualcom HS-USB QDLoader 9008 interface
Add: Samsung firmware lz4 unpack support (Write by vendor - Samsung)
Add: Import from cm2qlm xml backups (Write by vendor - Qualcomm)
Add: Unpack Bootloader.img archive from Motorola firmware files
Add: Import GP partition parameters from ExtCSD backups (General - eMMC HW Partitions)
Add: Import Boot and RPMB sizes from ExtCSD backups (General - eMMC HW Partitions)
Add: Allow to create a GP with zero size (fix "Error writing at address: 000000000000", fine for Samsung eMMC, and may be destroy SanDisk and other eMMC)
Add: Explorer: Pin and Password decoding (only English and Russian letters)
Setting frequence to 21 Mhz
CMD Pullup Level: 268 mV
CMD Active Level: 2248 mV
Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD]
CMD Pullup Level: 278 mV
CMD Active Level: 2268 mV
CMD Pullup Level: 1763 mV
CMD Active Level: 2464 mV
Can't init device. Reason: CMD Timeout Error
CMD Pullup Level: 2062 mV
CMD Active Level: 2371 mV
EMMC Device Information :
EMMC CID: 150100514E5730304D0032C6DE21C12A
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacture : SAMSUNG , EMMC NAME: QNW00M , HEX: 514E5730304D , S/N: 32C6DE21 , rev. 0x00
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2014
EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 512 KB (000000080000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QNW00M_32C6DE21_20190630_125353.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: apnhlos, [000000400000 - 000001300000], size: 000000F00000 (15.0 MB)
Partition: modem, [000001300000 - 000004C70000], size: 000003970000 (57.4 MB)
Partition: sbl1, [000004C70000 - 000004CF0000], size: 000000080000 (512. KB)
Partition: ddr, [000004CF0000 - 000004CF8000], size: 000000008000 (32.0 KB)
Partition: aboot, [000004CF8000 - 000004EF8000], size: 000000200000 (2.00 MB)
Partition: rpm, [000004EF8000 - 000004F78000], size: 000000080000 (512. KB)
Partition: qsee, [000004F78000 - 000004FF8000], size: 000000080000 (512. KB)
Partition: qhee, [000004FF8000 - 000005078000], size: 000000080000 (512. KB)
Partition: fsg, [000005078000 - 000005378000], size: 000000300000 (3.00 MB)
Partition: sec, [000005378000 - 00000537C000], size: 000000004000 (16.0 KB)
Partition: pad, [00000537C000 - 000005E00000], size: 000000A84000 (10.5 MB)
Partition: param, [000005E00000 - 000006800000], size: 000000A00000 (10.0 MB)
Partition: efs, [000006800000 - 000007600000], size: 000000E00000 (14.0 MB)
Partition: modemst1, [000007600000 - 000007900000], size: 000000300000 (3.00 MB)
Partition: modemst2, [000007900000 - 000007C00000], size: 000000300000 (3.00 MB)
Partition: boot, [000007C00000 - 000008900000], size: 000000D00000 (13.0 MB)
Partition: recovery, [000008900000 - 000009800000], size: 000000F00000 (15.0 MB)
Partition: fota, [000009800000 - 000009D00400], size: 000000500400 (5.00 MB)
Partition: backup, [000009D00400 - 00000A3FE000], size: 0000006FDC00 (6.99 MB)
Partition: fsc, [00000A3FE000 - 00000A6FE000], size: 000000300000 (3.00 MB)
Partition: ssd, [00000A6FE000 - 00000A700000], size: 000000002000 (8.00 KB)
Partition: persist, [00000A700000 - 00000AF00000], size: 000000800000 (8.00 MB)
Partition: persdata, [00000AF00000 - 00000B800000], size: 000000900000 (9.00 MB)
Partition: system, [00000B800000 - 000069000000], size: 00005D800000 (1.46 GB)
Partition: cache, [000069000000 - 00007BC00000], size: 000012C00000 (300. MB)
Partition: hidden, [00007BC00000 - 00007C600000], size: 000000A00000 (10.0 MB)
Partition: userdata, [00007C600000 - 0001D1FFB000], size: 0001559FB000 (5.34 GB)
GPT header successfully parsed
Get firmware version
Firmware info not found
CMD Pullup Level: 2052 mV
CMD Active Level: 2382 mV
Backup saved: QNW00M_32C6DE21_20190630_125623.extcsd
Backup saved: QNW00M_32C6DE21_20190630_125724.extcsd
Opening file: FORTUNA3G_EUR_OPEN.pit
Pit: FORTUNA3G_EUR_OPEN.pit
Entry count: 31
The size of the last section has been updated
BL_G530HDXU1ANK2_282014_REV00_user_low_ship_MULTI_ CERT.tar.md5
The list of files in the firmware:
aboot.mbn
sbl1.mbn
rpm.mbn
tz.mbn
hyp.mbn
non-hlos.bin
sec.dat
CMD Pullup Level: 2072 mV
Backup saved: QNW00M_32C6DE21_20190630_125732.extcsd
Operation: Write by vendor (Samsung)
Creating GPT-partitioninig
Writing PrimaryGPT at address: 000000000000
Writing BackupGPT at address: 0001D1FFBE00
Writing PIT at address: 000000004400
GPT-partitioning done
Unpacking file: non-hlos.bin
Unpacking file: sbl1.mbn
Unpacking file: aboot.mbn
Unpacking file: rpm.mbn
Unpacking file: tz.mbn
Unpacking file: hyp.mbn
Unpacking file: sec.dat
Partition name: APNHLOS
Filename: non-hlos.bin , Offset: 000000400000 , filesize: 8570624 bytes
eMMC switching to ROM1
Erasing partition...
Writing partition...
Done writing partition. Write speed: 714.76 KB/s
Partition name: SBL1
Filename: sbl1.mbn , Offset: 000004C70000 , filesize: 288216 bytes
Done writing partition. Write speed: 676.63 KB/s
Partition name: ABOOT
Filename: aboot.mbn , Offset: 000004CF8000 , filesize: 1040760 bytes
Done writing partition. Write speed: 759.98 KB/s
Partition name: RPM
Filename: rpm.mbn , Offset: 000004EF8000 , filesize: 182004 bytes
Done writing partition. Write speed: 673.19 KB/s
Partition name: QSEE
Filename: tz.mbn , Offset: 000004F78000 , filesize: 413680 bytes
Done writing partition. Write speed: 720.92 KB/s
Partition name: QHEE
Filename: hyp.mbn , Offset: 000004FF8000 , filesize: 53112 bytes
Done writing partition. Write speed: 427.12 KB/s
Partition name: SEC
Filename: sec.dat , Offset: 000005378000 , filesize: 684 bytes
Done writing partition. Write speed: 13.36 KB/s
Check BootConfig for the selected vendor
All done time: [00:00:31:097]
Old 06-30-2019, 10:28   #128 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Samsung G530H boot repair and eMMC change problem and solution thread
Some threads merge to one
Old 06-30-2019, 10:29   #129 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Need solution
Try to use latest version (1.6.0).
We add GPT Samsung fix
Old 07-07-2019, 08:11   #130 (permalink)
Member: 2738247
Thanks Meter: 5
dump test no pasword
https://mega.nz/#!Ai5nUS5L!_5OpkTE0B...LsoTTDL_eBsTwo
Page generated in 0.26357 seconds with 8 queries
