02-21-2017, 16:08 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Samsung g530h pit error after repaire also Z3X EasyJtag Software ver. 2.5.0.7 Skip loading eMMC Addon Firmware CMD Pullup Level:1753 mV CMD Active Level:2371 mV Box IO Level:3300 mV CLK Rate:21000 khz Formatting eMMC card, please wait up to 3 min... Setting Service Mode... eMMC Format Done. Done. Running:Repair extCSD... Z3X EasyJtag Software ver. 2.5.0.7 Skip loading eMMC Addon Firmware CMD Pullup Level:1753 mV CMD Active Level:2371 mV Box IO Level:3300 mV CLK Rate:21000 khz Writing... Done. Z3X EasyJtag Software ver. 2.5.0.7 Skip loading eMMC Addon Firmware CMD Pullup Level:1753 mV CMD Active Level:2371 mV Input file : E:\Z3X\JTAQ\SAM\G530H\Samsung_SM-G530H_dump_rom1\Samsung_SM-G530H_dump_rom1.bin Writing 000B800000 bytes to 00000000 ...ROM1 (USER ROM) Done. Write Speed: 1563 kB/s Z3X EasyJtag Software ver. 2.5.0.7 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 010070222EE63D88, ,FW Ver.: 01.58 CMD Pullup Level:1773 mV CMD Active Level:2371 mV Box IO Level:3300 mV CLK Rate:21000 khz HiPower mode is ON! ---------- eMMC Device Information ---------- EMMC CID : FE014E50314A39354B139E97D7C142DE EMMC CSD : D06E01320F5913FFFFFFFFEF92400070 EMMC Manufacturer ID: 00FE , OEM ID: 014E EMMC Date: 04/2015 Rev.0x13 EMMC NAME: P1J95K , S/N: 2660751297 EMMC NAME (HEX): 50314A39354B00 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 2048 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: P1J95K_2660751297_20170221_1241.extcsd Searching for partition tables... Detected GPT over MBR... Medium UUID: 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Warning: Entries Count = 128 MMCBLK0P0 (APNHLOS) Range: [0X400000,0X12FFE00] ,Len: F00000 MMCBLK0P1 (MODEM) Range: [0X1300000,0X4C6FE00] ,Len: 3970000 MMCBLK0P2 (SBL1) Range: [0X4C70000,0X4CEFE00] ,Len: 80000 MMCBLK0P3 (DDR) Range: [0X4CF0000,0X4CF7E00] ,Len: 8000 MMCBLK0P4 (ABOOT) Range: [0X4CF8000,0X4EF7E00] ,Len: 200000 MMCBLK0P5 (RPM) Range: [0X4EF8000,0X4F77E00] ,Len: 80000 MMCBLK0P6 (QSEE) Range: [0X4F78000,0X4FF7E00] ,Len: 80000 MMCBLK0P7 (QHEE) Range: [0X4FF8000,0X5077E00] ,Len: 80000 MMCBLK0P8 (FSG) Range: [0X5078000,0X5377E00] ,Len: 300000 MMCBLK0P9 (SEC) Range: [0X5378000,0X537BE00] ,Len: 4000 MMCBLK0P10 (PAD) Range: [0X537C000,0X5DFFE00] ,Len: A84000 MMCBLK0P11 (PARAM) Range: [0X5E00000,0X67FFE00] ,Len: A00000 MMCBLK0P12 (EFS) Range: [0X6800000,0X75FFE00] ,Len: E00000 MMCBLK0P13 (MODEMST1) Range: [0X7600000,0X78FFE00] ,Len: 300000 MMCBLK0P14 (MODEMST2) Range: [0X7900000,0X7BFFE00] ,Len: 300000 MMCBLK0P15 (BOOT) Range: [0X7C00000,0X88FFE00] ,Len: D00000 MMCBLK0P16 (RECOVERY) Range: [0X8900000,0X97FFE00] ,Len: F00000 MMCBLK0P17 (FOTA) Range: [0X9800000,0X9D00200] ,Len: 500400 MMCBLK0P18 (BACKUP) Range: [0X9D00400,0XA3FDE00] ,Len: 6FDC00 MMCBLK0P19 (FSC) Range: [0XA3FE000,0XA6FDE00] ,Len: 300000 MMCBLK0P20 (SSD) Range: [0XA6FE000,0XA6FFE00] ,Len: 2000 MMCBLK0P21 (PERSIST) Range: [0XA700000,0XAEFFE00] ,Len: 800000 MMCBLK0P22 (PERSDATA) Range: [0XAF00000,0XB7FFE00] ,Len: 900000 MMCBLK0P23 (SYSTEM) Range: [0XB800000,0X68FFFE00] ,Len: 5D800000 MMCBLK0P24 (CACHE) Range: [0X69000000,0X7BBFFE00] ,Len: 12C00000 MMCBLK0P25 (HIDDEN) Range: [0X7BC00000,0X7C5FFE00] ,Len: A00000 MMCBLK0P26 (USERDATA) Range: [0X7C600000,0X1D1FFAE00] ,Len: 1559FB000 Done...Presets has been updated... Done. |
02-22-2017, 20:03 | #2 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | It is not samsung emmc only solution is change emmc Sent from my iPhone using Tapatalk |
The Following User Says Thank You to deepakgarg For This Useful Post: |
